> MazdaSpeed 6 - How-To's
Like Tree6Likes
 Old 07-29-2008, 04:44 PM   #1
SSinstaller's Avatar
Posts: 3,985   (View Stats)
Groans: 60
Default HOW TO: Remove MIL's caused by deleting the VTCS system
I used a dei 8616 relay, it's very small, and can be found for less than $10. Just about any 1~3 amp diode will work just fine..
Red Connects to green/black at the vacume solenoid(86)
Black Connects to black/red at the vacume soleniod(85)
Brown No connection(87)
Orange Connects to a wire at the plunger(87a)
Yellow Connects to a wire at the plunger (30)
It's basically a starter kill relay with the triggers connected to the vacume soleniod and the contacts connected the to the plunger(the polarity doesn't matter here, just cut the plug off the pluger and wire it up). I used a DEI 8616 relay(because it's small), and a diode I had laying around. You could probably just go down to a stereo shop and buy a starter kill relay, the wire colors might be different, but it will still work..
Wire it up and you can completly remove the VTCS solenoid, vacume reservoir and the plunger, and you wont throw any codes. Just make sure to plug the extra vacume ports.
ESB Jiu JItsu likes this.
The Following 14 Users Say Thank You to SSinstaller For This Useful Post:
ak_spray (01-03-2012), alphasaur (03-16-2014), anavrinIV (10-28-2012), Axspeed6 (09-03-2012), boost_me (08-06-2008), dadasracecar (07-29-2008), El_Diablo (10-30-2013), ESB Jiu JItsu (08-16-2012), FezMS6 (01-19-2009), SpeedSixxx (12-02-2009), Tomas (12-21-2011), Tres3 (12-28-2013), WetzMS3 (12-08-2014), wingcmdr (01-22-2019)
 Old 07-29-2008, 04:57 PM   #2
kingpin748's Avatar
Posts: 2,611   (View Stats)
kingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the world
Groans: 78
Groaned at 48 Times in 31 Posts
What's this for? You might as well put a explanation in here now, lots of people will ask.
In reality I love lenny
kingpin748 is offline   Reply With Quote
 Old 07-29-2008, 04:58 PM   #3
Grim's Avatar
Posts: 2,395   (View Stats)
Grim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the worldGrim is the leader of the world
did you read the title?
Black 2003 Evo VIII-3in TBE,HKS 280's,ETS Intake,Halman pro MBC,Forge BOV,Precision 6262,4" Intercooler,AEM Meth injection,Manely S&R's.4G63 FTW!
Grim is offline   Reply With Quote
 Old 07-29-2008, 05:26 PM   #4
Groans: 60
When you remove the complete VTCS system you can throw two codes..IIRC you will get P2006 VTCS shutter valve stuck closed, and you might get VTCS P2009 variable swirl soleniod valve control circuit low. The relays coil being wired in elimiates P2009, and the connections to the pluger mimic the action of the switch on the pluger getting rid of the P2006. The computer thinks everything is there so it doesn't throw any codes..
littleloogy (07-08-2018)
 Old 07-29-2008, 05:32 PM   #5
Grim's Avatar
does anything happen to your car like limp mode,or do you just have the annoying cel
 Old 07-29-2008, 05:37 PM   #6
Groans: 60
You just have the MIL..
 Old 07-29-2008, 05:45 PM   #7
ATE BALLER's Avatar
Posts: 3,227   (View Stats)
ATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the worldATE BALLER is the leader of the world
What plunger are you refering to, just to be clear?
Originally Posted by StreetUnitMark View Post
I don't think I could go one day without some sort of meat in my mouth.
ATE BALLER is offline   Reply With Quote
 Old 07-29-2008, 05:55 PM   #8
dadasracecar's Avatar
Posts: 741   (View Stats)
dadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the worlddadasracecar is the leader of the world
Groaned at 70 Times in 44 Posts
http://www.mazdaspeedforums.org/foru...w-project.html
2008 BMW 335i 6MT black on black
www.p3performance.net
dadasracecar is offline   Reply With Quote
 Old 07-29-2008, 06:40 PM   #9
Groans: 60
When the vacume canister moves the actual rod in the IM it has a tab that hits a little plunger type switch, it's how the ECM knows the VTCS system is working properly...
 Old 07-29-2008, 06:53 PM   #10
kingpin748's Avatar
Groans: 78
Screw you.
 Old 07-29-2008, 06:57 PM   #11
Grim's Avatar
Screw you.
lol i wasnt trying to be an ass if i came off that way,i was just asking cause the title pretty much explains what its for.
