Like Tree2Likes
  • 2 Post By Bucker
 Old 03-29-2012, 05:09 PM   #1
sallyspeed3's Avatar
Posts: 638   (View Stats)
sallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the worldsallyspeed3 is the leader of the world
Default How much can the K04 blow?
Hey guys, I know it's been covered and I've read that the K04 usually peaks around 285 g/s which is generally what I've seen from my datalogs however in the log I attached I get up to 298 g/s which is certainly the most I've ever gotten out of it. Not sure if thats necessarily a good thing cause it's just blowing hot air at that point. Anyway, ambient temp was around 33 degrees, from the looks of things it looks like I need a better intercooler.
2008 Cosmic Blue Mazdaspeed 3 GT - COBB AP DIZZYTUNED for 30% E85//JBR Whale Penis//COBB TIP//COBB DP//COBB STS//COBB Knob//COBB shift weight//COBB Piping TR8L Core//Magnaflow CBE//Turbosmart BPV//PTP internals//SU RMM//TRZ tranny mount//Koni + H&R springs//Tinted 35% front, 20% rear//Lamin-X head-light & tail-light film//ASA GT1 18x8//Hankook Ventus V12 225/40//
sallyspeed3 is offline   Reply With Quote
 Old 03-29-2012, 05:32 PM   #2
dantes5823's Avatar
Posts: 6,576   (View Stats)
Yup got into 4th and temps shot up. My most recent log also hit about 290. But yea at the top end its just heat. I have meth and im seeing the tops trying to fight it.
 Old 03-29-2012, 05:43 PM   #3
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
I flow ~ 260 g/s in my logs and VD says that is ~ 330 whp. I don't trust g/s values (in that I don't feel they directly correlate to whp)
rfinkle2 and SLOWHATCH like this.
403whp/451ft/lb Dry Shot
The Following 5 Users Say Thank You to Bucker For This Useful Post:
AZSPEED3 (03-30-2012), Broxer (03-29-2012), MSMS3 (04-01-2012), shawn. (03-29-2012), SLOWHATCH (03-29-2012)
 Old 03-29-2012, 05:45 PM   #4
ckMS3's Avatar
Posts: 1,112   (View Stats)
ckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the world
Ive hit around 330-340 g/s in the cooler ambients with my stock ic and turbo. Bucker is right because with me flowing 340g/s vd only shows around 315whp with the 1.01 cf.
BNR S3 // E85 Mix // Freektune
348tq/367whp -21.5 psi
Now - 25-26 psi + JBR 3.5 Intake
ckMS3 is offline   Reply With Quote
 Old 03-29-2012, 05:47 PM   #5
708
Erich's Avatar
Posts: 4,274   (View Stats)
Definitely not a 1:1 type correlation. On my car in the 600's it seems to be close, but it seems based on the results posted for bolt-ons, these numbers (~260g/s ~330HP) are fairly consistent.
2 years after hitting 700hp and still running strong. Happy to see others joining the club.
Erich is offline   Reply With Quote
The Following 2 Users Say Thank You to Erich For This Useful Post:
rfinkle2 (03-30-2012), SLOWHATCH (03-29-2012)
 Old 03-29-2012, 05:51 PM   #6
shawn.'s Avatar
Posts: 541   (View Stats)
shawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the world
Groans: 29
i agree, i see from 250-260 g/s and am around 320whp and 400wtq
ATP GTX3071r// Cobb 3 Port EBCS // 3 Bar MAP // Cobb Accessport Freek Tuned // E85 Mix // JBR 3.5" Intake/TIP // Treadstone TR8C FMIC // Autotech HPFP Internals // Ported IM //C-pe Catted Downpipe // TRZ RMM // Corksport CBE // ISC Coilovers // EBC Slotted Rotors--Redstuff Pads // TWM shifter bushings // Dashhawk v2 // 6000k HIDs
Built engine--Manley H Beam Rods--Wiseco Pistons
shawn. is offline   Reply With Quote
 Old 03-29-2012, 05:51 PM   #7
Bucker's Avatar
Groans: 451
Originally Posted by Erich View Post
Definitely not a 1:1 type correlation. On my car in the 600's it seems to be close, but it seems based on the results posted for bolt-ons, these numbers (~260g/s ~330HP) is fairly consistent.
What I really love is when I spray and make ~400/500 VD and g/s is still 260-270 lol.
The Following 2 Users Say Thank You to Bucker For This Useful Post:
 Old 03-29-2012, 05:55 PM   #8
G26
G26's Avatar
Posts: 2,988   (View Stats)
Groans: 39
260-270 g/s here, virt dyno 305-310hp.
The Following User Says Thank You to G26 For This Useful Post:
 Old 03-29-2012, 05:56 PM   #9
708
Erich's Avatar
Makes me want to spray.... would have to save it for 6th though.
