> MazdaSpeed 6 - How-To's
Like Tree20Likes
 Old 02-23-2011, 04:24 PM   #1
Jimmer307's Avatar
Posts: 128   (View Stats)
Jimmer307 is the leader of the worldJimmer307 is the leader of the worldJimmer307 is the leader of the worldJimmer307 is the leader of the worldJimmer307 is the leader of the worldJimmer307 is the leader of the worldJimmer307 is the leader of the worldJimmer307 is the leader of the worldJimmer307 is the leader of the worldJimmer307 is the leader of the worldJimmer307 is the leader of the world
Neutral  +9 score
Default How-To: Injector & Intake Manifold Removal
Injector seal Write-up
Tools needed:
Pliers
3/8 Ratchet
3/8 extensions
3/8 swivel
Sockets: 8mm, 10mm, & 12mm
12mm Wrench (P/S bolt)
Pulley tensioner tool or 14mm (Belt)
Adjustable wrench (EGR Tube)
Injector socket / extractor (If corroded)
T40 Torx bit (Fuel Rail)
Here is the engine bay with the TMIC still on. I have an ETS TMIC, but I assume if you are willing to attempt to change the injectors or seals on your own you already know how to remove the TMIC.
There are 2 hose clamps and a few 10mm bolts.
There is also a vacuum line and intake hose that run to the back of the BOV that must be removed.
Remove the Vacuum Regulator thing that sit’s on top of the Manifold
(4) 8mm Bolts
Remove the 3 clips that are in the front left of the manifold by the power steering pump.
You will also need to remove the 2 bolts that attach the wiring harness to the manifold as well as the 1 bolt that holds the dip stick on to the manifold.
Power Steering Pump Removal:
(3) 12 mm bolts
(1) Ground
There are 2 options for moving the P/S pump.
1: You can loosen the serpentine belt via the tensioner pully. Get enough slack in the line and simply pull the belt off. Then loosen the bolts holding it to the block (See method 2 for location on those bolts). (This method is easier if you have the proper tools)
2: You can loosen the 2 bolts on top completely and the one on the bottom 4-5 full turns. You then need to pull the pump towards yourself, then towards the passanger side. This will give you enough room to get to the bolt holding the manifold on. (If you used this method you will need to hulk the P/S pump back on because there is literally no slack in the serpentine belt.
PS Before
PS After
Throttle Body:
(4) 8mm bolts
1 Wiring harness clip
There are 4 that hold the TB to the IM. It is pretty straight forward.
I removed the bolts and the clip and just moved it out of the way to avoid having to deal with spilling coolant.
To remove Intake Manifold:
(8) 10mm bolts
There are two vacuum hoses that you need to remove in front of the manifold & 1 more connected to the valve control module.
There is 1 wiring harness attached that needs to be valve control module that needs to be removed as well
To remove the one with the red clip, push down on the read clip and pull up on the vacuum hose.
To remove the one with the blue clip, pry the blue clip off and the vacuum hose will slip off.
There are 5 bolts that hold the manifold on that are easy to see. The far most bolt on the top is under the runner highlighted in red. There are 2 bolts that hold the manifold to the fuel rail bracket. There is one more bolt that is not visible that is to the left of the EGR tube.
You will also need to remove the EGR tube, I used an adjustable wrench.
You will have to reach under the manifold to reach the PCV hose and pull it off. It is on the far left side of the manifold, but you must reach from the right in order to get access to it.
Fuel Rail Bracket:
(2) 10mm bolts
Fuel Rail:
(5) 10mm bolts (Attached to Block)
(4) T40 Torx bolts
(2) 10mm bolts (Attached to Fuel Line)
The yellow dot indicate the vacuum hose to the fuel rail.
The green indicate the 2 10mm bolts that hold the fuel line to the rail.
The red dots indicate 5 10mm bolts that hold the rail to the block.
The blue dots indicate 4 Torx bolts that hold the crows feet to the block and hold the injectors in place.
Install in reverse order and whala… Your car should now be running like a champ.
