> MazdaSpeed 6 - How-To's
Like Tree4Likes
 Old 09-23-2012, 04:32 PM   #1
mczimer's Avatar
Posts: 1,249   (View Stats)
mczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the world
Default Headlight Restoration: How to
So, as some of you may recall I tinted and wetsanded my LED tail lights a while back. Basically, the process is identical for retouching headlights as well.
*Note: you can buy a Sylvania headlight restoration kit which contains all of the following except masking tape and ScratchX, and it comes with a Lifetime warranty if you screw it up too
To do do this yourself you will need the following from your local AutoParts store:
  • Wet-sanding Sandpaper: 400 grit, 1000grit, 2000grit (does not have to be exact, but you need to go low to high, with 2000+ needed for finishing)
  • Polishing compound: ScratchX 2.0 or other polishing compound (I highly recommend ScratchX over anything... has given amazing results every time)
  • UV Seal/Clear Coat- this stops oxidation from returning and protects lights from scratching
  • Tape (electrical and masking tape)
  • Lint free towel
  • A roll of quality paper towels which will not leave debris
  • Spray bottle of soapy water
Step 1:
Soak sand paper in water. Open hood and clean headlights and surround area with water/soap, then rub off with rubbing alcohol
Step 2:
Mask off around the lights using electrical tape (this will stay in place from the water later). Make sure to get slightly under the lip of the lights as well-slightly press down on the bumper to get some space.
Step 3:
Spray the lights with soapy water and then sand the lights using 400 grit with slight pressure going in circular motions. As you do this you will see yellow and white oxidation start running off, make sure to keep spraying lots of water as you go. Do this for ~5min, or until you feel a uniform & smooth surface across the light. Now spray the lights down with water and dry them off with paper towels to inspect the sanding for a uniform hazy look (you will see if you did not do it evenly, or if you need to do more).
Pic after starting 400 grit:
Pic after done with 400 grit:
Pic after done with 1000 grit:
Pic after done 2000 grit:
Step 4:
Repeat step 3 with 1000 and 2000 grit. At the end of each grit process you should see uniform white/cloudy appearance.
Step 5:
Apply ScratchX compound to your buffer or your paper towel and rub the hell out of the lights. The more you do this, and the more you work it in, the clearer your end result will be. Do this ~3 tmes per light, about 5min for each round of polishing.
Pic after polishing with Scratch X:
Step 6:
Your lights will look great now, but you want to keep it that way. Remove all the electrical tape and spray the lights down afterwards to remove any debris, then dry with paper towels.
Now apply masking tape where the electrical tape was, this will protect and allow you to apply the clear coat/UV without worrying about touching any paint.
Take rubbing alcohol and rub the lights down to prepare them for sealing with a paper towel.
Step 7:
Fold a piece of the lint free towel into a 2 inch square.Take the Clear Coat/UV sealer and liberally apply it to the lint free towel's folded edge, soaking it pretty well.
Now for the fun part; swipe the light with the soaked edge, starting from the top of the car's light and in a continuous/steady motion go towards the wheel. You want to go top-down, taking about 4 swipes to get the whole light, slightly overlapping each prior swipe. Now, look at the light for any running (should not be any) and walk away, DO NOT apply more.. you will mess up your new lights. The lights may look strange, but give it a minute and watch as it goes clear as glass.