The Following 5 Users Say Thank You to Erich For This Useful Post:
Bucker (03-30-2012), mazdafreak (03-29-2012), rfinkle2 (03-30-2012), sidekick (03-05-2013), TexasSpeed3 (03-30-2012)
 Old 03-29-2012, 06:00 PM   #10
dantes5823's Avatar
vd hasnt been accurant for shit lately. Ive gotten 465whp, 1649Whp
MSFer87 (03-29-2012)
 Old 03-29-2012, 06:06 PM   #11
I think I just need meth, told myself I would stop with the downpipe and tune......
 Old 03-29-2012, 06:10 PM   #12
Broxer's Avatar
Posts: 875   (View Stats)
Broxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the world
Groans: 90
Wheel spin? Thats the only thing to cause mine to spike crazy high.
Also, 360 g/s and around 370hp/380tq on VD. Tune isn't finished though. still boost to stabilize and timing to add.
2012 Triumph Street Triple
SOLD -- 2010 Velocity Mica Red MS3
ATP GTX3071r - Cobb AP(Freek Permed) - CNT Catted DP - UR CBE - DO Stage 2 WMI(80/20) - cp-e TMIC - cp-e xcelXL - cp-e invicid inlet - Grimmspeed MBC - KMD v2.2 hpfp internals - Bosch 3bar MAP - H&R Springs - DDM 6k Raptor Kit - ITV22's - Forge v2 BPV - 225/40/18 Nitto Neogens - SURE RMM
Broxer is offline   Reply With Quote
The Following 2 Users Say Thank You to Broxer For This Useful Post:
Bucker (03-30-2012), rfinkle2 (03-30-2012)
 Old 03-29-2012, 06:25 PM   #13
dantes5823's Avatar
Im in third and no spin. shit gives me crazy numbers and the lines are nuts.
 Old 03-29-2012, 06:34 PM   #14
mazdafreak's Avatar
Posts: 2,610   (View Stats)
Groans: 124
~290g/s at 16lbs on k04 here.....never did vd yet tho.
713whp/569wtq!
10.72 @ 139.44! (10/1/2015)
10.43 @ 140.95! 10/9/2015
10.35 @ 140.86 (10/30/2015)
 Old 03-29-2012, 06:38 PM   #15
Enki's Avatar
Posts: 7,539   (View Stats)
Groans: 189
MAF Voltage is a FAR better indicator of flow level.
Also, you'll make more on E vs Meth especially when using a top mount.
 Old 03-29-2012, 06:48 PM   #16
f-castrillo's Avatar
Posts: 1,342   (View Stats)
I hit a peak of ~250g/s, staying mostly in the high 240s, on my last Dynojet run, which ended up with the whp/wtq figures in my sig.
 Old 03-30-2012, 07:22 AM   #17
skiptowncat's Avatar
Posts: 1,592   (View Stats)
skiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the world
Groans: 49
Groaned at 34 Times in 25 Posts
270g/s making 305-310whp on VD.
A guy over here was hitting 315g/s in his 6, with intake, corksport ramair ic and catted downpipe.
Tuned with by
K1 Rods//Wiseco Pistons//CX Racing FMIC//JBR Widepath Intake//Custom 3" TBE//Grimmspeed EBCS//Forge BPV//JBR SSP//JBR RSB//JBR Side Mounts//ISC-N! coilovers//JBR BSD and Baffle//Sure TIG Set//Sure R3 RMM//KMD Internals//XS Power Exhaust Manifold//P&P Intake Manifold//Fidanza Flywheel//EM Organic Compound Clutch//GTX3071//DVC30 Meth Kit//3 Gauge Pod.....415WHP....so far!!
skiptowncat is offline   Reply With Quote
 Old 03-30-2012, 07:49 AM   #18
skeurton's Avatar
Posts: 745   (View Stats)
skeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the world
Wouldn't it be more appropriate to ask how efficiently are you flowing, as opposed to how much?
