 Old 10-13-2009, 07:49 AM   #1
sheltbh's Avatar
Posts: 63   (View Stats)
sheltbh has a spectacular aura aboutsheltbh has a spectacular aura about
Default Turbosmart Dual Port
So first let me say this thing was well needed on my car. I received it on Saturday so I changed my oil, put on new tires and replaced the BPV! After installation the car runs so smooth, actually so smooth I'm worried it might explode or turn into a giant robot. Before the BPV upgrade when letting the engine slow the car it was very jumpy and the exhaust gargled very loudly, now it has now jumpiness and you can't here any backfiring going on
Should I be Worried?! or is it just that much needed? I was also wondering on how to tune this thing to achieve the best performance? I have reduced the spring tension down to a turn before you see the red line... I know people say that it is good out of the box but I kept loosening it because I hear the fluttering on recirc only and it only was reduced by lowering the spring tension. Any help or thoughts would be appreciated
sheltbh is offline   Reply With Quote
 Old 10-13-2009, 09:53 AM   #2
Always Blasted
DCLXVI's Avatar
Posts: 653   (View Stats)
DCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the worldDCLXVI is the leader of the world
Groans: 34
Groaned at 274 Times in 34 Posts
you're supposed to let the spring settle for 2 weeks as stock. 1/4th inch away from the base. from there, you need to tighten it to weed out backfires as well as flutter. if you want to get rid of all of your problems, put it to full recirculation and tighten it little by little until no more popping.
07 Speed 6 GT Cobb AP Stage 2+TIHSF+TMIC 93 Octane, ETS 3.5'' TMIC, Cobb Short Ram Intake, Cobb Turbo Inlet Pipe, Turbosmart Dual Port Blow Off Valve, SU Test Pipe, Custom CPE/Magnaflow Exhaust, Corksport Strut Brace, TWM Stage 2 Short Shifter, TWM Weighted Desert Eagle Shift Knob, AWR Transmission Mount, SU Base Bushings, SU Rear Motor Mount, Optima Yellowtop Battery, PIAA Plasma Ion Fogs, EBC Red Brakes, Denso ITV22s .28 Gap, Prosport Boost Gauge, RPM Sport Springs, Bilstein Shocks, SPC Balljoints, Continental Extreme Contact DWS AAA XL, Pirelli Sottozero snow tires, 5zigen ProRacer GN+ 18x8.5.
DCLXVI is offline   Reply With Quote
 Old 10-13-2009, 10:11 AM   #3
sheltbh's Avatar
Well I have no popping no matter where I put the spring, and the flutter got worse the more I tightened it, I guess my main concern is if there are any performance degradation by lowering the spring rate? I know from past experience that you should use the lowest rate possible to allow the vacuum to reset the quickest possible. The flutter is barely noticeable under light recirculation, but I don't want that to have adverse side effects later on
 Old 10-26-2009, 02:38 PM   #4
Jogadoggz's Avatar
Posts: 50   (View Stats)
Jogadoggz is just really niceJogadoggz is just really niceJogadoggz is just really niceJogadoggz is just really nice
I spoke to a Tech guy at turbosmart in Cali and if you are still fluttering, he recommended to turn the valve to the hard settings half a turn, keep adjusting it until the fluttering sound is gone. But he had pointed out that when you first install this bpv/bov before driving is to have it turned all the way to soft and keep reving your motor and adjusting the settings until the idle is smooth.
2007 Pearl White MS3 | 18x8.5 Work Schwerts SC4 | H&R Sport Springs | Autoexe Emblemless grill painted black | GV Copy Front Lip | RE-Amemiya Rear Lip | Black Roof | Magnaflow CBE | Cobb SRI | Cobb FMIC | Cobb AP | Turbosmart BOV | Defi Red Racer Gauges
Jogadoggz is offline   Reply With Quote
turbosmart dual port adjustment Boostaholic MazdaSpeed 3/6 - Turbo Induction 1 10-06-2009 10:20 AM
Page generated in 0.24700 seconds with 22 queries
