> MazdaSpeed 6 - How-To's
Like Tree2Likes
  • 2 Post By ArmySpeed6
 Old 05-01-2013, 12:51 PM   #1
ArmySpeed6's Avatar
Posts: 672   (View Stats)
ArmySpeed6 is the leader of the worldArmySpeed6 is the leader of the worldArmySpeed6 is the leader of the worldArmySpeed6 is the leader of the worldArmySpeed6 is the leader of the worldArmySpeed6 is the leader of the worldArmySpeed6 is the leader of the worldArmySpeed6 is the leader of the worldArmySpeed6 is the leader of the worldArmySpeed6 is the leader of the worldArmySpeed6 is the leader of the world
Groaned at 20 Times in 8 Posts
Neutral  +2 score
Default How To: BCM Replacement/Swap
Alright guys, this is my attempt to try and write up a DIY, given that I am such a "great mechanic"...Mechanic level - Obama(lower than Brownie)
My reason for writing this up is cause, for some time I have been driving around not being able to use my blinkers/hazards due to the BCM(Body Control Module) has crapped out on me. This was determined after fuses were checked, and wirings were also checked.
Mods please feel free to edit anything that you feel as an error...thanks
Alright! So BCM(Body Control Module)
You will need to disconnect the negative from your battery
Location: it is connected to the cabin fuse box as depicted here
In order to remove the housing that contains BCM/Fusebox, you will need to remove the inner plastic lining that lays on the flooring of this "thingy". Doing so will unhinge the housing that contains the BCM.
As soon as housing is removed, you will see that the BCM is secured by a single 11mm bolt as shown below
Once bolt has been removed, it is then all self explanatory where all that's left to do is simply unfasten the wiring through its "connector clips" and transfer wires/Fusebox to the new BCM
There you have it! Pretty simple 15-20 min job or maybe less. Don't think I need to remind you folks to reconnect your battery =P
Stay Frosty
SSG P out
Mleff001 and walkerlw like this.
GT3076R//Custom FMIC with 13" Core with 3" piping//HTP 3.5 Intake/Inlet System with AEM Cone//CorkSport SS DownPipe//Custom 3inch Exhaust with Single Flowmaster Exit//Autotech Fuel Pump Internals//Prosport OCC//Devils Own Meth//GrimmSpeed EBCS//Bosch 3Bar//Cobb AccessPort V2//MSD DashHawk//TWM Stage 2 Short Throw Shifter//D2 Racing Coilovers//RotorPro Front and Rear Cross Drilled and Slotted Rotors//EBC Green Stuff Front and Rear Pads//ACT 6 Puck Clutch and Flywheel//CorkSport Front Strut Bar//CorkSport Rear Brace Bar//CorksSport Rear Differential Mount//CorkSport Front Sway Bar//Whiteline Rear Sway Bar//CorkSport LED Kit//AWR 80 Duro TMM/RMM/PMM//GTSpec 4 Point Ladder Brace Bar//
////MADSCIENTISTTUNED////
ArmySpeed6 is offline   Reply With Quote
The Following 5 Users Say Thank You to ArmySpeed6 For This Useful Post:
:: Gusto :: (03-04-2015), ChrisMazda3Owner (10-25-2018), mczimer (05-07-2013), Mistersix (06-17-2013), Poohster (05-18-2013)
 Old 05-07-2013, 02:50 PM   #2
mczimer's Avatar
Posts: 1,249   (View Stats)
mczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the worldmczimer is the leader of the world
Best how to EVER
mczimer is offline   Reply With Quote
 Old 05-17-2013, 11:02 PM   #3
ArmySpeed6's Avatar
Originally Posted by mczimer View Post
Best how to EVER
Lol...haha the sarcasm just slapped me so hard
 Old 06-17-2013, 11:41 AM   #4
Mistersix's Avatar
Posts: 2,585   (View Stats)
@ArmySpeed6; I have the same issue as you did. Horn blaring lights flashing. I'm wondering if this is my issue, that i zapped the bcm some how.
Questions:
1.Did you short something and fry the bcm?
2.How did you come to the conclusion this was your issue?
3.Did this solve your problem completely?
