Notices
 Old 10-02-2012, 04:21 PM   #1
Cudarich's Avatar
Posts: 35   (View Stats)
Cudarich is a name known to allCudarich is a name known to allCudarich is a name known to allCudarich is a name known to allCudarich is a name known to allCudarich is a name known to all
Groaned at 7 Times in 4 Posts
Default Please check my boost leak logic
Hello everyone,
I'm just posting this to get a second opinion, to check and see if my logic is correct. I was driving along the other day, when suddenly I noticed an unusual woosh sound coming from the engine compartment, from a different area than my tip. I also noticed it seemed down on power, so I plugged in my AP and saw that I was only getting 10psi max, when I am set to hit 18psi. I assumed it was a boost leak, as I got closer to home the car seemed to idle more and more erratically and by the time I got home I had a trouble code. I don't remember the trouble code off the top of my head, but It was for a lean condition on... bank 2, if i remember correctly. I just tallied up the lean trouble code to the boost leak.
I did the boost leak check trick with the PVC pipe cap and tire valve stem and found approximately where I was leaking. I later found out that the line going from the intake manifold to the oil catch can I installed a few months ago was ripped. Everything on the intake manifold where I felt/heard the leak coming from looks good. I am thinking the broken catch can line between the can and intake is where my issue is.
Does this sound correct?
Thanks for any help
Cudarich is offline   Reply With Quote
 Old 10-07-2012, 01:27 AM   #2
skiptowncat's Avatar
Posts: 1,209   (View Stats)
skiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the worldskiptowncat is the leader of the world
Groans: 34
Fix it and find out.
Tuned with by
Su tmic/corksport intake/custom 3" tbe/grimmspeed ebcs/forge bpv/jbr ssp/jbr rsb/Jbr side mount/sure tig set/sure r3 rmm/kmd internals/pg sst (tune in progress)/3 gauge pod
skiptowncat is offline   Reply With Quote
 Old 10-07-2012, 07:14 AM   #3
Shadow's Avatar
Posts: 420   (View Stats)
Shadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the worldShadow is the leader of the world
Yes. Also your car doesn't have a bank 2 as its a straight 4.
Sent from my ADR6400L using Tapatalk 2
2012 Black Mica MS3 w tech
Cobb AP, CS SRI, CS TIP, Catless DP/TP, Autotech Internals, NGK Plugs 1 colder, Magnaflow CBE, HKS V2 BOV Recirc, ETS TMIC, CS SSP, CS RMM Inserts, CS RSB, CS Springs, Hankook ventus z214 c71 225/45r17 r comp tires for autocross, Stock doneflops for everything else
Shadow is offline   Reply With Quote
 Old 10-07-2012, 07:51 AM   #4
anavrinIV's Avatar
Posts: 2,078   (View Stats)
Groans: 35
Groaned at 25 Times in 14 Posts
bank 2 refers to the second o2 sensor in this car
2007 Black Mica MS3
Go Fast Bits: Tune in progress - AutoTech HPFP Internals - 3.5" JBR WP - CP-E Catted Downpipe - HKS SSQV3 VTA - CNT CBE- JBR EGR Block-off - TB TIG - IM TIG - Ported Stock Intake Mani - NGK Step Colder Plugs - Treadstone TR8L FMIC Core - Custom FMIC Piping
Cornering: Koni Yellows - JBR Rear Sway Bar - TR Motorsport C3s - 5mm Front Spacers
Shifting: JBR SSP/Solid Bushings/Counter Weight - JBR 88a RMM - JBR 70a PMM - JBR 70a TMM
Fiddly Bits: WOLO Model 417 Long Horns - JBR OCC - Spin-on Filter Conversion
 Old 10-07-2012, 08:48 AM   #5
Shadow's Avatar
Funny since bank 2 refers to second head. Sensor 2 usually refers to "sensor 2".
Not hitting Stage 2 boost targets (boost leak?) Bubba Ho-Tep 2010 MS3 - ECU Computer Tuning 15 04-26-2012 07:25 PM
Help! MS6 Boost Fading In/Out. Boost Cut? Leak? MS600RR MazdaSpeed 3/6 - Troubleshoot/Diagnostics 10 02-28-2012 07:48 AM
Interesting Find During boost Leak check Nitr0EngiE MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 10-17-2011 04:48 PM
Vacuum leak, but no boost leak? vbt101 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 23 04-18-2010 12:06 PM
Page generated in 0.27992 seconds with 23 queries