BTW: Please feel free to comment with anything I may have missed. I will clean up the thread in a little bit. I threw this together quickly and didn't look over it too thoroughly.
jax ms3gt, speed23, p057 and 10 others like this.
2006 Mitsubishi Lancer Evo IX MR - Garage Queen
2006 Mazdaspeed 6 - Daily Driver
1998 Mitsubishi Eclipse GSX - Weekend Warrior
Last edited by Jimmer307; 05-08-2011 at 04:55 PM. Reason: I missed a couple of things...
Jimmer307 is offline   Reply With Quote
The Following 129 Users Say Thank You to Jimmer307 For This Useful Post:
2008MS3H (04-25-2017), 3dpilot (02-02-2012), 3mazdaspeed (05-08-2011), 4G63 (03-22-2011), 5doorsoffury (04-24-2013), 801MS3 (02-23-2011), 802MS3 (03-27-2011), AJ713 (03-27-2011), ak_spray (01-04-2012), Alpha (05-05-2011), Altenius (12-18-2018), anavrinIV (04-28-2014), Andrewbox (06-23-2013), aromig (11-19-2014), balint (01-18-2016), BigjohnB20 (05-07-2011), Bill6639 (10-07-2014), biochrome (02-13-2013), Blackspeed (07-04-2011), Boro (06-24-2012), Broxer (08-04-2011), bstover17 (01-14-2014), CamSpeed360 (01-13-2013), Castillo817 (02-04-2016), Cataphract_40 (04-05-2011), chris323 (12-26-2014), Ckmazdaspeed3 (03-27-2011), cld12pk2go (04-02-2011), clete (07-28-2014), Code Monkey (01-13-2013), Dano (02-24-2011), dantes5823 (03-30-2012), DingoDave (09-13-2015), Docnox (04-06-2011), Domino81 (03-16-2013), doubleflusher (05-08-2011), dougefresh_ (03-31-2011), Douggievee (03-07-2014), Eighty8 (09-30-2012), Fatguy729 (09-13-2011), fishin53 (02-22-2012), Fobio (03-26-2011), forgedzoomzoom (04-01-2012), H3R3TIC (03-30-2012), HardAntics (04-16-2014), helmetface (03-30-2012), hyejimany (08-18-2017), i8urgti (07-24-2011), impossible (01-17-2016), jabeel00 (12-04-2015), jacek3743 (06-17-2014), JacksonMS30 (02-23-2011), jack_hammer (05-31-2012), JasonMzdSpd3 (05-08-2012), jax ms3gt (02-23-2011), jracer (03-17-2011), karl-hungus (02-23-2011), Karmat (04-15-2012), kenny7821 (02-09-2016), Kfunk (03-31-2013), kish89 (07-14-2013), Kydizzle (08-27-2012), l4nc3r (09-28-2013), LatinKraze (06-28-2013), Livingframe (06-29-2015), m.a.vega1 (06-01-2011), magicka (02-06-2013), manselainen (03-27-2011), mason (11-26-2011), MATT DAMOND (02-23-2011), MattJackson86 (02-23-2011), mayer (10-16-2011), MD1032 (02-11-2016), meelo88 (05-30-2013), meicalnissyen (12-20-2014), Menace1 (02-21-2013), mike w (03-30-2013), mike8748 (03-18-2011), mituc (10-05-2014), Mochi (10-02-2014), Monotonous ONE (04-18-2011), mterry660 (06-07-2014), Muzzybud (12-06-2015), Nathan 6 (08-10-2012), NJSPEED3 (02-23-2011), NoLeftTurn (02-23-2011), obijack (03-29-2011), p057 (02-17-2012), PapaSmurf (03-26-2011), Pointless (10-14-2012), Poohster (02-23-2011), psychophyr (08-15-2012), R.MS3 (02-23-2011), Raider (01-15-2012), Realgib3 (04-05-2011), redboat (03-10-2014), redneck4Christ (11-19-2014), rfinkle2 (05-05-2011), rob ms6gt (05-11-2011), sadak (01-17-2015), sellers (05-16-2011), skeeter149 (02-23-2011), sleeperstang1994 (11-10-2013), soulitified (05-16-2017), speed23 (02-23-2011), Speed3eak (05-19-2011), Speed3Pedro (06-25-2016), speed6qc (11-12-2015), SpeedSixxx (03-30-2012), Strangel (01-10-2015), Tedspeed6 (12-19-2012), theschrum (06-17-2011), the_caruch (02-23-2011), Toddy22587 (04-09-2011), torquemaniac (02-06-2016), toybiz (06-24-2012), Tres3 (12-24-2013), triplejumper18 (04-05-2011), turd burglar (03-26-2011), Vitamin M (11-28-2016), vtdone (10-21-2016), wette460 (05-19-2011), wolly6973 (05-05-2011), WRX_Fan_0717 (04-05-2011), xdm88 (02-04-2012), XLT_66 (05-04-2011), XsillyputtyX (04-05-2017), YammerR1 (02-23-2011), Z32_MS3 (07-23-2014)
 Old 02-23-2011, 04:36 PM   #2
spnkr21's Avatar
Posts: 2,827   (View Stats)
Groans: 105
Very nice write up man.
