> MazdaSpeed 6 - How-To's
Like Tree8Likes
  • 6 Post By SpeedRebirth
  • 1 Post By dereeek
  • 1 Post By SpeedRebirth
 Old 01-06-2014, 03:14 PM   #1
SpeedRebirth's Avatar
Posts: 685   (View Stats)
SpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the worldSpeedRebirth is the leader of the world
Groans: 33
Default How-To: Primary EGR Delete
Plan on installing big turbo in the future? Or just want more space for your wrenching moments? Then you might consider removing the EGR Valve!
If you already know how to remove turbo Intake and Battery, please proceed to Section 2.
Section 1: Battery & Intake removal
Section 2: EGR Valve removal and installation
Section 3: Alternative coolant hose
Section 4: Disable DTCs
Kozmic Primary EGR Delete. Buy it from edgeautosport: Primary EGR Delete
Use some sealing tape on the threads of the copper fitting to avoid leakage
Section 1: Battery and Intake removal
Here we can see where the EGR Valve is located, right behind the fuel pump.
To get access to it we'll need to remove the battery and intake.
Unhock MAF cable from MAF housing using a flat screwdriver
Remove SRI from turbo inlet (10mm)
Remove Bypass Valve Hose
Remove hose that connects inlet to valve cover
Disconnect turbo inlet from bracket (10mm)
Remove vacuum hose from inlet, then loosen the clamp that holds inlet to the turbo using 10mm socket and long extensions. Remove TIP!
Now you can proceed to removing the EGR Valve
Section 2: EGR Valve Removal
Remove the electrical connection on the egr unit, and then the black boost controler connection behind the egr.
This will free up alot of space and enables you to move the big harness out of the way.
Remove clamp and use a screw driver to push the hose out a little bit. Dont disconnect it yet!
Use a ratchet and a 10mm socket to get the first screw out. Put some rags under the egr unit to catch some of the coolant that will flow out when removing the hose in next step
Remove the hose from egr unit and quickly move to the next step
Get the 10mm socket onto the second bolt holding the egr unit
EGR removed!! The gasket has some tabs on the sides so it will most likely stay in place
Removing this lump of metal and plastic just made your car a little bit faster by saving some weight
Get the delete plate in place and use a 14mm socket to get it tight. Connect hose to the barbed fitting
The hose might be too short, as it was for me. If it is, go to Section 3 to make your own from the throttle body coolant hose.
This is how crocked my hose was, not good enought!
Look how much space we will have when installing a bigger turbo
This is a alternative way to get the coolant hose to correctly connect between egr plate and coolant hardline on turbo unless you have a different hose available.
This requires two caps to put on the nipples on the throttel body, you dont want dirt in there if you for some reason would reconnect the hoses later.
By using the coolant lines connected to the throttle body you get a longer hose to play with to avoid it from bending to much.
Start by removing the hoses that's connected to the throttle body and put caps on the nipples (these caps are from JBR's coolant bypass kit)
Remove the hose that was connected to the big aluminium coolant hardline. Looks like this. You will need to cut this to proper length when installing it onto the egr plate. I used the right side of it
Connect the other hose to the aluminium coolant hardline to make the coolant circulate
Here is my hose, there is still a bit of a fold in the line, but much better than before
The barbed fitting exapandes the hose a bit so i could not get the clip on. So i used it to make the hose round (hose was folding where the clip is in this picture)
I ziptied the hose on the egr fitting to make it snug!
You will get a CEL or two when the EGR Valve is disconnected.
They are: P0403 and P0401
Use Accessport or Versatuner to delete them!
In VT you go here: Home > Settings > "Edit Tune Customizer Profile" > Disabling DTCs > Advanced
Congratz! You are done! Finished! Fatto! Klar! Completar!
