![]() | | #1 | ![]() |
![]() Join Date: May 2011 Location: Indianapolis, IN
Rep Power: 101 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 90
(Thread Starter) | Not Ranked : 0 score To start gather the following parts: -Both axles from The Driveshaft Shop part #: RA6285L2 (Left/Driverside), RA6286L2 (Right/Passide) I found that THMotorsports had them pretty cheap mine shipped were $704.22 using discount codes found on the net -Differential seals from the Mazda or Ford Stealership part#: F003-27-238C about $10 Tools Needed: -1/2" and 3/8" drive Ratchets -10mm socket with driver -17mm Sockets in both drives -17mm open end wrench -mini sledge -1 1/4" impact Socket -Impact driver for above socket -Large Center Punch Steps 1) Remove both Rear tires 2) Set Parking brake 3) Remove Axle Nuts with Impact ![]() ![]() 4) With 10mm remove speed sensor cable bracket located front of the wheel well both sides. 5) Remove the bolts to the upper control arm, lower control arm, and what I would call the pan hard (fix if you know) ![]() ![]() ![]() 6) Now the axle is ready to be pulled out. Place Center Punch in the divit of the axle end and smack with the Mini Sledge untill axle comes out of spindle. Now to pull the axle out of the Differential grab the axle end you have and use it like a slide hammer. The axle should pop out if not then use pry bar and wedge it between the diff housing and axle and pry like hell! ![]() ![]() 7) The axles are ready to go back in go in reverse order and make sure you get the c-clip on the axles to click into place when pulling them into the differential. Also note that the caliper will need you to turn the piston back in which is where the needle nose pliers come in handy. Thank you
__________________ 2006 MS6: STOCK 1988.5 Suzuki Samurai built with lockers, lower gears, cam, header, 4w disk, and 33" rubbers 1986 Suzuki Samurai stock with bigger engine Last edited by CruZ_MS6; 03-10-2013 at 04:54 PM. Reason: No brakes, shocks, and speed sensor cable bracket |
| The Following 16 Users Say Thank You to CruZ_MS6 For This Useful Post: | 6ixof1 (11-01-2012), BigjohnB20 (02-08-2012), Black Metal (09-08-2012), Docnox (02-08-2012), Don06speed6 (02-08-2012), JMEngineer (02-27-2012), karl-hungus (02-08-2012), Karmat (02-12-2012), meelo88 (04-01-2013), Mistersix (04-17-2012), MS6FL (02-10-2012), phate (10-19-2012), Raider (02-08-2012), RichieRichness (07-02-2012), theschrum (10-18-2012), Tomas (10-19-2012) |
| Scammer Hunter ![]() ![]() Join Date: Mar 2008 Location: Jacksonville, FL
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,872
Groans: 449
$500,000 MSF Bucks sent for this thread!
__________________ ![]() ![]() ![]() 1) Looking to Buy a used Mazdaspeed? Read this! 2) New member? Read this before posting (UPDATED 10/2012!!) as well as the welcome PM and email. Details are here. 3) Wanna buy and sell here? DONATE for VIP 4) For Sale Section Rules UPDATED 5-17-2013! Please read before posting! 5) Help MSF grow with FAQ threads!? |
| The Following User Says Thank You to Raider For This Useful Post: | CruZ_MS6 (02-08-2012) |
![]() Join Date: Sep 2008 Location: CT/NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,363
Groans: 35
Nice writeup, that actually doesn't look that bad. Now no one will have an excuse not to launch the tits outta their car at the track.
__________________ ---------------------------------------------------------------------------- '06 Speed 6 Black MicaMazdaspeed SRI, Medieval inlet, Eibach Springs, Magnaflow cbe, 3 ebay catless dp, SU rmm, HKS ssqv, JBR stage 2 ssp Altered Customs fmic, Autotech fp internals Cobb AP, Stage 2+ 93 tweaked Centric blanks, EBC red pads Lotek center gauge pod: AEM wideband, Autometer boost and volts Tints, blacked emblems, spec-v front lip, Shark fin Redline MT-90, ITV-22s, Matt Damond OCC 13.66@102 Lebanon Valley 4/10/11 (sri, tp, rmm, ap) DO Meth kit waiting on install |
| The Following User Says Thank You to Docnox For This Useful Post: | CruZ_MS6 (02-08-2012) |
![]() | | #4 | ![]() |
![]() Join Date: Jul 2011 Location: Tamaqua, PA
Rep Power: 37 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groaned at 6 Times in 2 Posts
Just snapped my rear driver side axle the other day. I've been looking all over for a new one. I don't want to pay dealer price nor do I want to upgrade I just want own standards. Can you fill me in on where to get one? Maybe a price range? I've tried NAPA, advance auto and auto zone. They only carry the the fronts. Typo. Own=OEM. Btw very nice write up! It will help me tons!
