Like Tree11Likes
  • 1 Post By tegxsi
  • 2 Post By CWP_MS3
  • 1 Post By zenit
  • 1 Post By mituc
  • 1 Post By Code Monkey
  • 1 Post By zenit
  • 1 Post By sharksinspace
  • 1 Post By Atticaz
  • 2 Post By Atticaz
 Old 01-30-2017, 09:04 AM   #1
Atticaz's Avatar
Posts: 621   (View Stats)
Atticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the worldAtticaz is the leader of the world
Default Flutter after BNR S4 install.
So I installed a BNR S4 for about a week ago. After the install I noticed that my Turbosmart bypass valve is fluttering upon release at and above 10psi. It did not flutter with the K0snore. What the shit causes this? K04 was running 20psi... BNR is currently 20ish.
Only change to my setup is:
BNR S4
Bosch 3bar MAP
Grimmspeed 3 port EBCS
Vid of flutter.
https://youtu.be/8rLYv5PU5ok
2017 Mustang V6 - Soon to be Supercharged
2007 MAZDASPEED3 - SOLD
Atticaz is offline   Reply With Quote
 Old 01-30-2017, 09:45 AM   #2
tegxsi's Avatar
Posts: 1,213   (View Stats)
Groans: 80
Did the vacuum line on the BPV come off? You would have a big vacuum leak though...
Maybe clean and relube the valve.
2018 Audi RS3
2007 Acura TSX 6MT
 Old 01-30-2017, 09:49 AM   #3
Atticaz's Avatar
That's wait I was thinking. Re-lube. All hoses are snug. The TS BPV is a pain in the ass to open. This'll be fun.
 Old 01-30-2017, 10:07 AM   #4
tegxsi's Avatar
Groans: 80
If it's the kompact version I use a rubber or silicone grip thingie... the type that is used to open jars.
Atticaz likes this.
2018 Audi RS3
2007 Acura TSX 6MT
Atticaz (01-30-2017)
 Old 01-30-2017, 10:15 AM   #5
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Self-adjusting HKS SSQV4 FTMFW!
I had a turbosmart dual port that I loved, but just could not get it right. Kept causing hesitation and backfires no matter what I did. Finally went back to TurboXS and then SSQV.
Atticaz and APEXistud like this.
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
The Following 3 Users Say Thank You to CWP_MS3 For This Useful Post:
Atticaz (01-30-2017), MS3Shadow (01-30-2017), WAMBUSHHHH! (02-02-2017)
 Old 01-31-2017, 10:27 PM   #6
Atticaz's Avatar
Serviced it today. Wasn't too dirty. I re-lubed it. I'm still getting the same shit. No flutter in low boost... just in boost of around 10psi and higher. I have a call in to Turbosmart, to see what they say. I don't get the BPV was fine with the K04, but is being a picking hooker with the BNR S4.
 Old 02-01-2017, 04:16 AM   #7
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Do you have the factory BPV still?
Rich Tuned
330WHP and 363TQ
 Old 02-01-2017, 04:56 AM   #8
mituc's Avatar
Posts: 3,424   (View Stats)
Groans: 107
The BPV piston is simply too heavy to flutter because the pressure pushing the piston can't simply vary that fast to make it flutter. I reckon the flutter comes from the wastegate actuator or from the turbo itself. I ran my turbosmart at 26PSI and it didn't flutter. I switched then to the Cobb XLE and I only got some turbo flutter when I made the valve too stiff.
2008 Cosmic Blue Mazda 3MPS
StratiVersaTuned FTW to 28PSI, self-tned to 31PSI
SU TMIC, Autotech HPFP internals
Versatuned
 Old 02-01-2017, 05:11 AM   #9
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Yeah, I would try to swap it out and see if its compressor surge.
Rich Tuned
330WHP and 363TQ
 Old 02-01-2017, 05:30 AM   #10
zenit's Avatar
Posts: 1,354   (View Stats)
Groans: 56
Groaned at 7 Times in 6 Posts
That's compressor surge, which is no bueno for a journal bearing turbo.
It sounds like the turbo smart needs a lighter weight oil (sewing oil or lightweight hydraulic oil) and/or a lighter spring.
