 Old 07-20-2011, 10:26 AM   #1
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
Default porting the iwg on a 3076r
just ordered my lovely new turbo. i will be using the iwg for a while and it is suggested that i port the iwg out a bit. i am not afraid to do something like this, but i am a little unsure of what tools to use. i ported a small block chevy head back in high school using a carbide burr, but i know there are other things like this sand paper stuff that is mostly used. can someone please point me in the right direction on which i should use for this specific job?
thanks in advance
 Old 07-20-2011, 10:38 AM   #2
I Love Brownies's Avatar
Posts: 3,791   (View Stats)
I Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the worldI Love Brownies is the leader of the world
Groans: 371
Groaned at 62 Times in 39 Posts
hey man my buddy just put in this turbo and he gets no boost creep. i know it wouldnt hurt im just letting you know.
I Love Brownies is offline   Reply With Quote
The Following User Says Thank You to I Love Brownies For This Useful Post:
Alpha (07-20-2011)
 Old 07-20-2011, 10:42 AM   #3
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
I think pretty much if the IWG hole is greater than 25mm, then you're good to go...the newer ATP turbo's are supposed to have enlarged IWG's anyway, so might want to check that before worrying yourself.
My 3071 has a ported IWG, much largr than 25mm...no creep.
-- Mario Andretti --
 Old 07-20-2011, 08:36 PM   #4
driver311's Avatar
Posts: 1,769   (View Stats)
driver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the worlddriver311 is the leader of the world
Ported till till barely smaller than the flapper. simple as that. Dont risk the creep. Lenny still gets it on the new 3071r.
2008 Mazdaspeed3, Fully built then fully parted. Sold
2007 ccsb Silverado, 3/5 drop Procharged, longtubes, 10psi Daily
Mazdaspeed
12.5 @109 k04 stock ecu 18psi pump gas stock motor 311whp
11.7 @120 atp gtx3071r ap tuned 22psi 30/70 e85/pump stock motor. 422whp
driver311 is offline   Reply With Quote
 Old 08-07-2011, 12:26 AM   #5
burntmushu's Avatar
Posts: 128   (View Stats)
burntmushu has a reputation beyond reputeburntmushu has a reputation beyond reputeburntmushu has a reputation beyond reputeburntmushu has a reputation beyond reputeburntmushu has a reputation beyond reputeburntmushu has a reputation beyond reputeburntmushu has a reputation beyond reputeburntmushu has a reputation beyond reputeburntmushu has a reputation beyond reputeburntmushu has a reputation beyond reputeburntmushu has a reputation beyond repute
well you could use pink white or the blue stones on a air grinder. remember to dip it in oil and grind. occansionally relubricating the stone. once you're close to where you want it stop coz the grinds are going to be somewhere like 30 grit. if you got a dremel then hook up the 80 grit and start smoothing it out. when the scratches look about the same which means you took out all the deep scratches from the stone go to a lighter sand paper like 120 or 220 and do the same thing. once your done with that it should be good enough but if you want to be anal like i was... i'd put a polishing wheel on it and polish it until you're happy with it.
burntmushu is offline   Reply With Quote
Head Porting Potential pbblaster MazdaSpeed 3 - Engine, Transmission & Driveline 14 11-25-2008 05:29 PM
Page generated in 0.25914 seconds with 24 queries