Mazdaspeed6 -06
Tuned with by Alex@Stratified
CP-E Atmosphere Kit GTX3076 Tial 0.82AR / EWG / 3,25" MAF / Catless DP
Simons 3" Catback CP-E Diff Mount HDI FMIC HTP Battery Relocation
Corksport: Rear Brace Bar - Front Strut Bar - Stubby Antenna - Interior + Underhood LED Kit
JBR: TMM+PMM+RMM - Short Shift Kit /w Bushings - TIG Throttle - Coolant Bypass - EGR Delete - JBR OCC Stage 2
Whiteline Rear Swaybar SPC Camber Joints Turbosmart BPV Autotech Internals SURE Juggernaught Stratified Guardian Angel & Boost Dial NGK IX @ 0.025
Bosch 3 bar MAP w/ PNP Harness Block8Head Dual Gauge Pod Defi Racer Boost & Oil Pressure & Oil Temp
Techna-Fit Clutch Line + Brake Lines ATE Super Blue Racing ProSport Oil Filter Adapter Mazda Spin-On Conversion + NPT/BSPT adapter
Not installed yet: SP63 longblock, FreekTune 4" Intake, JBR TIG IM, DM Meth Spacer
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
SpeedRebirth is offline   Reply With Quote
The Following 30 Users Say Thank You to SpeedRebirth For This Useful Post:
Addikted To Boost (04-05-2015), Agent_Orange (01-12-2014), almcbs (02-27-2014), Amnesiac (01-06-2014), Bill6639 (10-07-2014), bioevolve (03-23-2014), brandon3212 (08-12-2015), budeny (03-08-2016), ButtholeRedMS3 (01-04-2015), darkstar5440 (01-14-2014), davros (04-10-2015), ELKhunter (03-23-2015), Fonsi (02-26-2015), ibcrusn (01-12-2014), Karmat (01-06-2014), kpuser1 (08-19-2014), kritz (01-12-2014), k_kid (07-12-2018), Lbspeed (07-03-2014), Mauro_Penguin (01-14-2014), mituc (01-06-2014), Mr Wilson (03-06-2014), ms6_604 (02-03-2016), Murcielago311 (03-07-2014), NoRegrets (03-06-2014), simply_pandora (10-11-2014), thepatient77 (03-26-2015), TiGraySpeed6 (01-08-2014), torquemaniac (09-17-2014), trekkie1031 (10-21-2014)
 Old 01-06-2014, 08:45 PM   #2
Karmat's Avatar
Posts: 1,179   (View Stats)
Karmat is the leader of the worldKarmat is the leader of the worldKarmat is the leader of the worldKarmat is the leader of the worldKarmat is the leader of the worldKarmat is the leader of the worldKarmat is the leader of the worldKarmat is the leader of the worldKarmat is the leader of the worldKarmat is the leader of the worldKarmat is the leader of the world
Nice detailed write up!
2007 Mazdaspeed 6 (Velocity Red)
2002 Corvette Z06 (Black)
2001 Mazda Millenia S (Brilliant Black) - GONE
Karmat is offline   Reply With Quote
 Old 01-06-2014, 08:59 PM   #3
dereeek's Avatar
Posts: 2,053   (View Stats)
dereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the world
Groans: 386
nice write up. I have this sitting in my garage right now.
How much coolant came out when you took the egr off?
Mr Wilson likes this.
BNR3-FREEK-PU-398HP
I lost track of the mods in my car.
dereeek is offline   Reply With Quote
 Old 01-06-2014, 10:15 PM   #4
Groans: 33
First 30secs there was not that much coming out, after that it started to flow a bit more. How much that is lost depends alot on how much time it takes you to get the hose onto the fittings. Took alot of time for me because i didnt have a solution for the bent hose until i came up with the throttlebody idea. In the meantime i put the original egr hose back o
Mazdaspeed6 -06
290 AWHP / K04
 Old 01-12-2014, 06:19 PM   #5
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
If you want to keep your throttle body hose you can stop at a local hardware store and pick up some high temp gas hose. It should work just fine and won't collapse like the stock one did.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
 Old 01-12-2014, 06:21 PM   #6
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,162   (View Stats)
Groans: 792
nice write up, but, is there a secondary egr we don't know about?
