> MazdaSpeed 6 - How-To's
 Old 07-15-2010, 10:36 AM   #1
qtrmile beast's Avatar
Posts: 2,423   (View Stats)
Default bc coilover rears part 2
Ok the rear shock are a little bite harder and this is not for your average installer.
All of these pics are while laying on your back with your feet hanging out of the rear of the car. Also most of these pics are of the driverside shock unless other wise stated. Ok so lets get started...
This bolt is a 17mm and you also might want to have an additional one for the other side just incase the entire bolt turns together. The bolt that i am refering to is the one just to the right of the jackstand.
After you have gotten that one loose there are three bolts that hold the upper plate for the shock in place. They are 14mm.
This is where is gets a little difficult. IT IS HIGHLY SUGGESTED THAT YOU GET A SWIVEL 14mm not just a swivel with a 14 on it the on that is already made with 14 on the other end. I will get a pic of what i am talking about later. You CAN do it without one by using a regular swivel with a 12' and 6' extension 3/8 drive it will just take little more time to get out.
Remember these pics are taken while laying on my back on the driverside wit my head pointing to the front of the car.
Here are all three bolts.
this one here you will need to use a closed end 14mm wrench as a socket will not fit.
both of these are the same pic just from a different angle. the bolt that you want to take out is the on to the right on pic one and the lower one in pic two notice the plate is bent around the bolt.
I will be taking pics of how i got the swivel up on there later so you will know how i got the bolts out. Once you have these bolt all out then you will have to maneuver the plate out of the area it is in. It will come out you will just have to find the right angle to get it out also are the tip of that plate if a safety hook. It is easy to bend. You will need to have this bent un order to get the shock out. This will come loose very easily while you are trying to find the right angle to get the plate out. FYI..YOU CAN NOT GET THE NUT AND BOLT OFF THE TOP OF THE SHOCK WITHOUT TAKING THE PLATE OUT.....
If these pics prove to be too difficult to understand then please let me know.
Once you have the shock out the you will need a 17mm to get the shock loose from the plate.
The Following User Says Thank You to qtrmile beast For This Useful Post:
lolubeenpwned (08-04-2014)
 Old 07-15-2010, 10:55 AM   #2
lol and to add a little more,
it helps if you lower the subframe as far as it can go without coming off the bolts, it may seem like extra work but it def helps. also i found it easier NOT to bend that hook as mine came out just fine with it still in its original position and you definitely need it back to where it was to be able to thread the bolts back in. if you can do this on a lift i highly suggest it.
ive also heard that the bottom mount on the BC coils tends to be slightly larger then the bracket on the trailing arm so you may need to grind down either to get it to go back in. and make sure the dampening adjustment is at the top of the shock where the plate is and facing outwards of the car. be sure that you reinstalled the new shock at the same angle with the plate as the old one came out.
 Old 07-15-2010, 12:27 PM   #3
Ive also heard that the bottom mount on the BC coils tends to be slightly larger then the bracket on the trailing arm so you may need to grind down either to get it to go back in. and make sure the dampening adjustment is at the top of the shock where the plate is and facing outwards of the car. be sure that you reinstalled the new shock at the same angle with the plate as the old one came out.
I am going to get a pic of the best swivel that is needed for this job which will save you from any extra work. Also on the bracket there is a "SLEEVE" that will need to be tapped back out to make room so you don't have to do any sanding... More pics i have to take now thanks skater!!!!
 Old 12-29-2010, 09:41 AM   #4
speedms6's Avatar
Posts: 825   (View Stats)
any updates on this?
 Old 12-29-2010, 10:22 AM   #5
on what the swivel.. sorry i have not posted this as i have been doing other HOW TOs...
http://www.ntxtools.com/network-tool...SKT-33432.html they have some that are not impact as well and also thinner walled one as well..
track weight 3220
street weight 3370
 Old 12-31-2010, 01:37 AM   #6
06speed's Avatar
Posts: 96   (View Stats)
06speed will become famous soon enough
Groaned at 25 Times in 7 Posts
who ever thought that the bolt placement was a great idea needs to be shot. it was hell installing the rear coilovers
06speed is offline   Reply With Quote
 Old 06-28-2014, 04:24 PM   #7
Caldazar's Avatar
Posts: 293   (View Stats)
Caldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond reputeCaldazar has a reputation beyond repute
I was just doing some fluid changes, air filter etc, and I saw that my rear shocks are leaking. So I started looking up there for the top bolt and, yes I agree, whatever dumbass came up with this should be taken out back and beaten. what a dolt.
thanks for the writeup.
