 Old 11-27-2008, 09:17 PM   #1
Lymerock's Avatar
Posts: 1,436   (View Stats)
Default Questions about porting the WG on the stock turbo
What is the minimal overlap recomended for the wastegate flap to maintain a proper seal?
PTP mentioned in another thread that the pic below showed "plenty of room to port it out"
if thats the case, how thin would I dare go? Im down to port it, but only if I feel confident im not gonna junk yard it by doing so.
07 CB Speed3
COBB AP S2+, MS CAI (shorty w/ straightener), RPMC inlet, ETS 3.25", Devils Own S2 Alchy Injection, PG Manifold V2, TXS DP (with Cobb highflow cat soon), TXS mid, MS CBE, HKS Plugs (1 step colder), Fidanza Flywheel, KMD CDFP internals, COBB Sways, Koni Dual Adjustable Shocks, AWR 88 trans mount, Hawk HP+ pads (F+R), Motul RBF 600 brake fluid, 18x8 +50 weds sa70's 245/40 falken rt-615's, V1 hardwired, Autometer ES Gauges (boost/vac, water, oil pres), Dashhawk, stock turbo with modified boost control system
 Old 11-28-2008, 02:35 PM   #2
CraigHJr's Avatar
Posts: 676   (View Stats)
CraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the world
What is your car doing? I took out some material along the hump in the flow path and smoothed it a good bit. I feel that the hump is there to make exhaust flow to the wg so I rounded the edges alot. I enlarged my wg opening about 1mm all the way around. Just make sure you don't compramise the sealing surface you will see a clear ring where the flapper door sits.
If anyone needs install help in my area (Bergen County NJ) let me know. I have all the tools and work for cheap.
CraigHJr is offline   Reply With Quote
 Old 11-30-2008, 01:49 PM   #3
ptperformance's Avatar
Posts: 4,123   (View Stats)
ptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the world
You will need a minumum of .100 overlap. I have taken them to .080 but thats taking risks that are unecessary.
What you want to do is look at how the unit flows. Make changes in the areas that would induce proper or more flow to the exhaust gasses. By doing this you should see a higher boost hold to redline and lower EGT's. I would also have to say that if you plan on doing the port work I would get it ceramic coated as well. This makes a huge difference in spool time for the turbo. Start porting and I will post pictures of what we have done to our units so you have a kind of guide to port off of.
ptperformance is offline   Reply With Quote
GT Series Turbo Questions. JimmyMac MazdaSpeed 3/6 - Turbo Induction 71 11-07-2013 04:47 PM
Head Porting Potential pbblaster MazdaSpeed 3 - Engine, Transmission & Driveline 14 11-25-2008 05:29 PM
Upgraded/reworked turbo questions red07 Mazdaspeed3/6 General Discussion 5 11-08-2008 11:08 AM
Exhaust manifold porting costs? Mellman Mazdaspeed3/6 General Discussion 2 03-20-2008 05:29 PM
Page generated in 0.24476 seconds with 22 queries