"Exclusivity" - CP-enis
Demodded.
The Seals
SpeedRebirth (01-12-2014)
 Old 01-12-2014, 06:24 PM   #7
Code Monkey's Avatar
Posts: 7,657   (View Stats)
"Secondary" EGR is the EGR pipe.
2006 Mazdaspeed6
stripped|caged|freektuned
2017 Subaru BRZ
 Old 01-12-2014, 06:36 PM   #8
Groans: 33
There are probably alot of other hoses out there that can do the job just as good or better.
Secondary is like monkey said, the hardpipe thats connected to the intake mani.
Secondary EGR Plug > Secondary EGR Plate > Primary EGR Plate
I belive its even possible to delete the aluminum thats bolted to the block, think i saw that i someones thread. But i think that included some welding and rerouting of the big coolant hose that goes to the radiator. May be a bit much =)
Mazdaspeed6 -06
290 AWHP / K04
 Old 01-12-2014, 06:39 PM   #9
Tokay444's Avatar
Groans: 792
ah.
Demodded.
The Seals
 Old 01-12-2014, 06:40 PM   #10
Posts: 7,290   (View Stats)
Nice write up and photoz.
Nator is what it does.
 Old 01-12-2014, 06:46 PM   #11
Tokay444's Avatar
Groans: 792
i like my egr.
Demodded.
The Seals
 Old 01-14-2014, 09:06 PM   #12
darkstar5440's Avatar
Posts: 477   (View Stats)
darkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the worlddarkstar5440 is the leader of the world
Groaned at 13 Times in 3 Posts
I just got one of these due to the way precision turbos fit, it is needed. Thanks for the write up!
OMWTFYB
darkstar5440 is offline   Reply With Quote
 Old 01-14-2014, 09:10 PM   #13
2012FailWheelDrive's Avatar
Posts: 327   (View Stats)
2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world
Are you blocking off the coolant ports or are you mating them together?
"under construction"
2012FailWheelDrive is offline   Reply With Quote
 Old 03-06-2014, 09:27 AM   #14
SilverMS307's Avatar
Posts: 298   (View Stats)
SilverMS307 has a reputation beyond reputeSilverMS307 has a reputation beyond reputeSilverMS307 has a reputation beyond reputeSilverMS307 has a reputation beyond reputeSilverMS307 has a reputation beyond reputeSilverMS307 has a reputation beyond reputeSilverMS307 has a reputation beyond reputeSilverMS307 has a reputation beyond reputeSilverMS307 has a reputation beyond reputeSilverMS307 has a reputation beyond reputeSilverMS307 has a reputation beyond repute
@SpeedRebirth; Did you have any problem with it leaking out the bottom after? I reused the gasket and it's still got a very small leak. I tightened the fuck out of the bolts too.
07 Sunlight Silver MS3 GT: JBR 3.5", CS Race Pipe, M2 DP, CNT Racing CBE, SURE Shortcut, Autotech Internals, Forge V1, Cobb AP, FREEK tuned, JBR 88a RMM, CXRacing FMIC w/ TR8 core, BNR S3, PG V2 Exhaust Manifold, and Devil's Own DVC-30 Stage 2 w/ 100% meth.
Best 1/4 mile: 12.18 @ 115.48
06 Speed 6 GT, rescued from a vented block. Pu motor, Fujita CAI, Autotech Internals, RMM, ATP Catted DP, GHL Catback, AP, FREEK OTS+ in progress
SilverMS307 is offline   Reply With Quote
 Old 03-06-2014, 09:31 AM   #15
It's still questionable I've seen faggots put all the Saleen shit on gt's
OMWTFYB
 Old 03-06-2014, 09:56 AM   #16
Groans: 33
Its leaking coolant?