 Old 08-04-2008, 08:30 PM   #12
CraigHJr's Avatar
Posts: 676   (View Stats)
CraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the worldCraigHJr is the leader of the world
HAHA sorry to be picking your brain here but I was also checking the wiring for this trick on the Sped 3. Just to be clear the "vac solenoid" is on the black plastic box between the #2 and #3 runners. Then the "plunger" is the cylindrical thing under the gray plastic dohicky on the trans side of the intake manifold. The plunger has 2 wires and goes to a gray connector on the opposite side of the gray plastic do hicky. The 3's wire colors match what the 6 has on the vac solenoid so this write up should work on both cars then. I will try it before I take off the manifold and gut it just incase though.
MS6FL likes this.
CraigHJr is offline   Reply With Quote
 Old 08-04-2008, 11:13 PM   #13
ATE BALLER's Avatar
As long as the colors match the orientation on both cars, then yes it will work the same. That would suprize me, cause nothing else seems to match up easily between the two.
 Old 01-25-2009, 10:28 AM   #14
jhershorin's Avatar
Posts: 2,087   (View Stats)
jhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the worldjhershorin is the leader of the world
Groans: 31
Groaned at 86 Times in 65 Posts
So all i did was take the rod out and cut it off right before the plastic part that attaches to the ball socket that goes into the plunger. This way it all still works but there are no flaps. I am getting a p2006. wtf?
-JEWBERT
jhershorin is offline   Reply With Quote
 Old 01-25-2009, 10:57 AM   #15
how bout an option to delete the EGR code?
 Old 01-26-2009, 01:37 PM   #16
Groans: 60
That's the purpose of the relay, it tricks the ECM into thinking the flappers are still working.
That plunger needs to move when the VTCS is actuated, if it doesn't the ECM thinks the flaps are stuck...and throws the DTC P2006 (variable swirl shutter valve stuck closed).
I checked into this last year for whoosh.. The EGR has 4 differnt modes of operation, and must return the corresponding proper voltage change to the ECM when each is activated. The problem is that the EGR test is done by the computer using the dealer scan tool and the neither the service manual nor the electrical manual list the specific voltage changes that should occur. That's not a huge issue as long as you are willing to leave the EGR itself in place and connected. The real issue is that the ECM actually monitors the MAP to insure the EGR system is flowing enough exhaust--there is no mention in either service manual of the voltage change that should occur when the egr is active. Even if there was it would be overly complicated to simulate the 4 difffernt modes of the egr operation while not influencing the MAP output at other times--even the resistance of a simple relay could effect the map ouput during normal driving.
This is a problem that will need to be solved in the ECM itself. Luckily I've been talking back a forth with Jordan at CP-E about thsi for a while now and they are very close to being able to delete these specific MIl's from the ECM firmware...
 Old 02-24-2009, 05:34 PM   #17
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
worked for me, but i just used a cheapo relay. couldnt find a dei microrelay...
 Old 05-23-2009, 10:50 AM   #18
flz33's Avatar
Posts: 44   (View Stats)
flz33 is a jewel in the roughflz33 is a jewel in the roughflz33 is a jewel in the rough
Mind telling us exactly which relay you used? I cant get a hold of a DEI 8616 either..
flz33 is offline   Reply With Quote
 Old 06-18-2009, 01:37 PM   #19
Jarods7920's Avatar
Posts: 1,415   (View Stats)
Ok for those who dont have a DEI relay and dont speak in colors. Here is a break down of the wiring to a SPDT relay.
85 black/red at the vacume soleniod
86 green/black at the vacume solenoid
87 No connection
87a Connects to a wire at the plunger
30 Connects to a wire at the plunger
Jarods7920 is offline   Reply With Quote
 Old 08-10-2009, 12:57 PM   #20
Groans: 60
For those having trouble finding the DEI 8616.
http://www.amazon.com/gp/offer-listing/B000CJ05WW/ref=dp_olp_new?ie=UTF8&qid=1249930236&sr=8-1&condition=new
 Old 08-12-2009, 08:55 AM   #21
jkunze's Avatar
Posts: 45   (View Stats)
jkunze will become famous soon enoughjkunze will become famous soon enough
Has anyone come across a detailed HOW-TO document with pictures for a complete VTCS system delete? I've found pieces here and there, but nothing complete.
2006 Mazdaspeed 6
Cobb AP 2.0 with 1.01 stage 2 93 octane SF map
Cobb Turbo Inlet, Cobb SF Intake
ATP 3inch downpipe with metal spun High-Flo Cat
jkunze is offline   Reply With Quote
 Old 08-12-2009, 09:52 AM   #22
Groans: 60
Once the manifold is off it's easy to see what needs to be done, that's probably why there isn't a step by step how to. Just remove the actual flappers, and either leave the rod, or remove the rod completely and have the hole welded shut.
