> MazdaSpeed 6 - How-To's
  • 1 Post By Easter Bunny
 Old 05-03-2014, 08:58 AM   #1
RUS Mazda's Avatar
Posts: 17   (View Stats)
RUS Mazda is an unknown quantity at this point
Default DIY EGR Delete
NOTE: Pictures will be up later, so far I just have the directions.
I didn't want to pay anything over $10 for a piece of aluminum and a bolt so I've decided to make my own EGR delete kit. Here is a quick guide on how to do it.
Step 1: Disconnect and remove the battery.
Step 2: Remove the TIP
Step 3: Locate and remove the brass pipe that exits the EGR valve. I believe they were 8mm bolts.
Step 4: Remove the gasket that is clipped to the brass pipe and trace it on a piece of metal. My choice of material was a wall outlet backing that I bought for $1.39 at Home Depot.
Step 5: Drill the two holes first and then cut out your gasket copy. I used metal shears but you can also use a grinder.
Step 6: Remover the IC piping going into the throttle body and remover your throttle body. I didn't unhook the electrical connection or the coolant lines, just moved the TB out of the way.
Step 7: Locate and remove the plug holding the other end of the brass pipe. I used an open ended wrench for 7/8, but I would recommend using a crow's foot wrench if you have it.
Step 8: Plug up the hole in the intake manifold. I don't remember the size of this plug off the top of my head because I had it laying around from my previous car's EGR block off.
I'll try to swing by O'reilly and get the size.
Step 9: Attach the gasket onto the block off plate that you cut earlier and put it over the original opening. My plate wasn't the exact size and shape of the original, but as long as its big enough to cover that hole I don't think it will be a problem.
Step 10: Re-install your TB, piping, TIP and battery.
After the block off my boost air temps dropped about 10-15 degrees Fahrenheit during my commute in the middle of the day in Houston.
2007 MazdaSpeed6 GT #9822
Current mods: AP V3//AT Internals//Mazdaspeed CAI//QTP electric cutout in place of 2nd cat//EGR Delete
Waiting to be installed: eBay DP//CX7 PTO
Visual: Redline goods leather shift and e-brake boots//Tenzo R 18X8.5
RUS Mazda is offline   Reply With Quote
 Old 05-03-2014, 11:00 AM   #2
Ferdball's Avatar
Posts: 1,340   (View Stats)
Ferdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the worldFerdball is the leader of the world
Or just clamp the tube.
Ferdball is offline   Reply With Quote
 Old 05-03-2014, 11:34 AM   #3
RUS Mazda's Avatar
Can you get a good seal that way? I think that under pressure some fumes would still leak into the manifold.
 Old 05-03-2014, 12:00 PM   #4
Ferdball's Avatar
You can clamp it twice. Or if you're that concerned, you can unplug it. If you have a Cobb AP, you can defeat the code.
 Old 05-03-2014, 12:16 PM   #5
RUS Mazda's Avatar
I guess that's another way...just seems almost as much work as doing it my way. And yeah I'm aware of the AP CEL solution, thanks.
 Old 05-03-2014, 12:22 PM   #6
Raider is mah Homie
Easter Bunny's Avatar
Posts: 6,460   (View Stats)
Groans: 2,978
Unplugging it is the way to go
Justin@Freektune likes this.
I hugged rfinkle2
The Following 6 Users Say Thank You to Easter Bunny For This Useful Post:
Ferdball (05-04-2014), Gr8Speed (05-10-2014), Justin@Freektune (05-03-2014), smoogs12 (05-03-2014), Snip (05-10-2014), speed_freak91 (05-03-2014)
 Old 05-03-2014, 12:34 PM   #7
RUS Mazda's Avatar
If its unplugged would it just stay closed all the time?
 Old 05-03-2014, 12:39 PM   #8
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Agent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the worldAgent_Orange is the leader of the world
Groans: 665
Groaned at 76 Times in 40 Posts
How is unplugging a wiring harness just as much work as the 10 step ordeal you outlined?
Agent_Orange is offline   Reply With Quote
 Old 05-03-2014, 12:41 PM   #9
Raider is mah Homie
Groans: 2,978
Yes.
I hugged rfinkle2
 Old 05-03-2014, 12:48 PM   #10
RUS Mazda's Avatar
I wasn't talking about unplugging it being as much work hahaha. I was referring to the clamping because you still have to remove all the shit to get to the tube.
Yes.
I was not aware of that, thank you.
Last edited by RUS Mazda; 05-03-2014 at 12:48 PM. Reason: MSF Database - Automerged Doublepost
 Old 05-03-2014, 03:20 PM   #11
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
Or just spend $10-$20 on the delete kit from JBR.
Of corse, DIY can always make for a fun project.
 Old 05-04-2014, 08:44 AM   #12
ms6mil's Avatar
Posts: 4,972   (View Stats)
ms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the worldms6mil is the leader of the world
Groans: 307
Groaned at 6 Times in 6 Posts
Nice!
So I don't really have any pictures, nor do I have any sizes or measurements, but this is a how to...
oh and yes its more work.
Patiently waiting for the pics..
"Here am I. Send me!"
