> MazdaSpeed 6 - How-To's
Bookmark and Share LinkBack Thread Tools Display Modes
 Old 04-23-2009, 10:57 PM   #1
I AM THE STIG
MATT DAMOND's Avatar
Posts: 854   (View Stats)
Groans: 53
Activity Longevity
12/20 11/20
Today Posts
0/7 ssssss854
Default How-To: Mazdaspeed6 Replace Pads and Rotors
To begin, I decided to completely upgrade my brake system, considering that my car will do some track time this summer. If you are planning on doing all that I did, make sure that you have plenty of time, brake jobs can be very time consuming. If this is your first brake job, all I have to say is good luck and I hope that you find this how-to helpful. I’m ASE certified in brakes, and I’ve done a lot of brake jobs on many types of cars. If you are having any troubles or have some questions, shoot me a pm, I’d be glad to help.
Difficulty for just pad and rotor replacement = 5
Cost total = $400+
New parts! Thanks go to Mark at SU
Tools needed for just pad and rotor replacement + why?:
Jack + jack stands – lift car
21mm socket wrench/or impact gun – remove wheels
7mm hex head wrench – front caliper guide pins
17mm socket wrench – front caliper bracket
Needle nose pliers – front caliper retaining clip, depress rear caliper
pistons(the method I used)
C-clamp – depress front caliper pistons
14mm socket wrench – rear caliper guide pins, bracket, e-brake bracket
10mm brake wrench – rear caliper bleeder
9mm brake wrench – front caliper bleeder
Impact wrench with screwdriver bits – remove rotor screws. Note: If you can’t get these out use a power drill + various size bits to drill out the rotor screws.
Recommended supplies needed for just pad and rotor replacement + why?:
Brake-clean – to clean all friction mating surfaces
Caliper guide pin lube – self explanatory
Brake fluid DOT3 or DOT4 – you will want to bleed the brakes
A friend – to help bleed the brakes(these are hard to find. If no friends exist, buy a brake bleeder thingy)
A bolt – to push rotor off hub(I don’t know the type, but one of the brake line bracket bolts will work)
Rubber hammer – to free rotor from hub
Gloves – this is a very dirty job
Let’s get started! Pad and rotor replacement:
1. Jack up the car, find a good spot for the jack stands(I used the inner car frame), remove the wheels. Note: If you do not know how to support a car safely in the air, stop now and go to a mechanic.
2. Locate and remove the 2 hexbolt guide pins on the rear of the front calipers, you will have to remove the dust caps to access these.
3. Remove the metal spring clip thing.
4. Remove the caliper. Once it is off the hub, you can depress the piston; use the old pad for a flat clamping surface.
5. Remove the pads.
6. Clean the guide pin sleeves in the caliper with brake-clean and paper towels.
7. Locate and remove the 2 caliper bracket bolts, and remove the bracket.
8. Now here comes the fun part. In order to remove the rotor, these screws need to come out. Get the Impact ready. If they do not come out easily, get the drill ready to drill out the screw heads. You really don’t have to replace these screws, the wheel hold the rotor on just fine. With the screws off, remove the rotor. If it won’t come off itself, use a bold in the threaded rotor hole, and screw it in until the rotor brakes free.
9. With the rotor off, inspect and clean the rotor-hub-mating-surface of rust build-up.
10. Install new rotor
11. Install the caliper bracket, making sure the bolts are tight.
12. Place the outer pad on the bracket, and the inner pad into the caliper piston. Note with Hawk HPS pads I had to bend inward on the tabs to get the pad into the piston.(this is an example with the old pads)
13. Now place the caliper onto the bracket and line up the guide pin holes.
14. Clean the guide pins with brake-clean and paper towels.
15. Lube up the guide pins and insert them into the caliper sleeves. Once you have them pressed in, thread the pins into the bracket, and tighten them in. Do not over tighten! Put the dust caps back on.(this is an example with a socket)
16. Install the metal spring clip thing, front brakes are done!
17. Locate and remove this bolt that holds on the e-brake mechanism. Slide the e-brake
mechanism out of its bracket, and set it aside.