2012 WRX HB w/mudflaps yo!
 Old 02-23-2011, 04:38 PM   #3
jax ms3gt's Avatar
Posts: 1,151   (View Stats)
jax ms3gt is the leader of the worldjax ms3gt is the leader of the worldjax ms3gt is the leader of the worldjax ms3gt is the leader of the worldjax ms3gt is the leader of the worldjax ms3gt is the leader of the worldjax ms3gt is the leader of the worldjax ms3gt is the leader of the worldjax ms3gt is the leader of the worldjax ms3gt is the leader of the worldjax ms3gt is the leader of the world
Groaned at 23 Times in 12 Posts
looks like very nice write up! I like the color coding..lol
CP-E HPFpump™ CP-E 3" SS Cat Back Exhaust System CP-E 3" SS Downpipe System CP-E Rear Engine Mount CP-E XcelNANO™ Air Intake CP-E Nviscid™ Pipe CP-E Triple Gauge Pod Cobb AccessPORTv2 Cobb Anti Sway Bar(rear) Corksport TMIC
PERM TUNED
Forge bpv Eibach ProKit Prosport Wideband AFR Boost Oil Temp Oil Pressure JBR Shift Knob SunTek CarbonXP 30% around
2002 Mazda Protege5:AEM sri KYB gr2's DDM hid RIP
jax ms3gt is offline   Reply With Quote
 Old 02-23-2011, 04:50 PM   #4
JacksonMS30's Avatar
Posts: 2,242   (View Stats)
JacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the worldJacksonMS30 is the leader of the world
Added to MS6 and MS3 How to database sticky
I'll be doing this on saturday so if there are any differences between the two (shouldn't be) I'll make a note about it in this thread.
JacksonMS30 is offline   Reply With Quote
 Old 02-23-2011, 04:54 PM   #5
R.MS3's Avatar
Posts: 987   (View Stats)
WOW, this write-up makes things much easier. Thanks!
R.MS3 is offline   Reply With Quote
 Old 02-23-2011, 07:29 PM   #6
was the last steps with the rail and injectors in order?
 Old 02-23-2011, 07:45 PM   #7
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
thanks man makes me feel a lot better about changing the gay factory pcv valve
skeeter149 is offline   Reply With Quote
 Old 02-23-2011, 07:55 PM   #8
Jimmer307's Avatar
They are now...
What I found is that some people pull the rail with the crows feet already removed so they don't have to risk trying to pull the injectors out of the head. Some people pull the rail before they pull the crows feet because their injectors will just pop out of the head after they remove the crows feet. There is no right or wrong way to remove it, just preference. However, I would strongly advise pulling the bolts from the fuel line and vacuum hose first in order to prevent bending the lines.