__________________ Zoom zoom boom, snap, crackle, pop. Story of my life. Last edited by Mcklveen02; 02-28-2012 at 08:27 PM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to Mcklveen02 For This Useful Post: | CruZ_MS6 (03-07-2012) |
![]() | | #5 | ![]() |
![]() Join Date: Jan 2011 Location: Scranton, PA (Deployed to Kuwait)
Rep Power: 1269 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,561
Groans: 58
You can have them rebuilt. Rock Auto offers that service for $163 a side
__________________ Cobb AP(FREEK TUNED)/CS TBE/SURE AEROS/CPE TIH/ ITV 22/SU RMM/KMD INTERNALS/SURE DREADNAUGHT/JUGGERNAUGHT/WHITELINE RSB/SURE ANCHORS/SURE COUNTERWEIGHT/SURE SHORTCUT/JBR HEAVY KNOB/JBR EGR DELETE/SPC BALL JOINTS/CENTRIC BLANKS/HPS PADS/BNOON BOLT/ALTERED CUSTOMS FMIC/TURBO XS RFL |
![]() | | #6 | ![]() |
Thanks a lot, never heard of rock auto though. I searched google, looks like I'll have to ship it to them to do?
__________________ Zoom zoom boom, snap, crackle, pop. Story of my life. |
| The Following User Says Thank You to Mcklveen02 For This Useful Post: | CruZ_MS6 (03-10-2013) |
![]() | | #7 | ![]() |
Groans: 58
That I don't know. I would imagine you would ship to whoever is rebuilding them. They are a great site. Got my lower control arms from them, and I believe the spill valve is a direct replacement too!
![]() | | #8 | ![]() |
![]() Join Date: Sep 2011 Location: Birmingham AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
Cool deal thanks for the write up
| The Following User Says Thank You to Tenchix For This Useful Post: | CruZ_MS6 (03-07-2012) |
![]() | | #9 | ![]() |
Awesome man thanks a lot! I also see your from Scranton, I'm right below you in Tamaqua, let me know if there are ever meets or anything around the area!
![]() | | #10 | ![]() |
It's going to be cheaper to just do the upgrade. I put a used one in and that same week broke it. A rebuild takes to long and it's just going to brake again. Use the links and places I mentioned and do it once then forget it. If not 169 fixed then brake 169 fixed then brake Now you tore it down three times and wasted 600 and was down for almost a month. OR You can put the strong shit in your not stock application and be done with it.
__________________ 2006 MS6: STOCK 1988.5 Suzuki Samurai built with lockers, lower gears, cam, header, 4w disk, and 33" rubbers 1986 Suzuki Samurai stock with bigger engine |
| The Following User Says Thank You to CruZ_MS6 For This Useful Post: | Matx (03-19-2012) |
![]() | | #11 | ![]() |
| <span style="text-shadow:2px 2px 4px purple; "><span style="color:#6B6B6B; "><span style="text-shadow: 0px 0px 0.2em red, 0px 0px 0.2em red, 0px 0px 0.2em red; ">Axle Breaker</span></span></span> ![]() Join Date: Mar 2008 Location: Rio Rancho, NM
Rep Power: 3495 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,772
Groans: 152
Just to clarify, if your axle is already broken then you can't use the outer part like a slide hammer. My upper cv joint had disintegrated when I decided to be guinea pig for the DSS axle and it pulled out of the cup without much force. I had to use a real slide hammer to get the upper section out of the diff. A couple of other notes about replacing the axles. You are supposed to replace the seal in the diff each time you swap an axle and they are fairly cheap so no reason not to. Lastly, the C clip on the new axle is supposed to be installed with the opening at the top.
__________________ |
| The Following 6 Users Say Thank You to jmhinkle For This Useful Post: | bcmurphy87 (04-02-2012), CruZ_MS6 (03-10-2013), Don06speed6 (03-21-2012), LMB77 (11-18-2012), Mistersix (04-17-2012), superskaterxes (07-02-2012) |
![]() | | #12 | ![]() |
![]() Join Date: Aug 2008 Location: Pittsburgh, PA
Rep Power: 363 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 535
I found that the drivers side axle and throwing some grease around so its time for a new seal. Can someone elaborate on this "slide hammer" your talking about.