I was having issues with the turbo smart bpv actuation, similar to what you described. I swapped to a lighter weight spring, and it helped.
I think the mechanism of action with the bpv causing surge, is that you swapped a smaller, more restrictive k04 compressor wheel (produces some vacuum off boost), to a bigger, less restrictive s4 compressor wheel, and now have less vacuum.
-feejay
-wetzel
 Old 02-01-2017, 06:27 AM   #11
mituc's Avatar
Groans: 107
The turbosmart BPV is fine (as in properly sized), I've used one with both the factory K04 and with a GTX3071.
The only problem with it was the sealing o-ring which swelled over time, probably from the sewing machine oil I was using. It's really uncommon for a BPV to flutter. the BPV however can start clunking when it opens if it doesn't have lubrication. But it can't flutter!
Versatuned
 Old 02-01-2017, 06:37 AM   #12
Atticaz's Avatar
It's the Turbosmart BPV. The Street Unit version. Yeah, I can't see the issue being the TS BPV. The spring pressure of TS BPV is noticeable lighter than the OEM BPV and I don't get any flutter at boost. All happens after I let off the gas.
http://www.streetunit.com/Turbosmart...-0997-1009.htm
 Old 02-01-2017, 06:44 AM   #13
Atticaz's Avatar
I have always used CLP gun oil. It's really light stuff. When I cleaned it yesterday, it was still well lubed and piston moved freely. I am waiting for a Turbosmart Rep to call me back. We will see what they say.
 Old 02-01-2017, 06:46 AM   #14
mituc's Avatar
Groans: 107
Mine was the SU version as well, I purchased it back in 2010.
Versatuned
Atticaz (02-01-2017)
 Old 02-01-2017, 06:57 AM   #15
Atticaz's Avatar
I'm lost here. I was speaking to another speed owner that has a TS BPV and BNR S3, she said hers does the same. I still have my OEM BPV. I also have the optional stronger Trubosmart spring (pink). I may give those both a try, while waiting for the Rep to get back to me.
 Old 02-01-2017, 07:33 AM   #16
zenit's Avatar
Groans: 56
Get a green or blue spring.
OEM and TS bpv springs cannot be compared, as they function differently.
Atticaz likes this.
-feejay
-wetzel
 Old 02-01-2017, 08:05 AM   #17
mituc's Avatar
Groans: 107
The pink spring is too stiff, use the green one.
A stiffer spring will not hold boost better as the BPV does not open under boost (at least not at these boost values we run them at, say below 30PSI), it will only dictate how fast and soon the BPV will open when you let off the acceleration, and in these conditions you want it to open as fast as possible.
Atticaz likes this.
Versatuned
 Old 02-01-2017, 08:13 AM   #18
Atticaz's Avatar
The green one is in there.
 Old 02-01-2017, 10:35 AM   #19
Atticaz's Avatar
So I put my stock BPV in. Flutter is gone. Also all the excessive exhaust piping I've been getting is gone. I think I need a completely different BPV definitely. I got tired of waiting around for turbosmarts reply.
EDIT: Stock BPV is not holding full boost. Current revision is at 21PSI. Only hitting 19.2.
 Old 02-01-2017, 10:37 AM   #20
Code Monkey's Avatar
Posts: 7,639   (View Stats)
I was speaking to another speed owner ..., she said
Pictures or gtfo.
Atticaz likes this.
2006 Mazdaspeed6
stripped|caged|freektuned
2017 Subaru BRZ
sharksinspace (02-01-2017), Thor Hammer (02-01-2017)
 Old 02-01-2017, 10:53 AM   #21
Atticaz's Avatar
Originally Posted by Code Monkey View Post
Pictures or gtfo.
HAHAHHAAHHAAAAA. *Cries as walking out.* *door slams*
The Following User Says Thank You to Atticaz For This Useful Post:
Code Monkey (02-01-2017)
 Old 02-01-2017, 11:58 AM   #22
Atticaz's Avatar
@Code Monkey; What BPV you running with your S3? I just have the full recirc one now, with the green spring (the one that is supposed to be for the MS3/MS6/CX-7). As stated above, I put my OEM BPV back to check shit out and flutter is gone. It's not holding full boost pressure (about 90ish%). But, I am thinking I need to get a different one.
