 Old 01-11-2010, 06:33 PM   #1
Jujiro_Prodigy_31's Avatar
Posts: 172   (View Stats)
Jujiro_Prodigy_31 has a reputation beyond reputeJujiro_Prodigy_31 has a reputation beyond reputeJujiro_Prodigy_31 has a reputation beyond reputeJujiro_Prodigy_31 has a reputation beyond reputeJujiro_Prodigy_31 has a reputation beyond reputeJujiro_Prodigy_31 has a reputation beyond reputeJujiro_Prodigy_31 has a reputation beyond reputeJujiro_Prodigy_31 has a reputation beyond reputeJujiro_Prodigy_31 has a reputation beyond reputeJujiro_Prodigy_31 has a reputation beyond reputeJujiro_Prodigy_31 has a reputation beyond repute
Default Drop in Boost Pressure
I usually hold 15 - 16 pounds of boost. On my way home just now I got on it a little bit and it was holding between 13 - 14. I have only put 93 gas in my car since I have had it but my last fill up I realized I accidentally put in 92. You think the 92 gas is the culprit or a coincidence?
'08 MS3 GT - CPE RMM - MS Racing Springs - Boost Gauge - TWM MS Short Throw & Bushings - MS CAI - Forge BPV - Cobb TI
Jujiro_Prodigy_31 is offline   Reply With Quote
 Old 01-11-2010, 06:55 PM   #2
speedms6's Avatar
Posts: 825   (View Stats)
was it really cold down south today? boost drops in really cold temps, i live in ny and have a friend that lives in miami and it was 28 down there today
my guess is it was really cold down there and you probably never see temperatures like that, thats why this seems so odd to you
Last edited by speedms6; 01-11-2010 at 06:55 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-11-2010, 07:05 PM   #3
yes, unusually cold today, below freezing. that was my other suspicion. thanks
 Old 01-11-2010, 07:42 PM   #4
ATAZ's Avatar
Posts: 314   (View Stats)
ATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond repute
when the temperature drops air becomes more dense. So basically the car needs less boost to achieve the same output. Perfectly normal. I usually see 17.5 but with the colder temps I usually run between 12-15.
ATAZ is offline   Reply With Quote
 Old 01-12-2010, 03:04 PM   #5
desertrat's Avatar
Posts: 132   (View Stats)
desertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant futuredesertrat has a brilliant future
Your fortunate enough to get 93 where you live, here in NM all the stations have 91. There is a place I can get 101 but it $7.00+ a gal. This car is very gas sensitive, got some bad gas once and was casuing a miss fire.
desertrat is offline   Reply With Quote
Boost Oil Pressure Voltmeter Gauge install with Triple Pod by CPE dasmikechen MazdaSpeed 3 - How-To's 17 07-13-2010 07:49 PM
Stock boost pressure Brum-Ole MazdaSpeed 3/6 - Turbo Induction 2 12-17-2009 02:44 AM
Smooth Boost or boost jump. What is causing this, I am baffled. FreeFlyFreak
Cobb ATR Support
9 10-31-2009 12:38 PM
ideally whats the best boost targets for custom tune from full boost to redline? Wenis Prinkle
Cobb ATR Support
26 08-24-2009 05:36 PM
fixed boost psi vs boost table settings? johnac08 MazdaSpeed 3/6 - ECU Computer Tuning 8 02-03-2009 03:05 PM
Page generated in 0.25834 seconds with 23 queries