Step 8:
Let the UV cure in shade for 4-6 hours, undisturbed. Remove the tape & wash the car the following day...DONE
Pic after applying clear/uv sealant:
mczimer is offline   Reply With Quote
The Following 39 Users Say Thank You to mczimer For This Useful Post:
3Gee Tee (10-13-2012), acts (09-23-2012), aggierandy (01-17-2013), alphasaur (03-06-2014), amggilly305 (12-07-2012), Badger_ (07-23-2013), BruhhWill (09-23-2013), charlesfist (09-24-2012), Code Monkey (09-25-2012), CWP_MS3 (09-25-2012), dale_gribble (09-23-2012), Docnox (10-15-2012), Don06speed6 (09-23-2012), dot584 (09-22-2013), doubleflusher (09-25-2012), EwMPS (10-22-2015), flappypaddles (11-21-2013), IanMacKenzie (09-22-2013), InfamousSpeed6 (02-15-2013), J'sSpeed3 (09-23-2012), JacksonMS30 (09-24-2012), jracer (09-26-2012), Kellerspeed3 (10-18-2012), KusteLokal (01-17-2013), Masterofnone (10-14-2012), MATT DAMOND (09-23-2012), Mazdalover01 (09-23-2012), Micha (11-27-2013), Ms3_Miami (09-23-2012), NCZ13 (09-23-2012), Pseud0logik (12-13-2012), SofaKingAwesome (09-25-2012), SpeedThrizzle (09-22-2013), Speed_j23 (12-09-2012), tddvrrn (10-18-2012), TRSpeed (10-18-2012), turbo test (07-28-2013), Uberfly (09-24-2012), uncorked11 (09-24-2012)
 Old 09-23-2012, 05:35 PM   #2
JAGspeed6's Avatar
Posts: 138   (View Stats)
JAGspeed6 has much to be proud ofJAGspeed6 has much to be proud ofJAGspeed6 has much to be proud ofJAGspeed6 has much to be proud ofJAGspeed6 has much to be proud ofJAGspeed6 has much to be proud ofJAGspeed6 has much to be proud ofJAGspeed6 has much to be proud ofJAGspeed6 has much to be proud ofJAGspeed6 has much to be proud of
Groaned at 20 Times in 6 Posts
Thank you mczimer. I need to do this badly.
Cobb SRI, Cobb TIP, Forge V2, JBR RMM, AWR PMM, Cobb AP, CP-E downpipe, CP-E dual cat-back exhaust, CP-E TMIC, JBR EGR delete kit, JBR T.I.G., Sure shortcut and counterweight, Autotech internals, ACT 6-Puck clutch, Megan Racing springs, Enkei Imola rims 18x7.5, 235/40/18 Continental DWS Extreme Contact
JAGspeed6 is offline   Reply With Quote
 Old 09-23-2012, 11:17 PM   #3
NCZ13's Avatar
Posts: 1,268   (View Stats)
Groaned at 44 Times in 32 Posts
Nice write up. the outer layers of plastic are starting to peel and get hazy, so theyve been due for a wetsanding. will probably be my next project.
2008 Cosmic Blue Mazdaspeed3
1986 Mazda RX7
 Old 09-24-2012, 08:13 AM   #4
mczimer's Avatar
Here are some pics in daylight, still not cleaned up, but you get the point. Once I get some Windex on these the bitches be comin'...
dot584 likes this.
The Following 5 Users Say Thank You to mczimer For This Useful Post:
Docnox (10-15-2012), J'sSpeed3 (09-25-2012), jracer (09-26-2012), Micha (11-27-2013), Nom (05-16-2015)
 Old 09-24-2012, 09:24 AM   #5
Uberfly's Avatar
Posts: 773   (View Stats)
Uberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the world
@mczimer
what do you recommend for a UV Seal/Clear Coat? i've never been able to find a decent supply of it that didn't cost me a boat load.
2008 MS3 GT - Guardian Angel, Cobb Acessport, hacked up mazda CAI converted to SRI, Turbosmart BPV
Uberfly is offline   Reply With Quote
 Old 09-24-2012, 10:17 AM   #6
mczimer's Avatar
Originally Posted by Uberfly View Post
@mczimer
I used what came in the Sylvania kit, but any clear coat should work fine. I do not recommend using a spray though, unless you want to do more wetsanding to remove orange-peel.
 Old 09-24-2012, 01:31 PM   #7
J'sSpeed3's Avatar
Posts: 722   (View Stats)
J'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the worldJ'sSpeed3 is the leader of the world
Groans: 76
OK so here's some pics of what have been happening to my headlights lately. They feel almost like tinny little scratches. I tried to get some good pics of the headlights, will this Sylvania kit help with this??
| 2007 True Red Mazdaspeed 3 GT |
GO: | SURE SRI V2 | COBB TIP | CP-E FMIC | Corksport DP | Corksport CBE | Cobb AP RICHTUNED | Autotech Internals | SURE RMM | Denso ITV-22's | Turbosmart BPV |
SHOW: | Evo X Enkei's 18x8.5 +38 Painted CWP| Nitto Motivo's 225/40 | BC Racing Coilovers | SPC Camber Arms | DDM 3000k fogs | CPE Tow Plate |
J'sSpeed3 is offline   Reply With Quote
 Old 09-24-2012, 01:50 PM   #8
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
Damn, using a Brillo pad to wash and dry the car?