 Old 02-01-2017, 12:04 PM   #23
Synapse DV.
2006 Mazdaspeed6
2017 Subaru BRZ
 Old 02-01-2017, 12:23 PM   #24
Atticaz's Avatar
Synapse DV.
I take it, no issues... and you love it. I need to get rid of this flutter. I HATE it. I'll check this one out.
I'm trying to decide if I wanna try the new CS VTA BPV, the Turbosmart Dual Port, GFB 50/50 or..... Current one is NOT cutting it.
 Old 02-01-2017, 01:12 PM   #25
mituc's Avatar
Groans: 107
Maybe your BPV piston doesn't move properly and that's why you get the flutter, and that's why the flutter got away with the factory BPV. So you just need a new BPV and yes, whatever you get keep it in full recirc.
Versatuned
The Following 2 Users Say Thank You to mituc For This Useful Post:
Atticaz (02-01-2017), Code Monkey (02-01-2017)
 Old 02-01-2017, 02:54 PM   #26
zenit's Avatar
Groans: 56
OEM uses a lightweight plastic piston and under low vacuum cracks open a hair (kind of like a synchronic BPV's).
It also tends to leak at the assembly seam.
Atticaz likes this.
-feejay
-wetzel
 Old 02-01-2017, 03:12 PM   #27
Atticaz's Avatar
Yeah. I already took it out.
 Old 02-01-2017, 03:50 PM   #28
Atticaz's Avatar
It's unbelievable. Yesterday I called Turbosmart USA directly. They said the tech guy was busy and they'd call me back. I even messaged them on Facebook. Got a reply to email them, if I had a tech question. Still no reply.
I also messaged BNR, just to see what their thoughts were on the matter, since it "does' involve one of their products. No reply.
I'm gonna give the new Corksport VTA BPV a chance. It only vents to atmosphere at high boost. Wish me luck. I'll report back, when I get and install it.
 Old 02-01-2017, 08:39 PM   #29
mituc's Avatar
Groans: 107
Don't VTA, just stay full recirc.
Versatuned
 Old 02-01-2017, 09:40 PM   #30
impossible's Avatar
Posts: 723   (View Stats)
Groans: 30
Surprised no one asked this but how often are you maintenancing your push type bov?
2009 Mazdaspeed 3 w/ Manley Forged, keyed and lightened crank, ported, 2018 JMF v2 port injection fueled, CM twin disk clutch and Precision 6466 turbo setup underway. PD Tuned by Ryan Martin.
 Old 02-02-2017, 06:11 AM   #31
sharksinspace's Avatar
Posts: 752   (View Stats)
Groans: 117
FWIW, the CS dual-port is only VTA at higher boost pressures, and even then I think it's still only partly VTA. They say it requires no tweaks to your tune to run properly (reviewers report no issues with richness) and won't mess with idle, etc. Personally, I'd love to give the thing a try but I already have their original BPV and can't justify dropping almost $300 just for it to make different sounds.
Atticaz likes this.
2007 MS3
PD by Will
 Old 02-02-2017, 07:15 AM   #32
Atticaz's Avatar
Every oil change. I did and extra cleaning the day before yesterday.
 Old 02-02-2017, 07:24 AM   #33
tegxsi's Avatar
Groans: 80
I had the original CS BPV and didn't like how it didn't have an air tight seal when closed. The new VTA version as a gasket at the piston seat which is better.
Does the new CS VTA valve still use that "wave" spring that like breaks into 2-3 pieces?
2018 Audi RS3
2007 Acura TSX 6MT
 Old 02-02-2017, 07:24 AM   #34
mituc's Avatar
Groans: 107
VTA at any boost level is not that good. It means (probably only marginally) hotter exhaust gases, more soot therefore higher chances for getting hot spots, and some extra fuel in the cylinders which at that high boost - so high piston and cylinder temps - will also thin out or even wash away the oil film from the cylinder walls.
