Notices
 Old 08-02-2010, 06:24 PM   #1
h0rsies's Avatar
Posts: 88   (View Stats)
h0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond reputeh0rsies has a reputation beyond repute
Groaned at 4 Times in 2 Posts
Default pg exhaust manifold w/ ewg fitment
So I tried putting the mani on today and the flange connecting to the head would not sit flush. I could only get 2 studs on one side completely flush, and the studs on the other side are barely on the mani. Is anybody else running this manifold or has problems with fitment?
h0rsies is online now   Reply With Quote
 Old 08-02-2010, 06:45 PM   #2
SSinstaller's Avatar
Posts: 3,619   (View Stats)
Groans: 46
Groaned at 16 Times in 11 Posts
It would have to be seriously warped to fit that bad.. Unless your blind, there is no way you wouldn't notice it before you started the install.
Look around for something in the way...
 Old 08-03-2010, 07:59 PM   #3
Stockturbo_Ms3's Avatar
Posts: 120   (View Stats)
Stockturbo_Ms3 is a splendid one to beholdStockturbo_Ms3 is a splendid one to beholdStockturbo_Ms3 is a splendid one to beholdStockturbo_Ms3 is a splendid one to beholdStockturbo_Ms3 is a splendid one to beholdStockturbo_Ms3 is a splendid one to beholdStockturbo_Ms3 is a splendid one to beholdStockturbo_Ms3 is a splendid one to behold
try removing the stud, lining up the mani and the putting the studs back on... just a suggestion.
cpe sri, cpe tip, cpe fmic, cpe catted dp, cp-e towplate, deso 2 step colder plugs,cp-e rmm(75) cobb ap atr
Stockturbo_Ms3 is offline   Reply With Quote
 Old 08-03-2010, 11:19 PM   #4
h0rsies's Avatar
i got it to fit but now I cant get it off to put hte turbo on. Isnt it dangerous to take out the studs? should I keep trying to pry the mani off?
 Old 08-03-2010, 11:33 PM   #5
rodrigo's Avatar
Posts: 17,647   (View Stats)
Groans: 345
Groaned at 491 Times in 371 Posts
i dont think its the flange that isnt str8. i have a pg mani and have seen a few..... try this:
facing the front of the car..... and with the exhaust manifold installed(or pretend it s installed) drill out the 2 drivers side farthest holes on the mani just a little.... the holes basically need to be elongated and the manifold will then sit flush.
i dont think u are having a flange straightness problem..u are having a misalignment of the stud holes on the flange issue. ( i have seen it on 3 pg exhaust manfolds already....including my own)
make sense??
- I see meh people
The Following User Says Thank You to rodrigo For This Useful Post:
h0rsies (08-04-2010)
 Old 08-04-2010, 09:43 AM   #6
nothing to see here....
drknyte's Avatar
Posts: 444   (View Stats)
drknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the worlddrknyte is the leader of the world
Groans: 39
Groaned at 43 Times in 18 Posts
Ok here is another suggestion... there is a bolt on the mani side head near the valve cover that holds the engine cherry picker eyelet (see picture) ..... remove that bolt and eyelet. I could not get it to seal because of that bolt. The runner would hit that bolt and not allow it to seat properly.
And as for removing studs NO!! Don't do it!
I have more suggestions on getting the manifold on relatively easily without drilling the holes out... or removing studs. Let me know if you want an explanation.
Removing the mani is pretty easy. Just use a pry-bar between the head and mani. Very carefully work it off NOT using brute force but more finesse.
2008 Mazdaspeed 3 GT in Black Mica:
60ft: 2.167
1/8: 9.052
1/4: 13.922 @ 100.37
(26psi tire pressure & stock tires)
CP-E CAI; CP-E Turbo Inlet Pipe; CP-E RMM; Engals ETD; TRZ TM; PG ExhMani; JBarone Shifter Weight, E4 Performance Shift Knob; Solid Shifter bushings; JBarone SSP
drknyte is offline   Reply With Quote
The Following User Says Thank You to drknyte For This Useful Post:
 Old 08-04-2010, 09:57 AM   #7
-cj-'s Avatar
Posts: 645   (View Stats)
-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world-cj- is the leader of the world
Groaned at 13 Times in 7 Posts
What version of the PG mani do you guys have? It's scary that there's so many fitment issues, especially hitting that eyelet thing up above... It isn't like our engines are all physically different... I have the PGv3, haven't thrown it on yet, but this thread worries me.
Mod List: ATP 3071R @ 22 psi, Grimspeed in 3-port mode, Steedspeed Manifold, Snow Performance Stage 2 Meth Kit, Cobb AP, CP-E 3" Nano SRI, CP-E Big Inlet TIP, Cobb "Stage 2" Suspension Kit, CP-E FMIC, CP-E DP, CP-E HPFP, CP-E MM, TWM STS, Custom Tuned by Fobio.