06 Speed6, camber balljoints and alignment, HankookV12 Evos, Konigs, Corksport full intake system, PTP pump internals, Cobb Ap, Forge BPV. Daily driver
91 Talon TSi, 5spd AWD, GT3076R, fmic, 3" exhaust, Jackal EMS, methanol injection, JIC C/O and more. Looking at 10's
Caldazar is offline   Reply With Quote
 Old 08-05-2014, 02:11 PM   #8
lolubeenpwned's Avatar
Posts: 12   (View Stats)
lolubeenpwned is an unknown quantity at this point
Yep. Tried to do this yesterday and after an hour I had one upper bolt out, my hand was cramped and I was bleeding. Someone at Mazda needs their head bashed in. Why not do a traditional top mount in the trunk instead of being fucking retarded Mazda? Uff.
lolubeenpwned is offline   Reply With Quote
 Old 04-14-2015, 06:45 PM   #9
sporkbomb's Avatar
Posts: 295   (View Stats)
sporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the world
I used a long-ish 14mm offset wrench to break the rear bolts of the shock upper plates ... then finished the "dreaded bolt" w/ extensions + universal joint attached to the 14mm socket. I thought the more annoying part of this install was getting the damn plate+shock back in on the left-hand side. It left me wanting to punch a baby.
2007 MS3 GT
Autotech CDFP Internals || Cobb AP, SRI, TIH, DP, CB, BPV, EBCS, FSB & RSB || cp-e Injector Seals, EGR Delete|| JBR OCC, Shifter Plate, PMM & TMM, TB & Intake TIG, Coolant Bypass|| Mazdaspeed Coilovers || TRZ RMM|| TWM Bushings || MOOG Front & Rear Endlinks
2006 MS6 GT (ZZB Rebirth)
Autotech CDFP Internals || BNR Stage 3 || Bosch 3 Bar || Cobb AP || cp-e Injector Seals, CBE, DP || ETS TMIC || Full Race EM || H&R Coilovers || JBR Mounts, 3.5" WP Aluminum Intake || Matt Damond OCC, Shifter Plate, EGR Delete || Racing Beat Rear Endlinks || Relentless PnP IM || SPC Balljoints || Whiteline RSB || The Company of Which I Will Not Name Front & Rear Diff Mounts
1990 Miata
I like it raw
sporkbomb is offline   Reply With Quote
 Old 12-30-2015, 07:37 PM   #10
aviator79's Avatar
Posts: 3,934   (View Stats)
Groans: 67
Third time doing this. Swivle socket on outer bolts. Broke PS loose with wrench but did DS with this setup.
GT Snail (02-12-2017)
 Old 04-12-2017, 10:32 AM   #11
Mazd1222's Avatar
Posts: 74   (View Stats)
Mazd1222 has a spectacular aura aboutMazd1222 has a spectacular aura about
Does anyone know the torque specs of the rear shock assembly.
Mazd1222 is offline   Reply With Quote
 Old 11-18-2019, 12:56 PM   #12
dynamho's Avatar
Posts: 7   (View Stats)
dynamho will become famous soon enoughdynamho will become famous soon enough
Just got to doing this last weekend and trying to slide the bottom of the shock into the lower bracket, but that "SLEEVE" you mentioned...
If you're referring to the the eyelet that resembles a bushing on the rear side of the bracket, I couldn't get it to budge using a slide hammer and I don't want to grind the bottom sleeve of the shock because any gaps would cause noise.
What did you use to ease that out? I'm thinking of McGyvering a puller using screws and nuts.
dynamho is offline   Reply With Quote
 Old 11-18-2019, 01:08 PM   #13
dynamho's Avatar
FYI: Without dropping the chassis subframe, I was able to remove all three top bracket bolts using Kobalt 14mm flex-head combination ratchet wrench. I used the flex-head ratchet end. To break loose the bolts, I also needed to use Maxx Leverage 9.5 inch extension wrench with the combi wrench.
 Old 11-18-2019, 04:14 PM   #14
dynamho's Avatar
Top three 14mm bracket bolts: 28-38 ftlb
17mm Upper Shock Bolt/Nut: 64-85 ftlb
17mm Lower Shock Bolt/Nut: 69-93 ftlb
BC coilover fronts part 1 qtrmile beast MazdaSpeed 6 - How-To's 5 03-30-2014 06:58 PM
Jessica Simpson -- Part Indian, Part Mysterious Haltech Celeberty Smut 2 05-26-2011 06:35 AM
Lamborghini Ankonian by Slavche Tanevski is part wasp, part alien, all black Haltech Automotive News 1 12-17-2009 05:26 PM
30% tint rears 35% front pics on my black mica Huligan Appearance - BLACK 4 09-19-2009 05:25 PM
BC coilover 06speed MazdaSpeed 3/6 - Suspension & Brakes 43 07-11-2009 11:18 AM
Page generated in 0.35037 seconds with 30 queries
