> MazdaSpeed 6 - How-To's
Like Tree2Likes
  • 1 Post By BlueStreak
  • 1 Post By SilverDemon
 Old 03-12-2012, 04:32 AM   #1
06speed's Avatar
Posts: 96   (View Stats)
06speed will become famous soon enough
Groaned at 25 Times in 7 Posts
Default serpintine belt help
can anyone help me out with and easy how-to on loosening the belt up.
06speed is offline   Reply With Quote
 Old 03-12-2012, 04:37 AM   #2
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Put 15mm box end wrench on bolt through tensioner pulley. Push pulley up and towards rear of the car (in the direction indicated by the arrow). Slip belt off of crank pulley.
"Exclusivity" - CP-enis
Demodded.
The Seals
BlueStreak (03-12-2012)
 Old 03-12-2012, 06:46 AM   #3
BlueStreak's Avatar
Posts: 1,467   (View Stats)
^^^ 14mm wrench.
'07 CWP MS3
Forged.
The Following User Says Thank You to BlueStreak For This Useful Post:
Tokay444 (03-12-2012)
 Old 03-12-2012, 06:58 AM   #4
Tokay444's Avatar
Groans: 793
Ah. I knew there was a difference between oem and my napa tensioner.
Demodded.
The Seals
BlueStreak (03-12-2012), btstarcher (09-18-2015)
 Old 03-12-2012, 07:23 AM   #5
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
It is in the friggin How-to database sticky even.
DIY replace belt tensioner
Search fail.
The Following 2 Users Say Thank You to Raider For This Useful Post:
MS6FL (03-12-2012), Tokay444 (03-12-2012)
 Old 03-12-2012, 08:04 AM   #6
06speed's Avatar
sorry, i meant to say is there an easier way to get to it rather then taking the tire off.
 Old 03-12-2012, 08:05 AM   #7
Raider's Avatar
Groans: 856
Put it on ramps. That is how we did it on my wife's CX-7.
 Old 03-12-2012, 08:09 AM   #8
Tokay444's Avatar
Groans: 793
If taking a WHEEL off increases your difficulty level to a degree where you're looking for an easier way, don't bother with the tensioner.
Demodded.
The Seals
The Following 11 Users Say Thank You to Tokay444 For This Useful Post:
ABSpeed3 (03-12-2012), BlueStreak (03-12-2012), breakfstincluded (08-21-2012), Ckmazdaspeed3 (03-12-2012), Coaststarlight (04-29-2014), FenixTX717 (07-18-2016), jack_hammer (08-24-2012), MS6FL (03-12-2012), p057 (03-31-2012), superskaterxes (02-22-2013), Tommy (03-10-2013)
 Old 03-12-2012, 08:23 AM   #9
BlueStreak's Avatar
^^^This.
I generally loosen mine from underneath. Makes life 1324089176142309x easier when putting the belt back on.
Remove the undertray and get at it from there. Once you secure the box wrench, push towards the back of the car and slip the belt off the AC compressor (front of the engine, right at the bottom).
A ratcheting box wrench works really well here.
tbcota25 likes this.
'07 CWP MS3
Forged.
 Old 03-12-2012, 08:28 AM   #10
SilverDemon's Avatar
Posts: 3,034   (View Stats)
Wrenches tend to bust knuckles and pinch fingers. I have found this to be quite effective.
Frequentflyer likes this.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 4 Users Say Thank You to SilverDemon For This Useful Post:
daztdMS6 (08-25-2012), FenixTX717 (07-18-2016), Sid3wayS (02-22-2013), Tokay444 (03-12-2012)
 Old 03-19-2012, 06:21 AM   #11
AntonioSpeed6's Avatar
Posts: 4   (View Stats)
AntonioSpeed6 is an unknown quantity at this point
btw, make sure and get yourself an oem belt...you'll save yourself unnecessary stress, cuss words, and time.
i recently had my ac compressor pulley go bad, ruined a brand new oem belt. bought a dayco since autozone was closer, and it took me having to re-think wtf was wrong. i read on another thread aftermarket belts tend to be shorter, although not by much, but that little does help alot when u can't get it over. no matter how much i compressed the tensioner, i couldnt get the belt just far enough to slide over the water pump pulley.
after not being able to find an oem belt locally, i went back and fully compressed the tensioner and actually got the dayco on by removing the power steering pump getting the belt over the top of the ps pulley, then pulling up on the pump, got the bolts back in and finally the dayco belt was on...funniest part of all, since its slightly shorter, the tensioner literally did not decompress.
AntonioSpeed6 is offline   Reply With Quote
 Old 03-19-2012, 07:38 AM   #12
Matx's Avatar
Posts: 1,681   (View Stats)
I bought my belt at autozone took it to dealer 20$ and they put it on. total 50 bucks well spent.