The Following 3 Users Say Thank You to Jimmer307 For This Useful Post:
dougefresh_ (03-31-2011), Menace1 (02-21-2013), rfinkle2 (05-07-2011)
 Old 03-26-2011, 08:15 PM   #9
MattJackson86's Avatar
Posts: 1,407   (View Stats)
So do you need to remove the belt from the idler pulley at all?
 Old 03-26-2011, 08:33 PM   #10
Blackrider's Avatar
Posts: 356   (View Stats)
Blackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the worldBlackrider is the leader of the world
Groaned at 20 Times in 14 Posts
How many Miles on the car and how gunked up were the intake valves?
2008 MazdaSpeed 3
Exhaust - Mazdaspeed & Ebay Downpipe
Induction - MazdaSpeed CAI, Unknown TIP, JBR TIG's & CXR FMIC
Tuning - Auto Tech Internals, Cobb Accessport, Grimmspeed 3 port EBCS
Suspention - Koni FSD's, RX-8 Rims, Potenza RE - 11's 235 / 40 / 18's
Drivetrain - J-Speed Shifter Plate, Sure Anchors, SU RMM
Random - Pontiac G8 Horns
2013 Ford Edge Sport AWD, the family car...
Blackrider is offline   Reply With Quote
 Old 03-27-2011, 12:16 AM   #11
Jimmer307's Avatar
It is not necessary to remove the belt but I went ahead removed it.
My car had 40k at the time of install. My valves looked like shit.
 Old 03-27-2011, 01:03 AM   #12
Blackrider's Avatar
Yeah, my 08 has 80,000KM on it, of which most are highway. I'm thinking it might be time to get into the ports and clean the valves. From the pictures I've seen the carbon buildup can be pretty bad. I don't think DI with an EGR is the smartest combo.
My G8 has 45,000KM on it, again mostly highway. However, the intake valves look like the day they were installed in the head.
2008 MazdaSpeed 3
 Old 03-31-2011, 01:08 PM   #13
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
For the PS pump.... You can just undo the top bolts as shown (one comes out, one doesn't), and loosen the bottom bolt 4-5 full turns, but DO NOT REMOVE. Then lift the PS pump assembly up & towards the firewall iirc, so it clears the pin on the bottom. They it will just sag to the left, and be out of the way for the entire install/uninstall. This will save you some time.
Also, the bottom bolt on the power steering pump is a bitch to get at if you're not using the right tool combination. Use a deepwell socket with a 6" extention and a 3/8 ratchet to lossen this bolt. It's the only combo that fits that I know of... I had to find out the hard way, lol. Your ratchet should just clear the radiator.... go in from the top, and snake the deepwell on from there, and you'll have it in 2 minutes.
OP- Great write up!!
The Following 6 Users Say Thank You to dougefresh_ For This Useful Post:
Alpha (01-16-2012), Dano (03-31-2011), Menace1 (02-21-2013), QwkEVO (03-18-2012), redboat (03-10-2014), rfinkle2 (05-07-2011)
 Old 04-05-2011, 08:37 PM   #14
tddvrrn's Avatar
Posts: 2,571   (View Stats)
Groans: 103
so, once you've removed all this crap, how do you clean it? or do you just replace certain things?
kinda new to opening up engine parts...
 Old 04-05-2011, 08:48 PM   #15
I just wiped down the throttle body with a clean rag, and I used 3-4 cans of brake cleaner on the intake mani. I have a w/m kit now + OCC, so I'm not worried about shit building back up. Here's what mine looked like before I cleaned it:
Many people reuse the stock gasket and say it's fine, but as you can see from the video, mine was shot and needed to be replaced (30K miles at the time). I'd buy one ($12) to have on hand or an intake mani spacer just in case. You don't want to create a leak there, and have to remove all that shit again for $12. If you do the spacer, only the 5 head bolts go back on.
The Following 3 Users Say Thank You to dougefresh_ For This Useful Post:
Docnox (04-06-2011), Pointless (04-11-2013), rfinkle2 (05-05-2011)
 Old 05-05-2011, 08:17 AM   #16
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
great write up.. going to tackle this project this weekend..