4.Does this require and software writing? As in, how does it know your key fob?
5.Did you get this part from the dealer? Was it expensive?
Trying to explore all options before i head to the dealership.
 Old 06-17-2013, 12:10 PM   #5
ArmySpeed6's Avatar
Questions:
after i let my buddy back at my old station wire my lights, i noticed that shortly after that my blinkers had failed along with hazards(duh).
1. I assume that whatever my buddy did, fried my bcm.
2. I did a few trouble shoots. tested fuse box inside the engine bay, checked for current and fuse life. Checked in cabin fuse box, but I checked what else were affected.
3. Once concluded/pinpointed the issue, it was all in the matter of finding someone who has one laying around.
4. My vehicle is the GT model but I lost my credit card key fob, so I am not sure whether or not any type of wiring was necessary, it was pretty much plug in play.
5. Dealership quoted me for $430 just for the part, time and labor is ridiculous, that alone would cost $185 per hour.
also, make sure if you decide to lurk on here, make sure it corresponds to your vehicles model, ie. GT to GT, sport to sport.
installation was very simple...but if you are like me, patience is NOT my best skill...nearly destroyed all the clips
Cheers bud...
The Following User Says Thank You to ArmySpeed6 For This Useful Post:
 Old 06-17-2013, 12:24 PM   #6
Mistersix's Avatar
Thanks so much. I intend to pull it and make sure the numbers match. I just hope i don't need key codes written in or anything. This stuff is kinda new to me so i'm unsure of that.
The Following User Says Thank You to Mistersix For This Useful Post:
ArmySpeed6 (06-17-2013)
 Old 06-17-2013, 02:17 PM   #7
ArmySpeed6's Avatar
Yup, good luck brother...
I know there are a few dudes on here that, unfortunately totaled their six's...they should have it laying around.
 Old 03-04-2015, 12:18 PM   #8
:: Gusto ::'s Avatar
Posts: 1,455   (View Stats)
Where did you buy your bcm from??
yea yea - i know i cant spell
 Old 03-04-2015, 12:32 PM   #9
sporkbomb's Avatar
Posts: 295   (View Stats)
sporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the world
If your question was for the OP, @ArmySpeed6;, he hasn't been active since 04-14-2014 04:00 PM. Seeing as his last post on this thread was on 06-17-2013 04:17 PM ... it's probably safe to say he will not be answering.
Just a wild guess ...
2007 MS3 GT
Autotech CDFP Internals || Cobb AP, SRI, TIH, DP, CB, BPV, EBCS, FSB & RSB || cp-e Injector Seals, EGR Delete|| JBR OCC, Shifter Plate, PMM & TMM, TB & Intake TIG, Coolant Bypass|| Mazdaspeed Coilovers || TRZ RMM|| TWM Bushings || MOOG Front & Rear Endlinks
2006 MS6 GT (ZZB Rebirth)
Autotech CDFP Internals || BNR Stage 3 || Bosch 3 Bar || Cobb AP || cp-e Injector Seals, CBE, DP || ETS TMIC || Full Race EM || H&R Coilovers || JBR Mounts, 3.5" WP Aluminum Intake || Matt Damond OCC, Shifter Plate, EGR Delete || Racing Beat Rear Endlinks || Relentless PnP IM || SPC Balljoints || Whiteline RSB || The Company of Which I Will Not Name Front & Rear Diff Mounts
1990 Miata
I like it raw
sporkbomb is offline   Reply With Quote
The Following 2 Users Say Thank You to sporkbomb For This Useful Post:
:: Gusto :: (03-05-2015), ASHMS3 (03-04-2015)
 Old 09-06-2016, 08:37 AM   #10
Mazdaphil's Avatar
Posts: 1   (View Stats)
Mazdaphil is an unknown quantity at this point
Default Computer Flash
My BCM went bad as well, taillights/dashlights go off intermittently when headlights are on. I have a replacement, but was told I need to get the computer flashed after I install it. Did you need to do this after your swap?
Mazdaphil is offline   Reply With Quote
 Old 09-06-2016, 08:47 AM   #11
Police - Grammarhead
Vansquish's Avatar
Groans: 1,909
In answer to your question . . .
