> MazdaSpeed 6 - How-To's
 Old 03-08-2013, 07:39 PM   #1
SpeedRebirth's Avatar
Posts: 685   (View Stats)
SpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the world
Groans: 33
Default How-To: Install Guardian Angel on MS6
How to install the Guardian Angel in the MS6 engine bay, with many detailed pictures
The reason i made this write down is that there really isnt any detailed How-To of how people install this device in their MS6's. There is one big difference from the MS3 install, where the LED wire goes
Note: This is the way i did it, there are several other locations that the GA and wire/tubes can be installed at. But this worked very well for me and im extremely satisfied with it!
Parts used:
* Guardian Angel
* Add-A-Fuse (a.k.a Add-A-Circuit)
* 40" of 5/32" vacuum hose
* 12" of 3/16" vacuum hose
* 2 5/32" clamps and 2 3/16" clamps
* Some zip ties
Tools needed:
* Lights
* Pliers
* 10mm socket and matching ratchet
* Drill with 3/16" and 8/32" drills
Preparation:
Remove the red crimp seal from the GA wire and connect it with the blue crimp seal on the "Add-a-fuse". Make sure the wire is secure
Everything testfitted and ready to be installed
Now lets get things installed!!
Remove the battery and battery tray
Remove vacuum from BPV (pic was taken before i cleaned things up)
And from the maifold. This might be a bit tight to get to if you have a TMIC and haven't removed it. But it does work
Connect the new vacuum hose to manifold
Routing using the supplied fasteners and zip ties
I installed GA on the fuse lid. Just drill two holes and use screws and nuts to make it real tight. On this picture everything is connected
Connect the Add-A-Fuse to ENG BAR and route the wiring through the opening on the backside of the fusebox. Make sure the lid doesnt jam down on the wire.
You can also see that i zip tied the big black GA wires on the right side of the fusebox.
On the top of the picture is where i mounted the GA ground wire (stock location), just to the right of the big black OEM ground cable. This is also where you should tape the blue External Trigger Wire together with the rest of the wires, unless you'r actually going to use it
Black LED wire zip tied to some solid pipe
This part could be a bit tricky. I used a long screwdriver to push some wire through this rubber thingy where the cars electrical cables are gathered (picture shows LED wire already pulled through)
Tied it to the LED wire and just pulled it through the hole i made in the rubber with the screwdriver
"Button" removed. There are two ways of doing this:
1) Insert two tiny screwdrivers on top and bottom and pry it out
2) From under the dashboard you could reach up and press on the clips that hold this button (i didnt make it, was too tight)
Now use a 8/32" drill to make a hole on the back of the button
And a 3/16" drill on the front side. This size is pretty much perfect and makes the LED sit really tight
LED installed. You may use glue on the inside of the LED wire to really make sure it stays there (test the system first so you know that it actually works)
Backside of the buttons, wire is installed and ready to go
Final result!! Though button is not pushed in until system has been checked at the 10 PSI setting (lowest)
Now set it to 10 PSI and get some logs to make sure it works the way it should
For now i will not cover how it is operated and adjusted, i think there are plenty of how to's on that. And @Lex; is here to support you if you need any info
Buy your Guardian angel here: Stratified Automotive Controls
One tip to you all, BUY the Boost Dial as well! Amazing product!
Mazdaspeed6 -06
Tuned with by Alex@Stratified
CP-E Atmosphere Kit GTX3076 Tial 0.82AR / EWG / 3,25" MAF / Catless DP
Simons 3" Catback CP-E Diff Mount HDI FMIC HTP Battery Relocation
Corksport: Rear Brace Bar - Front Strut Bar - Stubby Antenna - Interior + Underhood LED Kit
JBR: TMM+PMM+RMM - Short Shift Kit /w Bushings - TIG Throttle - Coolant Bypass - EGR Delete - JBR OCC Stage 2
Whiteline Rear Swaybar SPC Camber Joints Turbosmart BPV Autotech Internals SURE Juggernaught Stratified Guardian Angel & Boost Dial NGK IX @ 0.025
Bosch 3 bar MAP w/ PNP Harness Block8Head Dual Gauge Pod Defi Racer Boost & Oil Pressure & Oil Temp
Techna-Fit Clutch Line + Brake Lines ATE Super Blue Racing ProSport Oil Filter Adapter Mazda Spin-On Conversion + NPT/BSPT adapter
Not installed yet: SP63 longblock, FreekTune 4" Intake, JBR TIG IM, DM Meth Spacer
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
SpeedRebirth is offline   Reply With Quote
The Following 8 Users Say Thank You to SpeedRebirth For This Useful Post:
bigspender (07-02-2014), Caligula (04-01-2013), Code Monkey (03-08-2013), dsmguy (10-22-2013), dynamix (03-09-2013), Jh8909 (03-08-2013), Lex (05-06-2013), LilGator (06-01-2013)
 Old 10-09-2014, 09:21 PM   #2
Taheny's Avatar
Posts: 46   (View Stats)
Taheny is a splendid one to beholdTaheny is a splendid one to beholdTaheny is a splendid one to beholdTaheny is a splendid one to beholdTaheny is a splendid one to beholdTaheny is a splendid one to behold
I am looking at your dashboard and I notice some serious differences from mine(US Market). I don't have that little pocket next to the airbag switch. nor the airbag switch. In fact my dash is molded different to seem like those weren't even supposed to be there. but I do have a dial to adjust headlight angle... no blank socket to drill either.
2006 VRM MS6 GT
FREEKTUNED 354HP/340TQ
/3.5" CUSTOM SRI/ /3.5" MAF HOUSING/ /COBB AP/ /AUTOTECHS/ /CUSTOM DOWNPIPE/ /JBR TRILOGY 80 DURO/ /JBR SHIFTER BUSHINGS/ /TR8 FMIC W. CUSTOM PIPES/ /CS FRONT & REAR TOWER BARS/ /GROM USB/ /DIY SUB EQ/ /VG SHARK FIN/ /CS LED KIT/ /SMOKED LENSES/ /CUSTOM FX-R PROJECTOR UPGRADE/
Taheny is offline   Reply With Quote
 Old 10-10-2014, 05:11 AM   #3
Groans: 33
There are a couple differences yes, and we don't have any GT or Sport packages here. No sunroof either.
If i did this install again i would put the LED light in a better spot, higher up. Because now i can't really see it when having my hands on the steeringwheel. I would probably put it somewhere around the left vent
Mazdaspeed6 -06
290 AWHP / K04
 Old 10-10-2014, 07:54 PM   #4
Taheny's Avatar
I don't have the nav so i was going to put it in the blank to the right of the dash cubby. i'll probably have to extend the wires though.
2006 VRM MS6 GT
Guardian Angel VTA...how? iammike 2010 MS3 - Engine, Transmission & Driveline 21 11-23-2012 12:41 AM
A Guardian Angel Looking Over Me...... Novej Stratified Automotive Controls 3 09-07-2012 05:22 PM
Guardian Angel help? MS6FL Mazdaspeed3/6 General Discussion 2 04-28-2012 07:13 PM
How-To Install Guardian Angel Dano Stratified Automotive Controls 5 03-31-2012 03:04 PM
Guardian Angel Install the_rolex_guy Stratified Automotive Controls 7 03-25-2012 06:03 AM
Page generated in 0.27559 seconds with 21 queries