__________________ ![]() Cobb ap,sf,inlet//Custom fmic TR-8//Cp-e dp//3bar map//fp internals//Stratified GA//GFB respons//MD OCC//AWR mounts//TT diff mount//H&R springs//235's on RX-8's |
![]() | | #13 | ![]() |
Groans: 152
![]() | | #14 | ![]() |
Then use a screw driver to pry out the seal.
__________________ 2006 MS6: STOCK 1988.5 Suzuki Samurai built with lockers, lower gears, cam, header, 4w disk, and 33" rubbers 1986 Suzuki Samurai stock with bigger engine | |
| The Following User Says Thank You to CruZ_MS6 For This Useful Post: | Mistersix (04-18-2012) |
![]() | | #15 | ![]() |
| SPEED PERF6RMANC3 ![]() ![]() Join Date: Jun 2011 Location: Laurel, Maryland
Rep Power: 2076 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,164
Groans: 273
Groaned at 55 Times in 37 Posts
Good find on the cheaper DSS axles. Id also like to point out that removal of the break caliper is not needed. Just an extra step. Otherwise, great write up.
__________________ //KILLAH BUILT, SPEED PERF6RMANC3// Steedspeed T4 Twin Scroll // Precision 6265 Single 44mm Wastegate. KILLAH BUILT //FREEKPERM // Nuffsaid
| The Following User Says Thank You to Downmented For This Useful Post: | CruZ_MS6 (03-10-2013) |
![]() | | #16 | ![]() |
![]() Join Date: Apr 2009 Location: Cincinnati
Rep Power: 1884 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 987
Groans: 32
Groaned at 19 Times in 15 Posts
My right rear axle will NOT come out of the hub. The PB Blaster and torch did nothing at all. The full size sledge hammer did succeed in fucking up my hub and bearing so now I get to buy more parts but the axle still hasn't moved at all. I don't think working on a car has ever pissed me off like this.
__________________ "You don't know what fast is" "They tried to make me go to rehab. Now I'm dead" -Amy Winehouse |
![]() | | #17 | ![]() |
| Must Have Teh 10's! ![]() ![]() ![]() Join Date: Mar 2008 Location: Rockville, md
Rep Power: 9994 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,732
Groans: 98
i used a slide hammer to get the axle out of my hub
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Web Cams w/Tomas Grind ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ Squash Performance In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust 510awhp/473awtq ~ 11.30@125.5 1.730 60' 3455 lbs WWW.SONICTUNING.COM Certified RichTune e-Tuner KILLAH BUILT by SPEED PERF6RMANC3 |
| The Following User Says Thank You to superskaterxes For This Useful Post: | CruZ_MS6 (03-10-2013) |
![]() | | #18 | ![]() |
Groans: 152
Out of your hub as well? Out of the diff side definitely, but how did you do it on the hub?
__________________ | |
![]() | | #19 | ![]() |
Groans: 98
yea, my axle was in 2 pieces like yours so i used the slide hammer to PUSH the axle out of the hub instead of the way u would normally use a slide hammer to pull something out lol
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Web Cams w/Tomas Grind ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ Squash Performance In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust 510awhp/473awtq ~ 11.30@125.5 1.730 60' 3455 lbs WWW.SONICTUNING.COM Certified RichTune e-Tuner KILLAH BUILT by SPEED PERF6RMANC3 | |
![]() | | #20 | ![]() |
Groans: 152
That makes more sense.
![]() | | #21 | ![]() |
Groans: 32
I ended up pulling off the rest of the axle (separated the outer CV and cut the boot) and bolting the knuckle back in place so I could get more force on the stub axle with the hammer. The air hammer also did nothing last weekend. I'll keep trying the torch-PB blaster-air hammer combo until it works or until I decide to pay $800+ for a new knuckle just to be done with it.
__________________ "You don't know what fast is" "They tried to make me go to rehab. Now I'm dead" -Amy Winehouse | |
![]() | | #22 | ![]() |
![]() Join Date: Nov 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Thanks for this post, only my inner axle is in my differential, I had a guy trying to build a 400 hp axle for me but couldn't get it to work. My question is the seal that comes out of the.differential if that gets bent or damage would the.differential leak fluid? I am only speaking about the end of the seal that projects out of the.differential.
![]() | | #23 | ![]() |
![]() Join Date: Mar 2011 Location: Birmingham, Al
Rep Power: 146 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 202
I may be looking to do this. I don't quite have everything but think I can swing it. Anyone want to chime in on a difficulty scale 1-10?
