| MazdaSpeed 3/6 - Turbo Induction MazdaSpeed 3/6 - Turbo Induction - Have a turbo, intercooler, downpipe question? Anything turbo related belongs here! |
![]() | | #1 | ![]() |
| NATOR Photog ![]() Join Date: Jul 2008 Location: Syracuse, NY
Rep Power: 1831 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,645
Groaned at 61 Times in 26 Posts
__________________ ![]() Anthony D. Christiano 2008 CosmicBlue Mazdaspeed3 - 294whp/335wtq on stock K04, new BNR Stage 3 numbers coming soon... BNR Stage 3, Cobb AccessPort, HTP tray and 3" intake, 3-bar map and connector, PTP injector seals and studs, Kritz 3-port boost solenoid, Sure Return, CP-E FMIC, TWM STS, AutoTech Fuel Pump Internals, James Barone 88-Duro RMM, Forge Version 2 BPV, Koni Yellows, H&R's, Sonic Tuning ST100's 18x8.5 ET48, Cobb Rear Sway Bar, UR Downpipe, CorkSport Race Pipe, Magnaflow Cat-back. BF Goodrich g-Force Sport 235/40/18's, MSD DashHawk, 35% tint, Semi-debadged ...Unicorn Jizz |
![]() Join Date: Feb 2011 Location: Miami
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 100
Groans: 38
Leak somewhere?
__________________ Current Build: Liquid Silver Metallic Pu - JBR Shifter Bushings, Cobb AP, JBR RMM JBR SSP, ProSport Premium Boost Gauge, Custom Tune - In Progress PTP HPFP Internals, CorkSport Intake/TIP Sold: 2008.5 Black Mica GenWon - Fully Bolted |
Rep Power: 11893 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 42,817
Groans: 235
__________________ CPE ATMOSPHERE KIT / (GTX3071 w/ .82 hotside A/R) ● CPE HPFP ● CPE RMM ● CPE FMIC ● CPE TOW PLATE ● CPE TRITON CBE ● HTP 3" TIP ● HTP BATTERY RELOCATE● COBB AP ● GRIMMSPEED 3 PORT BCS ● COOLING MIST / DEVILS OWN METHANOL INJECTION ● DEFI Boost gauge ● TWM FULL REPLACMENT ● TWM M1 ABRAMS ● JBR SSP ● JBR RSB JBR TIG ● H&R COILOVERS● JUMPING JACKSON 3 BAR MAP HARNESS ● STOPTECH STAINLESS LINES ● AKEBONO EURPO 915a ● TANABE STRUT BRACE ● NEXTMOD M'z KIT CORKSPORT UNDERHOOD LED KIT ● GRAM LIGHTS 57 DR ● TOYO PROXES PLUS | |
![]() | | #4 | ![]() |
I can't imagine, I'm boosting 19+ all the way to redline. YES, I do.
__________________ ![]() Anthony D. Christiano 2008 CosmicBlue Mazdaspeed3 - 294whp/335wtq on stock K04, new BNR Stage 3 numbers coming soon... BNR Stage 3, Cobb AccessPort, HTP tray and 3" intake, 3-bar map and connector, PTP injector seals and studs, Kritz 3-port boost solenoid, Sure Return, CP-E FMIC, TWM STS, AutoTech Fuel Pump Internals, James Barone 88-Duro RMM, Forge Version 2 BPV, Koni Yellows, H&R's, Sonic Tuning ST100's 18x8.5 ET48, Cobb Rear Sway Bar, UR Downpipe, CorkSport Race Pipe, Magnaflow Cat-back. BF Goodrich g-Force Sport 235/40/18's, MSD DashHawk, 35% tint, Semi-debadged ...Unicorn Jizz Last edited by Domino81; 03-13-2012 at 11:14 AM. Reason: MSF Database - Automerged Doublepost |
![]() | | #5 | ![]() |
![]() Join Date: Dec 2008 Location: Toledo OH
Rep Power: 398 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 318
I doubt the stocker cooled any better, and the cp-e should be much less restrictive. Before I went meth my SU was averaging 20+ over ambient. Maybe put the stocker back on and see what it does, you might have something else going on generating more heat in your engine bay. Sent from an iPhone conformist using Tapatalk
__________________ | CP-E 75 Duro RMM/TMM + TBE | Corksport SR/TI | Forge BPV | Cobb AP- DJ Tuned | NGK Plugs | Hotchkis RSB @ 140% | PTP IM Gasket/TB Coolant Delete + BSD | Autotech FPi | AEM Meth Injection | SU TMIC | JBR SSP + Stage2 OCC |PG Oil Filter Conversion | Toyota Injector Seals | Bizzerko PnP IM | Grimmspeed EBCS | Ingalls ETD | Sonic Tuning S3 Coilovers |Fluids Rotella T6 A lot Rislone Engine Treatment Motorcraft XT-M5-QS(trans) VP Methanol ~Splash of E85~ |
![]() | | #6 | ![]() |
![]() Join Date: Nov 2010 Location: rialto, ca
Rep Power: 61 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 319
Groans: 28
Not sure what BAT's are supposed to look like exactly but mine are about the same and I have a fmic. 19psi is the upper end of the efficiency range for the ko4 so it will naturally produce heat as result. Any body else have input?
