![]() | | #1 | ![]() |
![]() Join Date: Nov 2011 Location: north jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
(Thread Starter) | Not Ranked : 0 score the seal from the dealer was only $6.50 part # A60117131 1. remove the air box for the intake (i'm all stock) and the battery, battery tray. under this rubber boot is the seal. will be fluid all over this area http://www.mazdaspeedforums.org/foru...1&d=1339612652 2. disconnect the clutch cables. i used needle nose pliers to pop off the top one the other is connected to a bracket on the plate that has to come off anyway so i just pulled out the two 12mm bolts holding it http://www.mazdaspeedforums.org/foru...1&d=1339613359 3. remove the motor mount. before you do this you must set the front on jack stands and support the engine from under with a floor jack to release tension on the motor mount bolt. (i'm on h&r's so i had to jack it from the side and slide a old rim with a box on top under the trans to support it.... had no jack stands). at that point remove the bolt going thru the chassis(on top in pic) 18 mm i think and be sure not to lose the nut on the back side of the mount. then the other bolt going into the trans http://www.mazdaspeedforums.org/foru...1&d=1339613359 2nd bolt going into trans, its under the clutch cables http://www.mazdaspeedforums.org/foru...1&d=1339613359 3rd bolt going into trans, and the nut from the chassis bolt that u already dropped into the engine bay. mount should come right off now http://www.mazdaspeedforums.org/foru...1&d=1339613359 4.pull the rest of the 12mm bolts out of the plate and break the seal holding it to the trans (i used a big flat head screw driver) 5. ok i'm not 100% sure this bolt had to come out but the shaft was fighting me to come out and seemed to come alot easier when i did. its located on the front of the trans and is lined up perfectly with the shaft. once it was out i was able to wiggle the shaft out (no homo) http://www.mazdaspeedforums.org/foru...1&d=1339613359 shaft out http://www.mazdaspeedforums.org/foru...1&d=1339613359 6. remove cotter pin, a punch is perfect if you have one. i dont so i used a t25 torx driver and a hammer to tap it out. http://www.mazdaspeedforums.org/foru...1&d=1339613359 7. once the pin is out slide it off. i think it only goes back on one way but be sur to keep an eye on how it came apart once thats off the plate slides right off, the seal is right on top. put on the new one and get her back together http://www.mazdaspeedforums.org/foru...1&d=1339613359 Edit: some have popped off the shifter cable and had a small clip left on the plate. be careful not to lose it and set it aside for reassemble. Also clean off the old sealant from the plate and trans and reseal with gasket sealant. Last edited by jrzy ms6; 03-04-2013 at 04:10 PM. |
| The Following 31 Users Say Thank You to jrzy ms6 For This Useful Post: | 6Y MAZDA (03-29-2013), 89T (08-03-2012), ak_spray (09-02-2012), Angr-E1 (08-04-2012), AtTheDriveIn (04-25-2013), BigjohnB20 (01-19-2013), Constantin (06-14-2012), Dahouse702 (05-14-2013), darkcherry (07-05-2012), DCYT (02-03-2013), Decepticon (09-03-2012), dexter_5000 (12-05-2012), Don06speed6 (06-13-2012), Easter Bunny (08-24-2012), grantmm (04-13-2013), himurax13 (04-22-2013), kritz (07-14-2012), leejustin80 (07-16-2012), MattJackson86 (11-10-2012), Mattsy (06-23-2012), MrPrime (01-26-2013), MSFer87 (06-21-2012), Neverlift (02-22-2013), phate (10-10-2012), PhillyCheese (02-04-2013), robertof (03-11-2013), SJP0tato (03-02-2013), speedysix (07-26-2012), TiGraySpeed6 (06-13-2012), Tomas (04-27-2013), TR4guy (09-12-2012) |
| lowspeed ![]() Join Date: Jun 2009 Location: Tally, FL
Rep Power: 1752 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,684
Nice, this was needed on MSF Raider, can add brownies write-up to the How-To MS6 list, snd probably to the MS3 list too?
