> MazdaSpeed 6 - How-To's
Like Tree3Likes
  • 2 Post By Code Monkey
  • 1 Post By Code Monkey
 Old 02-27-2016, 04:43 PM   #1
Code Monkey's Avatar
Posts: 7,676   (View Stats)
Default How to depower steering rack!!!!!
Don't.
Stop here, turn around, gtfo, and never think about it again. Road racing tested courtesy of Code Monkey.
brandon3212 and Castillo817 like this.
2006 Mazdaspeed6
stripped|caged|freektuned
2017 Subaru BRZ
brandon3212 (02-27-2016)
 Old 02-27-2016, 06:00 PM   #2
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
Pics or it didn't happen.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
 Old 02-27-2016, 06:04 PM   #3
Check my road racing thread.
2006 Mazdaspeed6
2017 Subaru BRZ
Mazdazilla6 (02-27-2016)
 Old 02-27-2016, 06:19 PM   #4
sporkbomb's Avatar
Posts: 295   (View Stats)
sporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the worldsporkbomb is the leader of the world
Mods: this deserves a sticky!
2007 MS3 GT
Autotech CDFP Internals || Cobb AP, SRI, TIH, DP, CB, BPV, EBCS, FSB & RSB || cp-e Injector Seals, EGR Delete|| JBR OCC, Shifter Plate, PMM & TMM, TB & Intake TIG, Coolant Bypass|| Mazdaspeed Coilovers || TRZ RMM|| TWM Bushings || MOOG Front & Rear Endlinks
2006 MS6 GT (ZZB Rebirth)
Autotech CDFP Internals || BNR Stage 3 || Bosch 3 Bar || Cobb AP || cp-e Injector Seals, CBE, DP || ETS TMIC || Full Race EM || H&R Coilovers || JBR Mounts, 3.5" WP Aluminum Intake || Matt Damond OCC, Shifter Plate, EGR Delete || Racing Beat Rear Endlinks || Relentless PnP IM || SPC Balljoints || Whiteline RSB || The Company of Which I Will Not Name Front & Rear Diff Mounts
1990 Miata
I like it raw
sporkbomb is offline   Reply With Quote
The Following 2 Users Say Thank You to sporkbomb For This Useful Post:
Code Monkey (02-27-2016), speedfreak44 (02-27-2016)
 Old 02-28-2016, 04:25 PM   #5
Ok, update after day 2, it is not actually that bad, will try a larger steering wheel before I decide if I should go back to power steering. The steering rack was depowered using the guidelines provided by Flyin' Miata which included cutting out the inner seal inside the rack. The power steering pump has a shaft and bearing, all the holes are capped, and the pump has engine oil inside. Some pictures.
Edit: You also want to run 3.5* caster or less.
Eric_Joseph likes this.
2006 Mazdaspeed6
2017 Subaru BRZ
 Old 03-26-2016, 08:27 PM   #6
MSP611's Avatar
Posts: 2,291   (View Stats)
wats ur ideas of just gettin rid of the pump and looping the feed and return lines close to the rack and puttin on a genpu idler?
In progress:
 Old 03-26-2016, 08:35 PM   #7
I will be putting a genpu idler on, need to find it used as it is like $200 new, wtf.
Looping the lines on the rack will work, but not as well as cutting the inner seal and packing the rack with grease, give it a try and see.
2006 Mazdaspeed6
2017 Subaru BRZ
 Old 03-26-2016, 08:50 PM   #8
MSP611's Avatar
im good off completely doin wat u did.... i have a genpu idler already and will see how it is just looping the lines and if its too nasty i guess ill go back to power steering, but ill need a new pump cuz i think mine is shot
In progress:
The Following User Says Thank You to MSP611 For This Useful Post:
Code Monkey (03-26-2016)
 Old 04-08-2016, 12:11 PM   #9
aviator79's Avatar
Posts: 3,934   (View Stats)
Groans: 67
Are you able to you remove the rack by just lowering rear of subframe or just drop the whole thing as FSM says to do.
Seems like there is enough room to get it out like this
http://support.corksport.com/instruc...-3-080-WEB.pdf
 Old 04-08-2016, 12:40 PM   #10
No need to drop the subframe, just loosen the bolts to lower it enough.
2006 Mazdaspeed6
2017 Subaru BRZ
aviator79 (04-08-2016)
 Old 04-08-2016, 01:06 PM   #11
aviator79's Avatar
Groans: 67
Oh so you can just slip it out the side. Fuk ya. Thanks! This is why I never use the service manual.
 Old 04-08-2016, 07:05 PM   #12
aviator79's Avatar
Groans: 67
I dont see this happening w/o dropping subframe. Unable to get the hard to reach bolt on rack from top.
I guess I need to undo bottom of strut forks on front LCS to subframe will drop lower. IDK if will make it so I can get that last bolt. Taking longer than I had planned. Would have been much easier to replaced when the engine was out...
 Old 04-08-2016, 07:33 PM   #13
I know my shop was able to swap the rack without removing the subframe completely?
2006 Mazdaspeed6
2017 Subaru BRZ
 Old 04-08-2016, 09:57 PM   #14
aviator79's Avatar
Groans: 67
Ya I got it.
Code Monkey (04-09-2016)
 Old 06-06-2016, 07:26 AM   #15
Got the Whiteline W53395 caster bushings installed and caster went from 4.2/3.9 to 3.3/3.1, now the car is finally driveable and I can turn the wheel with one hand in parking lots once the car starts moving.
You install the bushing such that the offset hole is facing the front of the car, which pushes the rear lower control arm back.
2006 Mazdaspeed6
2017 Subaru BRZ
Tomas (04-15-2019)
Quicker steering rack mituc MazdaSpeed 3 - Engine, Transmission & Driveline 19 05-28-2019 06:38 AM
Page generated in 0.34182 seconds with 25 queries