I have not seen any coolant leak. But my AFR's are very rich but that looks to be the BPV gasket. So i dont think i have any leak at the EGR unit.
I just bought a papergasket that will allow me to make my own gaskets. But the egr gasket need to be of a different material to withstand coolant and exhaust gases. If you find a good material, its pretty easy to make a gasket
Just bought the new Atmosphere turbo kit so we'll see if it everything stays leakfree
Mazdaspeed6 -06
290 AWHP / K04
 Old 03-06-2014, 10:12 AM   #17
Yeah it might be excess leaking for now. I'll just keep an eye on it for the next few days. When are you putting that kit on?
 Old 03-06-2014, 10:15 AM   #18
Groans: 33
Just payed for it, and i live on the other side of the atlantic so it might be a few months hehe.
Mazdaspeed6 -06
290 AWHP / K04
 Old 03-23-2014, 01:01 PM   #19
BJSpeed3's Avatar
Posts: 81   (View Stats)
BJSpeed3 has much to be proud ofBJSpeed3 has much to be proud ofBJSpeed3 has much to be proud ofBJSpeed3 has much to be proud ofBJSpeed3 has much to be proud ofBJSpeed3 has much to be proud ofBJSpeed3 has much to be proud ofBJSpeed3 has much to be proud ofBJSpeed3 has much to be proud of
Talking
Great write up! Thank you for the help.
2010 Blue Mazdaspeed3
Hypnotic Tuned
SRI
DP
TP
SSP
BJSpeed3 is offline   Reply With Quote
The Following User Says Thank You to BJSpeed3 For This Useful Post:
SpeedRebirth (03-23-2014)
 Old 04-17-2014, 06:28 PM   #20
PapaBruno's Avatar
Posts: 940   (View Stats)
PapaBruno is the leader of the worldPapaBruno is the leader of the worldPapaBruno is the leader of the worldPapaBruno is the leader of the worldPapaBruno is the leader of the worldPapaBruno is the leader of the worldPapaBruno is the leader of the worldPapaBruno is the leader of the worldPapaBruno is the leader of the worldPapaBruno is the leader of the worldPapaBruno is the leader of the world
Excuse me, sir. Your images, they aren't loading.
2012 Crystal White Pearl MS3 - http://i.imgur.com/duln01Z.png
JBR 88 Durometer RMM, Autotech HPFP Internals, COBB Accessport V3, CS Hood Strut Kit, CS Underhood LED Kit, CS Eyelids (painted), BFG CS2s with JBR 5mm spacers, Password JDM Gurney Flap, FREEKTUNE e-Tune, Full Race FMIC, RÄZO RA138 Shift Knob, RÄZO 270mm Convex Rear View Mirror, Rally Armor Limited Ed. Flaps, JBR Stage 2 Short Shifter, NGK One Step Colder Plugs, Ultimate Racing: V3 Down Pipe (w/ Metal Substrate Core), Straight Test Pipe, and CBE, Go Fast Bits Respons TMS Blowoff Valve, CS Injector Seals, DM Stage 1 OCC + VTA, DM EGR Delete Kit, DM PMM, HTP 3.5" Intake, BNR S4, Grimmspeed EBCS, CS 3.5 Bar MAP, Prosport 52"mm Premium Evo Boost Gauge, RÄZO RP81 and RP85 Sports Competition Pedals
PapaBruno is offline   Reply With Quote
 Old 04-18-2014, 04:08 AM   #21
Groans: 33
Server error fixed!
Mazdaspeed6 -06
290 AWHP / K04
The Following User Says Thank You to SpeedRebirth For This Useful Post:
PapaBruno (04-18-2014)
 Old 05-05-2014, 05:59 PM   #22
Stealthvr4's Avatar
Posts: 84   (View Stats)
Stealthvr4 is a name known to allStealthvr4 is a name known to allStealthvr4 is a name known to allStealthvr4 is a name known to allStealthvr4 is a name known to allStealthvr4 is a name known to all
Great write up
Stealthvr4 is offline   Reply With Quote
 Old 03-26-2015, 06:38 AM   #23
Azspeed628's Avatar
Posts: 5   (View Stats)
Azspeed628 is an unknown quantity at this point
who makes your egr plate?