J'sSpeed3 (09-24-2012)
 Old 09-24-2012, 01:56 PM   #9
mczimer's Avatar
Well, it will not get any worse, it can only get better. What you have is micro cracks in the plastic. This is usually just on the surface, so if you do a good job of sanding you should hopefully get rid of it. Give it a go...
The Following User Says Thank You to mczimer For This Useful Post:
 Old 09-24-2012, 02:10 PM   #10
J'sSpeed3's Avatar
Groans: 76
lol i use a water blade and a shammy, it's weird it came out of no where really, I didn't even notice it until @slikr mentioned it, not it drives me insane
thank you! how much was the kit? did you just get it at autozone?
Last edited by J'sSpeed3; 09-24-2012 at 02:10 PM. Reason: MSF Database - Automerged Doublepost
 Old 09-24-2012, 02:13 PM   #11
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
Micro fiber to dry bro... Water blades are dangerous if one spec of dirt gets embedded into the silicone.
 Old 09-24-2012, 02:15 PM   #12
mczimer's Avatar
Kit is under 20 bucks, from any AutoParts store, wallyworld, sears, ect..
 Old 09-24-2012, 02:17 PM   #13
J'sSpeed3's Avatar
Groans: 76
So shammy then microfiber or no shammy at all?
 Old 09-24-2012, 02:19 PM   #14
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
No spammy period..
 Old 09-25-2012, 12:16 PM   #15
J'sSpeed3's Avatar
Groans: 76
OK so i just finished the whole process with this kit and it looks amazing! I highly recommend this kit even if your headlights aren't too bad. You can see my before pics above with the micro scratches and here's some of the pics now during the curing phase
Last edited by J'sSpeed3; 09-25-2012 at 12:25 PM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to J'sSpeed3 For This Useful Post:
Dash08 (09-25-2012), jracer (09-26-2012)
 Old 09-25-2012, 12:17 PM   #16
mczimer's Avatar
Glad this helped you
The Following 2 Users Say Thank You to mczimer For This Useful Post:
J'sSpeed3 (09-25-2012), jracer (12-08-2012)
 Old 09-25-2012, 12:21 PM   #17
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
I'm probably going to have to do this, my fucking 2011 already looks like this. Too lazy to try and go after new ones under warranty, though I did hear rumors on other sites that there was a TSB for them.
 Old 09-25-2012, 12:26 PM   #18
J'sSpeed3's Avatar
Groans: 76
Just do it this weekend, the process takes an hour MAX if you take your time, you just gotta have another means of transportation for 6 hours after lol
 Old 09-25-2012, 12:31 PM   #19
I <3 your mom
Dash08's Avatar
Posts: 7,166   (View Stats)
Groans: 293
Excellent thread and how to.
I'll be doing this immediately. My headlight housings are proper fucked.
Reijin likes this.
this forum serves 2 purposes
 Old 09-25-2012, 12:43 PM   #20
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
mine are messed up but I think it's mostly from my 55w hids. I heard they could melt the housing and i think they are. I could get a pic up later if anyone is interested.
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
 Old 09-26-2012, 08:26 AM   #21
mczimer's Avatar
always a good feeling to make people happy...
jracer (09-26-2012)
 Old 10-14-2012, 01:55 AM   #22
TrePaul86's Avatar
Posts: 197   (View Stats)
TrePaul86 has much to be proud ofTrePaul86 has much to be proud ofTrePaul86 has much to be proud ofTrePaul86 has much to be proud ofTrePaul86 has much to be proud ofTrePaul86 has much to be proud ofTrePaul86 has much to be proud ofTrePaul86 has much to be proud ofTrePaul86 has much to be proud ofTrePaul86 has much to be proud of
If you could post up the damage that would be good info.... As I've recently thought about converting from 35w factory to some 55w'ers as well as upgrade the projector itself.
