![]() | | #1 | ![]() |
| The Interior Guy ![]() ![]() Join Date: Dec 2009 Location: Midlothian, VA
Rep Power: 8 ![]() Thanks: 6
| Not Ranked : 0 score
06 MS6 Trying to figure out (without having to pull apart my dash to get at the back of the factory radio) if there are any plugs on the back of the deck in which to plug in my iPod. I am using an FM transmitter now, but we all know the downfalls of that. I know there is the SAT button on the radio, so I figured there might be a plug in the back in which to plug in a satellite radio. If there is a plug, is it RCA's? Would love some feedback, or other suggestions on a solid way (and a cheap way!) to listen to my iPod. | ||||||||
![]() Join Date: Apr 2008 Location: DFW
Rep Power: 40 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17
Check this out, pretty good write up. How To: 3.5mm stereo to Bose System - Mazda6 / Atenza
__________________ '06 Mazdaspeed6 GT - Titanium Gray - CP-e XCel Intake - CP-e FMIC - COBB Turbo Inlet - COBB AccessPORT - PGv3 Tubular Manifold - ATP Downpipe - Custom 3" Dual Magnaflow CBE - HKS BOV in recirc - mrlilguyCDFP (KMDv1) - Denso ITV-22 Plugs - F2 BSD & Baffle - CP-e Upper Rear Diff Mount - TurbineTech Forward Rear Diff Mount - TurbineTech Front Motor Mount - AWR Rear Motor Mount - Tanabe Strut Tower Brace - RPM Sport Springs .75/1.1 - TWM Stage 2 SS w/bushings - COBB Shift Weight - Défi-Link BF Boost Gauge - Innovate LC-1 Wideband - Hardwired Passport 8500 X50 - AuxMod Basic for CarPC - 276hp/334tq Mustang Dyno | ||||||||
Rep Power: 0 ![]() ![]() ![]() Thanks: 12
Should add that there are several plug and play options available as well if you don't want to go the DIY route. Google aux-mod, Grom Audio, Xlink/audiolink for Mazda 6 and you will see several different options for aux-in to the Bose HU. Prices seem to be about $60-120 for these options.
| The Following User Says Thank You to BigjohnB20 For This Useful Post: | chadeckler (12-21-2009) |
![]() | | #4 | ![]() |
![]() ![]() Join Date: Jan 2009
Rep Power: 21 ![]() ![]() ![]() Thanks: 39
just replaced X car link with a NEO ipod adapter. The X car link kept switching off of Shuffle to alphabetical non shuffle with repeat. Did this with two different units. Was starting to get sick of nothing but Allman Bros!
![]() | | #5 | ![]() |
![]() Join Date: Dec 2009 Location: Virginia Beach
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 0
Awesome...gonna check these out.
__________________ 2006 Black Cherry Mica Speed6 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. MODS: CP-E Front Mount||Cobb Ram Air||Cobb Turbo Inlet Pipe||Magnaflow CBE||Forge BPV||Apexi Turbo Timer||Prosport Boost Gauge|| | ||||||||
![]() | | #6 | ![]() |
Allman Brothers, classic! Brandoid, in your display pic, i see your steering column mounted gauge. The red matches the gauges perfectly, what brand and type of gauge is it? Last edited by chadeckler; 12-31-2009 at 01:50 PM. | ||||||||
![]() | | #7 | ![]() |
![]() Join Date: Mar 2008 Location: Terryville, CT
Rep Power: 0 ![]() ![]() ![]() Thanks: 2
Yeah the write up I did is fairly easy to do and it's less than $20 (it's the link up top)
![]() | | #8 | ![]() |
__________________ 2006 Black Cherry Mica Speed6 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. MODS: CP-E Front Mount||Cobb Ram Air||Cobb Turbo Inlet Pipe||Magnaflow CBE||Forge BPV||Apexi Turbo Timer||Prosport Boost Gauge|| | |||||||||
![]() | | #9 | ![]() |
![]() Join Date: Oct 2008 Location: Atlanta, GA
Rep Power: 0 ![]() ![]() ![]() Thanks: 0
Axxess integration kit works great for me and was pretty easy to install
__________________ Forge BPV, Cobb SRI, PG Turbo Inlet, AWR rear MM, TWM SS stage II, Race Import Design Catless Downpipe, Magnaflow Catback, Cobb AP Stage 2+ 93 Denso ITV22, RPM street springs, Rear Seat Fold down mod | ||||||||
![]() | | #10 | ![]() |
![]() | | #11 | ![]() |
![]() | Not Ranked : 0 score
i got the grom adaptor but its for the 3 i dont know if the HU of the 3 and 6 and the same in the back? if they are ill sell u mine.