![]() | | #7 | ![]() |
![]() Join Date: Apr 2010 Location: Miami FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,403
Groans: 256
Groaned at 69 Times in 41 Posts
damn thats pretty horrible. with my Fmic at WOT i am about 8-12 degrees over ambients temps. cruising im about 15-18 degrees over ambient temps. get an Fmic, so worth it
__________________ 2010 Black Mica ] ![]() |
![]() | | #8 | ![]() |
| Engineered Tuning ![]() ![]() ![]() Join Date: Jun 2008 Location: Vancouver, Canada
Rep Power: 8350 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,234
The TMIC will be poorer at cooling than an FMIC - especially since the bottom of it is constantly heated by the engine. This is the biggest issue by far.
__________________ We Engineer, and that's better than just tuning! ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. |
| The Following User Says Thank You to Lex For This Useful Post: | helmetface (03-13-2012) |
![]() | | #9 | ![]() |
![]() Join Date: Dec 2009 Location: Minneapolis, MN
Rep Power: 281 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,386
It is 60 here today and I am seeing about the same thing with my CPE. 90-100s BATs while cruising, dropping maybe 5-10 degrees during WOT but then starting to climb again around the end of the pull. I agree the TMIC just isn't going to cool as well and it will only get worse over the summer. I mainly think that it will cool about as well, maybe slightly better than stock but be less restrictive than stock to work the turbo a little bit less. If you are really concerned, FMIC and/or meth is going to be a much better option. I went ahead and removed the weather stripping at the back of the hood like finkle suggests and it seems to help just a little. This spring I plan to get some heat reflective tape and cover the back end tank and maybe the bottom of the front. I think I read someone says that helps with the heat soak a tad. Can't hurt for a few bucks worth of tape.
__________________ 2006 BCM MS6 GT CS SRI/TIP Jbarone SSP/bushings cp-e RMM, TMIC, Stiff Diff AP KMD V2.whatever Ebay Catless DP Grom Ipod |
![]() | | #10 | ![]() |
That'll be an idea.
![]() | | #11 | ![]() |
![]() Join Date: Apr 2010 Location: Charlotte, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 388
In 60 degree weather I'm ussually around 100 bat at low speeds on my ets tmic. If I start a pull at 80 bat it climbs to around 105 or so by redline at 19psi. I don't have the shroud on right now and no heat sheild on manifold so that dosnt help. For summer I may wrap my manifold and set up wind shield washer squirters to squirt water on the tmic When the car sits at a light the bat climbs pretty quick from all the heat rising EDIT: last summer on the stocker I was seeing bats near 140 while sitting in staging at the drag strip, shit sucks
__________________ 2010 super smiley Red MS3 - Corksport SRI/TIP - ETS TMIC - CNT hiflow catted long DP - Sure boost tubes - SURE motorsports anchors - SU RMM - Greddy Type S BPV - KMD HPFP Internals - harryclay tune - Semi-flat black wheels (painted stockers) - Eibach pro springs ftw - Pirelli PZero Asimetrico 225 40 r18 - Yellow 55v fogs 13.69 @ 106 (4g eth mix, intake/tune) 13.67 @106 (intake,dp,tmic, 50/50 eth) Last edited by harryclay; 03-13-2012 at 05:20 PM. |
| Cant get my BAT's down | mghtymouse380 | 2010 MS3 - Turbo Induction | 75 | 07-06-2011 06:21 AM |
| high bat's with new FMIC??? | Realgib3 | MazdaSpeed 3/6 - Turbo Induction | 62 | 06-15-2010 06:23 AM |
| BAT's, Heat Soak, & the Mazdaspeed 3 | Race Roots | Mazdaspeed3/6 General Discussion | 48 | 11-27-2009 09:29 PM |
| Please post your BAT's | Campo | MazdaSpeed 3/6 - Turbo Induction | 36 | 10-01-2009 09:36 AM |
| hows your BAT's like? | johnac08 | MazdaSpeed 3/6 - ECU Computer Tuning | 5 | 02-19-2009 11:53 AM |
