Like Tree8Likes
 Old 11-11-2014, 09:36 AM   #41
Posts: 9,484   (View Stats)
FYI from the other thread. ATP/Garrett Hate - failure GTX3076
12pk runs some sort of restrictor purchased from ATP but I have no idea exactly what it is nor W(hy)TF ATP doesn't ship their kits with said restrictor if its necessary.
if his kit is like mine then its the non restrictive banjo bolt pictured on the far left which is damn near the same size as an OEM (K04) bolt. He indicates a much smaller orifice size when measured compared to a fully open bolt. Perhaps he is measuring the side port(s) IDK.
soooo LSS (Long Story Short) I don't have an answer I am confident in giving at this point. I am currently running the middle restrictor pictured in my other post.
IIRC from 3.5 years ago, the 0.090'' orifice I mentioned on my banjo bolt that came with my ATP kit was the size of the side hole, not the bottom hole. I believe the bottom was considerably larger.
ahhh ha! Now it think we are getting somewhere. The bolt with the largest hole in my pic is from ATP, I now have 2 just like it. One that came with my GT28 and the new GTX30.
AFAIK the side holes are all the same size on a banjo bolt (At least they are on the 2 ATP bolts, 2 ebay bolts, and both ends of the OEM feed line which are banjo on both ends) and its the bottom hole that provides the "reverenced" restriction.
So until more information may prove otherwise, in my mind you are not running an external restrictor.
I'm going to cross post this in the failure thread.
Thanks for the clarification.
So I am pulling the middle "restrictor" bolt out and going with the "open" bolt that comes with the ATP kit. I still don't know what any "official" answer or best practice would be regarding running a restrictor.
 Old 11-24-2014, 11:02 AM   #42
ricardo_yen's Avatar
Posts: 27   (View Stats)
ricardo_yen will become famous soon enough
Hi just to post my fail,
Gtx3071
No restrictor
Under 3000kms
Bearing collapsed, shaft broke, both blades damaged,
No recursive action, as the local distributor of Garrett claims it's user error, they can replace chra at a cost
Upgrading to a kamak tdo6sl2 gtx25 with sts 9 blade wheel.... Journal bearing turbos are less finicky than the ball bearing turbos,
ricardo_yen is offline   Reply With Quote
 Old 01-18-2015, 07:45 AM   #43
Plimmer's Avatar
Posts: 695   (View Stats)
Plimmer is the leader of the worldPlimmer is the leader of the worldPlimmer is the leader of the worldPlimmer is the leader of the worldPlimmer is the leader of the worldPlimmer is the leader of the worldPlimmer is the leader of the worldPlimmer is the leader of the worldPlimmer is the leader of the worldPlimmer is the leader of the worldPlimmer is the leader of the world
OK, I've just joined this club:
Turbo type: ATP GTX3071r
Restrictor used: None found.
Failure Mode: CHRA bearing failure
Oil feed line used: OE
Oil return line used and if modified for length: ATP
Vendor Purchased from: Don't know, local speed shop did work.
Answer/resolution from vendor or manufacturer: Response from ATP below:
"Please note for inspection time, this may take 2-3 weeks to complete. Fee is $50.00.
If you rather skip inspection, we can process the CHRA through the BB service program and cost is $742.74.
If full complete turbo is shipped into us, please factor $100.00 for labor fee."
Symptoms: No boost and obvious bearing noise and play
Turbo mileage: Approx 20,000 miles
Turbo failure after blown motor: No
This thread has a lot of discussion on oil restrictors and feed etc, but what about cooling? I've noticed that my set up is the typical ATP setup where the hot coolant outlet banjo points down before making its way to the EGR nipple.
BUT if you go to the Garrett site:
http://www.turbobygarrett.com/turbob...er_Cooling.pdf
they clearly show how important it is to have the water outlet pointing upward to allow thermal siphoning.
Therefore maybe we are overheating our bearings because no cooling versus in adequate lube.
Either way, when i put my new CHRA in I'm going to ensure I have it installed exactly as described in the Garrett whitepaper.
Update: Not going to pay the $50 inspection fee to hear them tell me insufficient oil or cooling. My own close inspection of the CHRA seems there is plenty oil in the bearings and the shaft does not appear blue from over heating. Just a fail after 20,000 miles. Hopefully my new CHRA will have better engineered bearings and last a little longer.
Was: 2012 with GTX3071 and BF Goodrich g-Force Rivals
Now: 2015 Mustang GT 5.0, soon to be track toy
Plimmer is offline   Reply With Quote
The Following 3 Users Say Thank You to Plimmer For This Useful Post:
GrumpyMPS (02-25-2015), meicalnissyen (03-23-2015), Revmatch (02-16-2015)
 Old 03-24-2015, 07:11 PM   #44
meicalnissyen's Avatar
Posts: 1,158   (View Stats)
meicalnissyen is the leader of the worldmeicalnissyen is the leader of the worldmeicalnissyen is the leader of the worldmeicalnissyen is the leader of the worldmeicalnissyen is the leader of the worldmeicalnissyen is the leader of the worldmeicalnissyen is the leader of the worldmeicalnissyen is the leader of the worldmeicalnissyen is the leader of the worldmeicalnissyen is the leader of the worldmeicalnissyen is the leader of the world
HELL TO THE YEAH!