06 MS6 Sport 290whp/295wtq sold 11/2013
Little brothers 06 MS6 GT BCM : H&R CO's, CS - Front Sway bar, Front and rear strut bars, power series 3" TBE exhaust with catted DP, Power series FMIC kit (TIP, Intake), Full LED interior and exterior with LED fogs JBR - SSP and weight with shift bushings, cylindrical shift knob SURE - RMM, Rear Diff mountCarLED tails AutoTech HPFP internalsTuned by StratifiedHKS SSQV4 VTA
TrePaul86 is offline   Reply With Quote
 Old 10-18-2012, 09:33 AM   #23
aggierandy's Avatar
Posts: 2,241   (View Stats)
aggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the world
Groaned at 18 Times in 14 Posts
I have seen another user @S-hendrix with this exact problem. I have it too. I believe it to be severe UV degradation. We are both here in Bryan/College Station. Numerous days over 100 F. Neither of us had a garage. He had one side that was worse than the other. I'm gonna pick up a kit and give it a shot. Ill post up some before and afters for everyone.
@mczimer, you said you used this on your tail lights, any pics? I just painted mine with the tamiya paint and they are pretty foggy. I was hoping to attempt something similar for those.
2010 MS3 Mica Black Tech
Cobb AP | JBR RMM 70 Duro | JBR SSP | CS SRI+TIP | CS Racepipe | NGK Plugs | KMD Internals
CS Interior LEDs | Custom Hatch LEDs | Rear Wiper Delete | Custom "Evil M" | Red Taillights | Resonator Delete | SWAS Switch
aggierandy is offline   Reply With Quote
 Old 10-18-2012, 10:09 AM   #24
mczimer's Avatar
i was referring to wetsanding. I tinted my tail lights and used wetsanding to get them glass-clear. You could use this procedure to "seal" them once completed.
 Old 10-18-2012, 10:17 AM   #25
Groans: 50
I'll take some pics tomorrow. My car is dirty so it looks worse then it is.
08 Mazdaspeed 3
The Following User Says Thank You to Boosted Beluga For This Useful Post:
TrePaul86 (10-18-2012)
 Old 10-18-2012, 11:11 AM   #26
Uberfly's Avatar
put a shirt on! lol, pretty impressive i can see your reflection in the plastic.
 Old 11-25-2012, 05:13 PM   #27
mczimer's Avatar
Thread updated with more pics after doing this again on another ms6
 Old 12-13-2012, 08:50 PM   #28
SIXual Panda's Avatar
Posts: 2,363   (View Stats)
SIXual Panda is the leader of the worldSIXual Panda is the leader of the worldSIXual Panda is the leader of the worldSIXual Panda is the leader of the worldSIXual Panda is the leader of the worldSIXual Panda is the leader of the worldSIXual Panda is the leader of the worldSIXual Panda is the leader of the worldSIXual Panda is the leader of the worldSIXual Panda is the leader of the worldSIXual Panda is the leader of the world
Groans: 56
posting up my results with the sylvania headlight restore kit..
my headlights were really about as bad as they could possibly be before i did this. every time i went to a meat, that is the first thing that people would say.. they just stuck out like a sore thumb. i was worried how much the kit would do, because my headlights were not just fogged, but they had 1000's of scratches on the surface. but i figured, it definitely wouldnt hurt it.
and this is my results.
I envy your ass raping.
The Money Pit: 2006 Mazdaspeed6 GT (BCM)
Fully built, Ported everything, GTX3582r, Port Injection, Twin disk clutch, 2-piece Driveshaft.... still slow.
The Daily Bitch: 2003 Mazda Protege5 with infinity miles on it
SIXual Panda is offline   Reply With Quote
The Following 2 Users Say Thank You to SIXual Panda For This Useful Post:
Don06speed6 (12-13-2012), Micha (11-27-2013)
 Old 12-13-2012, 08:59 PM   #29
Don06speed6's Avatar
Posts: 2,492   (View Stats)
Don06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the world
Groans: 62
You can do mine when I get home?
