> MazdaSpeed 6 - How-To's
Like Tree3Likes
  • 2 Post By Navy_Mech2
  • 1 Post By Navy_Mech2
 Old 01-25-2015, 12:13 PM   #1
Navy_Mech2's Avatar
Posts: 484   (View Stats)
Navy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the worldNavy_Mech2 is the leader of the world
Default Navy's MS6 Bumper Fix
Hey guys. So after getting in on the group buy for the Quik Latches, I installed them this weekend onto my 6. I know @Raider; already did a write up for his 3, but since my situation was different, i figured i would do one for my car and for all the 6 guys just in case there are any notable differences between the two cars. Also hats off to Quik Latch for an awesome product. So on to the good stuff.
Equipment:
Drill w/ various bits
Step Drill bit that goes up to 3/4"
7/16" wrench
7/8" Deep socket
Masking tape (anything will work, but i wouldn't recommend duct tape)
Pliers (to "adjust" tab on the fender)
Dykes (to "shape" the plastic piece that holds the upper edge of the bumper) - Dremel would have been ideal but i don't own one
Optional:
Tobacco of your choice
Beer of your choice
NOTE: The only other piece of hardware i bought was 4 locking washers just to make sure the nuts that hold the posts wouldn't back off from vibration. $.09/per at ACE.
1. Remove bumper in whatever fashion is applicable to your car. (Multiple write-ups for this)
2. According to your issue, determine what part of your bumper needs reinforcement. For me, I ripped off the eyelet on the passenger side of the bumper where it meets the fender the first time i took the bumper off. I Had a temporary repair that lasted the better part of 2 1/2 years but when i saw these it was obvious that this is a more permanent solution.
[IMG][/IMG]
3. Select a suitable mounting location for the post. On my car, and since it was the upper ends of the bumper that needed the fix, i drilled holes in these convenient tabs on each of the fenders right behind the plastic things that help hold the bumper up.
[IMG][/IMG]
I also had to trim the plastic clip thingy so that the washers would sit flush against the tab on the fender. Since the new mounting point for the bumper is going to be much stronger, i wasn't really worried about taking off some of the material.
[IMG][/IMG]
[IMG][/IMG]
4. Determine where the receptacle for the post is going to be mounted on the bumper.
NOTE: This is the point of no return. Once you start drilling into the bumper, that's where the receptacle is going to go. If you screw up and drill the hole wrong, you're going to have to find another way to attach the post behind the bumper so that it will still fit into the receptacle. @Raider; used a nugget of clay bar on the end of his post and pressed the bumper against it to mark his drilling point. I used a rolled up piece of tape and it worked fine. Again measure twice, cut once is the name of the game here. I test fit this probably 5 times before i drilled so i could keep the receptacle off of the edge of the bumper that forms the lip of the fender.
5. Mask off the painted side of the bumper and drill a pilot hole from the back side of the bumper towards the front. Its plastic so you don't have to push hard, just let the bit cut through. If you push too hard, the bumper will flex and the bit could slip and punch a hole in the wrong spot.
[IMG][/IMG]
After the pilot hole, i used a 1/2" bit to enlarge it since my step drill bit starts at 1/2".
6. Use the step bit to drill a 3/4" hole in the bumper. Since my bit goes up to 1", i taped off the step bit at the 3/4" mark to make sure i didn't go to deep. Drill from the outside in and again, go slow and focus on keeping the drill straight so you don't end up with a crooked hole. Afterwards, pull off the tape and you should have a clean hole and the paint wont have cracked. If you take it slow, this shouldn't be a problem. I did mine in 30—° weather and didn't warm the paint up and mine came out fine on both sides.
7. Next, insert the receptacle into the hole in the bumper and tighten the backing nut (7/8"). Then, test fit the bumper back onto the car to see if your post will lock into the receptacle. Easiest way i found to do this was to keep the nuts on the posts loose and try and mate it that way. Once its locked in then you can tighten the nuts up. Also this is where i used the lock washers.
[IMG][/IMG]
8. Now, get your bumper flush with the rest of the car. I loosened or tightened the nut on the back side to pull the bumper in or move it out. Once i had it flush i hand tightened the nuts so the post wouldn't move, popped the bumper off and tightened the nuts down.
9. Put the bumper back on and have a victory beer.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Other notes, the pictures of the finished project show the bumper sticking out a bit from the fender. I took those pictures when i first put the bumper on and hadn't adjusted the posts. They fit flush now. Also, make sure your drill is charged before you start. I had to finish this morning because the drill took a shit on me last night.
Mauro_Penguin and ItsNox like this.
