> MazdaSpeed 6 - How-To's
  • 1 Post By Doucems6
 Old 08-06-2016, 02:29 PM   #1
wes3id's Avatar
Posts: 611   (View Stats)
wes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the worldwes3id is the leader of the world
Default HOW-TO: REPLACE MS6 REAR AXLE INNER BOOT
Don't know if there has been a how to on this already, but i have not found it. Was doing this anyways and figured i'd take pics for a write up. I had already taken the axle apart and cleaned it up so that you can see what's inside without the grease in the way.
Boot repair kits are pretty cheap...a lot cheaper than buying a new or used axle, and really isn't hard to do. Can't recall where i bought mine, but it came with the boot, new clamps, grease, lock ring, snap ring.
Step 1.) remove rear axle. There are plenty of how to's on this already.
Step 2.) remove the metal clamps that hold the boot to the shaft. you can unfold the 2 tabs and pry it open enough to get a cutter in there and cut it off.
Step 3.) Pull the boot down a few inches and start cleaning away some of the grease from the top of the bearing housing.
Step 4.) use a small angled pick to remove lock ring at the bearing housing opening, do not separate yet.
Step 5.) with input shaft facing down, slowly pull the shaft out of the housing while using your other hand to wrap around the bearing and keep from falling out. Once clear of the housing, carefully remove bearings.
Step 6.) remove snap ring and bearing supports from shaft
Step 7.) clean all parts
Step 8.) Reassemble and lube
Pretty simple really
07 SPEED 6 W/ GEN PU MOTOR SWAP/BNR S3/ K27 OIL FEED LINE/CUSTOM OIL DRAIN LINE/COBB INJECTOR SEALS/COBB XLE/CX RACING FMIC/CORKSPORT POWER SERIES 3" EXHAUST (CATLESS)/M2 3" DOWNPIPE (CATLESS)/COBB AP V3/GRIMMSPEED EBCS/JBR 3.5" WIDE PATH INTAKE/XS POWER V3 TURBO MANIFOLD/PNP INTAKE MANIFOLD/AUTOTECH INTERNALS/3 BAR MAP SENSOR/VTCS DELETE/KOZMIC MOTORSPORTS EGR DELETE/JBR BSD & BAFFLE TRAY/JBR OCC/NGK PLUGS/SURE TORQUE R6 RMM/AWR TRANSMISSION & PASSENGER MOUNTS/SURE JUGGERNAUGHT REAR DIFF MOUNT/CORKSPORT REAR DIFF MOUNT/FIDANZA FLYWHEEL W/ LUK CLUTCH/TWM SHORT SHIFTER/SURE COUNTER SHIFT/SURE SHORTCUT/H&R LOWERING SPRINGS/KONI YELLOWS/ WHITELINE RSB/ AWR END LINKS FRONT&REAR/ CORKSPORT FRONT & REAR STRUT BARS/SPC FRONT CAMBER BALL JOINTS/BRAIDED STEEL BRAKE & CLUTCH LINES/FIBER IMAGES VENTED HOOD/CORKSPORT FRONT PLATE RELOCATE/PC VALVE COVER/TRUNK MOUNTED RED TOP/INTERIOR MODS
K04 93 FREEKTUNED 271 AWHP/296TQ
K04 E85 FREEKTUNED 309 AWHP/360TQ
BNR S3 93 FREEKTUNED 336 AWHP/360TQ
BNR S3 E85 FREEKTUNED 375 AWHP/376TQ
wes3id is offline   Reply With Quote
The Following 2 Users Say Thank You to wes3id For This Useful Post:
Doucems6 (01-27-2018), Mazdazilla6 (01-06-2017)
 Old 03-12-2018, 07:53 AM   #2
Doucems6's Avatar
Posts: 62   (View Stats)
Doucems6 has a reputation beyond reputeDoucems6 has a reputation beyond reputeDoucems6 has a reputation beyond reputeDoucems6 has a reputation beyond reputeDoucems6 has a reputation beyond reputeDoucems6 has a reputation beyond reputeDoucems6 has a reputation beyond reputeDoucems6 has a reputation beyond reputeDoucems6 has a reputation beyond reputeDoucems6 has a reputation beyond reputeDoucems6 has a reputation beyond repute
Great write up thank you!
wes3id likes this.
BNR stage 3 *cpe sri * sure TIP* sure TIG * Cobb ap * autotech hpfp * PNP IM vtcs delete *custom fmic 2.5" piping * optima red top trunk mounted *egr block off * moroso occ * ets cat-back * bosch 3 bar map sensor * turbosmart bov (recirc) * 3" m2 catless dp* grimmspeed 3 port ebcs* sure ssp* solid shifter bushings * ss brake lines * stoptech slotted rotors w/ oem pads* ngk 1 step colder plugs * mt 90 tranny & diff oil * front & rear strut tower bars * badge-less grill * evo x wheels * 225/40/18 nitto invo's * triple gauge pod autometer gauges*
*** Freak tuned ***
21psi
best 1/4mile----13.5 @ 104 mph 1500' above sea level
Doucems6 is offline   Reply With Quote
Best option for fixing this (CV boot/axle) stratman MazdaSpeed 3 - Engine, Transmission & Driveline 17 11-03-2015 05:23 PM
Axle boot kit? SkippyScallop MazdaSpeed 3 - Engine, Transmission & Driveline 4 11-07-2013 06:35 PM
Anyone had to replace an axle yet? socks MazdaSpeed 3 - Engine, Transmission & Driveline 21 01-14-2009 08:51 AM
Chevy Malibu Interior Smells Like Gas, How To Replace Boot on Lower Ball Joint of Dodge Dakota, Incorrectly Routed Serpe Haltech Automotive News 1 12-05-2008 09:46 AM
Page generated in 0.25537 seconds with 22 queries
