  • 1 Post By platinum07
 Old 11-09-2010, 10:04 PM   #1
platinum07's Avatar
Posts: 80   (View Stats)
platinum07 has much to be proud ofplatinum07 has much to be proud ofplatinum07 has much to be proud ofplatinum07 has much to be proud ofplatinum07 has much to be proud ofplatinum07 has much to be proud ofplatinum07 has much to be proud ofplatinum07 has much to be proud ofplatinum07 has much to be proud of
Neutral  -1 score
Default Turbosmart dual port HELPPPPP
Any advantages or disadvantages with with running it harder or softer? I love the fact that it is 50:50 but I'm not sure how I should adjust it, I bought it used and the seller didn't tape the box shut so the little CD that is comes with broke. I have played around with it quite a bit making it both harder and softer and it doesn't make the car run funny either way really. Sooo does it maybe mean it only adjusts noise because that's what I'm getting form it? btw it seems to run a little bit better when its turned a bit harder but like I said there is barley any difference either way. I would love any help I can get thanks guys!
sp33dfr3ak likes this.
platinum07 is offline   Reply With Quote
 Old 11-10-2010, 01:00 AM   #2
Night Wolf's Avatar
Posts: 894   (View Stats)
Night Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the worldNight Wolf is the leader of the world
Groans: 38
If you'll run it 50:50 make sure you clean it up and lubricate it once in a while cause if dirt gets to the piston it might seize up. And that would suck big time (bye bye turbo).
2008 Mazdaspeed 3GT
Wiseco pistons || K1 rods || GT3076 at 21 PSI (for now) || Built by Pablo and tuned by Dustin || Steedspeed exhaust mani || TIAL 38mm EWG || Custom dump tube || Grimmspeed EBCS
CP-e safe seals || CP-e 4" TIP || CP-e big maf || CP-e catless DP || CP-e HPFP || CP-e gauge pod with Prosport gauges || COBB FMIC || COBB XLE BPV || COBB STS || COBB AP
Matt Damond OCC || CNT exhaust || BSD || EGR del || DENSO ITV22 || TRZ RMM || TRZ TMM || JBR PMM || JBR shift knob || Stoptech slotted rotors || KONI FSD || ROTA GRID 18 x 8.5
NATOR NJ FTW
Night Wolf is offline   Reply With Quote
 Old 11-10-2010, 03:03 AM   #3
forever_skyline's Avatar
Posts: 28   (View Stats)
forever_skyline is a splendid one to beholdforever_skyline is a splendid one to beholdforever_skyline is a splendid one to beholdforever_skyline is a splendid one to beholdforever_skyline is a splendid one to beholdforever_skyline is a splendid one to beholdforever_skyline is a splendid one to behold
TURBOSMART: INSTRUCTIONS & DOWNLOADS
here you can find the installation instructions
Black MPS6 -2007
EcuTek - 306hp and 332lb/ft
forever_skyline is offline   Reply With Quote
The Following User Says Thank You to forever_skyline For This Useful Post:
Doucems6 (11-10-2010)
 Old 11-10-2010, 05:17 AM   #4
Aetherfury's Avatar
Posts: 1,227   (View Stats)
Aetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the world
Harder and softer will make a drivability difference (and is the same as changing shims on the Forge) but when you adjust it you have to leave it alone for 25-30 miles to break in each setting. So don't adjust it a bunch.
As a matter of fact, I remember seeing a thread telling people to turn it all the way hard, then back it off like two full revolutions for the speeds. I can't remember if it was two or three actually.
I drive a white car with a HUGE spoiler
Cobb Accessport Stage 1 + Cobb SF Intake
Aetherfury is offline   Reply With Quote
 Old 11-10-2010, 07:03 AM   #5
platinum07's Avatar
thank you sir! that helped a lot looks like need to turn it a bit more to the harder side, I am getting one small back fire shifting from 3rd to 4th it says that should clear it up! thanks guys!
 Old 11-10-2010, 01:17 PM   #6
Hope you sort it out
Black MPS6 -2007
 Old 11-11-2010, 12:21 PM   #7
Marty Staggs's Avatar
Posts: 9   (View Stats)
Marty Staggs has a spectacular aura aboutMarty Staggs has a spectacular aura about
This may also be of some help to folks -
Marty Staggs is offline   Reply With Quote
 Old 01-03-2011, 03:41 PM   #8
avillamarin's Avatar
Posts: 74   (View Stats)
avillamarin is on a distinguished road
Groaned at 7 Times in 5 Posts
clean the dual port? how is that done?
avillamarin is offline   Reply With Quote
 Old 01-03-2011, 08:59 PM   #9
Night Wolf's Avatar
Groans: 38
Unscrew the cap, but be careful because it may shoot away because of the tension on spring inside. Then remove spring and piston out of the cylinder. Clean all part from old lubricant residue and apply new one. Then reverse procedure to put it back together. Be careful not to break rubber gasket because then your dual port might leak.
2008 Mazdaspeed 3GT
NATOR NJ FTW
 Old 01-04-2011, 07:52 PM   #10
got it. i read a bunch of lubes for cleaning, which one is the best as you know?
 Old 01-04-2011, 08:55 PM   #11
Night Wolf's Avatar
Groans: 38
I have no clue. I used gun lubricant. =)))
2008 Mazdaspeed 3GT
NATOR NJ FTW
 Old 01-04-2011, 09:05 PM   #12
pearl_ms3's Avatar
Posts: 545   (View Stats)
pearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the worldpearl_ms3 is the leader of the world
Groans: 32
Groaned at 27 Times in 12 Posts
i like http://www.streetunit.com/TurboSmart...g-pa-ms050.htm
CP-E INTAKE W/ AMSOIL FILTER, CP-E INLET, TURBOSMART BOV, DENSO ITV22, AWR RMM, STREET-UNIT TMM & PMM, STEEDSPEED MANI CERAMIC COATED, T3 GT3076, TIAL EWG, CUSTOM V-BAND DOWNPIPE, UR CATTED TESTPIPE, TURBO XS CATBACK EXHAUST, COBB FMIC, CP-E FUEL PUMP, DASHHAWK+CP-E MOUNT, JBARONE SSP, COBB ACCESSPORT STAGE 2 SF 91 FMIC. SELF TUNED WITH 400HP/375TQ @ 21 PSI ON 100 OCTANE.
pearl_ms3 is offline   Reply With Quote
 Old 01-09-2011, 07:47 PM   #13
Boostedspeed3's Avatar
Posts: 39   (View Stats)
Boostedspeed3 is a jewel in the roughBoostedspeed3 is a jewel in the roughBoostedspeed3 is a jewel in the rough
awesome time to chime in as i haven't had time to introduce myself on the forums, but you can also use sewing machine lubricant that you can pick up at walmart or target. it's the same petro based lubricant as in the one on streetunit's website
Boostedspeed3 is offline   Reply With Quote
Turbosmart Dual Port sheltbh MazdaSpeed 3/6 - Turbo Induction 3 10-26-2009 02:38 PM
Page generated in 0.35092 seconds with 27 queries