 Old 08-16-2009, 09:01 PM   #23
marc15skate's Avatar
Posts: 5   (View Stats)
marc15skate will become famous soon enoughmarc15skate will become famous soon enough
great discussion!!!!
marc15skate is offline   Reply With Quote
 Old 08-24-2009, 10:42 AM   #24
jkunze's Avatar
For those of you who have done the VTCS delete, have you experienced any cold weather issues or do you all live in the southern US?
2006 Mazdaspeed 6
 Old 08-24-2009, 10:49 AM   #25
Groans: 60
I'm in NC, and I've never had any issues. I don't see sub 0 temps or anything, but it gets down below freezing in the winter...
 Old 10-30-2013, 09:22 AM   #26
cbunn79's Avatar
Posts: 425   (View Stats)
cbunn79 is the leader of the worldcbunn79 is the leader of the worldcbunn79 is the leader of the worldcbunn79 is the leader of the worldcbunn79 is the leader of the worldcbunn79 is the leader of the worldcbunn79 is the leader of the worldcbunn79 is the leader of the worldcbunn79 is the leader of the worldcbunn79 is the leader of the worldcbunn79 is the leader of the world
@BigO; peep this.
cbunn79 is offline   Reply With Quote
The Following User Says Thank You to cbunn79 For This Useful Post:
jeopardy98 (10-06-2014)
 Old 12-08-2014, 12:29 PM   #27
blake0521's Avatar
Posts: 302   (View Stats)
blake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud of
I know this thread is older then old but none of the relays I could find have those color wires. They come with just black and grey. Any ideas? Would this one work? New Dei 8616 Mini Circuit Relay 20 10 Amp Prewired Directed 4 Car Alarm System | eBay
2010 Mazda Speed3-
Mods:
Cobb sri-Cobb tip-Cobb dp-Cobb bvp xle-Cobb ap v3-Cobb shift knob-AutoTech internals-JBR occ stage 2-JBR short shift plate-JBR solid shift bushings-JBR motor mounts (80 rear 70 side)-JBR TruTorsion 125 rear sway bar - JBR FMIC with crash bar and TR8 - Snow Performance meth kit with devils own fuel cell
Next up: tune.
blake0521 is offline   Reply With Quote
 Old 12-08-2014, 01:08 PM   #28
Mattyhawk1's Avatar
Posts: 739   (View Stats)
Mattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the world
You have an AP, why not just turn off the sensor?
VTCS Delete
Mattyhawk1 is offline   Reply With Quote
 Old 12-08-2014, 01:17 PM   #29
blake0521's Avatar
Because then I will be up to 4 not ready when I go in for testing. I am not sure if that test in my state only looks at emmsions items or the over all system. If it's the over all system I would fail the test big time which is why I want to solve it this way.
2010 Mazda Speed3-
Mods:
Next up: tune.
The Following User Says Thank You to blake0521 For This Useful Post:
davros (08-14-2015)
 Old 12-08-2014, 03:11 PM   #30
Mattyhawk1's Avatar
Don't see why the dei 8616 you link to would be different than the one the OP posted.
I assume you don't have a way or don't want to install the oem actuator?
 Old 12-08-2014, 03:33 PM   #31
blake0521's Avatar
I am going with a pnp mani so not vtcs.
2010 Mazda Speed3-
Mods:
Next up: tune.
 Old 12-08-2014, 03:50 PM   #32
Mattyhawk1's Avatar
Gotcha. Kinda figured as much.
 Old 12-08-2014, 08:28 PM   #33
Bill6639's Avatar
Posts: 4   (View Stats)
Bill6639 is a splendid one to beholdBill6639 is a splendid one to beholdBill6639 is a splendid one to beholdBill6639 is a splendid one to beholdBill6639 is a splendid one to beholdBill6639 is a splendid one to beholdBill6639 is a splendid one to behold
Thanks for the how to... I'm looking to delete my VTCS soon
06 Black Cherry Mica Mazdaspeed 6 GT
Stratified Stage 2 93 OTS Tune
JBR S2 Intake - JBR TRILOGY Mounts
JBR Shift Plate, Weight & Knob - CP-e HPFP
Ebay Test Pipe - AP V2b - UltraGauge
MISHIMOTO Retrofitted Projectors - 35W HID
CS2 STI Lip
Bill6639 is offline   Reply With Quote
 Old 12-31-2014, 09:39 AM   #34
kvg823's Avatar
Posts: 58   (View Stats)
kvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant future
Haha, I was just lazy and took out the rod, cut off everything past the first hole, put it back in there and wired it back up.
