> MazdaSpeed 6 - How-To's
 Old 10-18-2012, 02:57 PM   #1
qtrmile beast's Avatar
Posts: 2,423   (View Stats)
Default Pulling the cams in the MZR
The HOW-TO is to show you how to pull your cams without pulling the head or timing cover.
Step one pull the valve cover. For those that have a TMIC pull that first.
At this point you will see the cams and the timing chain. Also while you are in there take a look on the underside of the valve cover above where the timing chain is to see if the chain has been hitting the valve cover. This is an indication that the chain may have been hitting and that is a sign of your chain or tensioner is going bad.
Next step is to pull the high pressure fuel pump housing:
Here are the bolts to the fuel pump housing.
Removed....
This line goes to the fuel rail..
Fuel pump harness and Feed and Return line:
Next install your blind plug.
Note i pulled one of the timing cover bolts and installed that in the BLIND PLUG hole. make sure you use the UPPER BLIND PLUG HOLE to do this. Also when installing it there is no need to TORQUE is down just go far enough til you feel a little tension. TIP: It might be best to use a 1/4in ratchet for this... This step is down so that when you loosen the exhaust cam sprocket to get the chain loose you will not loose tension on the tensioner because the timing chain guide will prevent that.
Next pull the EXHAUST CAM sprocket.
Next step is to pull the cam caps:
NOTE on the cam cap you will see numbers on each of them. Pay attention to the letters and the arrow that are inscribed on each of the caps. This pic shows the inscribed letter E 2 and also you see the arrow. The "E" is for exhaust and the "2" is for the second cap and the arrow is the direction the arrows should be pointing.
Now just lift your cam out of the head..
This is what it looks like with the cams out..
track weight 3220
street weight 3370
The Following 3 Users Say Thank You to qtrmile beast For This Useful Post:
djuosnteisn (07-30-2013), El_Diablo (08-03-2013), Tomas (03-01-2013)
 Old 10-18-2012, 03:24 PM   #2
Now putting it back together............
If you didn't already have the pistons at TDC this is how you can find it....
VIDEO (This video is without the timing cover on)
This is for those that have the cover still installed and want to see what the crank bolt is doing..
If you done have the proper SST (CRANK ALIGNMENT TOOL) don't worry you can use this..
when you have found TDC install this until you feel a little tension. You dont have to tighten down as there is a flat spot on the crank that this will rest on and will prevent the crank from turning. FYI this will not prevent the crank from turning if you are trying to loosen the CRANK BOLT only when tighting it. No need to do anything with the crank bolt for this how-to FYI...
Now that you have found and lock down TDC you can install your cams.
Again there is no need to pull the timing cover...
Make sure that when you install the cams that the first lobe on the passengerside of the motor(timing chain side) are almost pointing to each other (ie. The exhaust cam lobe is pointing toward the intake cam lobe. This is TDC for the cams. Make sure this is done BEFORE you install the cam caps. Now install your cam caps with the exhaust caps all are pointing in the same direction and in order by number. Do that same for the intake cam caps. FYI on the last cam cap nearest the CDFP make sure you use some permatex in the grooves located on the underside of the cap. If there is already some on there clean it out and install new permetex.
Here is the SST( cam alignment tool)
Also when tightening the caps you want to do them in sequence like when you do your head. I believe its 12in lbs for each bolt. Once you have done this now you can attach your timing chain to your exhaust sprocket BEFORE YOU BOLT IT YOUR CAM and then while your chain is attached attach the sprocket to the cam. Now with the cover still on the car you will not have a chance to use a torque wrench.
Will update more later....
track weight 3220
street weight 3370
The Following 4 Users Say Thank You to qtrmile beast For This Useful Post:
djuosnteisn (07-30-2013), El_Diablo (08-03-2013), redboat (04-28-2014), Tomas (03-01-2013)
 Old 10-18-2012, 03:44 PM   #3
Roddiy's Avatar
Posts: 5,388   (View Stats)
Roddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the worldRoddiy is the leader of the world
Groans: 279
Groaned at 58 Times in 47 Posts
Now we just need a good set of Aftermarket cams...
2010 LSM Speed3
Bolted + Corn + Meth + ACT 6-Puck
#BakeryTuned
Roddiy is offline   Reply With Quote
 Old 03-01-2013, 03:14 PM   #4
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,810   (View Stats)
Qbeast, How do use a torque wrench on the VVT bolt for the intake cam with the timing cover on? There is no space there for a socket and a ratchet. You can not even use a standard wrench since there isn't enough space between the head of the bolt the timing cover. At least I couldn't.
 Old 03-27-2013, 07:28 AM   #5
aviator79's Avatar
Posts: 3,934   (View Stats)
Groans: 67
Question
... Now with the cover still on the car you will not have a chance to use a torque wrench.
You are not able to. But I have never used a torque wrench so I think it would be OK for just the exhaust cam sprocket, but that is me. I would use one on the crank pulley of course though.
Tomas (03-27-2013)
 Old 07-30-2013, 02:35 PM   #6
Here is what i did to torque mine down... i beleive that bolt is to be torqued to 65 lbft so i am a pretty strong guy so i just tighted it as tight as i can get it with in reason. I have torqued a lot of things down so i kind of know where 65 lbft is. I how ever would not used that "feel" on my head bolts though..LOL
track weight 3220
street weight 3370
The Following 2 Users Say Thank You to qtrmile beast For This Useful Post:
Downmented (07-30-2013), Tomas (07-30-2013)
 Old 07-30-2013, 03:55 PM   #7
Bob Ross Fanclub
Tomas's Avatar
Holly shit better late than never.
djuosnteisn (07-30-2013), qtrmile beast (07-30-2013)
 Old 04-27-2014, 09:11 AM   #8
redboat's Avatar
Posts: 634   (View Stats)
redboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the world
Groaned at 12 Times in 8 Posts
I'm assuming when you pull the ex cam gear the chain will lose tension, which will allow you to pull it off intake can gear?
Would I need to buy any new hardware doing it this way?
redboat is offline   Reply With Quote
 Old 04-28-2014, 01:05 PM   #9
Bob Ross Fanclub
Tomas's Avatar
Yes. See OP.
You need to buy new friction washers when you loosen up the cam sprockets.
PT-P regrind cams story -- need Web weld & regrind cams MazdaGaragePat MazdaSpeed 6 - Engine, Transmission & Driveline 30 08-10-2016 03:46 PM
Pulling the cams in the MZR qtrmile beast MazdaSpeed 3 - How-To's 9 09-10-2015 03:19 PM
Cams Cams Cams.... blkspeed6 MazdaSpeed 6 - Engine, Transmission & Driveline 11 12-17-2010 08:10 PM
ptp cams? Buildabong MazdaSpeed 3 - Engine, Transmission & Driveline 11 06-14-2009 11:02 PM
What Do Cams Do? kingpin748 MazdaSpeed 3 - Engine, Transmission & Driveline 37 02-16-2009 08:25 PM
Page generated in 0.31177 seconds with 24 queries