18. Remove the 2 caliper guide pin bolts, and remove the caliper.
19. Remove the pads, a flathead screwdriver can help with prying them from the retaining clips.
20. Locate and remove the caliper bracket bolts, and set the bracket aside
21. Remove the 2 rubber guide pin boots, clean the pins and lube them. Then insert them back into the caliper bracket.
22. Remove/Install rotor same as steps 8, 9, 10.
23. Install the caliper bracket, tighten the bolts.
24. Place the new pads in the retaining clips on the caliper bracket.
25. Depress the caliper piston. In order to do this, you have to turn the piston. I used some pliers on the notches in the piston. Turn slowly, so that the piston dust boot does not bind up, gently with your fingers turn the boot back and forth to keep it from binding/ripping. Get it in enough so that it barely fits over the new pads/rotor, then loosen it Ľ turn. Make sure that the notches are vertical/horizontal with the orientation of the caliper, so that it will go on the little stub on the pad.
26. Bolt the caliper on. Do not over tighten!
27. Slide the e-brake mechanism into its bracket. Install the bolt that holds on the e-brake mechanism.
28. Bleed the brakes, make sure everything is on right, and then use brake-clean to clean all friction mating surfaces.
29. Burnish in the pads. Hawk’s instructions are on the box. If you are using different pads do about four 50-30mph firm brake applications.
30. Celebrate, you are done!
Note: if you avoid the cleaning and lubrication of the guide pins as stated in steps 6, 14, 15, 21, you may be susceptible to un-even pad wear. If you avoid steps 28, 29 you could experience noisy brakes and glazed rotors.
Sorry for no how-to on painting the brakes, there are plenty of them out there.
additional info space:
Current cars:
2006 Mazdaspeed 6 GT DD/Track Toy
1986 Porsche 944 turbo LSD+M030 bits
I make OCC kits. For more info, PM me.
2010 EECMM Sponsor
MATT DAMOND is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!
The Following 23 Users Say Thank You to MATT DAMOND For This Useful Post:
6-Speed-6 (04-24-2009), AmillieMS6 (01-02-2010), atenza_freak (08-21-2009), djuosnteisn (12-27-2009), doubleflusher (06-08-2009), Ferdball (04-23-2009), Haltech (04-24-2009), long101 (03-12-2010), meelo88 (03-29-2010), Mistersix (11-14-2009), mouse0330 (08-15-2009), mr_mazda329 (02-01-2010), MS666 (05-11-2010), obylium (09-01-2009), opt_ms3 (04-24-2009), Qwik6 (05-04-2009), RayRayBauder (12-12-2009), retrobmx63 (05-01-2009), SgtP (08-14-2009), SLS MS3 (04-24-2009), speed23 (01-22-2010), tbot (02-25-2010), tunersteve (02-28-2010)
 Old 04-24-2009, 03:38 AM   #2
6-Speed-6's Avatar
Posts: 322   (View Stats)
6-Speed-6 has a reputation beyond repute6-Speed-6 has a reputation beyond repute6-Speed-6 has a reputation beyond repute6-Speed-6 has a reputation beyond repute6-Speed-6 has a reputation beyond repute6-Speed-6 has a reputation beyond repute6-Speed-6 has a reputation beyond repute6-Speed-6 has a reputation beyond repute6-Speed-6 has a reputation beyond repute6-Speed-6 has a reputation beyond repute6-Speed-6 has a reputation beyond repute
Activity Longevity
2/20 16/20
Today Posts
0/7 ssssss322
That is awesome man, great write-up. I have to do this in the next couple of months myself.
2007 MazdaSpeed 6
Low and Slow!
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
6-Speed-6 is offline
 Old 04-24-2009, 03:44 AM   #3
Gangster Member
serium's Avatar
Posts: 317   (View Stats)
serium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the worldserium is the leader of the world
Groaned at 32 Times in 10 Posts
Activity Longevity
1/20 12/20
Today Posts
0/7 ssssss317
very nice... im assuming probably the same concept for the speed3. Great write up!
2008.5 Red Mazdaspeed 3
Power Mods: Don't worry bout it!