2011 MAZDASPEED 3
BNR: 352 hp / 342 ft-lbs
K04: 296 hp / 343 ft-lbs
BNR Supercars Stage 3 Turbo Aquamist HFS-4 Alcohol Injection Cobb Tuning AccesPORT • AccessTUNER Race KMD Tuning HPFP Internals v2.2 NGK 6510 Spark Plugs Bosch 3-Bar MAP Sensor Saikou Michi Oil Catch Can Grimmspeed 3-Port EBCS JBR TIGs • EGR Delete • Rear Sway Bar • RMM • PSMM • TMM HTP 3" TIP • Battery Tray SURE Motorsports 3" MAF • Shortcut • CounterShift • Anchors • AGS 621g Shift Knob Ultimate Racing Catted Downpipe • Test Pipe • Cat-Back Exhaust CP-e FMIC • SAFEseals Turbosmart Dual Port BOV PTP Injector Seal Studs EBC RedStuff Brake Pads • UPR Rotors Swift Spec R Springs Bilstein B8 Shocks SPC Performance Rear Camber Arms Tanabe Sustec Strut Tower Brace TWM Performance Full Replacement Shifter 5zοgen ZR+ 18x7.5 (Ceramic Bronze) Nitto NeoGen Tires Rally Armor Mud Flaps Morimoto 6000K HID Replacement Bulbs DDM Tuning 3000K HID Fog Lights Headlight Armor Yellow Fog Overlays Qualir QL-MZD723 Headunit Glowshift Mechanical Boost Gauge • A-Pillar Gauge Pod Aeroforce Dual Interceptor Gauges
skeurton is offline   Reply With Quote
The Following 3 Users Say Thank You to skeurton For This Useful Post:
Broxer (03-30-2012), MSMS3 (04-01-2012), rfinkle2 (03-30-2012)
 Old 03-30-2012, 08:17 AM   #19
Bucker's Avatar
Groans: 451
No, because most of us K04 guys are here:
The Following 7 Users Say Thank You to Bucker For This Useful Post:
atvfreek (03-30-2012), Enki (03-30-2012), Juyoung (12-11-2012), KevMS6 (03-30-2012), p057 (03-30-2012), ruthless013 (03-30-2012), skeurton (03-30-2012)
 Old 03-30-2012, 08:21 AM   #20
skeurton's Avatar
Fair enough, lol.
2011 MAZDASPEED 3
The Following User Says Thank You to skeurton For This Useful Post:
Bucker (03-30-2012)
 Old 03-30-2012, 09:16 AM   #21
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
Dyno or no dyno bro!
NATOR PA
 Old 03-30-2012, 09:27 AM   #22
300g/s and about 4.5V on the MAF if I remember correctly. On E50.
Remember guys; if you scaled your MAF for meth or E85, your g/s will be bloated.
Broxer (03-30-2012), Enki (03-30-2012), MS3-a(sore)ASS-rex (03-30-2012)
 Old 03-30-2012, 10:44 AM   #23
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
This will help if comparing a Borg Warner map vs. Garrett Maps.
I wish the two used the same unit of measurement, but unfortunately that is not the case.
The red hashes are in terms of lbs/min like we are used to seeing on the Garrett maps.
The Following 4 Users Say Thank You to rfinkle2 For This Useful Post:
Broxer (03-30-2012), charlesfist (03-30-2012), Enki (03-30-2012), skeurton (03-30-2012)
 Old 03-30-2012, 10:53 AM   #24
Broxer's Avatar
Groans: 90
Conversion chart is showing 280g/s is roughly 37lb/min
The Following User Says Thank You to Broxer For This Useful Post:
 Old 03-30-2012, 10:54 AM   #25
KevMS6's Avatar
Posts: 316   (View Stats)
KevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the world
260-270 g/s here, not done a VD yet however...
Cpe tmic&sri, 3" HTP tip, 3" ebay downpipe, BNR stage1, Autotech internals, Snow stage 2 meth with Aqaumist jet/parts, GoFastBits Respons BOV, Grimmspeed ebcs 3-port, Turbinetech diff mount, Cpe diff brace, Whiteline rarb, Bilstein B8's, Eibach springs, NGK iridium IX plugs, Corksport Mods, JBR mods... 324whp 361lb/ft
Tuned with by
KevMS6 is offline   Reply With Quote
 Old 03-30-2012, 10:57 AM   #26
rfinkle2's Avatar
Groans: 298
Many people overspin the compressor. LOL.
There isn't really too much of an issue with that if spraying meth / running e85, but I find it does pay on pump gas to stay within the comp map.
I really do believe that is why Lex was able to squeeze 300 hp out of that one tune that was done under autocross rules (couldn't tweak the boost).
Broxer (03-30-2012)
 Old 03-30-2012, 11:15 AM   #27
MS3 Boss's Avatar
Posts: 43   (View Stats)
MS3 Boss is just really niceMS3 Boss is just really niceMS3 Boss is just really niceMS3 Boss is just really niceMS3 Boss is just really nice
I hit 310-320 g's on every log, and I still have a lot of timing that is not utilized.. Its a pretty conservation tune. That virtual dyno I don't believe at all.. Trys to say I have 360hp or some bull..
Gas, cash or ass.:phillyb:
MS3 Boss is offline   Reply With Quote
Blow Through MAF Mid_Life_Crisis MazdaSpeed 3/6 - Turbo Induction 44 10-31-2012 10:14 AM
blow through maf help mrkdspd MazdaSpeed 3/6 - Turbo Induction 10 08-13-2012 12:59 PM
blow through maf TWOptSL0W Mazdaspeed3/6 General Discussion 4 11-24-2011 11:30 AM
1.5k to blow on my '09 MS3 M4Nathan MazdaSpeed 3 - How-To's 25 06-11-2010 07:22 PM
Will i blow? Grim MazdaSpeed 3 - Engine, Transmission & Driveline 26 02-20-2009 09:22 AM
Page generated in 0.47030 seconds with 38 queries
