> MazdaSpeed 6 - How-To's
  • 1 Post By dougefresh_
 Old 10-22-2011, 02:58 PM   #1
oh_yeams6's Avatar
Posts: 104   (View Stats)
oh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond repute
Groaned at 9 Times in 7 Posts
Default How To: Install ATP CEL trick kit
Ok, this is not a hard install at all, but when dealing with the o2 sensors, you want to be safe!
Step 1: Drive onto ramps or jack up front end of car
Step 2: Find the Rear o2 sensor on the downpipe
Step 3: Remove o2 sensor from Downpipe (use PB blaster if it does not budge). Loosen it slightly, then spray with pb blaster again and retighten. Wait 5min, and unscrew completely.
*note- I used an o2 socket, but you can use an open-end wrench (7/8")
Step 4: apply anti seize to o2 threads & ATP bolt threads or it will not screw in smoothly!
Step 5: screw o2 sensor into ATP socket, and tighten with o2 socket (a little past hand tight)
Step 6: Screw ATP bolt into downpipe, with one washer on each side of unit. Tighten with 22mm, a bit past hand tight
oh_yeams6 is offline   Reply With Quote
 Old 10-22-2011, 04:01 PM   #2
SSinstaller's Avatar
Posts: 3,922   (View Stats)
Groans: 56
Step 7. Await MIL P0139
Soon to be installed:
 Old 10-22-2011, 04:04 PM   #3
oh_yeams6's Avatar
I don't see that happening?
 Old 10-22-2011, 05:26 PM   #4
Groans: 56
Why don't you just turn off the cat MIL in ATR?
 Old 10-22-2011, 05:39 PM   #5
oh_yeams6's Avatar
Can only have one "not ready" here. Have EGR deleted also :/
 Old 10-22-2011, 08:56 PM   #6
Groans: 56
You can prevent the cat effiency MIL with a 1 amp rectifier diode on the signal wire of the rear O2 sensor. No other parts are necessary.
The issue is that the rear O2 sensor is used to calibrate the primary O2, so anything you do to the rear O2 will effect the output of the primary...
The Following 2 Users Say Thank You to SSinstaller For This Useful Post:
dougefresh_ (10-22-2011), zpele (11-02-2011)
 Old 10-22-2011, 09:31 PM   #7
oh_yeams6's Avatar
I was considering that route, but didn't want to mess with the o2 wires...too pricey after replacing them both already (COBB installed/stripped both)
This setup shouldn't have any negative effects though...I am unsure what you mean?
Last edited by oh_yeams6; 10-22-2011 at 09:31 PM. Reason: MSF Database - Automerged Doublepost
 Old 10-22-2011, 09:43 PM   #8
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
If the ATP cel thing works, you can just remove it after inspection, and it won't interfere with the primary. I considered doing this (same boat... no cats + egr del), but I've heard they are hit or miss, and didn't want to risk it. So I put egr back on (twice, lol). I got a rejected sticker for my evap not being ready despite doing almost every drive test and having 92 miles since the batter was out... fml.
What DP do you have? Sig says ATP catted... I assume that is old?
GL
swampthigger likes this.
 Old 10-22-2011, 11:34 PM   #9
oh_yeams6's Avatar
I have an ATP catted DP, but the p0421 comes on after a while anyhow...
Would I have a negative effect on my car from using this all the time? I was under the impression that the rear o2 is simply monitoring the health/function of the catalytic converter.... If it is showing less flow than the front one, it should fool the car into thinking there is no issue...or?
 Old 10-23-2011, 11:31 AM   #10
Groans: 56
The rear o2 does monitor the cat, but it also is used to correct the sensor drift of the primary o2, and must react to output changes from the primary o2 within a very short time period(iirc .3 seconds).. The problem you run into with o2 spacers like the atp part is that they slow the rear o2 responce down enough that you end up with the p0139 mil and fail your inspection anyway, and as a side effect of the slower/incorrect responce the calibration of the primary sensor will no longer be accurate...
dougefresh_ (10-23-2011)
 Old 10-23-2011, 12:02 PM   #11
oh_yeams6's Avatar
Okay, I will let you guys know how this behaves, and if it does trigger any lights...hope not
Good input @SSinstaller !