Appearance Mods: 15% tint. Blacked-out emblems, side markers and side reflectors. Glowshift A-pillar with Prosport boost, a/f and voltage gauges.
serium is offline
 Old 04-24-2009, 07:20 AM   #4
smartass
SLS MS3's Avatar
Posts: 1,248   (View Stats)
SLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the world
Activity Longevity
1/20 20/20
Today Posts
1/7 sssss1248
Another good writeup
2007 Sunlight Silver MS3
Graphite RX8 Rims · 235/40R18 Kumho SPTs
BC Coilovers · Cobb Swaybars · DBA 4000 Slotted Rotors · Technafit SS Brake Lines · SU Rear MM · TRZ Trans Mount · TopSpeed Passenger MM
Cobb AP · MS CAI w/ AEM Straightener · Cobb Turbo Inlet · Cobb FMIC · Black HKS SSQV (recirc) · PG Exhaust Manifold · Corksport Downpipe · Vibrant Exhaust
mrlilguy CDFP · Denso ITV22s plugs · Cobb STS, Shift Knob, & Shifter Weight · F2 Balance Shaft Delete & Oil Baffle
SLS MS3 is offline
 Old 04-27-2009, 12:54 PM   #5
I<3Groceries's Avatar
Posts: 1,018   (View Stats)
Activity Longevity
8/20 13/20
Today Posts
3/7 sssss1018
Thanks for taking the time to do a write-up. This is a great help to the community.
Live a little, be a gypsy, get around. Get your feet up off the ground, live a little, get around.
I<3Groceries is online now
 Old 05-15-2009, 01:22 PM   #6
spdfrk's Avatar
Posts: 61   (View Stats)
spdfrk will become famous soon enoughspdfrk will become famous soon enough
Activity Longevity
0/20 16/20
Today Posts
0/7 sssssss61
Default !
spdfrk is offline
 Old 05-15-2009, 01:36 PM   #7
cm-jp1's Avatar
Posts: 151   (View Stats)
cm-jp1 is a name known to allcm-jp1 is a name known to allcm-jp1 is a name known to allcm-jp1 is a name known to allcm-jp1 is a name known to allcm-jp1 is a name known to all
Activity Longevity
4/20 13/20
Today Posts
1/7 ssssss151
I really dont want to take the time to do this. But i also dont want to spend 300 dolalrs for mazda to do it...Hmmmmm .decisions. decisions.
cm-jp1 is offline
 Old 06-05-2009, 12:19 PM   #8
Anti-Jihad
RUMBLEFISH's Avatar
Posts: 622   (View Stats)
RUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the worldRUMBLEFISH is the leader of the world
Groans: 32
Groaned at 7 Times in 4 Posts
Activity Longevity
3/20 19/20
Today Posts
0/7 ssssss622
I have a question for you. Iwill be doing my front pads in the next few weeks. I have no shimmy in the front so do I still need to cut the rotors or could I just scuff them up good with the die grinder to get off any edges that appear and hit them with a da sander then install the pads? I keep cars for a long time and dont want to buy rotors 3 years from now. Or maybe Im just fooling myself but want to ask you because you know a hell of a lot better then me.
Thanks
CPE-NANO-Forge BPV-TRZ dog bone-Spin on filter conversion-Hella Horns-Hids-CS racepipe-Tubo inlet pipe-Dashawk-Rally Flaps--Dont make fun of them. TBC and Map clamp in box for fear of blowing up.
NOT GOD DAMN AMERICA BUT GOD BLESS AMERICA!
Im pushing 400hp---well the boat is anyways.
RUMBLEFISH is offline
 Old 06-05-2009, 09:42 PM   #9
I AM THE STIG
Groans: 53
Activity Longevity
12/20 11/20
Today Posts
0/7 ssssss854
Thanks
Make sure you measure the thickness of the rotors, to see if they're in specs. But yeah, using little sanding pads+die grinder, put a swirl finish on the rotors, clean off all the left over metal dust with brakelean, and you should be fine.
Current cars:
2010 EECMM Sponsor
 Old 08-10-2009, 08:17 PM   #10
cohjus55's Avatar
Posts: 31   (View Stats)
cohjus55 is a jewel in the roughcohjus55 is a jewel in the roughcohjus55 is a jewel in the roughcohjus55 is a jewel in the rough
Activity Longevity
0/20 9/20
Today Posts
0/7 sssssss31
Cut or replace, Doing it by hand can cause some pulse in the pedal if you take a little to much off. In my personal experience's in customer cars as well as my own. Pads also make some funny noises and create alot of dust for a very long time if you just pad slap. Lots of life is also taken out of the pad if the rotors are grooved pretty good as they try to wear match. Most part stores can cut rotors for you at like 10 bux a pop.
