-   MazdaSpeed 3/6 - Turbo Induction (http://www.mazdaspeedforums.org/forum/f11/)
-   -   Turbosmart Dual Port Flutter/Surge/Flutterdump? (http://www.mazdaspeedforums.org/forum/f11/turbosmart-dual-port-flutter-surge-flutterdump-69234/)
ChimmyChong 01-10-2011 08:53 AM
Hey gays.... I mean guys...
I just got a turbosmart dual port and was wondering if the sounds I am hearing are normal.
All the videos Ive seen of the dual port don't emit the fluttery sound I get when letting off the throttle in low rpms/low boost situations.
Heres a video I just uploaded of the sounds... I tried to lift off the throttle at lower rpms and gradually go to higher rpms towards the end of the video... You notice the flutter then dump at lower boost/rpms and then a clean dump at high rpms/full boost.
Also I cleaned the bpv/bov and lubed up the internals. After lubing up the piston and walls I double checked the install and it changed nothing... Note that even going from the hardest setting to the softest by quater turn increments did nothing but waste time and lube.
thanks dudes for any input
ChimmyChong 01-10-2011 09:29 AM
just donated for results/opinions and sexy threads
Page generated in 0.17625 seconds with 11 queries