__________________ 07 Liquid Plat Silver W/BNR S3 ~325/340 Pump gas self tune |
![]() | | #24 | ![]() |
Groans: 273
| Not Ranked : 0 score 5
| The Following User Says Thank You to Downmented For This Useful Post: | JDW1 (09-17-2012) |
![]() | | #25 | ![]() |
![]() Join Date: May 2012 Location: Akron, ohio
Rep Power: 0 ![]() Thanks: 2
thanks
__________________ 2007 Red MS6 AEM CAI, Custum exhaust, AP. 2005 Red Hyundai Tiburon SE V6 6MT, K&N CAI, Borla Full exhaust, Headers-Sold | |
![]() | | #26 | ![]() |
Groans: 152
The clip is holding the axle in place in the diff and the statement that the axle slides in and out of the diff for the suspension travel is completely wrong and actually quite assinine. The cv joints are were the play is. You push those all the way in and then attempt to yank hard and pop the clip in the diff. When that doesn't work or if one of your cv's is broken like mine you will need to resort to the slide hammer I posted.
| The Following User Says Thank You to jmhinkle For This Useful Post: | CruZ_MS6 (10-12-2012) |
![]() | | #27 | ![]() |
Ur so quik nice write up ![]()
![]() | | #28 | ![]() |
![]() | | #29 | ![]() |
Groans: 152
The slide hammer I have has different shaped ends. One would get behind the portion right at the diff. Sent from my DROID BIONIC using Tapatalk 2
![]() | | #30 | ![]() |
Not looking like autozone has anything. But then again I dont know exactly what I'm looking for. Any chance you could post a picture of your attachment?
__________________ 2007 Red MS6 AEM CAI, Custum exhaust, AP. 2005 Red Hyundai Tiburon SE V6 6MT, K&N CAI, Borla Full exhaust, Headers-Sold Last edited by mlamp89; 10-19-2012 at 06:55 AM. Reason: new info | |
![]() | | #31 | ![]() |
| Not Ranked : 0 score Not looking like autozone has anything. But then again I dont know exactly what I'm looking for. Any chance you could post a picture of your attachment?
![]() | | #32 | ![]() |
Groans: 98
you just need to put a pry bar between the diff and the cup of the axle. u need to pry like a mofo and make a jerking motion and it will come out.
| The Following 2 Users Say Thank You to superskaterxes For This Useful Post: | CruZ_MS6 (03-10-2013), RichieRichness (10-19-2012) |
![]() | | #33 | ![]() |
| Not Ranked : 0 score I'll give it another go. The problem is that its the rear passenger side, so the exhaust pipe is in the way. While I was prying, I was moving the diff around. So i didnt know if that was a bad thing. Maybe I can get someone to pull the axle while I pry.
![]() | | #34 | ![]() |
Groans: 98
pry away at that bitch, no fear!
![]() | | #35 | ![]() |
| Not Ranked : 0 score How about a picture of that? I just had someone pulling while I pryed. And no luck.
![]() | | #36 | ![]() |
Groans: 152
This should be what you are looking for.
| The Following User Says Thank You to jmhinkle For This Useful Post: | superskaterxes (10-29-2012) |
![]() | | #37 | ![]() |
| Not Ranked : 0 score Dang. Yea that would work. But I haven't found an attachment like that anywhere.
![]() | | #38 | ![]() |
Groans: 152
You can see in the pic mine came with all sorts of different attachments. I like it better than those kid that have fingers.
![]() | | #39 | ![]() |
| Not Ranked : 0 score did you get it at an autoparts store like autozone? or somewhere special?
![]() | | #40 | ![]() |
Groans: 152
My dad picked it up years ago from somewhere. Handed it down to me about 5 years ago as he doesn't do heavy car work anymore. It wasn't anything fancy though brand wise. Had to come from some sort of discount type store.
| rear badge removal | bowlburner | MazdaSpeed 3/6 - Appearance | 10 | 10-31-2011 09:24 AM |
| How to: CX-7 Rear Bumper Removal | Raider | CX-7 > How-To's | 3 | 02-28-2011 01:34 PM |
| Rear axle removal how to? | rob ms6gt | Mazdaspeed3/6 General Discussion | 3 | 01-17-2011 06:42 PM |
| Rear Bumper Removal ?? | damianinpa | MazdaSpeed 6 - How-To's | 1 | 12-16-2010 03:39 PM |
| Rear bench removal? | ridenfish39 | Exterior | 6 | 06-07-2010 07:44 PM |