This ^^^
sporkbomb (09-06-2016)
 Old 02-16-2017, 03:52 PM   #12
Tactown98499's Avatar
Tactown98499 has a little shameless behaviour in the past
Attachment 106143
Attachment 106145
Attachment 106144
Attachment 106147
Attachment 106148
Attachment 106149
Stay Frosty
SSG P out
Hey the yellow clip on top of the BCM i have it off and was wondering how to get actual BCM out because it seems like its wedged in there. Help..
Tactown98499 is offline   Reply With Quote
The Following User Says NO Thank You to Tactown98499 For This Un-useful Post:
g00s3y (02-16-2017)
 Old 02-16-2017, 04:30 PM   #13
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
Holy shit, how many times can stupid happen in the same thread
Because reading is hard...
Last edited by g00s3y; 02-16-2017 at 04:30 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-23-2018, 10:29 AM   #14
dishman316's Avatar
dishman316 is an unknown quantity at this point
Default Dishman316
Hello fellow Mazdaspeed Forum users,
I own a 2012 Mazda 6 which I have had for 3+ years now. I look forward to receiving useful tips from this forum!
dishman316 is offline   Reply With Quote
 Old 10-25-2018, 09:04 AM   #15
ChrisMazda3Owner's Avatar
Posts: 2   (View Stats)
ChrisMazda3Owner is an unknown quantity at this point
Question Awesome... but do we have a hot-to on BCM for 2010 Mazda 3?
Alright guys, this is my attempt to try and write up a DIY, given that I am such a "great mechanic"...Mechanic level.
Stay Frosty
SSG P out
+1 Rep.
Absolutely awesome how-to guide with pics..... But does anyone know if we have a BCM replacement for a 2010 Mazda 3?
I have searched and searched and cannot find one....
Thanks!
Chris
ChrisMazda3Owner is offline   Reply With Quote
 Old 10-25-2018, 09:18 AM   #16
Bertospeed3's Avatar
Posts: 148   (View Stats)
Bertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant future
Hello and welcome but I honestly dont think this forums gonna help you much with that '12 Mazda 6
2010 MS3 - Tuned By Nishan
OBX R Custom Exhaust
Cobb SF Intake & TIH w. Blitz Filter
CP-e TMIC
Corksport Dual VTA BPV
JBR 88 Duro RMM
 Old 10-25-2018, 01:06 PM   #17
Jeff23spl's Avatar
Posts: 2,192   (View Stats)
I hope he get that since January
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 10-25-2018, 04:07 PM   #18
Yeah he probably got that quick lol. I didnt even notice, i thought that was the post that bumped the thread. I gotta put the crackpipe down smh
CP-e TMIC
JBR 88 Duro RMM
The Following User Says Thank You to Bertospeed3 For This Useful Post:
monkey.bones.007 (10-25-2018)
 Old 10-25-2018, 11:31 PM   #19
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,990   (View Stats)
Groans: 546
Bert is fat.
94 M
MS6
IS350
 Old 10-26-2018, 06:59 AM   #20
Jeff23spl's Avatar
hum that bumping post isn't even better....a guy not finding used parts for a 2010 mz3 won't be lucky here. And... you should find parts very easily in any local junkyard for a common 2010 car unless you live somewhere you are the only one with that car lol
Wife drive 2010 CX7
CP-E TC3 ECU Swap for gen 2 Torque_steer 2010 MS3 - Turbo Induction 91 02-24-2017 07:35 AM
Fs-ZE Swap Focus MSP - ECU Computer Tuning 4 09-11-2014 08:43 AM
LSD Swap out Tomas MazdaSpeed 3 - How-To's 81 10-08-2012 09:16 PM
HID swap TXspeed3 MazdaSpeed 3/6 - Appearance 19 06-28-2009 05:04 PM
Serpentine Belt Replacement, GM Replacement Parts For Older Cars, Fixing A Radiator Fan, Rebuilt Brake Calipers: Mike Al Haltech Automotive News 0 03-27-2009 02:30 PM
Page generated in 0.42653 seconds with 34 queries