06 MS6 |SP Built motor - Weisco Pistons .020" over, Manley H-Beam Rods, Ported Head, Ported Intake, VTCS Delete, BS Delete, VVT Actuator, Keyed Crank, 6th Port Fuel Injection | ACT 6 Puck w/ Streetlite Flywheel | Bullseye S259 .70 A/R Single Scroll | 3.5" Intake/MAF Housing | Steedspeed Twin Scroll T3 Top Mount Manifold | Tubosmart 40mm EWG | Custom DP | Custom TBE | Custom LTA Intercooler | HKS Type IV TT | Dashhawk | COBB AP | AWR RMM | PTP HPFP Guts |
KILLAH BUILT
Navy_Mech2 is offline   Reply With Quote
The Following 16 Users Say Thank You to Navy_Mech2 For This Useful Post:
Addikted To Boost (06-04-2015), cletusb (01-31-2015), Code Monkey (01-25-2015), Dizzy Turbo (01-25-2015), Hargarbl (01-25-2015), jfspeed6 (01-26-2015), Lewis7789 (09-24-2015), Mauro_Penguin (01-25-2015), melly mel (06-19-2015), Micha (03-13-2015), msantana101 (02-25-2015), PapaBruno (08-25-2015), Raider (01-25-2015), speed3 britz (01-26-2015), SyntheticAtmosphere (02-15-2016), TiGraySpeed6 (01-25-2015)
 Old 01-25-2015, 12:38 PM   #2
Navy_Mech2's Avatar
Better pictures of hella flush bumper
:: Gusto :: likes this.
KILLAH BUILT
The Following 5 Users Say Thank You to Navy_Mech2 For This Useful Post:
Hargarbl (01-25-2015), Mauro_Penguin (01-25-2015), mxlplx71 (01-25-2015), Raider (01-25-2015), TiGraySpeed6 (01-25-2015)
 Old 01-25-2015, 12:49 PM   #3
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
Nice!!'
The Following 2 Users Say Thank You to Raider For This Useful Post:
Mauro_Penguin (01-25-2015), Navy_Mech2 (01-25-2015)
 Old 01-25-2015, 01:45 PM   #4
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Awesome, thanks for the great write-up!
340hp / 371tq
 Old 01-25-2015, 02:23 PM   #5
Navy_Mech2's Avatar
Not a problem. Came together well for my first how-to
Just added a picture I forgot about to step 6
KILLAH BUILT
Last edited by Navy_Mech2; 01-25-2015 at 02:23 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to Navy_Mech2 For This Useful Post:
 Old 01-25-2015, 03:58 PM   #6
ItsNox's Avatar
Posts: 3,076   (View Stats)
ItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the worldItsNox is the leader of the world
Thank you for this Navy!!!
Sent via Tapafail
'06 Mazdaspeed 6 GT
Power & Drivetrain BNR S3v2 / AP V3 + 100% Meth / Autotechs / JBR Tru 3.5" SRI w/ 51R Battery / ETS TMIC / DO Meth D07 @ 100% / ACT6 Puck w/ Streetlight FW / 80mm CorkSport Exhaust / SLS Test Pipe / Turbosmart BPV / Techna-Fit SS CL / AP Shift Hammer / Bosch 3Bar / Grimspeed EBCS / NGK 1 Step Colder / JBR Boost Tubes / ProSport Sammich Plate / Rotella
Suspension & Mounts KWv2 Fronts & Bilstein Rears / AIDS Rear Diff Mounts / Whiteline RSB / Prothane Lowpro Bushings / Steeda Endlinks / JBR 88RMM / JBR Solid Bushings
Brakes & Wheels StopTech Slotted Rotors & Pads / Technafit SS Brake Lines / Evo X Wheels / 245/40/18 Potenza RE760s
Misc Redline & Unicorn Jizz (XTM5QS) / Sharkfin Antenna / Kuda Mount of Sweetness / Full TRS Mini-H1 Retrofit w/ Demon Eyes / TRS Xb LED Fogs / Hardwired Valentine 1 w/ Bluetooth / AuxMod w/Bluetooth
- Miltuned
On order/To be installed: E-btec Built Motor , BNR S4, CPe EWG Exhaust Mani, Precision 46mm WG, Kozmic 6th Port, CS FSB, RDMotorsportz Crash Bar, CS Injector Seals.
Georgia Motherfucking Nator
Originally Posted by Ziggylittles View Post
I hate that you can sleep on suckas and then make rape with your family sedan
ItsNox is offline   Reply With Quote
The Following User Says Thank You to ItsNox For This Useful Post:
 Old 01-25-2015, 04:33 PM   #7
Mauro_Penguin's Avatar
Posts: 1,997   (View Stats)
Mauro_Penguin is the leader of the worldMauro_Penguin is the leader of the worldMauro_Penguin is the leader of the worldMauro_Penguin is the leader of the worldMauro_Penguin is the leader of the worldMauro_Penguin is the leader of the worldMauro_Penguin is the leader of the worldMauro_Penguin is the leader of the worldMauro_Penguin is the leader of the worldMauro_Penguin is the leader of the worldMauro_Penguin is the leader of the world
Groans: 171
Very nice! I have do mine on the Pu soon.