__________________ Mazdaspeed6 GT #3476 TiGray slicktop Cobb AP, SRI & TIP, BNR S3, MAC 3 Port, FMIC, TS BPV, 3 BAR MAP, VTCS Delete M2 DP & Magnaflow, KMD Internals, GPWerks BSD & Baffle, SM OCC, EGR Delete, TB Coolant Bypass, SU Billet RMM TWM Stage II STS & JBR SSB, Prosport Mech Boost RX-8 wheels & 235/40 RE760, H&R Sport Springs, SPC abj's, Strapped diff Stage 1 Brakes: Slotted, Hawk’d, Lined & Blued 405/394 AWD - cf1.01 e38 BNRs3 315/372 AWD - cf1.01 e38 k04 |
| King Pimp/Scammer Hunter ![]() ![]() Join Date: Mar 2008 Location: Jacksonville, FL
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,821
Groans: 446
If OP goes VIP, I got MSF Bucks...
__________________ ![]() ![]() ![]() 1) Looking to Buy a used Mazdaspeed? Read this! 2) New member? Read this before posting (UPDATED 10/2012!!) as well as the welcome PM and email. Details are here. 3) Wanna buy and sell here? DONATE for VIP 4) For Sale Section Rules UPDATED 5-17-2013! Please read before posting! 5) Help MSF grow with FAQ threads!? |
| The Following User Says Thank You to Raider For This Useful Post: | rfinkle2 (02-21-2013) |
![]() | | #4 | ![]() |
| The Following User Says Thank You to jrzy ms6 For This Useful Post: | Raider (06-13-2012) |
![]() | | #5 | ![]() |
Groans: 446
PM me when you do. I'll make you rich!
![]() | | #6 | ![]() |
| Must Have Teh 10's! ![]() ![]() ![]() Join Date: Mar 2008 Location: Rockville, md
Rep Power: 9975 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,719
Groans: 98
Groaned at 122 Times in 91 Posts
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Web Cams w/Tomas Grind ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ Squash Performance In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust 510awhp/473awtq ~ 11.30@125.5 1.730 60' 3455 lbs WWW.SONICTUNING.COM Certified RichTune e-Tuner KILLAH BUILT by SPEED PERF6RMANC3 |
![]() | | #7 | ![]() |
| <span style="text-shadow:2px 2px 4px purple; "><span style="color:#6B6B6B; "><span style="text-shadow: 0px 0px 0.2em red, 0px 0px 0.2em red, 0px 0px 0.2em red; ">Axle Breaker</span></span></span> ![]() Join Date: Mar 2008 Location: Rio Rancho, NM
Rep Power: 3494 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,740
Groans: 152
Thank you. We just recently found an online diagram from Jim Ellis Mazda and were going to attempt this on my tranny I swapped out 2 weeks ago. We have 2 cars with this problem we need to work on. djuosnteisn spd6guy90
__________________ |
| The Following User Says Thank You to jmhinkle For This Useful Post: | rfinkle2 (02-21-2013) |
![]() | | #8 | ![]() |
![]() Join Date: May 2011 Location: Portage, IN
Rep Power: 454 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,102
Groans: 83
Just noticed this on my car like 2 day ago. Thanks for the write up guy.
__________________ -#1 2007 Mazdaspeed 3 GT Black Mica - BBS RX in Dark Gray, KW V2s, SPC Camber Arms, Cobb AccessPORT w/ JBR mount, Full-Race Prostock Mani, TurboXS FMIC, Grimmspeed EBC, ACT 6 puck & flywheel, TWM STS, PTP Internals, Cobb SRI w/ TIP, Cobb Shift Weight, TurboXS BPV, TurboXS Full TBE, JBR Trilogy, JBR RSB, Cobb FSB...........needs bigger turbo -1970 Chevelle - Needs full resto |
![]() | | #9 | ![]() |
Parts diagram & part number for seal matching first post
![]() | | #10 | ![]() |
Groans: 152
Wait, did you not actually replace the seal? The boot isn't the problem. There is a seal under the boot that needs replaced. Let me get the link up here in a second. He beat me to it, 17-131 is the seal that leaks with time. The boot isn't an actual seal just a dust cover. Official part number is A60117131 for the actual seal.
