 Old 11-08-2008, 04:59 AM   #1
tbone's Avatar
Posts: 55   (View Stats)
tbone is an unknown quantity at this point
Default rough idle?
hi guys,
after putting my test pipe on i noticed teh idle went below 8 and rough? is this normal?
THKS
2008 ms3
tbone is offline   Reply With Quote
 Old 11-08-2008, 07:58 AM   #2
you have a vacuum leak. check your hoses.
 Old 11-08-2008, 08:43 AM   #3
Frequentflyer's Avatar
Posts: 1,948   (View Stats)
Did you reset the ECU?
08.5 CWP MS3 - Cobb AP *Stage 2* ATR tweaked - Cobb SRI w/AEM dry flow filter - RPMC Inlet - Corksport TMIC - Corksport Downpipe (w/OE midpipe) - PTP HPFP - Stock BPV - TWM SS w/bushings - CP-e RMM - Bilstein Sports w/OE springs - Rota 18x8.5 48+ SVN Black/w Red Lip - Bridgestone Potenza RE760 - Cobb RSB - Prosport Boost Gauge/Mearcat pod - Motorcraft XT-M5-QS in the tranny!
 Old 11-08-2008, 11:55 AM   #4
tbone's Avatar
no ididnt reset it. take the ground off right?
 Old 11-08-2008, 02:01 PM   #5
Yep.
 Old 11-08-2008, 02:07 PM   #6
tbone's Avatar
thanks....took it off for 2 minutes, pumped brakes, still low idle........no leaks i can see. maybe i should reset again?
 Old 11-08-2008, 04:59 PM   #7
Do you have a boost/vacuum gauge? If so, what in/hg is it reading at idle?
 Old 11-09-2008, 10:03 AM   #8
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
well, it sounds like a leak somewhere.
and, i don't think disconnecting the neg terminal for 2 minutes is enough to reset. 15-20 is more like it.
but...rough idle is normally a leak somewhere.
were you in the engine bay for any reason lately?
did something get loosened?
check the couplers for the tmic...check the hoses on the valve. good luck
 Old 11-09-2008, 05:16 PM   #9
tbone's Avatar
thanks...but im new here and a tmiic? what is this and where? on th elift only for the test pipe......BTW the idle is at 8. it was at 10
 Old 11-09-2008, 05:42 PM   #10
Do you mean 1,000 and 800 RPM? My car idles at about 750-800 normally when fully warmed if I recall. Your vacuum should be about 20-22 in/Hg at a warm idle. If it's significantly lower than that, you've got a leak.
 Old 11-09-2008, 07:01 PM   #11
phillyb's Avatar
Groans: 1,940
tmic - top mount intercooler
 Old 11-10-2008, 05:51 AM   #12
tbone's Avatar
thanks guys.........ill check it out
 Old 11-10-2008, 06:38 PM   #13
I looked at my car today at idle. It's idling at 750 RPM. Granted, it's smooth, but it's at 750 RPM.
 Old 11-11-2008, 06:10 AM   #14
tbone's Avatar
thanks...................mine is abt 8.
Rough clutch pedal feel dread MazdaSpeed 3/6 - Troubleshoot/Diagnostics 16 06-13-2013 09:38 PM
HELP - Rough idle after dp install ccs70 MazdaSpeed 3/6 - Turbo Induction 25 10-14-2008 02:40 PM
rough timeline/price on the single-adjustable coilovers for the speed3? Case MazdaSpeed 3/6 - ECU Computer Tuning 2 10-07-2008 11:01 AM
NADA adds 'Rough' and 'Average' categories for trade-ins Haltech Automotive News 0 09-07-2008 07:10 AM
Help!! Rough 1st to Second Shift CSlater21 MazdaSpeed 3 - Engine, Transmission & Driveline 8 06-17-2008 10:15 AM
Page generated in 0.31634 seconds with 23 queries