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
 Old 05-07-2011, 05:33 PM   #17
Speedie6's Avatar
Posts: 1,819   (View Stats)
Speedie6 is the leader of the worldSpeedie6 is the leader of the worldSpeedie6 is the leader of the worldSpeedie6 is the leader of the worldSpeedie6 is the leader of the worldSpeedie6 is the leader of the worldSpeedie6 is the leader of the worldSpeedie6 is the leader of the worldSpeedie6 is the leader of the worldSpeedie6 is the leader of the worldSpeedie6 is the leader of the world
I'm just starting my install here, and, I was already about ready to throw in the towel. I'm a pussy. SD's directions said to loosen the idler pulley, but, mine's a bitch or I'm a pussy as I can't move the fucking thing. So, I figured I would try this way. But it wasn't making sense to me...
The belt is presumably pretty tight. If you remove the pump, then it seems like you'd have to loosen and retighten the belt, which seems like a PIA. With your way, it seems like you just leave the belt tight and manhandle the pump. I guess that makes sense. I guess I'll go back out to the car and look at it again.
360 AWD HP/380 TQ Cobb Mustang Dyno: 3071 .83 A/R, Steedspeed manifold, CPE FMIC, Cobb AP/tuning, CP pistons, Pauter Rods, CPE DP hacked to have V-band, GHL exhaust
Speedie6 is offline   Reply With Quote
 Old 05-07-2011, 06:31 PM   #18
The belt is tight, and you do have to man handle the pump. Loosen that bottom bolt 4-5 full turns, but DO NOT REMOVE. I think my instructs above were off... you DO have to clear this pin (so pulling UP is correct), but I forget the direction. As soon as you clear the pin you'll know, because it'll want to hang to the left.
Don't give up, unless you think you're gonna break something. I'm FAR from mechanically inclined, so if I can pull it off, so can you . "I'm just starting my install" --> Get back in there and get er' done!! After doing it once, the next time will be a joke, and you'll have the satisfaction of not letting the install beat ya to boot
GL
EDIT:
7. Loosen bottom bolt of PS pump about 4-5 full turns DO NOT REMOVE. 7mm
No pic but it is on the left side almost up against the pully. I used a Deepwell socket with a 6" extention and a 3/8 ratchet to lossen this bolt.
8. While holding pulley with left hand and the housing with your right, pull the PS pump towards you and rotate counter clockwise until it just hangs to the left slightly. You must pull it out far enough to clear the "pin" on the bottom right side of the pump. If it isn't rotating you propbably haven't cleared the "pin". Either pull harder or loosen the bolt in step 7 a little more. DO NOT REMOVE THE BOLT ALL THE WAY. This step is necessary because you need to access the left most bolt on the IM head flange (when reversing this step its much easier to have an extra set of hands).
-Taken from MS6-582's 'how to' on 6crew.
The Following User Says Thank You to dougefresh_ For This Useful Post:
wolly6973 (05-09-2011)
 Old 05-07-2011, 08:22 PM   #19
Speedie6's Avatar
Dougefresh_'s recommendations for the power steering pump worked great. Glad I gave up on loosing the idler pully per SD's instructions.
But, I've got something way way way fucked up, I'll post it in Silver Demon's original thread. (Hint: ever hear of a MISSING crow's foot?)
The Following User Says Thank You to Speedie6 For This Useful Post:
dougefresh_ (05-07-2011)
 Old 05-07-2011, 08:35 PM   #20
jracer's Avatar
Groans: 89
Missing crows foot ? The injector would fly out of the block
If it was missing ...
Can't wait to see what your talking about !
Edit*** I forgot the fuel rail holds the injector in also .. So my bad on thinking the injector would fly out ... Lol
But I would think it would rattle and douse some serious KR ...
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
AEM wideband gauge
EvoX piller pod
30%Tint
**** SOLD *****
2006 speed6
The Following User Says Thank You to jracer For This Useful Post:
 Old 05-07-2011, 11:23 PM   #21
Speedie6's Avatar
Check SD's thread. I keep trying to think is there any way that I'm mistaken? Any way that I could have taken off the crows foot and not remembered having done so? But I couldn't even find my Torx bit so I was going to run to the store after removing the fuel rail.