__________________ Last edited by jmhinkle; 06-14-2012 at 04:19 PM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to jmhinkle For This Useful Post: | BigjohnB20 (01-19-2013) |
![]() | | #11 | ![]() |
Yea the seal is under the boot. When tracing the leak it will lead you to the boot. Fluid pooled up on the plate also.
![]() | | #12 | ![]() |
![]() Join Date: Nov 2010 Location: Hudson, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7
Good stuff, definitely doing this soon on my car, been leaking for a while.
__________________ Matt 06 Mazdaspeed 6 - CP-E engine mount, Forge BPV, Sure Aeros, Sure Anchors, JBarone SS, HD Lip, Corksport CBE, Sure Dreadnaught, Sure Juggernaught |
![]() | | #13 | ![]() |
![]() Join Date: Oct 2011 Location: Beverly MA
Rep Power: 256 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 935
Been meaning to say thank you. Bought the seal a few weeks ago from mazda dealer. Going to do very soon.
__________________ mods: Do wmi 50/50, freek tune 306hp/350tq. blitz dd bov, cpe hpfp, cpe tmic, cpe excel nano sri, cpe tip, 3"ss corksport cat back exhaust, 3"ss m2 performance dp, Cobb AP, cpe blue duro rmm, sure short cut, counter weight, twm stage 1&2, ms cf shift knob, dashhawk, occ, front led side markers smoked, sp fuel door, autoexe rep lip, autoexe rear brace, whiteline rsb, tt rear diff mount, awr pmm , rear led smoked tails, led smoked rear reflectors, pc valve cover, tow plate lic plate, winter=stock wheels / summer=18x8 adr hyperblack wheels with bfg gforce kdw's, hid yellow fogs, eibach sportline springs soon to come: grimspeed tb, slotted rotors, cf fi hood |
![]() | | #14 | ![]() |
Here are some more pics to add to your how to if you want. Thank you. http://www.mazdaspeedforums.org/foru....php?p=1497274
![]() | | #15 | ![]() |
Listen up boys and girls... do the seal before it really pukes all over the place.. like mine did. Attached some photos of the mess (and in case anybody wants another perspective).
| The Following 2 Users Say Thank You to Mattsy For This Useful Post: | jrzy ms6 (08-24-2012), TiGraySpeed6 (07-14-2012) |
![]() | | #16 | ![]() |
Nice pics! Some odd looking sludge stuff in the last one. Wish you'd donate, these pics are worth reputation points!!
![]() | | #17 | ![]() |
Damn I did donate some time ago, I guess you need to do it every year. Will get on that soon.