Do you gen1 and ms6 guys also get flex marks along the edge of the bumper where you installed the latch?
-Fearless vampire killers, banned in DC, how low can a punk get?
-Delray/Grieco Mazda or Direct Auto Body, ask me why you should NOT take your car to either.
-It is more fun to drive a slow car fast, than it is to drive a fast car slow
Mauro_Penguin is offline   Reply With Quote
 Old 01-25-2015, 08:25 PM   #8
Hargarbl's Avatar
Posts: 642   (View Stats)
Hargarbl is the leader of the worldHargarbl is the leader of the worldHargarbl is the leader of the worldHargarbl is the leader of the worldHargarbl is the leader of the worldHargarbl is the leader of the worldHargarbl is the leader of the worldHargarbl is the leader of the worldHargarbl is the leader of the worldHargarbl is the leader of the worldHargarbl is the leader of the world
Groans: 51
Very nicely done, I'm gonna have to do this on mine as my driver side pokes out.
2006 TITANIUM GREY METALLIC MS6 SPORT
Cobb AP v3 \\ Turbosmart Dual Port \\ Mazda Spin-On Conversion \\ Autotech HPFP \\ CP-E RDM \\ Turbine Tech FDM \\ CX Racing IC Piping \\ Treadstone TR8 Core \\ M2 Downpipe \\ JBR Power Path stage 2 \\ Denso ITV22 \\ JBR 80a Trilogy \\ JBR OCC \\ JBR TIGs \\ JBR EGR Delete \\ Corksport Springs
Hargarbl is offline   Reply With Quote
 Old 01-25-2015, 08:34 PM   #9
Turbosuby's Avatar
Posts: 218   (View Stats)
Turbosuby has a reputation beyond reputeTurbosuby has a reputation beyond reputeTurbosuby has a reputation beyond reputeTurbosuby has a reputation beyond reputeTurbosuby has a reputation beyond reputeTurbosuby has a reputation beyond reputeTurbosuby has a reputation beyond reputeTurbosuby has a reputation beyond reputeTurbosuby has a reputation beyond reputeTurbosuby has a reputation beyond reputeTurbosuby has a reputation beyond repute
Groaned at 7 Times in 3 Posts
Thank you. Nice write up, very detailed.
Turbosuby is offline   Reply With Quote
 Old 01-25-2015, 08:36 PM   #10
Raider's Avatar
Groans: 856
I sent the link to quik latch. They loved it and said big thanks for making the solution!
 Old 01-25-2015, 10:00 PM   #11
dereeek's Avatar
Posts: 2,053   (View Stats)
dereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the worlddereeek is the leader of the world
Groans: 386
you can buy the clips you know right?
#8
2011 Mazda 3/M Parts - Online Mazda Parts
BNR3-FREEK-PU-398HP
I lost track of the mods in my car.
dereeek is offline   Reply With Quote
 Old 02-14-2016, 01:23 PM   #12
Lewis7789's Avatar
Posts: 290   (View Stats)
Lewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the world
Thanks again to OP for posting this. I installed these this weekend and the install was very easy and they work great. And barely noticeable on my black MS6.
I bent the mounting tab a bit for better fitment and used a small piece of claybar on the stud to mark where the pilot hole should go.
2006 MS6 aka "Fatty". Only 278hp but I'll catch you in the corners.
Lewis7789 is offline   Reply With Quote
 Old 12-10-2017, 09:02 PM   #13
Anubis450's Avatar
Posts: 80   (View Stats)
Anubis450 is a glorious beacon of lightAnubis450 is a glorious beacon of lightAnubis450 is a glorious beacon of lightAnubis450 is a glorious beacon of lightAnubis450 is a glorious beacon of lightAnubis450 is a glorious beacon of light
Such as awesome write up, do we have anyway to get the pictures uploaded again. Looks like I'm going to need to do this too, but can only see one of the pictures.
Anubis450 is offline   Reply With Quote
 Old 04-01-2018, 06:16 PM   #14
DareDevilMS6's Avatar
Posts: 16   (View Stats)
DareDevilMS6 has a little shameless behaviour in the past
just an fyi.....most of the pics on this how to aren't working anymore.....still
DAREDEVIL
DareDevilMS6 is offline   Reply With Quote
The Following 2 Users Say NO Thank You to DareDevilMS6 For This Un-useful Post:
rymanmazda (04-02-2018), Thor Hammer (04-02-2018)
Navy's BT Build Navy_Mech2 MazdaSpeed 3/6 - Big Turbo Builds 199 11-04-2015 08:03 AM
Page generated in 0.37455 seconds with 31 queries