Cobb AP(FREEK TUNED)/CS TBE/SURE AEROS/CPE TIH/ ITV 22/SU RMM/KMD INTERNALS/SURE DREADNAUGHT/JUGGERNAUGHT/WHITELINE RSB/SURE ANCHORS/SURE COUNTERWEIGHT/SURE SHORTCUT/JBR HEAVY KNOB/JBR EGR DELETE/SPC BALL JOINTS/CENTRIC BLANKS/HPS PADS/BNOON BOLT/ALTERED CUSTOMS FMIC/TURBO XS RFL
Don06speed6 is offline   Reply With Quote
 Old 12-13-2012, 09:03 PM   #30
mach6's Avatar
Posts: 75   (View Stats)
mach6 has a reputation beyond reputemach6 has a reputation beyond reputemach6 has a reputation beyond reputemach6 has a reputation beyond reputemach6 has a reputation beyond reputemach6 has a reputation beyond reputemach6 has a reputation beyond reputemach6 has a reputation beyond reputemach6 has a reputation beyond reputemach6 has a reputation beyond reputemach6 has a reputation beyond repute
i'm definitely gonna do this, but after it's all said and done, do you think there's an advantage to laying down some Lamin-x overlays? Figure they should last a bit longer than just the clear coat by itself.
2006 LPM Mazdaspeed 6
Mazdaspeed CAI - AWR RMM - TWM Stage 2 STS - Cobb AP - M2 DP - AT Internals - Cobb TIP - NGKsparkers - CPE Rear Diff Mount - Whiteline Rear Swaybar - AWR Endlinks - Eibach Sportlines
mach6 is offline   Reply With Quote
 Old 12-13-2012, 09:03 PM   #31
Groans: 56
maaaaaaaaaaaybe.. if you ever decide to visit me down in lancaster!
Don06speed6 likes this.
The Following User Says Thank You to SIXual Panda For This Useful Post:
 Old 12-13-2012, 09:27 PM   #32
Groans: 62
Consider it a date filled with lots of unicorn jiz
SIXual Panda likes this.
The Following User Says Thank You to Don06speed6 For This Useful Post:
SIXual Panda (12-13-2012)
 Old 12-13-2012, 09:30 PM   #33
Groans: 56
DONE!!! ill supply the unicorn jizz!
 Old 12-13-2012, 09:30 PM   #34
Groans: 62
I'll have my own to supply!
 Old 12-13-2012, 09:31 PM   #35
Groans: 56
cant wait!
 Old 01-13-2013, 12:44 PM   #36
cessnan1315efw's Avatar
Posts: 34   (View Stats)
cessnan1315efw has a spectacular aura aboutcessnan1315efw has a spectacular aura about
Nice writeup im doing this the next sunny day we have
cessnan1315efw is offline   Reply With Quote
 Old 01-16-2013, 07:52 PM   #37
btstarcher's Avatar
Posts: 4,852   (View Stats)
Groans: 112
Just finished headlight number 1...so glad I did this!
SnailTune in progress
Boosted Beluga (01-16-2013)
 Old 01-17-2013, 12:03 PM   #38
Is that a Huffy?'s Avatar
Posts: 54   (View Stats)
Is that a Huffy? is a splendid one to beholdIs that a Huffy? is a splendid one to beholdIs that a Huffy? is a splendid one to beholdIs that a Huffy? is a splendid one to beholdIs that a Huffy? is a splendid one to beholdIs that a Huffy? is a splendid one to behold
Groaned at 9 Times in 4 Posts
big help
Is that a Huffy? is offline   Reply With Quote
 Old 01-17-2013, 08:10 PM   #39
btstarcher's Avatar
Groans: 112
It was even more awesome because I actually did this while at work....so I gots PAID to do it. Word.
 Old 01-17-2013, 08:32 PM   #40
mczimer's Avatar
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f111/headlight-restoration-how-125509/
Hazed headlights - Page 3 - DFW Mazdas This thread Refback 12-08-2012 09:07 PM
Help needed with wheel restoration Justin Lee MazdaSpeed 3/6 - Wheels & Tires 5 09-27-2011 08:20 AM
Memory Restoration sheltbh MazdaSpeed 3 - Engine, Transmission & Driveline 5 07-18-2009 10:28 PM
How to make the grade in car restoration Haltech Automotive News 0 05-25-2009 09:40 PM
Restoration completed on one-off Lamborghini Miura Spyder Haltech Automotive News 1 09-12-2008 12:46 PM
Page generated in 0.59583 seconds with 37 queries