__________________ Matt 06 Mazdaspeed 6 - CP-E engine mount, Forge BPV, Sure Aeros, Sure Anchors, JBarone SS, HD Lip, Corksport CBE, Sure Dreadnaught, Sure Juggernaught | |
![]() | | #18 | ![]() |
![]() Join Date: Jul 2011
Rep Power: 0 ![]() Thanks: 1
| The Following User Says Thank You to leejustin80 For This Useful Post: | jrzy ms6 (07-17-2012) |
![]() | | #19 | ![]() |
![]() Join Date: Nov 2010 Location: Moscow, Russia
Rep Power: 285 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 194
Groaned at 23 Times in 2 Posts
in case there is no OEM Mazda seal (p/n A601-17-131, USD 6.15) you can also use the same Toyota seal (p/n 9031118013, USD 5.34). It fits perfectly and cheaper that OEM Mazda part))
__________________ Mazda 6 MPS Velocity Red, cp-e nano, cp-e TIP, BNR Stg3, Custom FMIC, cp-e HPFP, HKS Twin Power DLI2 ignition, HKS M35LF spark plugs, EGR block-off, catless 3" dp with welded in resonator, AutoExe Grounding Earth System, Grimmspeed BCS, AWR competition radiator, JBR SSP, 355mm 4-piston JBT Big Brake Kit, Rays RE30 wheels, Advan v103 tires, etc.. |
| The Following 5 Users Say Thank You to paveltol For This Useful Post: | Masterofnone (08-25-2012), phate (10-10-2012), TiGraySpeed6 (07-16-2012), Tomas (04-27-2013), TR4guy (09-12-2012) |
![]() | | #20 | ![]() |
![]() | | #21 | ![]() |
![]() Join Date: Aug 2011 Location: Katterbach, Germany
Rep Power: 106 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 184
Ohhh hells yea, i was wondering what part was leaking right there exactly, gonna go get the parts and do this ASAP! Thanks for the write up man!
__________________ WARNING: This Mazdaspeed 6 is equipped with a GoPro Hero Camera. High Speed Filming May Be In progress. 2007 Mazdaspeed 6 Black ![]() Full Black Out 85% Complete DC Sports CAI/Muffler Delete/Test Pipe/ETS TMIC/Road Magnet Lowering Springs/Front Windows Tinted 15%/Rear Windows Tinted 5%/Blacked Out Emblems With Red Evil M/Shark Fin Antenna/6K Lows/AutoMeter Boost Gauge/Custom Red LED Interior Kit/ACT Performance Street Disk/ACT Heavy Duty Pressure Plate/ACT ProLite XACT Flywheel On Order ![]() Awaiting Install Nothing |
![]() | | #22 | ![]() |
![]() Join Date: Nov 2011 Location: Bluffdale, UT
Rep Power: 22 ![]() ![]() ![]() ![]() Thanks: 6
Thank you man, I unfortunately get to do this install today, as I just noticed I have the same issue!And of course the dealership wanted to charge me 9 hours of labor!
![]() | | #23 | ![]() |
![]() Join Date: May 2012 Location: Neustrassburg, Germany
So that orange seal, does that need to be replaced as well?
![]() | | #24 | ![]() |
![]() Join Date: Dec 2009 Location: Minneapolis, MN
Rep Power: 281 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,386
Hmmm. Noticed quite a bit more grimy/leakage crap around this area than usual while checking on something else the other day. Guess it looks like this should be addressed sooner rather than later. I know if I don't get to it before winter is isnlt getting done until next April. Thanks for the write up(s). Never would have thought to attempt to tackle this myself without it.
__________________ 2006 BCM MS6 GT CS SRI/TIP Jbarone SSP/bushings cp-e RMM, TMIC, Stiff Diff AP KMD V2.whatever Ebay Catless DP Grom Ipod |
| The Following User Says Thank You to BigjohnB20 For This Useful Post: | jrzy ms6 (08-24-2012) |
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score I used basic automotive silicone to seal it (thats all I had). Holding up fine but I think gasket sealant from a parts store would work just as good. just be carful not to use too much. When you bolt the plate back on it squeezes out the sides. dont think its good to have it doing that on the inside.
![]() | | #26 | ![]() |
![]() | | #27 | ![]() |
![]() Join Date: Nov 2011 Location: San Antonio, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 14
great write-up and just changed my fluids out and noticed my seal was bad. going to get this ordered asap and changed out.
![]() | | #28 | ![]() |
![]() Join Date: Apr 2012 Location: Ogden, utah
Rep Power: 0 ![]() ![]() Thanks: 0
| Not Ranked : 0 score When yours puked did it leave a large amount of fluid on the shield under the car? I came out to a pool of fluid under my 6 and i can't figure out where it came from. I have the fluid around the shifter pivot so I'm guessing thats what caused it.