I expect people to call bullshit. I would if it was someone else. But either it was missing, or I took serious drugs -- and I don't do drugs. Or someone ran into my garage and pulled it off while I wasn't looking.
The Following 2 Users Say Thank You to Speedie6 For This Useful Post:
dougefresh_ (05-08-2011), foodtime (10-01-2014)
 Old 05-08-2011, 03:12 AM   #22
SilverDemon's Avatar
Posts: 3,034   (View Stats)
I have seen one other member on this site that has had one of the torx bolts come completely out, but the crows foot stayed on the engine. So, I know it is possible....and this is why I recommended to use loctite on the torx bolts...
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 4 Users Say Thank You to SilverDemon For This Useful Post:
ak_spray (01-04-2012), dougefresh_ (05-08-2011), rfinkle2 (05-08-2011), Speedie6 (05-09-2011)
 Old 05-08-2011, 04:54 PM   #23
Jimmer307's Avatar
It seems that you have pretty well figured out how to put the power steering pump back on. For future referance, I have fixed/added to the original directions.
BTW: That is funny you are missing a crows foot.
 Old 05-09-2011, 07:48 AM   #24
Speedie6's Avatar
I didn't think about that possibility -- that it was put on but fell off. If that is what happened, that makes Cobb not look like complete fucking idiots. I was thinking, "how could they have possibly missed putting one on?"
Two of the other three were on, but the bolts were loose. Do you think Cobb forgot to torque them, or did they vibrate loose?
I used high-temp loctite on the studs. But the nuts are actually going to be lubricated, the the ARP Ultra Torque. Would that make the nuts more likely to come off? It was my expectation that the torque loading is supposed to hold the nuts in place. I plan on torquing them to 25 lbs. They better stay.
The injector removal tool is simple but brilliant, I'm glad that was included. I had one injector that was terribly corroded. And it was the one that the bolt was tight! I'm going to have to clean that hole, I figure on using my Dremel tool with the cloth polishing wheel.
I hope after all this, its fixed for good. My car will be down for the week, I'll have to round up the crows foot this week.
 Old 05-09-2011, 02:56 PM   #25
I think that cobb probably put them on, they just did not torque them to spec and/or they did not use loctite. Just my guess though. The use of the ultra lube is a wise choice, and should be the best for this application. Use a torque wrench that is known calibrated properly and all should be right with the install.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 05-09-2011, 03:11 PM   #26
Speedie6's Avatar
I understand that Ultra Torque helps to set the torque loading. But, it seems like it would make it slippery too, which would seem to help it to back back out. But, maybe not, I dunno, it just kinda seems like it.
I wound up buying a stack of tools for this project. I didn't have a torque wrench. My brother has one, but is like 30 years old and I have no idea how close to spec it is, so I just bought one. A 21/64" drill bit, a 27 mm wrench, a 12 point 10 mm socket and a T40 socket.
foodtime (09-30-2014), wolly6973 (05-09-2011)
 Old 05-19-2011, 02:37 PM   #27
wolly6973's Avatar
Posts: 2,364   (View Stats)
Groans: 386
I pulled the IM for my TIG install today. The how-to says you need to pull the pulley or belt off to do it. I did not have to.
Does pulling the pump/belt apply to 6 only, or 6/gen1 only?
Wish I would have tried it when I installed my seals, since getting that pump back in place is a real PIA by yourself.
 Old 05-19-2011, 04:38 PM   #28
lulz @Raider
burn813's Avatar
Posts: 3,171   (View Stats)
Nice write up!
2008 MS3 gt
470hp/463tq on GT35r at 29psi
HKS CBE/ Koni Yellows and H&R springs/ HTP Whale Penis Intake/ PTP Fuel internals/SteedSpeed Mani/CP-E SafeSeals/E85 Hypnotic Tuned
burn813 is offline   Reply With Quote
 Old 07-18-2011, 03:33 PM   #29
derrian's Avatar
Posts: 63   (View Stats)
derrian is just really nicederrian is just really nicederrian is just really nicederrian is just really nicederrian is just really nice
This is a great write and I used it on my own car recently. But now that i got my PnP Mani back, and am getting it back on I have a questions.