2006 "GTMO Green" Speed 6
{ Corksport TBE w/ resonator }{ COBB AP }{ Corksport Max-Flow internals }
{ TWM STS Stg 2 w/ bushings }{ Primary/Secondary EGR Deletes }{ JBR Motor Mount Trilogy}
{TurboSmart BPV }{ COBB TIP }{ SS Brake/Clutch Lines }{ ARP Head Studs }
HTP 4" intake w/ 51R }{ FMIC }{ Enkei PF01 Rims }{ Stoptech Slotted rotors }{ AEM Wide-band AFR gauge }
AEM TRU-Boost Controller }{ Gauge pod (Block8head) }{ Bnoon Bolt }
{ Turbo-timer (yeah...) }{ PERM Plate }{ JBR Intake/TB TIGs }
{ Coming Soon: install GT3071r EWG setup, CPE Seals, tune, and re-paint }
kvg823 is offline   Reply With Quote
The Following User Says Thank You to kvg823 For This Useful Post:
Tokay444 (12-31-2014)
 Old 12-31-2014, 01:11 PM   #35
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Same here. It has been fine for several years...
kvg823 likes this.
 Old 05-05-2015, 06:18 PM   #36
blam1's Avatar
Posts: 359   (View Stats)
blam1 is the leader of the worldblam1 is the leader of the worldblam1 is the leader of the worldblam1 is the leader of the worldblam1 is the leader of the worldblam1 is the leader of the worldblam1 is the leader of the worldblam1 is the leader of the worldblam1 is the leader of the worldblam1 is the leader of the worldblam1 is the leader of the world
Any pictures of what this looks like? The white plastic part broke near the plunger so I'll have to wire this in to eliminate cel and pass smog in Ca.
FYHN except Odyssey's. Ody's are bad-ass
1996 Acura Integra HB Sold
1998 Acura Integra GSR Sedan Sold
2008 Honda Pilot Sold
2006 Honda Accord Sold
2008 Honda Odyssey
2007 MS3 Silver Sport
Cobb AP SRI TIP // CNT DP // JBR SSP Bushings Knob RSB // CPE TMM // SU TMIC // AT INTERNALS // MD OCC RMM // NGK // Bilstein B8 // Swift Springs // Evo 9 wheels // SPC camber arms
Freek tuned 91 and 3 gal E85
blam1 is offline   Reply With Quote
 Old 06-05-2015, 10:29 AM   #37
SURGESPEED6's Avatar
Posts: 6   (View Stats)
SURGESPEED6 will become famous soon enough
Did you get it figured out? Any pictures?
SURGESPEED6 is offline   Reply With Quote
 Old 06-05-2015, 01:08 PM   #38
blam1's Avatar
I did figure it out. The part that confused me was on the plunger. The plunger has a green and a black wire. I don't remember which one I connected to which, but it worked and CEL went away. I can confirm tonight if you need me too.
2008 Honda Odyssey
 Old 06-07-2015, 10:49 PM   #39
If you could that would be great, that way I don't mess anything else up.
 Old 06-09-2015, 12:19 AM   #40
blam1's Avatar
It's ghetto looking. Don't judge.
Orange and Black
Yellow and Green
The other two are listed. Hope that helps.
2008 Honda Odyssey
The Following User Says Thank You to blam1 For This Useful Post:
Vader (06-09-2015)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f111/how-remove-mil-s-caused-deleting-vtcs-9150/
After VTCS Delete Code p2006 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-13-2015 11:38 PM
My list so far - Page 3 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 07-25-2014 12:39 PM
VVT Relay to get rid of Code - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 09-10-2012 12:33 PM
Intake butterflies This thread Refback 08-15-2012 08:55 AM
How to install new bumper protector to remove Front License Plate Holes. FastAttack MazdaSpeed 3 - How-To's 20 12-19-2014 01:19 PM
How-To remove O2 sensors without messing them up mazdaspeedjay MazdaSpeed 3 - How-To's 38 07-14-2009 08:02 AM
Interesting Thread on the Effects of Braking caused by Grippier Tires/Lighter Wheels Crossbow MazdaSpeed 3/6 - Suspension & Brakes 32 12-16-2008 10:33 PM
PTP's CAT back exhaust system, soon to be TBE system. ptperformance Mazdaspeed3/6 General Discussion 56 10-05-2008 02:08 PM
NVIDIA Drivers Caused Lions Share of Early Vista Crashes Haltech Computers & Technology News 0 03-26-2008 02:10 PM
Page generated in 0.58271 seconds with 41 queries