-cj- is offline   Reply With Quote
 Old 08-04-2010, 11:44 AM   #8
drknyte's Avatar
Groans: 39
BE AFRAID....... VERY AFRAID!!
J/K
But it is a pain in the ass!!
60ft: 2.167
1/8: 9.052
 Old 08-04-2010, 02:04 PM   #9
h0rsies's Avatar
make sense??
I think you are right Ive talked to someone else about this and I am going to drill one size bigger for the 2 drivers side and put washers on it. but how should I get this mani off the head?
what version of the mani do you have I dont think I had that problem with the bolt but I just need to get this mani out. isnt prying dangerous and cant it fuck up the gasket? why shouldnt I take out the studs wont it be safe with a 10 mm revorse torx wrench?
I have the v3 with ewg. but its gay he didnt put a vband on the ewg pipe. also its a bitch that the holes arent lined up now I got drill em bigger. This shits a pain in the ass. but this is my first car ive worked on and im only a teenager so you should be able to do it. just make sure you have deep sockets and a swiveling wratcheting wrench that swilves in all directions
Last edited by h0rsies; 08-04-2010 at 02:04 PM. Reason: MSF Database - Automerged Doublepost
 Old 08-04-2010, 04:10 PM   #10
rodrigo's Avatar
Groans: 345
MAKE SURE U HAVE SOME 14MM RATCHETING OPEN END/BOX WRENCHES (COMBINATION) AND SOME DIFFERENT LENGTH EXTENSIONS FOR A 3/8 DRIVE RATCHET AND DEEP 14MM SOCKETS OF THE SAME DRIVE
as far as (sorry for caps) prying the flange u shouldnt damage the metal gasket....take your time and let it come out semi straight 9use some flat head screw drivers also in there to wedge it and keep it open while using the pry bar to do the heavy prying
- I see meh people
 Old 08-04-2010, 04:16 PM   #11
BrianZX10R's Avatar
Posts: 1,163   (View Stats)
BrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the worldBrianZX10R is the leader of the world
Groans: 88
Groaned at 121 Times in 75 Posts
The steedspeed is better and is cake to install
1995 honda civic. 1.6L slow
2007 Kawasaki ZX10r
BrianZX10R is offline   Reply With Quote
The Following User Says Thank You to BrianZX10R For This Useful Post:
manelscout4life (07-25-2011)
The Following User Says NO Thank You to BrianZX10R For This Un-useful Post:
 Old 08-04-2010, 04:35 PM   #12
-cj-'s Avatar
I'm about to execute on my BT install, but someone I spoke to DID NOT like the quality of the PG... He said that it was too thin and it'll crack with the weight of my turbo... :/ He said that it shouldn't glow red on a simple dyno run lol...
 Old 08-04-2010, 04:42 PM   #13
BrianZX10R's Avatar
Groans: 88
i would never buy a PG maniold. My V3 EWG one is for sale tho
2007 Kawasaki ZX10r
 Old 08-04-2010, 04:48 PM   #14
h0rsies's Avatar
would putting a turbo bracket prevent the mani from cracking since its less weight on the mani
 Old 08-04-2010, 05:12 PM   #15
BrianZX10R's Avatar
Groans: 88
it cracked on the bottom of all the runners. the weight would cause the tops to crack i would think. i think its just cheap shitty welds
2007 Kawasaki ZX10r
 Old 08-04-2010, 05:14 PM   #16
rodrigo's Avatar
Groans: 345
re weld it, god damn..it isnt that hard to brace shit
- I see meh people
 Old 08-04-2010, 05:16 PM   #17
Tripple OG
NJSPEED3's Avatar
Posts: 4,903   (View Stats)
Groans: 110
Groaned at 40 Times in 34 Posts
You can also remove the 2 bolts holding the passenger side mount to the frame rail. Also remove the 3 bolts holding the rmm. That should give you plenty of play to remove the mani.
8:5:1CP pistons...Pauter rods...NJSPEED P&P cyl head...ACT 6 puck...T3 HTA3586...CPE Big maf...Custom inlet....Hks Bov....44mm Tial ewg vta..... T3 SCH40 ARdesign Tubular Manifold...3" Vband dp....Greddy TI-c...custom fmic...Hallman MBC...CPE HPFP...JBR dogbone...SU sidemounts...Occ w/t MD checkvalve...SILVERDEMONS Injector Seals...Perm tuned..Sixth Port powered.
445whp 397wtq 4/12
478whp 470ishwtq 10/12
Killah Built Perm tuned
The Following User Says Thank You to NJSPEED3 For This Useful Post:
rfinkle2 (12-18-2012)
exhaust fitment Vinnie R 4 MazdaSpeed 3 - Engine, Transmission & Driveline 8 10-25-2008 11:08 AM
exhaust fitment question Vinnie R 4 Mazdaspeed3/6 General Discussion 0 10-22-2008 01:08 PM
Exhaust Manifold speed3wannabe Mazdaspeed3/6 General Discussion 22 04-08-2008 07:52 AM
Page generated in 0.38788 seconds with 28 queries