cohjus55 is offline
 Old 08-14-2009, 05:59 AM   #11
s.gaspar's Avatar
Posts: 11   (View Stats)
s.gaspar will become famous soon enough
Activity Longevity
0/20 11/20
Today Posts
0/7 sssssss11
great write up i'll be using this once i do my speed6 upgrade, thanks
s.gaspar is offline
 Old 08-14-2009, 06:12 AM   #12
MSF &gt; M247
SgtP's Avatar
Posts: 1,655   (View Stats)
Groans: 91
Activity Longevity
0/20 20/20
Today Posts
0/7 sssss1655
awesome write up!
13.2@111
Sponsored By:
SgtP is offline
 Old 08-15-2009, 07:32 PM   #13
sleeperstang1994's Avatar
Posts: 493   (View Stats)
sleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the worldsleeperstang1994 is the leader of the world
Groaned at 7 Times in 5 Posts
Activity Longevity
1/20 14/20
Today Posts
0/7 ssssss493
lol at the avatar that shows the mater auto tech. congrats anyway. im pretty sure there are plenty of mater techs on here though. me included
sleeperstang1994 is offline
 Old 08-15-2009, 07:36 PM   #14
Nator
lenny127's Avatar
lenny127 is the leader of the worldlenny127 is the leader of the worldlenny127 is the leader of the worldlenny127 is the leader of the worldlenny127 is the leader of the worldlenny127 is the leader of the worldlenny127 is the leader of the worldlenny127 is the leader of the worldlenny127 is the leader of the worldlenny127 is the leader of the worldlenny127 is the leader of the world
Groans: 164
Groaned at 212 Times in 165 Posts
Activity Longevity
18/20 19/20
Today Posts
5/7 sssss6995
nice job matt, if i may add. maybe i skipped it but first thing u should always do is remove the cap from the master cylinder...once u compress the calipers the fluid will rise and if u are full already one of two things will happen.
a) u wont be able to overcome the pressure needed to compress the calipers since the cap will hold
b) u will bust a line,cap or w/e
fluid unlike gases doesnt compress so dont forget to take the cap off.
_____________________________________________2007 SILVER MS3______________________________________________
NATOR FMIC // NATOR SRI // NATOR INLET // NATOR COLD AIR BOX // NATOR BPV (RED SPRING, 1 SHIM) // NATOR SHIFT COUNTERWEIGHT // NATOR CATTED DP // NATOR AP (RUNNING N.A.T.R. TUNE 20PSI) // NATOR'S OWN STAGE II METHANOL INJECTION 100% METH !! // NATOR 2 STEP COLDER PLUGS // NATOR TRACTION BARS (WITH NYLON INSERTS) // NATORZ DERLIN REAR MM // NATOR SILICONE RECIRC TUBE // NATOR COOLANT HOSE KIT // NATOR-PE FRONT TOW PLATE // NATORHAWK // NATOREX-MANI V3
lenny127 is online now
The Following 2 Users Say Thank You to lenny127 For This Useful Post:
MATT DAMOND (08-16-2009), mouse0330 (08-15-2009)
 Old 08-15-2009, 11:21 PM   #15
mouse0330's Avatar
Posts: 1,025   (View Stats)
mouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the worldmouse0330 is the leader of the world
Activity Longevity
2/20 16/20
Today Posts
0/7 sssss1025
heres another DIY for me, seems easy for a first timer like myself..lol
thanks Matt
mouse0330 is offline
 Old 08-16-2009, 11:38 AM   #16
I AM THE STIG
Groans: 53
Activity Longevity
12/20 11/20
Today Posts
0/7 ssssss854
Thanks Lenny, there's always little things I forget to add.
Another thing to add, is that if you have the M/C cap removed and you still cannot de-press the caliper piston, open the bleeder valve on the caliper a little bit, then push the piston in. If this is the case, there is likely some buildup of crud inside the caliper/lines, and I would recommend bleeding the system, in order to flush it all out.
thanks Matt
Glad I could help.