When looking at the car the Mani has an area for something to plug into it on the left side. Looks like a plug about the size of a nickel and a area for a screw right next to it....
What the heck goes here! I I totally forgot.
Thanks!!
Are you a Geek??? ---> Minnesota Car Enthusiasts = MNGarageGeeks.com
Daily Driver: '09 MazdaSpeed 3 GT in Mica Black
Interior: cobb short shifter, cpe triple gauge pod w/ boost, oil temp and wideband gauges, su bushings
Exterior: turbosmart dual port bov, hks racing intake, cobb inlet, corksport testpipe, tri-point rsb, blacked-out everything, windows tinted, yellow fogs
Wheels: wedssport sa-55m wheels, yokohama Advan ad08 tires
What's Next?: E.V.E.R.Y.T.H.I.N.G (See my Build Thread -> http://www.mngaragegeeks.com/forum/threads/319-Project-Nani)
In the Garage: '97 Subaru Sti Type R • '90 RX-7 • '83 RX-7 • '91 Miata • '79 Fiat Spider • '04 Harley Sportster 1200
derrian is offline   Reply With Quote
 Old 07-18-2011, 03:35 PM   #30
Map Sensor??
Take a pic of the area in question...
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
 Old 07-18-2011, 03:39 PM   #31
derrian's Avatar
Red circled area
 Old 07-18-2011, 03:43 PM   #32
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Originally Posted by derrian View Post
Red circled area
Per page 1217 of the FSM:
SilverDemon (07-18-2011)
 Old 07-18-2011, 03:45 PM   #33
derrian's Avatar
Awesome! Thanks so much!
That is what I get for replacing about EVERY bolt on I can on my car at one time I'm starting to forget stuff.
The Following User Says Thank You to derrian For This Useful Post:
 Old 07-18-2011, 03:51 PM   #34
Damn 12 pk ...stole my thunder hahahaha!!!
I just have one question.... Call me crazy, but, how can it be circled with a square?
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 3 Users Say Thank You to SilverDemon For This Useful Post:
redneck4Christ (11-19-2014), Rich-PMS (12-04-2011), tddvrrn (03-18-2012)
 Old 07-18-2011, 03:53 PM   #35
Eth/Meth Junkie
cld12pk2go's Avatar
Naw....he circled it with a rectangle...that is why it works...
 Old 07-18-2011, 03:58 PM   #36
derrian's Avatar
She she
It would sound funny if I said "I rectangled it"
cld12pk2go (07-19-2011)
 Old 07-18-2011, 04:02 PM   #37
Eth/Meth Junkie
cld12pk2go's Avatar
She she
We have some females on MSF? I never saw that coming...lol
 Old 07-18-2011, 06:27 PM   #38
Posts: 9,484   (View Stats)
I hope the hounds don't key in on these posts....
derrian will be in for some "fun"
 Old 08-04-2011, 03:39 PM   #39
vipercwf's Avatar
Posts: 10   (View Stats)
vipercwf is an unknown quantity at this point
Hey Everyone - actually a new member here (member on 24/7). Anyways, long story short I have to replace an injector so this is super helpful how to. As far as actually pulling the injectors out is there anything else I need to know. When all the bolts are loosend up will they just pull out along with the fuel rail? If so any kind of special care regarding removing injectors from fuel rail? Or when reinstalling new injector?
