> MazdaSpeed 6 - How-To's
 Old 12-10-2011, 04:02 PM   #1
Stealth01's Avatar
Posts: 6,910   (View Stats)
Stealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the worldStealth01 is the leader of the world
Groans: 201
Groaned at 164 Times in 103 Posts
Default Changing the Fog Lamps
I'm going to replace the OEM white fogs with yellows tomorrow, but I can't figure out how to get to them. Do I go in from underneath, or from behind in the wheel well?
Stealth01
2006 Mazdaspeed6 GT
Black Cherry Mica, Two-tone Leather interior, Sunroof, Bose
SURE Full3 Aeros ID300 | SURE Shortcut | SURE Countershift | SURE Anchors | SURE AGS Atom Shift Knob | SURE Torque R6 RMM | SURE Ventus in Hybrid Mode | SURE Dreadnaught | SURE Juggernaught | SURE Flow M6 TP | SURE Charge Tubes | SURE Return | SURE S6 Side Motor Mounts | SURE Breather Line | Hawk HPS F/R Brake Pads | StopTech F/R Rotors | Technafit SS BL | Technafit SS Clutch Line | Primewell PZ900 Tires (blech) | Red LED Dome & Door Lights | O-series Stubby Antenna | Cobb AP | ACT 6 Puck Clutch w/Prolite FW | Autolite XP Plugs (One Step Colder) | Whistler Pro-78SE Hard-wired | STRATIFIED Tuned by Lex | COMING SOON: Autotechs | SURE TIG
Read my stories: https://www.smashwords.com/books/view/55318
Stealth01 is offline   Reply With Quote
 Old 12-10-2011, 04:04 PM   #2
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
underneath, take the undertray off in the front. opening the wheel well will give you some extra room too. taking the bumper off would be the easiest and takes 10 mins
 Old 12-10-2011, 04:14 PM   #3
tddvrrn's Avatar
Posts: 2,571   (View Stats)
Groans: 103
i went in from under. i had to jack it up to see what i was doing, but once it's up it's super simple. there are just 4 or 5 bolts, 8mm i think, holding on the small part of undertray. the bulb housing just twists into place..
 Old 12-10-2011, 06:02 PM   #4
Stealth01's Avatar
Groans: 201
Cool, thanks all. Wait, though...I have an MS6...should be the same, right?
Stealth01
2006 Mazdaspeed6 GT
 Old 12-11-2011, 12:07 PM   #5
Stealth01's Avatar
Groans: 201
I went in from underneath and the only thing I had to do to make it easier was removed one of the two horns and let it dangle out of the way. Pics will follow later, when it's dark out.
Stealth01
2006 Mazdaspeed6 GT
 Old 12-11-2011, 12:18 PM   #6
Toymachinespeed's Avatar
Posts: 244   (View Stats)
Toymachinespeed is the leader of the worldToymachinespeed is the leader of the worldToymachinespeed is the leader of the worldToymachinespeed is the leader of the worldToymachinespeed is the leader of the worldToymachinespeed is the leader of the worldToymachinespeed is the leader of the worldToymachinespeed is the leader of the worldToymachinespeed is the leader of the worldToymachinespeed is the leader of the worldToymachinespeed is the leader of the world
Groaned at 7 Times in 3 Posts
Subbed for pics!
2011 Black Mica Mazdaspeed3 w/ Tech Package
CorkSport SRI/TIP Combo: COBB AP Custom Tune @20psi: Autotech Internals: OBX Racing Cat Back: CNT Catless Long DP: CPe TMIC: Forge V1 BPV:
JBR 80 duro RMM: JBR SSP+Knob+Bushings: H&R Springs: Rota G-Force 18x8.5 +48 Continental Extreme Contact DW 235/40/18:
Toymachinespeed is offline   Reply With Quote
 Old 12-11-2011, 12:20 PM   #7
zenger's Avatar
Posts: 602   (View Stats)
zenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the worldzenger is the leader of the world
Groaned at 8 Times in 7 Posts
Cool would appreciate pics
2007-Mazdaspeed 6
BNRSIII~all supportings
Zoom Zoom Boom part out.
zenger is offline   Reply With Quote
 Old 12-11-2011, 03:39 PM   #8
memin's Avatar
Posts: 990   (View Stats)
where are the pic, Sthealt01?