__________________ 2006 Ms6 Black Mica, Fujita Cai, SU Turbosmart dualport bov "red," ETS Tmic, SU boost tubes, AP ots 1+ tune. |
![]() | | #29 | ![]() |
| Not Ranked : 0 score Yep.
![]() | | #30 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 6
Guys, you probably had a good look at the whole assembly while it was out. Which parts do you think are likely to casue this: "Mazda's do have some problems with the "gates" for lack of a better word.. as you pull the shifter down to go into a gear two things occur, a gate goes down and another gate moves left to right when switching from 2-3 4-5 or the other way around... however, when going straight down, the horizontal gate tends to get in the way of the vertical gate. It's directly on top of the transmission where this happens and the springs / gates tend to warp because of heat and obviously, the warmer the vehicle gets, the weaker the metal gets not allowing it to force it out of the way like it was cold." |
![]() | | #31 | ![]() |
Groans: 152
I think it's the forceful pressure from hard shifting wearing the seal is all. Not the largest or strongest seal I've seen.
![]() | | #32 | ![]() |
Surely that seal cannot be responsible for this: "when going straight down, the horizontal gate tends to get in the way of the vertical gate." Some of these parts physically moves these gates, don't they? |
![]() | | #33 | ![]() |
Groans: 152
That statement makes zero sense. Not sure what you are asking.
![]() | | #34 | ![]() |
Which parts from the below diagram should be replaced to eliminate this: "the horizontal gate tends to get in the way of the vertical gate; ... the springs / gates tend to warp because of heat and obviously, the warmer the vehicle gets, the weaker the metal gets not allowing it to force it out of the way like it was cold" |
![]() | | #35 | ![]() |
Groans: 152
__________________ | |
| The Following User Says Thank You to jmhinkle For This Useful Post: | jrzy ms6 (11-18-2012) |
![]() | | #36 | ![]() |
The quote is from here: Need some help bad - Dealership replaced turbo and now not shifting right - Page 3 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum These are the gates I assume: Last edited by Guthrie; 11-09-2012 at 04:11 AM. |
![]() | | #37 | ![]() |
![]() Join Date: Dec 2008 Location: Los Angeles, CA
Rep Power: 403 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 462
Thanks for the write up. Just found a puddle of transmission fluid under the car and traced it to the boot, it had popped off. Thought that would fix it but had no idea there was a seal that seems to go bad. Ill be using this to fix it correctly in the coming days. 93,000 miles btw. Kinda bummed I have to remove the mount, just installed a JBR a month ago.
__________________ Cobb AP - CP-E Xcel Nano - CP-E Turbo Inlet - CP-E FMIC - CP-E Catted Downpipe - CNT Catback Exhaust - HKS SSQV BPV - James Barone 88 Trilogy - KMD CDFP Internals - CP-E Injector Seals - Grimmspeed EBCS - ITV22 at .025 - 3 Bar MAP ![]() Torque for Mazdaspeed on Android Market! Gen2 now supported! Mazdaspeed MAP Harness - Bitwise Motorsports http://www.bitwise-motorsports.com |
![]() | | #38 | ![]() |
![]() Join Date: Mar 2011 Location: Minnesota
Rep Power: 201 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 144
You don't have to remove the mount completely. At least not on the speed 3. Not sure about the 6.
