> MazdaSpeed 6 - How-To's
Like Tree11Likes
 Old 01-06-2016, 09:05 AM   #121
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,810   (View Stats)
The whine might not be coming from the T-case then.
Or may be you havent filled it up enough with gear oil.
 Old 02-01-2017, 03:31 PM   #122
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Sorry to revive but replacing my case with a CX7 unit this Saturday. Gathering the seals I want to change and think I might need to change the bearing in the intermediate shaft housing on the passenger side.
Put my car up on the rack a couple weeks ago to check things out before total failure of my PTO occured. I grabbed the inboard CV joint on the passenger side and was able to move it up and down and inch or so. The movement was not the joint, but rather the shaft going into the housing. The mechanic standing next to me said "oh, that's normal". The more I read and studied the parts diagram past two days the more I doubt what he stated.
Does anyone know if its normal to have movement at that junction of the splines on the two shafts? I feel like that connection point should be tight and solid. Am I correct? In attached picture movement occurs where you see the orange seal.
I may just order the bearing and dust shields just to have on hand this weekend. Fortunately my friends shop has a press if it comes to that.
I also wonder if that bearing is indeed failed...that perhaps it caused the complete failure of my stock PTO pinion gear losing teeth....
 Old 02-02-2017, 09:18 PM   #123
Boltz's Avatar
Posts: 19   (View Stats)
Boltz has disabled reputation
the CV axle hub with female spline that goes on the male spline shown in that picture can wiggle on the male spline, and may go in. out a little but i doubt an inch. It is held in by a spring clip so it wont slide off. as for how much it can wiggle I haven't had my hands on one in a while. My guess is once it is apart you will find the problem. The Male spline shaft should not push in or pull out, nor should it be able to be pushed up or down. That indicates bearing problems or shaft wear.
To change that bearing just under the male spline seen in the picture you best have a bering press and i believe snap ring pliers. You can inspect that shaft and bearing once it is out by spinning the shaft feeling for crunchy rotation. also check for shaft to bearing inner race wear. the shaft is pressed in the bearing and should not move on the shaft. However the aluminum outer case can be sloppy on the bearing outer race as it tends to wear since its more of a slip fit. If you hammer bearings on you need to do so only pushing on the inner race or you damage the bearing. Something like a pipe or hollow round bar stock.
Easiest is to just buy that assembly new.
Boltz is offline   Reply With Quote
 Old 02-03-2017, 06:25 PM   #124
Groans: 211
Thanks for the reply. I picked up the bearing and dust seal. Tools are a non-issue. I'll know if the bearing is shot tomorrow when I tear it out.
 Old 02-05-2017, 12:25 AM   #125
Groans: 211
Another CX7 case successfully installed. Turns out the bearing on the passenger intermediate shaft was indeed shot. Installed a new one. All good.
The best part? My car is quiet again. No more bearing whine. Stoked.
9 hours start to finish working mostly on my own and taking my time. Dropped the subframe which made it much easier. And having a lift :-)
 Old 03-11-2017, 10:15 PM   #126
Bonestockms6's Avatar
Posts: 7   (View Stats)
Bonestockms6 has a spectacular aura aboutBonestockms6 has a spectacular aura about
Thanks for all the great info here. don't need it yet but it's nice to have spare parts lined up
Bonestockms6 is offline   Reply With Quote
 Old 02-13-2018, 08:22 AM   #127
Eth Fiend
phate's Avatar
Posts: 6,945   (View Stats)
Updating for seal part number clarification. If you want to replace all 3 seals (recommended), this is what you need:
Big end of PTO input shaft: LN01-27-238
Small end of PTO input shaft: LN01-27-514
Passenger axle output: LN01-27-398
-06 MS6
-Corn fed 07 MS3 - Sold
Fi5H (02-13-2018), Thor Hammer (02-13-2018)
 Old 02-13-2018, 05:50 PM   #128
Fi5H's Avatar
Posts: 58   (View Stats)
Fi5H has much to be proud ofFi5H has much to be proud ofFi5H has much to be proud ofFi5H has much to be proud ofFi5H has much to be proud ofFi5H has much to be proud ofFi5H has much to be proud ofFi5H has much to be proud ofFi5H has much to be proud ofFi5H has much to be proud of
I didn't make this pic, I found it on Facebook but while we are updating the thread this has some good info.
2006 MPS6 Gray - GTX3071 turbo| 2XS turbo manifold| CPE 3” catted down pipe| Magna Flow 2.5” cat back| 2XS 3.5” one peace intake| HDI front mount intercooler| Turbo smart plumb back BOV| 3 bar map sensor| 3 port cobb boost solenoid| Auto Tech fuel pump| CPE injector seals| EGR delete (second and primary)| VTCS delete| JBR Thermal Insulating Gasket Intake Manifold| JBR Thermal Insulating Gasket Throttle Body| Throttle body coolant bypass| NGK LTR7IX-11 Spark Plug | Stretched coil pack springs| V3 Access Port.
98RON 350hp 361ftlb
Fi5H is offline   Reply With Quote
 Old 01-16-2019, 03:36 PM   #129
driver-wsh's Avatar
Posts: 18   (View Stats)
driver-wsh is a jewel in the roughdriver-wsh is a jewel in the roughdriver-wsh is a jewel in the roughdriver-wsh is a jewel in the rough
Originally Posted by aviator79 View Post
Must measure depth as if you press it all he way down to the step you will install too far. I measured mine at adepth = 13.4mm so that is what I aimed to install the new on at.
From 9999–95–A26M-07, MS6 Transaxle and Transfer Workshop Manual (A26MX-R, A26M-R):
Install depth for LN01-27-514 should be approx. 18.7-20.3mm (see attached image).
File Type: png MS6 Transfer Case Oil Seal Install Depths.png (88.1 KB, 13 views)
driver-wsh is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f111/how-make-cx7-transfer-case-fit-your-125736/
Olde Guy w 2007 MazdaSpeed6- new to this "Forum" / "Thread" media- have questions - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 02-26-2015 04:54 PM
Transfer case still leaking....need advice - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 10-01-2013 01:50 PM
transfer case ms6 This thread Refback 09-29-2013 08:27 AM
Has anyone rebuilt a PTO? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 12-19-2012 10:21 PM
Transfer case? titaniumspeed MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 05-14-2012 03:11 PM
transfer case pic 06speed MazdaSpeed 6 - Engine, Transmission & Driveline 9 01-11-2010 07:13 AM
Page generated in 0.31601 seconds with 27 queries