Current cars:
2010 EECMM Sponsor
 Old 08-16-2009, 08:00 PM   #17
marc15skate's Avatar
Posts: 5   (View Stats)
marc15skate will become famous soon enoughmarc15skate will become famous soon enough
Activity Longevity
0/20 8/20
Today Posts
0/7 ssssssss5
Great job!!!!
marc15skate is offline
 Old 08-21-2009, 12:55 PM   #18
atenza_freak's Avatar
Posts: 609   (View Stats)
atenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the worldatenza_freak is the leader of the world
Activity Longevity
3/20 8/20
Today Posts
0/7 ssssss609
i will use this now thank you
2010 ford focus
andy
atenza_freak is offline
 Old 08-22-2009, 02:03 PM   #19
BADFISH6's Avatar
Posts: 30   (View Stats)
BADFISH6 has a spectacular aura aboutBADFISH6 has a spectacular aura aboutBADFISH6 has a spectacular aura about
Activity Longevity
1/20 15/20
Today Posts
0/7 sssssss30
Nice write up. What kind of rotors are those?
BADFISH6 is offline
 Old 12-09-2009, 11:13 AM   #20
SCPAms6's Avatar
SCPAms6 is an unknown quantity at this point
Activity Longevity
0/20 6/20
Today Posts
0/7 ssssssss5
good write up, thank you!
SCPAms6 is offline
 Old 12-25-2009, 04:48 PM   #21
memin's Avatar
Posts: 373   (View Stats)
memin has a brilliant futurememin has a brilliant futurememin has a brilliant futurememin has a brilliant futurememin has a brilliant futurememin has a brilliant futurememin has a brilliant futurememin has a brilliant futurememin has a brilliant futurememin has a brilliant futurememin has a brilliant future
Groaned at 9 Times in 7 Posts
Activity Longevity
6/20 13/20
Today Posts
1/7 ssssss373
I will be replacing my front rotors soon, what type of rotor did you get?
memin is offline
 Old 01-02-2010, 08:14 AM   #22
chisss's Avatar
Posts: 49   (View Stats)
chisss has a spectacular aura aboutchisss has a spectacular aura aboutchisss has a spectacular aura about
Activity Longevity
0/20 20/20
Today Posts
0/7 sssssss49
Thank you for the instructions!
chisss is offline
 Old 02-25-2010, 02:54 AM   #23
kalonov's Avatar
kalonov will become famous soon enough
Activity Longevity
1/20 4/20
Today Posts
0/7 ssssssss5
Can you give some info on those rotors? Brand, $$$, link?
Thanks
kalonov is offline
 Old 02-25-2010, 06:25 AM   #24
jmgute's Avatar
Posts: 7   (View Stats)
jmgute is an unknown quantity at this point
Activity Longevity
0/20 4/20
Today Posts
0/7 ssssssss7
I have the same question as above ^^
I am trying to source front calipers and at the moment having a damn hard time find loaded calipers like the ones you have. Any help on this?
jmgute is offline
 Old 02-25-2010, 07:27 AM   #25
tbot's Avatar
Posts: 1,050   (View Stats)
tbot is the leader of the worldtbot is the leader of the worldtbot is the leader of the worldtbot is the leader of the worldtbot is the leader of the worldtbot is the leader of the worldtbot is the leader of the worldtbot is the leader of the worldtbot is the leader of the worldtbot is the leader of the worldtbot is the leader of the world
Activity Longevity
2/20 5/20
Today Posts
1/7 sssss1050
Ok, so first off, great write up! My questions tho are:
1: with the abs, when you compress the calipers, don't you have to release the bleeder valve so the fluid goes out there instead of back thru the system? I remember something about not doing that with ABS systems can cause problems?
2: Like others have mentioned, what rotors are those, and are those the Hawk HPS or HP+ pads?
Again, great write up and thanks!
But enjoy your ride, make it better and quicker and develop a don't give a damn attitude about what other people think. It's your money and its for your enjoyment, not "theirs."
tbot is offline
 Old 02-28-2010, 08:31 AM   #26
Coming soon...
tunersteve's Avatar
Posts: 735   (View Stats)
tunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the worldtunersteve is the leader of the world
Activity Longevity
5/20 14/20
Today Posts
1/7 ssssss735
Nice write-up Matt! I will most likely be doing a swap up to new rotors and pads (thinking StopTech slotted from Mark @ SU and Hawk HPS pads) this summer. Any experience in changing out the brake lines with SS ones? Do you suggest it, even if they're DOT certified?
