  • 1 Post By Pu Manchu
 Old 10-17-2009, 02:05 AM   #1
johnac08's Avatar
Posts: 141   (View Stats)
johnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud of
Default full boost but no power
went on a dyno /tune earlier and 1st pull was around 330whp and 2nd run was 350whp. after that car got messed up. it lost its power its only making 190whp now. afr is around 11.5 and no knock retard. we tried to looks for boost leaks and looks like there was nothing, the only way that we can do it there was feel by hand while car is in boost. also inspected the bov to see if its leaking. none!! and then we watch the exhaust manifold if theres a fire or smoke coming out. theres nothing. after that we did a compression test and its good also. so after 3 hours trying to figure it out we just called it a night. drove the car home and the car is so slow now but i can hit target boost with no problems.
i will do a boost leak tomorrow again to see. if thats not the problem, what else it could be?
help
johnac08 is offline   Reply With Quote
The Following User Says Thank You to johnac08 For This Useful Post:
mattspeed6 (10-16-2015)
 Old 10-17-2009, 04:51 AM   #2
amp
amp's Avatar
Posts: 115   (View Stats)
amp has a reputation beyond reputeamp has a reputation beyond reputeamp has a reputation beyond reputeamp has a reputation beyond reputeamp has a reputation beyond reputeamp has a reputation beyond reputeamp has a reputation beyond reputeamp has a reputation beyond reputeamp has a reputation beyond reputeamp has a reputation beyond reputeamp has a reputation beyond repute
solenoid or ecbs as the culprit perhaps ...
amp is offline   Reply With Quote
The Following User Says Thank You to amp For This Useful Post:
martyxattack (10-18-2009)
 Old 10-19-2009, 09:01 AM   #3
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
He's hitting boost though, if the solenoid was f-d it'd be over boosting (stuck open) or under boosting (stuck closed).
I think you have a clog somewhere, or a ridiculously bad boost leak. For it to shed over 100hp, it'd have to be a gaping hole in your intake manifold or something.
Check both the intake and exhaust for restrictions. Maybe the intercooler? Not sure.
Maybe your VCTS got stuck? Not sure if you even still have it installed.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 10-19-2009, 12:18 PM   #4
18psiWhiteMS3
Lurkers
18psiWhiteMS3's Avatar
Posts: n/a
This is truly Bizarre
 Old 10-16-2015, 03:25 PM   #5
mattspeed6's Avatar
Posts: 7   (View Stats)
mattspeed6 has a spectacular aura aboutmattspeed6 has a spectacular aura aboutmattspeed6 has a spectacular aura about
What ended up being your issue?
I'm currently having this same problem!?! Any ideas would be helpful!
Last edited by mattspeed6; 10-16-2015 at 03:25 PM. Reason: MSF Database - Automerged Doublepost
mattspeed6 is offline   Reply With Quote
The Following 2 Users Say NO Thank You to mattspeed6 For This Un-useful Post:
g00s3y (10-17-2015), Pu Manchu (10-16-2015)
 Old 10-16-2015, 03:41 PM   #6
ImGryssLOL's Avatar
Posts: 783   (View Stats)
ImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the world
Lol....
2013 CWP W/ Tech" LS/VTEC swap running 9's
ImGryssLOL is offline   Reply With Quote
The Following 7 Users Say Thank You to ImGryssLOL For This Useful Post:
chaser27 (10-19-2015), Cheapspeed (10-16-2015), mattspeed6 (10-16-2015), MS3Shadow (10-16-2015), ms6mil (10-16-2015), mxlplx71 (10-16-2015), WetzMS3 (10-19-2015)
 Old 10-16-2015, 05:06 PM   #7
mattspeed6's Avatar
Originally Posted by ImGryssLOL View Post
Lol....
I'm not finding it to be funny! Lol unless you know the answer!?
 Old 10-16-2015, 05:14 PM   #8
mxlplx71's Avatar
Posts: 3,265   (View Stats)
Groans: 128
That member hasn't been on in 5 1/2 years.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
The Following 3 Users Say Thank You to mxlplx71 For This Useful Post:
chaser27 (10-19-2015), mattspeed6 (10-16-2015), Vansquish (10-17-2015)
 Old 10-16-2015, 05:23 PM   #9
Tachyonic Moderator
MS3Shadow's Avatar
Groans: 283
You come after two years and necro a 6 year post.
sent from my Nexus 6P
 Old 10-16-2015, 05:29 PM   #10
mattspeed6's Avatar
Got it!! I don't use the forum as you can see! So thats why I didn't get it!! Im not gonna pretend To know how this forum thing works! I've done a lot of work on my mazda and friends but never seen nor have had this problem before so was hoping for some input or just put it out there that I have the problem but I will post an answer when I figure it out or have help doing so!
 Old 10-16-2015, 05:29 PM   #11
gdawg25's Avatar
Posts: 248   (View Stats)
gdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the worldgdawg25 is the leader of the world
@mattspeed6; grab a flux capacitor, hook it up to your turbo, jump in your car and accelerate to 80mph and travel back to 2009...you might find your answer.
'08 MS3 // Corksport Turbo // JBR 3.5" WP // CNT Racing Turbo-Back // CX Racing FMIC // COBB AP // SURE Ventus // SURE Return // Damond Motorsports PMM & TMM // SURE Torq R3 // Stratified Guardian Angel // Autotech HPFP Internals // JBR EBCS // Corksport 3.5bar MAP // JBR S2 OCC // JBR EGR Delete // JBR TIG's // CP-e Safe Seals // SURE Shortcut // Corksport Swaybars // Bilstein Sports // H&R Springs // Tenzo R Type M 18"x8" // Michelin PSS
gdawg25 is offline   Reply With Quote
 Old 10-16-2015, 05:39 PM   #12
mattspeed6's Avatar
Lol Thanks doc, when you figure it out let me know if it works!