 Old 11-01-2011, 08:33 PM   #12
speedms6's Avatar
Posts: 825   (View Stats)
any updates, figured by now u would have gotten lights, im installing a catless soon, might go with this or the two sparkplug antifouler route
 Old 11-01-2011, 09:04 PM   #13
That sucks that you get a cel w/ a high flow cat. When I first went BT w/ catless DP, I forgot to uncheck cel, and I threw it w/in 5 mins or 2 miles... whichever came first, lol
 Old 11-01-2011, 10:08 PM   #14
oh_yeams6's Avatar
No CEL yet. I have not logged hundreds of mikes yet, but a light would have common by now. Also, people have been satin this messes with the grit o2, which I do not really agree with...chime in on this if you wish!
The Following 2 Users Say Thank You to oh_yeams6 For This Useful Post:
dougefresh_ (11-01-2011), speedms6 (11-02-2011)
 Old 11-02-2011, 05:44 AM   #15
speedms6's Avatar
i figured the light would be on by now too, hopefully that means its working
The Following User Says Thank You to speedms6 For This Useful Post:
dougefresh_ (11-02-2011)
 Old 11-02-2011, 05:59 AM   #16
speedms6's Avatar
O2 Simulator, Cel Fix
just order that, same idea as the atp one, just cheaper, when i do my install i'll post up how it goes
 Old 11-02-2011, 06:44 AM   #17
wolly6973's Avatar
Posts: 2,364   (View Stats)
Groans: 386
You can also use a spark plug fouler that you drill out.
DIY from Civic forum here...
DIY O2 Sensor Bypass / Spark Plug Non-Fouler Trick Installation (w/ pics) - Honda Civic Forum
 Old 11-02-2011, 05:30 PM   #18
oh_yeams6's Avatar
Lots of ideas!
 Old 11-04-2011, 07:20 PM   #19
oh_yeams6's Avatar
I would like to update this thread with some information from ATP:
According to them "there are no ramifications", and it should not hinder the performance of the primary 02 sensor if it's installed on the secondary sensor like it's designed".
Since this is specifically made for our car, that sensor, ect.. I think it is a pretty fair assumption that it will function correctly, and without issues.
 Old 11-05-2011, 10:31 AM   #20
Groans: 56
I've tried just about anything you can think of to get rid of the cat MILS.. Any modification to the rear O2 placement changes the output and results in a skewing of the primary O2 output.
It's easily seen if you have a means of viewing the AFR other than the OEM sensor.. The OEM wideband output always drifts leaner than the actual AFR. The diode fix resulted in a full half point drift in the AFR as show by the OEM wideband... and when I removed it, the AFR gradually corrected until it matched my innovate wideband again...
wolly6973 (11-06-2011)
 Old 12-07-2011, 10:07 AM   #21
speedms6's Avatar
just to update this, that link i provided in post 16, it works, no cel what so ever, with a completely catless exhaust and the turbo smoked for a day or two. the only drawback i have noticed is the fuel trims go rich a little at idle then all the sudden jump to their targets. seems like only a couple seconds. my assumption is that it takes a little longer for the exhaust gases to the sensor. so i just passed inspection on saturday, gonna take off the extender next chance i get to get the car up. and just clear out the cel using atr, then throw the extender back on for inspection next year.
dougefresh_ (12-07-2011)
How to: ATP check engine trick?? oh_yeams6 MazdaSpeed 6 - Engine, Transmission & Driveline 8 10-21-2011 08:32 PM
Video: BMW S 1000 RR pulls off the old tablecloth trick Haltech Automotive News 0 03-05-2010 06:30 PM
ecu learning trick?, will this work? johnac08 MazdaSpeed 3/6 - ECU Computer Tuning 6 12-31-2008 08:47 PM
Page generated in 0.84201 seconds with 25 queries