I appreciate the help! Thanks!
vipercwf is offline   Reply With Quote
 Old 08-04-2011, 04:10 PM   #40
Speedie6's Avatar
Number one, absolutely, positively get the CPE injector seals at the same time. It will include the tool to remove the injectors. Some may just fall out easily, some may be really caked up and take some work to pull. But the removal tool works like a champ. Read this thread and the CPE injecotr seal thread.
dougefresh_ (08-04-2011)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f111/how-injector-intake-manifold-removal-73170/
Ets tmic - Page 3 - DFW Mazdas This thread Refback 11-19-2014 11:09 AM
Wire tuck This thread Pingback 09-08-2014 01:17 AM
Untitled document This thread Refback 09-01-2014 01:54 AM
Whats New/General Speed 6 Discussion - Page 42 This thread Refback 08-26-2014 06:59 AM
Oil Catch-can fitting. & intake Thermal Gasket This thread Refback 04-05-2014 04:58 PM
Oil Catch-can fitting. & intake Thermal Gasket ? Mazda MPS Owners Club This thread Refback 04-07-2013 01:18 PM
? View topic - mps starting This thread Refback 02-15-2013 01:30 AM
MazdaSpeed3 - Injector & Intake Manifold Removal | MN Garage Geeks - A Minnesota Car Club of Car Enthusiasts bringing you Automotive News, Car Events, and Tuner information via Forum from the Minneapolis & St Paul - Twin Cities area. This thread Refback 07-12-2012 10:26 AM
Intake Valve - Cleaning - Mazda 3 Quebec This thread Refback 04-13-2012 04:48 PM
Whats New/General Speed 6 Discussion - Page 63 This thread Refback 03-19-2012 01:08 PM
injector replacement mazda 3 This thread Refback 02-02-2012 12:08 PM
How To: Replace Stock PCV Valve | SpeedForums.org This thread Refback 11-29-2011 12:53 PM
Mazda3 - MazdaSpeed3 Transmission Swap | MN Garage Geeks - A Minnesota Car Club of Car Enthusiasts bringing you Automotive News, Car Events, and Tuner information via Forum from the Minneapolis & St Paul - Twin Cities area. This thread Refback 10-18-2011 10:24 PM
How To: CPE Safe Seals install + EGR Delete | SpeedForums.org This thread Refback 10-11-2011 06:36 PM
How To: CPE Safe Seals install + EGR Delete This thread Refback 09-23-2011 12:07 PM
MS3 SURE Motorsports’ TIG Installation (includes Intake Manifold removal) | MN Garage Geeks - A Minnesota Car Club of Car Enthusiasts bringing you Automotive News, Car Events, and Tuner information via Forum from the Minneapolis & St Paul - Twin Citi This thread Refback 07-26-2011 11:10 AM
Injector & Intake Manifold Removal | MN Garage Geeks - A Minnesota Car Club of Car Enthusiasts bringing you Automotive News, Car Events, and Tuner information via Forum from the Minneapolis & St Paul - Twin Cities area. This thread Refback 07-23-2011 04:02 PM
MazdaSpeed3 Transmission Swap Into Mazda3 | MN Garage Geeks - A Minnesota Car Club of Car Enthusiasts bringing you Automotive News, Car Events, and Tuner information via Forum from the Minneapolis & St Paul - Twin Cities area. This thread Refback 07-14-2011 10:30 PM
How To Change stock PCV Valve + Venturi Set Up - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 06-17-2011 02:32 PM
How To CPE Injector Seals + Studs + EGR Delete - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum This thread Pingback 04-18-2011 10:02 PM
HOW-TO: Intake Manifold Removal superskaterxes MazdaSpeed 6 - How-To's 31 10-05-2013 01:56 PM
HOW-TO: Intake Manifold Removal superskaterxes MazdaSpeed 3 - How-To's 15 11-23-2011 04:20 PM
removal of exhaust manifold bolt behind turbo dooderek MazdaSpeed 3/6 - Troubleshoot/Diagnostics 3 02-27-2011 08:07 PM
Intake Manifold Removal! thabigo MazdaSpeed 6 - Engine, Transmission & Driveline 1 05-20-2009 09:33 AM
Intake Manifold Removal How-To - need help! LBV MazdaSpeed 3 - Engine, Transmission & Driveline 24 01-15-2009 04:40 PM
Page generated in 0.69963 seconds with 40 queries
