Like Tree10Likes
 Old 01-27-2017, 10:18 AM   #41
Jeff23spl's Avatar
Posts: 2,192   (View Stats)
Originally Posted by GroceryGtr View Post
I have a 6. On a side note nice to see a probe guy still around... I had a fsze swapped 95 mx6 and then a turbo fsde mx6.
ok maybe torque can be used on a 6, i don't know, but street driving a 3 is worthless to talk about lag below third gear with good tires as you need to manage around it to keep traction.
This is why i say the lag of a mid size turbo upgrade doesn't really matter. my actual gt28 start boosting just above the dangerous point...
I still have the Probe to carry my old sound system during summer. I have it since 1998 and it doesn't really worth to sell it. I run the second klze (first one hydrolocked...) The sound of these engine are wonderfull even if it comes with a limited potential. I was looking to do a V6T but i bought the Speed and find it worthless to go that route...
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 06-08-2017, 09:01 PM   #42
zenit's Avatar
Posts: 1,364   (View Stats)
Groans: 57
Groaned at 7 Times in 6 Posts
Update:
Super-cheater K04 works great, and flows ~46lb/min or 4 volts on a 4" htp intake.
I've run into a tuning problem that I can't make heads or tails of.
In high 30lb/min & >3.5 maf volts the car has trouble keeping up and is doing some weird fuel trimming which results higher requested lambda/AFR's(see attached log).
I must be missing something, but I not sure what. I recreated my tune, based off a high load OTS map in versatuner, but still have the issue.
-feejay
-wetzel
 Old 06-11-2017, 07:59 PM   #43
zenit's Avatar
Groans: 57
still seeing fueling not meeting targets, not sure why.
I redid the map in a different OTS tune in versatune with 93 for the larges amount of fueling overheard possible.
Not sure whats up- logs show WOT Fuel trimming still, and some random desired AFR's of 1.0/0.99 (car seems to ignore this).
3 logs attached, with tune (zipped due to file extension issues).
-feejay
-wetzel
 Old 06-26-2017, 07:15 PM   #44
zenit's Avatar
Groans: 57
Update time - super-cheater can haz 400hp
except I just noticed in logs from about a month ago:
brief/relevant mod list-
SURE Intercooler, Autotechs, 4" htp intake, 3" catless DP
For the sake of the rods and ringlands, the wgdc is going way down now that I've hit my self-imposed target power figure. That massive drop in power after the peak is due to the lean condition.
I still haven't figured out the fueling issue, but I did stumble across this issue in a recent thread revival:
Post-spool lean condition
Most notably, this nearly perfectly describes my problem:
the proposed treatment is time- at this current moment I don't have a hardware or tuning fix for this, but most have reported that this goes away with time.
-feejay
-wetzel
The Following 2 Users Say Thank You to zenit For This Useful Post:
AnimalMother (06-26-2017), Djohns (06-26-2017)
 Old 12-13-2018, 02:25 PM   #45
Jeff23spl's Avatar
I revive that old thread to ask if you made any progress with that turbo ?
Wife drive 2010 CX7
2.1M Audi vehicles used cheater software Haltech Automotive News 0 09-28-2015 08:30 AM
Mercedes named top cheater on Europe's fuel economy test Haltech Automotive News 0 11-09-2014 01:10 PM
O2 cheater? deadbeatrec Gen2 MS3 General Discussion 15 11-14-2011 10:54 AM
SEMA Preview: 900-HP Super Challenger and Super 'Cuda Haltech Automotive News 1 10-14-2008 04:41 PM
Super rich may avoid super expensive cars because of bad image Haltech Automotive News 0 10-02-2008 06:10 PM
Page generated in 0.26884 seconds with 22 queries
