 Old 01-10-2011, 08:53 AM   #1
ChimmyChong's Avatar
Posts: 591   (View Stats)
ChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the worldChimmyChong is the leader of the world
Groans: 39
Default Turbosmart Dual Port Flutter/Surge/Flutterdump?
Hey gays.... I mean guys...
I just got a turbosmart dual port and was wondering if the sounds I am hearing are normal.
All the videos Ive seen of the dual port don't emit the fluttery sound I get when letting off the throttle in low rpms/low boost situations.
Heres a video I just uploaded of the sounds... I tried to lift off the throttle at lower rpms and gradually go to higher rpms towards the end of the video... You notice the flutter then dump at lower boost/rpms and then a clean dump at high rpms/full boost.
Also I cleaned the bpv/bov and lubed up the internals. After lubing up the piston and walls I double checked the install and it changed nothing... Note that even going from the hardest setting to the softest by quater turn increments did nothing but waste time and lube.
thanks dudes for any input
2010 Liquid Silver MS3
// BNR S3 // 3Bar Map+MJ Harness // JBR 3.5" WP // CS TMIC // KMD HPFP // 3" Catless DP/RP // TS Dual Port // Cobb AP // GS 3 port EBCS // ITV-22's // MD OCC // JBR Small Battery Tray //
// JBR Dog Bone RMM // JBR Heavy Knob // JBR Solid Shifter Bushings // JBR Short Shifter Plate // JBR RSB // JBR 80D PMM // 15mm Front // 10mm Rear // SPC Rear Camber Arms // Sonic Tuning Coilovers //
// 6K HID // 35% tint // 12"RF with Infinity Amp // MZ Front Lip // 17x8 Enkei RPF1's //
ChimmyChong is offline
 Old 01-10-2011, 09:29 AM   #2
Groans: 39
just donated for results/opinions and sexy threads
Turbosmart Dual Port sheltbh MazdaSpeed 3/6 - Turbo Induction 3 10-26-2009 02:38 PM
Page generated in 0.24011 seconds with 20 queries