Azspeed628 is offline   Reply With Quote
 Old 03-26-2015, 06:59 AM   #24
Groans: 33
The primary plate is from Kozmic and the secondary is from JBR. Edge has them both
davros likes this.
Mazdaspeed6 -06
290 AWHP / K04
 Old 02-03-2016, 01:21 AM   #25
ms6_604's Avatar
Posts: 4   (View Stats)
ms6_604 will become famous soon enough
Default Hello
May I just say after a long day fiddling around, wrecked back and fucked up hands from all the twisting turning and unscrewing parts in epically tight spaces, it's finally done my EGR valve is clean as fuck, if that thing dares to throw an ECL I'm going to delete that thing like it never existed. Thank you for the thread and one who posted it, big respect!
Отправлено с моего iPhone используя Tapatalk
ms6_604 is offline   Reply With Quote
The Following User Says Thank You to ms6_604 For This Useful Post:
SpeedRebirth (02-03-2016)
 Old 04-09-2016, 04:15 PM   #26
matst's Avatar
Posts: 1   (View Stats)
matst will become famous soon enough
matst is offline   Reply With Quote
The Following User Says Thank You to matst For This Useful Post:
SpeedRebirth (04-09-2016)
 Old 01-11-2019, 06:34 PM   #27
rauce's Avatar
Posts: 9   (View Stats)
rauce can only hope to improve
Groaned at 5 Times in 2 Posts
rauce is offline   Reply With Quote
 Old 01-13-2019, 11:28 PM   #28
Jayzon's Avatar
Posts: 51   (View Stats)
Jayzon has disabled reputation
Amazing write up. Thank you!
Back to Stock
Jayzon is offline   Reply With Quote
 Old 01-28-2019, 03:26 PM   #29
rauce's Avatar
Thanks for the extremely thorough how-to!
 Old 02-08-2019, 10:39 PM   #30
hernandez1455's Avatar
hernandez1455 is an unknown quantity at this point
So I understand that with the ap one can delete the dtc but will the car pass emissions with the codes just deleted? And if it doesn’t does anyone make a resistor mod to trick the emu to thinking it’s on the car still?
hernandez1455 is offline   Reply With Quote
 Old 02-11-2019, 10:03 AM   #31
Jeff23spl's Avatar
Posts: 1,698   (View Stats)
Exactly like it was explained to you on your personal post, it just doesn't work this way....It is no longer an ecu that just look for a working load that can be simulated with a fixed resistor.
Removing a code with the AP just isolate it from triggering the CEL light. The emission test will remain incomplete for that part unless a working EGR valve is operating on the car for xxx driving conditions monitored.
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f111/how-primary-egr-delete-162147/
EGR block off ? Mazda MPS Owners Club This thread Refback 06-25-2015 07:59 AM
EGR Blanking plate. ? Mazda MPS Owners Club This thread Refback 06-16-2015 07:00 AM
EGR Blanking plate. ? Mazda MPS Owners Club This thread Refback 01-18-2015 03:36 AM
EGR Blanking plate. This thread Refback 05-12-2014 05:27 PM
Primary O2 Sensor MattJackson86 MazdaSpeed 3 - Engine, Transmission & Driveline 11 11-22-2012 08:47 AM
EGR delete/VCTS delete codes Speedie6 Mazdaspeed3/6 General Discussion 7 07-24-2009 10:22 AM
Cat delete vs resonator delete taf0422 MazdaSpeed 3 - Engine, Transmission & Driveline 7 04-08-2009 05:57 PM
Page generated in 0.47610 seconds with 39 queries