 Old 10-16-2015, 05:45 PM   #13
gdawg25's Avatar
Will do McFly.
 Old 10-16-2015, 07:14 PM   #14
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,967   (View Stats)
Groans: 546
ah, you dumb son of a bitch. i'd roast you but you seem like a good shit. grab some datalogs and make a new thread bro.
monkey.bones.007 likes this.
94 M
06 MS6
The Following 3 Users Say Thank You to Pu Manchu For This Useful Post:
chaser27 (10-19-2015), ImGryssLOL (10-17-2015), WAMBUSHHHH! (10-19-2015)
 Old 10-17-2015, 08:07 AM   #15
ImGryssLOL's Avatar
This, do this, and maybe we can help.
 Old 10-17-2015, 08:17 AM   #16
Voltwings's Avatar
Posts: 3,713   (View Stats)
At least he searched, give him that.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
The Following User Says Thank You to Voltwings For This Useful Post:
 Old 10-17-2015, 08:19 AM   #17
ImGryssLOL's Avatar
Fair enough.
When did you sell your 5.0 and come back mazda?
 Old 10-17-2015, 08:26 AM   #18
mattspeed6's Avatar
I sent justin (Freektune)a datalog and I got a cel for crankshaft position sensor fault so I'm digging into it now let you know what I find! Thanks for the support!
The Following User Says Thank You to mattspeed6 For This Useful Post:
Voltwings (10-17-2015)
 Old 10-17-2015, 08:35 AM   #19
Voltwings's Avatar
Fair enough.
bought a speed today
Past:
-Sold-
-Sold-
Current:
 Old 10-17-2015, 08:44 AM   #20
ImGryssLOL's Avatar
Glad you are back.
I still have my 5.0 and my speed, grated the speed still has a vented block so driving that isn't really a option and every morning when I look at my corolla and my mustang I can't help but drive the mustang.
I'm debating about saving the speed until the RS comes out then trading it for one of those. But to much ford... I just miss the battle wagon
 Old 10-17-2015, 09:08 AM   #21
Voltwings's Avatar
Yeah, i loved my mustang but it just didnt make sense to keep. Luckily my fiance's car is a fully bolted 3.7 with 3.55 gears. It may not have the grunt the 5.0 has, but its honestly still a lot of fun to drive, so it gets me my fix for now haha. Maybe in a few years that will get traded in on another GT.
Past:
-Sold-
-Sold-
Current:
 Old 10-17-2015, 09:45 AM   #22
ImGryssLOL's Avatar
I think I would take the ecoboost over the v6. But a friend has a new v6 with a 75 shot. Loves it for what it is.
I'm going to see what lands first, a new speed or the RS. At least we know the new RS exists, just up in the air on when it shows up
 Old 10-18-2015, 08:01 AM   #23
Voltwings's Avatar
I'd take an ecoboost too, but we got her car at the very tail end of 2014 when they were giving out $4,000 in rebates. $18k out the door for a brand new v6 was hard to say no to.
Past:
-Sold-
-Sold-
Current:
 Old 10-18-2015, 05:59 PM   #24
sheston's Avatar
Posts: 1,847   (View Stats)
Did you guys chase the OP away?
I was going to say like @Pu Manchu; said, post some logs.
Does anyone think his BPV could be acting up? Just staying partially open and shunting the boost?
 Old 10-18-2015, 07:03 PM   #25
mattspeed6's Avatar
So after a long Saturday I ended up pulling the valve cover and checking the timing of the cams and crank! The crank pulley was off. So I checked the crankpulley bolt and it was tight! So I took the bolt off and crank pulley and the thin washer behind it was split! I changed the bolt and washer and retimed the engine getting the cams to tdc and reassemble the motor and all is well car runs great with full power! I've never seen nor heard about spinning a crank bolt and pushing timing that far out! But we shall see how she holds! Good compression so no bent valves odd!! Thanks for all the help and jokes! It's nice to smile when shits not going well!
Last edited by mattspeed6; 10-19-2015 at 08:01 AM. Reason: Description error on my part!
The Following 4 Users Say Thank You to mattspeed6 For This Useful Post:
chaser27 (10-19-2015), Djohns (10-18-2015), Justin@Freektune (10-19-2015), sh4d0w (10-19-2015)
 Old 10-19-2015, 08:52 AM   #26
mxlplx71's Avatar
Groans: 128
good catch, lucky break on the valves.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
The Following User Says Thank You to mxlplx71 For This Useful Post:
mattspeed6 (10-19-2015)
ideally whats the best boost targets for custom tune from full boost to redline? Wenis Prinkle
Cobb ATR Support
26 08-24-2009 05:36 PM
REPORT: 2010 Suzuki SX4 to gain front-drive SportBack trim, power boost Haltech Automotive News 0 07-15-2009 08:00 AM
losing boost and power phantomspeed3 MazdaSpeed 3/6 - Turbo Induction 11 05-31-2009 02:13 PM
2009 Dodge Charger Cop Car gets boost in power and fuel economy Haltech Automotive News 0 10-10-2008 08:00 AM
Scientist Achieve Full Power Dense Coding With Superdense Photons Haltech Computers & Technology News 0 03-26-2008 12:20 AM
Page generated in 0.44612 seconds with 30 queries