I've done brakes a few times, but I'm sure there are a few things I can learn to make it easier.
2007 Mazdaspeed6 Sport | Liquid Platinum Metallic
Part-out coming soon...
tunersteve is online now
 Old 02-28-2010, 08:57 AM   #27
FORCED INDUCTION ONLY
meeker13's Avatar
Posts: 199   (View Stats)
meeker13 has a reputation beyond reputemeeker13 has a reputation beyond reputemeeker13 has a reputation beyond reputemeeker13 has a reputation beyond reputemeeker13 has a reputation beyond reputemeeker13 has a reputation beyond reputemeeker13 has a reputation beyond reputemeeker13 has a reputation beyond reputemeeker13 has a reputation beyond reputemeeker13 has a reputation beyond reputemeeker13 has a reputation beyond repute
Activity Longevity
7/20 5/20
Today Posts
3/7 ssssss199
Very nice write up...im bout do for brakes!
COBB AP | OEM BPV
NGK PLUGS | K&N SRI
JBARONE SSP / E4 KNOB
AWR RMM | F2 BSD
TURBINE TECH FMM |
KONIG ZERO 18X8 +40
EIBACH SPORTLINE SPRINGS
Used to be fast! Now rockin the K04 again!
meeker13 is offline
 Old 02-28-2010, 11:45 AM   #28
I AM THE STIG
Groans: 53
Activity Longevity
12/20 11/20
Today Posts
0/7 ssssss854
For all you folks that asked, those are Centric/Stop Tech plain surface rotors. I bought them from Mark at SU, so shoot him a call. I cannot remember the price, but it was a good deal for the package of all 4.
The pads are HPS's, all around, but I did switch the fronts to HP+'s after the how-to.
I bleed my brakes with a Motive pump bleeder. Bleeding the brakes on an ABS equipped vehicle, is the same procedure as a non-ABS car. Make sure to take the cap off of the master cylinder when you're depressing the calipers, to not pressurize the system, and make depressing the pistons easier. If you have a lot of fluid in the M/C, scoop some out, as to not cause an overflow of fluid.
Here Steve: How-To: Mazdaspeed6 Install Stainless Steel Lines
I love the SS lines, they firmed up the pedal a tiny bit, and I'm sure they helped when I tracked the car.
Current cars:
2010 EECMM Sponsor
The Following 2 Users Say Thank You to MATT DAMOND For This Useful Post:
mouse0330 (02-28-2010), tunersteve (02-28-2010)
 Old 05-09-2010, 02:43 PM   #29
Arinzeuno's Avatar
Arinzeuno has a little shameless behaviour in the past
Groaned at 12 Times in 4 Posts
Activity Longevity
0/20 6/20
Today Posts
0/7 sssssss11
d
Mercedes Benz E 320 TT
3.2L inline six with 392rwhp/406rwtq @ 12.6psi.
0-60: 3.8 sec (with sandbags)
0-100: 8.5 sec
1/4 mle: 12.2 @ 120 mph.
Top Speed: 171 (so far)
3400 lbs
I rep Michigan. Come see me.
Arinzeuno is offline
The Following User Says NO Thank You to Arinzeuno For This Un-useful Post:
MATT DAMOND (05-09-2010)
 Old 05-13-2010, 05:32 PM   #30
jaywo33's Avatar
Posts: 13   (View Stats)
jaywo33 is an unknown quantity at this point
Activity Longevity
0/20 13/20
Today Posts
0/7 sssssss13
NICE!! i was wondering why i striped the heads and broke 3 Philip head tips...
jaywo33 is offline
Thread Tools
Brake pads egbertnr MazdaSpeed 3/6 - Suspension & Brakes 13 05-04-2009 10:58 AM
rotors armarine04 MazdaSpeed 3/6 - Suspension & Brakes 7 03-30-2009 03:49 PM
Centric rotors/pads speed6frk MazdaSpeed 3/6 - Suspension & Brakes 11 02-19-2009 06:58 PM
Ordered Stoptech Rotors, Pads, SS Lines, Fluids.. Performance Racing MazdaSpeed 3/6 - Suspension & Brakes 10 04-02-2008 05:42 AM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.1
Advertisement System V2.6 By   Branden
©Copyright 2008 ; 2010 Cymru Internet Services LLC
Page generated in 0.97988 seconds with 131 queries