![]() | | #12 | ![]() |
![]() Join Date: Nov 2009 Location: Flushing, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 9
hey chadeckler, i bought a grom aux audio kit for my ms6 and didnt have to take the stereo out at all. someone mentioned you can manuver your way behind the console and plug it in. heres the ipod kit. IPOD just grab a flashlight, crawl down into the drivers side foot well, and look up towards the bottom right of the stereo. its the big rectangular CD port where you plug it into. there was like a foam tube in my way so i just pulled that off for a min and was able to squeeze my hand in there. i wont lie, its a pretty small space to get your hand in there (thats what she said), but its doable. you just have to be patient. then i just mounted the box with double sided tape under the steering column cause i dont like to drill holes inside if not necessary
__________________ 2007 MS6 GT Black Mica - Forge BPV - SU TP - DH | ||||||||
| The Following User Says Thank You to sno328 For This Useful Post: | chadeckler (02-28-2010) |
![]() | | #13 | ![]() |
![]() Join Date: Apr 2008 Location: Sunny San Diego
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 22
I got the neo Ipod connector myself, super easy to install, i think it took me 20 minutes? Probably less.
__________________ 06 MS6 Black Mica 15% tint rear, 30% tint front, HKS ssqv, SU test pipe, K&N drop in (Going to be replaced with COBB SRI), Autoexe lower springs, TWM Stage 2 Short Shifter I FREAKIN LOVE COBB!!!! | ||||||||
![]() | | #14 | ![]() |
![]() Join Date: Mar 2010 Location: Atlanta GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 37
I did mine today as well. Followed the write up from the link at the top and it works flawlessly. hooked up to the media button on my Speed 6 and ran the chord up through the center glove box
__________________ White 06 Speed6 GT CP-E TBE, Mazdaspeed CAI, HKS BOV, H&R Street Performance Coilovers, Whiteline Rear Adj. SB, Cobb AP, Spin On Oil Filter Conversion 15 inch MTX Thunder 9500 Sub, 1000 Wat Kenwood amp, Custom Ipod Jack, Passport 8500, BFG KDWs 20% Tint, Black Symbols w/ Evil M, Prosport Gauge Pack / Pod, HKS TT New Expense 3 Tickets For Tint Tags and Liscense Plate Cover | ||||||||
![]() | | #15 | ![]() |
![]() Join Date: Sep 2009 Location: Syracuse, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25
Hey All, I just completed my Grom Audio iPod Integration Kit Install for my 06 MS6. The adapter itself cost around $100 when all was said and done. I followed a tutorial for how to remove the HU, and after a little work it turned out pretty easy. The only trouble I had was with the glovebox. I felt like I was going to break the bottom pieces that held it together, but it simply needed some force. The kit allows for both the iPod connector as well as the AUX connector. I ran both of these wires up through the console, but needed to use a knife to cut out part of the vent on the bottom of the console in order to thread the wires nicely. I then left the AUX cord in the main console, and ran the ipod connector to the top part of the console. I am loving the location of the ipod because it is easy to access and use the controls if necessary. Also, I went with the GROM because it had all the same features as the other integration kits, just at half the price. I would recommend this kit to anyone because its a pretty simple install for most people with any knowledge of common tools and DIY mentality. If anyone has any questions feel free to pm me. - Cameron | ||||||||
![]() | | #16 | ![]() |
![]() Join Date: Jun 2010 Location: CT
Rep Power: 0 ![]() Thanks: 31
this question is for everyone w any hook up. How is the sound quality? I am assuming the grom is good but what ab the first link for the diu. Does it sound like its comming out of garbage headphones or is it normal? If so any way to make it better?
![]() | | #17 | ![]() |
![]() ![]() Join Date: Jun 2010
Rep Power: 5 ![]() ![]() ![]() ![]() Thanks: 50
sound is just as good as it would be with a grom. the quality will depend on how good you aux cables are. I get clean stereo sound from my DIY.
![]() | | #18 | ![]() |
sounds good - i am going to give it a shot, thanks
| Thread Tools | |
| Apple Outlet Refurb iPod Deals ( iPod Nano 4GB $99 w/FREE iTunes Gift Cert, iPod Shuffle 1GB $39) at Apple Store | Haltech | Hot Deals Section | 0 | 04-15-2008 01:30 PM |
| Apple Outlet Refurb iPod Deals ( iPod Nano 4GB $99 w/FREE iTunes Gift Cert, iPod Shuffle 1GB $39) at Apple Store | Haltech | Hot Deals Section | 0 | 04-11-2008 09:20 AM |
| Apple Outlet Refurb iPod Deals ( iPod Nano 4GB $99 w/FREE iTunes Gift Cert, iPod Shuffle 1GB $39) | Haltech | Hot Deals Section | 0 | 04-04-2008 05:50 AM |
| Apple Outlet Refurb iPod Deals ( iPod Nano 4GB $99, iPod Shuffle 1GB $39) | Haltech | Hot Deals Section | 0 | 03-26-2008 11:40 AM |