 Old 12-11-2011, 03:53 PM   #9
Stealth01's Avatar
Groans: 201
LOL when it's dark, I'll take the pics! SO you can actually see the lights, you know?
Stealth01
2006 Mazdaspeed6 GT
 Old 12-11-2011, 04:09 PM   #10
Stealth01's Avatar
Groans: 201
OK, here are a couple of the install pics. This is MS6-specific, since the MS3 has a different setup under there, with a faggy little girl horn.
First off, starting with the passenger side, remove the four screws holding the small portion of the undertray on. That is connected to the wheel well liner, so just bend it back out of the way, rather than removing the whole thing.
This shows the horn that needs removed. Sorry for my finger getting in the way, but it's the more forward of the two horns. Just remove that nut and let the horn dangle. Then you can get your hand up to the back of the fog light. This is on the PASSENGER SIDE. The driver's side had nothing getting in the way -- reached right up to the back of the fog light.
This one shows the back of the passenger side fog light. The fitting simply rotates counter-clockwise and then pops out.
I'll post pics of the yellow fogs in a couple of hours, once it's dark outside.
Stealth01
2006 Mazdaspeed6 GT
The Following User Says Thank You to Stealth01 For This Useful Post:
tddvrrn (12-11-2011)
 Old 12-11-2011, 06:38 PM   #11
Stealth01's Avatar
Groans: 201
Here's the night shot. THey look MUCH better in person, but my droid camera didn't do them justice.
Shit. My driver's side DRL is out.
Stealth01
2006 Mazdaspeed6 GT
 Old 12-11-2011, 06:51 PM   #12
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
Ricer. LOL j/k
NATOR PA
 Old 12-11-2011, 07:20 PM   #13
Stealth01's Avatar
Groans: 201
Yeah, yeah. I did it in hopes that they will actually serve as FOG LIGHTS when it's foggy. THe white is the worst or second-worst color for cutting through water vapor, while the yellow is the best, so we'll see if it's better.
Stealth01
2006 Mazdaspeed6 GT
 Old 12-11-2011, 07:24 PM   #14
Groans: 224
Excuses....
NATOR PA
 Old 12-11-2011, 07:27 PM   #15
memin's Avatar
man get a real camera!!! i got do the same to my 6 and I dont know if going your route or 6000 hid...... decisions
 Old 12-11-2011, 08:36 PM   #16
Stealth01's Avatar
Groans: 201
OK, I'll do one with the real camera as soon as I can. Probably tomorrow.
Stealth01
2006 Mazdaspeed6 GT
 Old 12-11-2011, 09:13 PM   #17
Don06speed6's Avatar
Posts: 2,492   (View Stats)
Don06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the world
Groans: 62
Ricer. LOL j/k
This coming from the guy with a purple emblem on his smashed ass.....
Cobb AP(FREEK TUNED)/CS TBE/SURE AEROS/CPE TIH/ ITV 22/SU RMM/KMD INTERNALS/SURE DREADNAUGHT/JUGGERNAUGHT/WHITELINE RSB/SURE ANCHORS/SURE COUNTERWEIGHT/SURE SHORTCUT/JBR HEAVY KNOB/JBR EGR DELETE/SPC BALL JOINTS/CENTRIC BLANKS/HPS PADS/BNOON BOLT/ALTERED CUSTOMS FMIC/TURBO XS RFL
Don06speed6 is offline   Reply With Quote
 Old 12-11-2011, 09:27 PM   #18
tddvrrn's Avatar
Groans: 103
I had the same dilemma. I ended up going hid 3500k, and they're awesome. Useful, amber yellow. I felt like the 6000k was too much, for me and for my fellow motorists.
There are a few threads where people have posted pics of yellow hids, me included... Search it up, I'm too lazy to find the link. It helped me make my mind up.