So no, only full recirc is a viable option.
Versatuned
 Old 02-02-2017, 07:29 AM   #35
Groans: 117
I don't know if the dual-port uses the wave design, but Vincent told me when I needed a replacement spring that they've worked with the manufacturer to start making them out of a stronger material; breaking shouldn't continue to be a problem, going forward.
Blah, blah, blah. Look man, I respect your level of knowledge but how many guys are running at least partial VTA with little or no problem? If you want to run full recirc forever, more power to you, but it does not appear to be "the only viable option."
2007 MS3
PD by Will
Last edited by sharksinspace; 02-02-2017 at 07:35 AM. Reason: MSF Database - Automerged Doublepost
 Old 02-02-2017, 08:52 AM   #36
mituc's Avatar
Groans: 107
I'm only trying to steer people in the right direction to do things right. If it's "blah blah" for you that's a different story. I know this kind of statements "I'm doing this and I've never had a problem" or "Used this with no problem". The fact that someone never had a problem so far doing something wrong doesn't mean it's the new correct approach.
These cars generate and build a lot of soot in various places in the engine. Running very rich at low load even for short amounts of time makes this issue a lot worse. The soot build-up is one of the reasons for cracked ringlands on otherwise stock cars. If you don't care about yours because you intend to sell it within the next 1-2 years doesn't mean that others don't care either.
So if you want to do something only for the show maybe other people are interested in applying the "blah blah" correctly. So let people hear both sides of the story and have them decide for themselves if they only want to blip the throttle in parking lots at 2000rpm to draw attention with that PSHHH PSHHH, or want the full enchiladas from their engine both in therms of power and longevity.
Versatuned
 Old 02-02-2017, 09:04 AM   #37
Groans: 117
I don't take issue with your desire to explain why you think full recirc is a better option (and I happen to agree for the most part, realistically); I take issue with your referring to it as "the only viable option." That's not presenting both sides, that's presenting one side and declaring out of hand that the other is inherently incorrect.
I wouldn't run full VTA on this car, and the BPV I've got is full recirc, but I think it's a bit hyperbolic to act like using a valve that is partial VTA under only certain circumstances, while otherwise being recirc, is such a hugely detrimental decision.
2007 MS3
PD by Will
 Old 02-02-2017, 09:05 AM   #38
Atticaz's Avatar
I messaged Luke to find out. He said:
"The new valve doesnt use a wave spring. We used a much stronger spring this time around"
The Following 2 Users Say Thank You to Atticaz For This Useful Post:
sharksinspace (02-02-2017), tegxsi (02-02-2017)
 Old 02-02-2017, 09:13 AM   #39
Atticaz's Avatar
For the record: I'm not buying it for the sound, but for function; no other reason. Everyone has their opinions and are entitled to them. I've done my research. I'm good with my choice. We'll see how things turn out after install.
sharksinspace likes this.
 Old 02-15-2017, 12:44 PM   #40
Atticaz's Avatar
Default UPDATE:
So I have had the Corksport dual VTA BPV in for about a week and a half. Flutter is gone.
I am digging this BPV. The VTA sound isn't overbearing at all. The only thing that bugged me is the BPV has a sequence of whistles it makes as its releasing lower pressures. Luke at Corksport and I call it the mockingjay. lol. Its annoying at first. But it grows on you. I thought there was an issue with it. But, turns out its a byproduct of the piston design.
Here's a vid I made.
https://youtu.be/tEsvlybAhoU
markos213 and sharksinspace like this.
BPV flutter I cant get rid of. Funktionull 2010 MS3 - Turbo Induction 28 03-01-2016 11:41 AM
Flutter Nikon187 Mazdaspeed3/6 General Discussion 2 06-21-2015 10:50 PM
BOV Flutter bsandspd6 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 1 11-26-2013 12:41 PM
Is this flutter? D08SPEED3 MazdaSpeed 3/6 - Turbo Induction 19 10-11-2011 06:26 PM
Would this be flutter? Zeya MazdaSpeed 3/6 - Turbo Induction 18 03-20-2009 11:49 PM
Page generated in 0.59151 seconds with 27 queries