THIS IS THE BEST OPTION FOR RETURN FLOW
15 a foot at napa
Needed 4 inches
But no kinks, correct length
Full bore from chra to block
Originally Posted by jdmage_mx5 View Post
I think this is a good thread idea to cover GT and GTX failures. So bump bump. @Dano; I know you have a recent failure also.
Turbo type:GTX3071r
Restrictor used: no restrictor using Garrett Turbo BB low profile banjo bolt
Oil feed line used: OEM
Oil return line used and if modified for length: OEM modified (cut accordion section out and installed 5/8" steel braided hose to allow better flex.
Vendor Purchased from: original owner purchased from ATP
Answer/resolution from vendor or manufacturer: CHRA exchange with ATP for $742.49
Symptoms: nails on chalkboard sound when turbo experienced any load.
Turbo mileage: 20,000-30,000 miles between two owners
Turbo failure after blown motor: no
I did have some compressor wheel to housing contact. There were some brazing marks on the housing but I was able to smooth it out with some 2000 grit wet sand paper.
A democracy, in its purest form, is well represented by a group consisting of 2 wolves and 1 rabbit. Voting on what to have for lunch
meicalnissyen is offline   Reply With Quote
 Old 03-24-2015, 07:23 PM   #45
Oh, and that cat that found the white paper, referring to the 20 degree pitch for coolant flow.
I'm down with that
In spades
I'm learning in a very steep curve that ATP is nothing more than a vendor, making a hotside casting, specific to the mzr flange
Thats about it
Mine was not set to garrett's 20 degree spec (fixed)
No support bracket (fixed)
No heater pipe bracket (fixed)
Comprimised return line (fixed)
Dodgy coolant feed line ( not sure if this will be used or not, proly not) {not}
Shit mechanical geometry on the WG actuator (still chewing on that, may just bolt up the oem, may get a forge actuator, may bend the arm, and fab a bracket)
I'll edit will pics when the lappttoopp arrives tommorow
 Old 03-24-2015, 08:26 PM   #46
Polish_Eagle's Avatar
Posts: 406   (View Stats)
Polish_Eagle is the leader of the worldPolish_Eagle is the leader of the worldPolish_Eagle is the leader of the worldPolish_Eagle is the leader of the worldPolish_Eagle is the leader of the worldPolish_Eagle is the leader of the worldPolish_Eagle is the leader of the worldPolish_Eagle is the leader of the worldPolish_Eagle is the leader of the worldPolish_Eagle is the leader of the worldPolish_Eagle is the leader of the world
According to the service manual, when the oil is 212 degrees Fahrenheit, the oil pressure in the system is 43.1 PSI - 79.9 PSI.
2011 MAZDASPEED3 Hypnotic Tuned - Rob
CPE HPFP - CPE Catted Downpipe - CPE Catback Exhaust - 3" ETS TMIC - Cobb RMM - AEM Boost Gauge & Vent Pod - CANBus Triple - Corksport BPV - Corksport hood strut - Corksport RSB - Corksport Short Shifter - HTP 3.5" Intake - Damond TMM - Damond Vented CC - Vented Oil Cap - Tokay v2 Seals - GTX3067R - Damond PCV Plate - Built Engine (Manley Rods, 88mm Supertech 4032 Piston) -
Polish_Eagle is offline   Reply With Quote
 Old 05-14-2015, 10:48 AM   #47
Jeff23spl's Avatar
Posts: 2,192   (View Stats)
ATP GT2871R
blown seal/bearings
Stock oil feed and banjo bolt
Stock return
Stock cooling feed
custom coolant return with home-depot solid pipes and 90deg
Bought it blown to rebuild, it was seriously burning oil. It didn't ran for long on the previous owner speed. Probably 1 year or less.
I have it serviced with a brand new genuine CHRA...(BB aren't supposed to be rebuilded, i learned it!!!!it was more expensive than expected...)
Then i fond a lot of trapped dust inside the supplyed TIH like if the intake/filter was leaking.
The TIH was provided with a 2'' reducer to fit the mazdaspeed accessory CAI and use one of the oem coupler!!!
I tried this install with the brand new CHRA and i noticed a strange noise when the turbo start spooling. A noise that i think is a surge sound because as soon as i upgraded the intake for a 3.25'', that noise disapear and the response get way better...
I really think it was surging a lot and after a while the thrust on the bearings went away and it destroyed the seals...
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 08-13-2015, 02:59 PM   #48
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
I just got this reply on my GTX warranty. Started blowing through quarts of oil within 2k miles.
"We did complete the inspection and testing on your turbo unit.
What we found was that the unit is 100% good and is per factory spec.
The ball bearing turbos are more sensitive to the breather/PCV/oil drain issues than the journal bearing BNR unit that you're running now.
I'm going to have to make a couple of installation changes and you will see the issue go away on your car:
1. I'm going to recalibrate the oil supply port at the turbo.
2. I'm going to send you a NEW banjo bolt to use at the oil feed port on your turbo. If you still have the old one, please throw it away."
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
Garrett m33 turbo skiptowncat MazdaSpeed 3/6 - Turbo Induction 9 08-14-2012 03:41 PM
Who DOESN'T run a Garrett turbo Ezekiel81923 2010 MS3 - Turbo Induction 138 08-02-2012 05:20 PM
GARRETT 3" Turbo Inlet Pipe Kit Blackedout1978 2010 MS3 - Turbo Induction 3 03-13-2012 01:51 PM
Failed Thread essejkcamraw MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 57 11-17-2010 11:16 AM
Page generated in 0.30438 seconds with 27 queries