The Following User Says Thank You to tddvrrn For This Useful Post:
MSP611 (12-18-2011)
 Old 12-12-2011, 03:58 PM   #19
Stealth01's Avatar
Groans: 201
Yeah, this wasn't an appearance mod for me. It was functional -- to see better in bad weather.
Stealth01
2006 Mazdaspeed6 GT
The Following 2 Users Say Thank You to Stealth01 For This Useful Post:
MSP611 (12-18-2011), tddvrrn (12-12-2011)
 Old 12-18-2011, 02:41 PM   #20
MSP611's Avatar
Posts: 2,291   (View Stats)
full of win.... i like... i think i will do TRS lenses and projectors with a 4-5000k bulb i dunno for fogs? did u change the lenses or housings or just the bulb? Is it actually emitting more light in the fog or any evidence or feedback on tht part.
In progress:
 Old 12-18-2011, 02:47 PM   #21
greenespeed's Avatar
Posts: 1,320   (View Stats)
greenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the worldgreenespeed is the leader of the world
Groaned at 6 Times in 3 Posts
^^^ Would like to know also. Part #'s and where from.
2006 Mazdaspeed6 BCM GT
MODS : Cobb AP // Cobb SF // Sure TIP // JBR RMM // JBR SSB // JBR SSP // Magnaflow CBE // MSR 045 18 X 8 +35 // ACT ZX5-HDG6 // M2 3" catless DP // AT HPFP Internals // NGK's -- FREEKTUNE in progress
Having a 12 second Honda is just like coming out of the closet; You're going to surprise a bunch of people, but in the end you're still gay.
greenespeed is offline   Reply With Quote
 Old 12-18-2011, 03:16 PM   #22
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
Daniel Stern Lighting Consultancy and Supply
It's a great read and cleared up that misconception for me, too.
Yellow looks better because our eyes hate blue.
 Old 12-18-2011, 04:46 PM   #23
Stealth01's Avatar
Groans: 201
It is actually a little dimmer, but because it reflects less and our eyes see it better, it's better for bad weather.
I changed only the bulbs and did so using Kokya Arctic Yellow bulbs ordered off Amazon.com.
Either way, it is better in the fog. LOL.
Stealth01
2006 Mazdaspeed6 GT
 Old 12-18-2011, 05:35 PM   #24
Mizzle's Avatar
Groans: 324
It's better all-around to have 3500k lights (though I think 4000-4500k looks better aesthetically.)
Better for oncoming traffic, better for reduced glare, less-apparent fog, much better in the snow (you don't get that WTF BRIGHT SNOW! thing going on,) and so-on.
If/when I get my HID's setup the way I want, I can't see me going over 4,300k for normal lows.
 Old 12-19-2011, 12:40 AM   #25
MSP611's Avatar
Ya ill prob go with a close to stock color for lows most likely a 4500k, but I'm doin the TRS lenses and projectors at the same time if I'm going to do it. I dunno if I like the look of mismatching lights, like 3000k fogs and 4500k lows. Looks funky too me
Sent from my GT-I9100 using Tapatalk
In progress:
 Old 12-19-2011, 10:46 PM   #26
Mizzle's Avatar
Groans: 324
I like:
 Old 12-22-2011, 08:32 AM   #27
MSP611's Avatar
naw ill stay with one color^^^
In progress:
 Old 12-22-2011, 05:43 PM   #28
Mizzle's Avatar
Groans: 324
For visibility's sake, you'd be better off with 3500-4000k.
Less blue light = reduced perception of glare.
Where's Nissan design headed? Look at the lamps Haltech Automotive News 0 04-25-2010 10:00 PM
tail lamps question ms3_518 Appearance - BLACK 4 11-22-2009 04:28 PM
Ford recalling nearly 9,000 F-150 pickups over faulty brake lamps Haltech Automotive News 0 05-12-2009 07:30 AM
Lamps Plus Coupon Codes - Up to $20 Off Haltech Hot Deals Section 0 04-09-2008 05:20 PM
Page generated in 0.64814 seconds with 30 queries