____________________________________________
Columbus, GA 2006 MazdaSpeed 6
EBTEC Motor ¤ PTE 5862 ¤ Custom 3" Exhaust ¤ Bosch 3.5 Bar ¤ Custom 4" Intake ¤ CS Seals ¤ JBR EBCS ¤ Kozmic DP ¤ TurboSmart BOV ¤ Treadstone TR10 FMIC ¤ NGK's ¤ AT Internals ¤ 6th Port ¤ DO Meth ¤ CPE Exh Manifold ¤ Tial 44mm EWG ¤ JMF Manifold ¤ COBB AP ¤ 18x8 Tenzo Cuzco's ¤ H&R Coilovers ¤ Dual OCC ¤ Guardian Angel
GT3076 - 393/380 3/9 e85
GT3076 - 426/400 E85/DO10 Meth
PTE5862 - TBD
ms6mil is offline   Reply With Quote
 Old 05-10-2014, 10:21 AM   #13
Snip's Avatar
Posts: 329   (View Stats)
Snip is the leader of the worldSnip is the leader of the worldSnip is the leader of the worldSnip is the leader of the worldSnip is the leader of the worldSnip is the leader of the worldSnip is the leader of the worldSnip is the leader of the worldSnip is the leader of the worldSnip is the leader of the worldSnip is the leader of the world
Sorry for bumping this, but simply unplugging the EGR will make it stay closed all the time without any downsides to it?
except for the DTC codes which i will have to permanently delete.
if so, why is everyone mounting all these egr delete kits when unplugging is the cheapest, simplest, and just as reliable? Just for the fact that you don't have a connector hanging loose?
MazdaSpeed3 GT '07
CP-e Xcel Nano 3" Air Intake - CP-e Nviscid 3" TIP - CP-e HPFP - CP-e DeltaCore FMIC - CP-e Stage 1 RMM - ACT clutch kit - ATP Race Pipe -
SU DualPort Turbosmart BPV - COBB anti swaybars - COBB Sport Springs - Goodridge Brakelines - Whiteline Swaybar endlinks - JBR SSP - Damond Motorsport OCC
AccessPort V2 Self tuned
Snip is offline   Reply With Quote
 Old 05-10-2014, 10:31 AM   #14
Groans: 665
The default position for the valve is closed. So as long as the mating surfaces are clean, it will stay shut.
Most people choose to do a full delete because it's fairly simple, and frees up some engine bay space.
For those that are worried about warranties, re-sale, and inspections, unplugging is the best bet.
The Following 2 Users Say Thank You to Agent_Orange For This Useful Post:
Easter Bunny (05-10-2014), Snip (05-10-2014)
 Old 05-10-2014, 11:48 AM   #15
Snip's Avatar
Thanks mister agent
I am reflashing my speed tomorrow with an updated map, so might as well put in the P0401 and P0403 codes to be ignored and then disconnect the EGR.
I've read this topic, where a lot of good information comes by, as well as the discussion about doing this simple egr mod or the block off kit:
New egr delete kit
MazdaSpeed3 GT '07
 Old 05-10-2014, 01:19 PM   #16
jdmage_mx5's Avatar
I know doing the primary and secondary delete made the BT install much easier along with being able to remove the intake manifold for valve cleaning was a lot easier.
The Following 2 Users Say Thank You to jdmage_mx5 For This Useful Post:
Agent_Orange (05-10-2014), Snip (05-11-2014)
 Old 05-11-2014, 11:16 PM   #17
Snip's Avatar
yeah, i'm not discussing the fact you get a lot of free space under the hood, just about the technical fact if this could be done safely.
But reading some topics on MSF (like the one I quoted in my previous post) learned me that if you only look at the technical part, unplugging and erasing the DTC's is just as safe as doing a block off kit.
So yesterday I reflashed the speed and also unchecked the P0401 and P0403 and unplugged the EGR.
MazdaSpeed3 GT '07
 Old 05-21-2014, 07:39 PM   #18
aviator79's Avatar
Posts: 3,934   (View Stats)
Groans: 67
So your P0403 was checked? IDK maps I look at it is not and some difference between one map and another like P0101 checked in one and not another...but all already have p0403 unchecked
Maybe just unchecked on MS6 maps and not used but seems it is on MS3:
Well...i learned the hard way
 Old 05-26-2014, 12:05 PM   #19
Snip's Avatar
Yes, my P0401 and P0403 were checked.
The base map i used for self tuning my car, was the COBB stage1+SF+TIH+IC 93 octane v2.31 map for the 2007 MS3.
Been driving for ~300miles now and car still runs great, of course
Takes a little bit longer to get the coolant on temperature, but i knew that would be happening from previous EGR deleting mods on my VW's
Overall idle sounds a bit more smoother and so does driving in part throttle at low speeds (city driving).
MazdaSpeed3 GT '07
 Old 07-31-2018, 10:32 PM   #20
achulz's Avatar
Posts: 94   (View Stats)
achulz has a spectacular aura aboutachulz has a spectacular aura aboutachulz has a spectacular aura about
Did you ever find the thread size for the intake manifold?
I am going to do the tube delete and just unplug the EGR so I don't have to mess with the coolant line for the turbo. That and bypass the throttle body coolant line.
achulz is offline   Reply With Quote
The Following User Says NO Thank You to achulz For This Un-useful Post:
Thor Hammer (08-01-2018)
New egr delete kit speed3gen1 MazdaSpeed 3 - Engine, Transmission & Driveline 341 05-14-2016 06:59 PM
EGR Delete 11cruzito11 MazdaSpeed 3 - Engine, Transmission & Driveline 6 08-15-2009 12:31 PM
EGR delete/VCTS delete codes Speedie6 Mazdaspeed3/6 General Discussion 7 07-24-2009 10:22 AM
Cat delete vs resonator delete taf0422 MazdaSpeed 3 - Engine, Transmission & Driveline 7 04-08-2009 05:57 PM
Page generated in 0.39605 seconds with 29 queries