__________________ 2008.5 CWP MazdaSpeed 3: --Cobb SRI--Cobb TIH--Cobb AP--Cobb V2 Piping--Treadstone TR8 Core --Autotech HPFP Internals----Grimmspeed EBC--NGK LTR7IX-11--JBR SSP+Bushings-- --JBR Trilogy Mounts--JBR RSB--JBR AP mount--JBR 5mm Wheel Spacers-- --M3 Endlinks--KW V2--Advan RZ 18x8.5+45--Dunlop Star Spec 235/40-18-- --Corksport Camber Plates--SPC Camber Arms--MD OCC V1-- ![]() |
| The Following User Says Thank You to speed_freak91 For This Useful Post: | MattJackson86 (11-11-2012) |
![]() | | #39 | ![]() |
thought i'd post about this and this is mainly on the speed6. You dont have to remove the mount completely. All i did was remove the bolt and loosen the nuts the hold the mount to the transmission. After that i was able to get a 12mm wrench on the last bolt holdin the shaft assembl to the transmission and wiggle it out. It took a lil bit of time but in the end it saved alot of time. I still used a jack underneath just for support. One thing i will say to do that is necessary is take a picture when you remove the cotter pin and take the shaft assembly apart. I didnt do this and it caused alot of frustration on my part. Also once you go back to puttin the shaft back it it will tak some time to wiggle it back into place. This was one the time consuming parts out of everything.
| The Following User Says Thank You to dynamix For This Useful Post: | TiGraySpeed6 (12-08-2012) |
![]() | | #40 | ![]() |
![]() Join Date: Jan 2013 Location: OKC THUNDER
Rep Power: 0 ![]() ![]() Thanks: 1
Groaned at 29 Times in 9 Posts
| Neutral : +1 score on the blow out view If you look at 17-530 that is the breather If you look at 17-131 that is the seal we need to get to I went to the dealership yesterday and it costs me $6.63 for the seal (no wonder this o-ring is a butt hole..Pain in the butt LOL) Labor costs me $650, so I plan to do it myself. My MSP 6 is at 164,000 miles and running strong. However, this is the first time the trans. got leak. Engine is doing fine and has no leak. One thing though at 6th gear during gas pedal is pressing at the speed range of 60-80mph, my car vibrates and makes humming noise, if gas pedal is released no noise or vibration.. if i shift to fifth gear during the same speed range nothing happen. Why its only making humming noise and vibration at sixth gear within that range speed while gas pedal is pressing and not when i release the pedal? Any other gears are fine at any speed I have everything changed out to see if those caused vibration and humming noise. changed wheel bearing, tires, wheels,fluids why only at six gear of the 60-80mph range? By the way discounttires got me the run flat 225/40/18 michellin for only $136 with 55K miles warranty even when my tires got no air, I can't tell its flatted and able to run on it but not recommend LOL. If you get those make sure you look at it pressure often due to the car is not equipped with pressure monitors, well the side wall is so stiff when corner and I like it. I got Continental ExtremeContact DWS( these tires are good too) with 50k warranty. by 30k on it threads are down to 3/32 and i get $72 subtracted out of my new michellin tires ON Each so I saved $288 on the total. I just want to share to you guys. Any one is experiencing the same problem and has the solution to it? FOUND OUT JUST LAST WEEK (FEB. 15 2013) ABOUT THE VIBRATION AT 6 GEAR AT 60-80 MPH RANGE. 3RD ENGINGE MOUNT BOOST LEAKED OIL IN IT CAUSE VIBRATION AT CERTAIN SPEED. SOLUTION IS AN AFTER MARKET 70 GRADE PASSENGER ENGINE MOUNT. Last edited by vutpn; 02-20-2013 at 06:34 AM. Reason: more info. |
| I think it called a shifter pivot seal | nospeed | MazdaSpeed 6 - How-To's | 39 | 04-19-2013 11:51 AM |
| Shifter Pivot/Seal Fix? | Gru_Nuts | MazdaSpeed 6 - How-To's | 5 | 06-14-2012 12:17 AM |
| shifter pivot seal fluid | rgvms6 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 7 | 05-22-2012 04:09 PM |
| Help me Seal the Deal! | helmetface | MazdaSpeed 3/6 - Wheels & Tires | 17 | 03-08-2012 07:24 PM |
| Injector seal how to ?? | jracer | Mazdaspeed3/6 General Discussion | 1 | 11-26-2010 02:26 PM |
