| MazdaSpeed 3/6 - Turbo Induction MazdaSpeed 3/6 - Turbo Induction - Have a turbo, intercooler, downpipe question? Anything turbo related belongs here! |
![]() | | #1 | ![]() |
![]() Join Date: Mar 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 35
Groaned at 9 Times in 7 Posts
(Thread Starter) | Not Ranked : 0 score Jimmy Mac for president! ![]() ![]() |
![]() Join Date: Mar 2008 Location: south texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,293
Groans: 102
sexy! mine is black, you dont have that protection sheild so you can really see how big it is!
__________________ |
Jesse after I installed the lilguy cdfp I noticed everything changed. Boost holding longer/higher, etc (no mbc). So on stock boost control even prior to the ETS in 2nd gear I would spike 16psi, and 3rd/4th I would spike 17-18psi and hold 15-16psi past 6000rpms. No drop off, no falling on its face. So after the ETS it was pretty dramatic with an increase in 2-3psi of spike/hold across the board.
![]() | | #4 | ![]() |
![]() Join Date: May 2008 Location: Goldsboro, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20
Very nice! It never looked that good on my car! I'd leave the shroud off. Did you say you didn't have a rear motor mount upgraded yet? I can't remember if that was you or someone else. I'd leave the shroud off until you get one. Even though I cut the reliefs in the rear of the shroud. Better safe than sorry. Good to see you finally got it and installed on your car.
__________________ 2012 MX-5 SE |
![]() | | #5 | ![]() |
I'm still waiting for my CPE mount. Over a month and counting...
![]() | | #6 | ![]() |
![]() Join Date: Sep 2009 Location: Surburban Detroit Michigan
Rep Power: 2149 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,194
Look sweet!
![]() | | #7 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Buena Park, OC, CA
Rep Power: 2394 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 610
Groaned at 22 Times in 20 Posts
| Not Ranked : 0 score holy thread from the dead! please consider the date on the upper left of the post before posting...
__________________ ![]() 2007 w/ Cheez // COBB AP // COBB SRI // COBB TIP // CXRacing FMIC // HKS SSQV v1 // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // BC Racing BR Coilovers // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Prosport Elec Boost Gauge // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob |
![]() | | #8 | ![]() |
![]() Join Date: Mar 2008 Location: In a house
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 54
FML
__________________ 7-Inch Jensen Flip Out Touch Screen, HKS SSQ, MS CAI, Prosport Premium Amber/White Boost Gauge,2nd Cat Gutted, Delrin TRZ MM,16 inch FD rims,TWM shifter Bushings,COBB Turbo Inlet, 28psi, rebuilt stock block, custom rods and piston heads/gaskets, underdrive pulleys, big cams, big oil filter, stage4 clutch, stage4 DISI injectors, Fuel Pump, 4inch Catless TBE with screamer pipe, external wastegate spring modification,Methanol direct twin port duty cycle injection. Tuned by Nator Performance |
| cobb RSB installed | Doc | MazdaSpeed 3/6 - Suspension & Brakes | 30 | 11-09-2008 10:28 AM |
| Installed some new rubber | 08_HellRaiser | MazdaSpeed 3/6 - Wheels & Tires | 2 | 06-28-2008 07:57 PM |
| HP Wheels Installed - Tell Me what you think | dallasms3gt | MazdaSpeed 3/6 - Wheels & Tires | 18 | 06-26-2008 10:29 AM |
| PG Manifold installed | SLS MS3 | MazdaSpeed 3 - Engine, Transmission & Driveline | 25 | 04-04-2008 11:53 AM |