MS6 COBB-BROKEN: SOLD
GXP G8: Sold
EVO 8: speed rapist
14 Wrangler
 Old 03-19-2012, 04:49 PM   #13
h.h.sk1nny's Avatar
Posts: 1,392   (View Stats)
h.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the world
Groans: 24
I did this the other day. It was tough for me to get enough leverage to loosen the tensioner enough. I looped a ratchet strap through a box end wrench and hooked the other end towards the back of the car. Cranked her down, slid old belt off, new one on. Done
Old stuff: Stock k04 12.301 @ 113.20
New Stuff: PTE 5858 and Built, not bought, by ME
h.h.sk1nny is offline   Reply With Quote
 Old 03-29-2012, 10:45 PM   #14
ispypsi's Avatar
Posts: 303   (View Stats)
ispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the worldispypsi is the leader of the world
my ac pulley is going bad, dropping it off at the dealer tomorrow. was going to get the belt done within this month, glad my pulley is going bad now and not after i have the belt replaced. actually searched to see if anyone else's had gone bad. i'm at 94,xxx miles, ac pulley started to make noise at idle, got progressively worse, when i looked at it, looked like the 3 circular pieces (clutch part?) were "catching" when the a/c wasn't even on and spinning, bearing/clutch part that engages going bad i guess. will know more tomorrow, hopefully just a pulley replacement and not an entire compressor replacement.
could have done the belt myself after reading the how to, but just lazy.
Dan - '08 MS3, some kinda silver
ispypsi is offline   Reply With Quote
 Old 08-21-2012, 01:30 PM   #15
megimpy's Avatar
Posts: 3   (View Stats)
megimpy is an unknown quantity at this point
@isypsi what was your conlusion to your problem? I seem to have the exact same problem. ac pulley rattle with a grinding noise with ac off, with ac on when clutch on cycle resumes, pressure plate moves with pulley, with ac on and clutch cycle off however it behaves as if ac off conditions i mentioned.
megimpy is offline   Reply With Quote
 Old 08-24-2012, 01:28 PM   #16
aviator79's Avatar
Posts: 3,934   (View Stats)
Groans: 67
I undo it by tilting the PS pump. Much easier IMO. Still a PITA to route belt as I took mine off CX-7 and had to look at my MS6 to figure out routing.
 Old 08-25-2012, 02:40 PM   #17
megimpy's Avatar
To anyone who had a similar problem to mine. It was the AC bearing. It was grease-less. One AC repair shop even quoted me 1400 for the repaor when all it needed was a 30 dollar bearing.
 Old 02-22-2013, 12:33 PM   #18
digitalskillz's Avatar
digitalskillz will become famous soon enough
Got a question for you guys. I had a speed3 but sold it before I got a chance to put in the replacement AC compressor and clutch assembly I had bought.
A year went by and I decided to sell the part on ebay to a mazdaspeed6 owner.
Their mechanic said the part was different and wouldn't fit.
There seems to be 2 different styles of AC compressors. Can you tell me which one you guys have on your speed6's? I've actually seen references to both.
129mm clutch:
105mm clutch:
Thanks.
digitalskillz is offline   Reply With Quote
 Old 06-21-2016, 04:38 AM   #19
Frequentflyer's Avatar
Posts: 1,954   (View Stats)
Bringing this back from dead (sorry), but does anyone know the answer to this AC compressor question?
Sent from my SM-G900V using Tapatalk
08.5 CWP MS3 - Cobb AP *Stage 2* ATR tweaked - Cobb SRI w/AEM dry flow filter - RPMC Inlet - Corksport TMIC - Corksport Downpipe (w/OE midpipe) - PTP HPFP - Stock BPV - TWM SS w/bushings - CP-e RMM - Bilstein Sports w/OE springs - Rota 18x8.5 48+ SVN Black/w Red Lip - Bridgestone Potenza RE760 - Cobb RSB - Prosport Boost Gauge/Mearcat pod - Motorcraft XT-M5-QS in the tranny!
 Old 07-11-2016, 04:21 PM   #20
johnnybochamp's Avatar
Posts: 35   (View Stats)
johnnybochamp can only hope to improve
Groaned at 28 Times in 6 Posts
Pretty sure the bottom picture is what is in a speed 6, I have to gen 1 speed 3 and that's the one I have in my car
Sent from my SM-N920V using Tapatalk
johnnybochamp is offline   Reply With Quote
 Old 07-11-2016, 04:37 PM   #21
Yep. I just ordered a replacement and that's the syle that showed up.
 Old 06-19-2018, 08:33 PM   #22
wortman's Avatar
Posts: 1   (View Stats)
wortman is an unknown quantity at this point
Default Hello
Hello to all.
I am new to the Mazda world and Have ben working on a 2007 CX-7 which has been a learning experiance to say the least.
Now I am trying to put on the serpintine belt whick is really a pain ...soooooo...if anyone can help me in this endevore please do I would really appriciate any advice
wortman is offline   Reply With Quote
 Old 06-20-2018, 06:16 AM   #23
shamie's Avatar
Posts: 948   (View Stats)
Make sure the belt you are putting on is 91" and not 90".
 Old 06-20-2018, 06:16 AM   #24
MSMS3's Avatar
Posts: 2,805   (View Stats)
Groans: 157
Originally Posted by wortman View Post
Hello to all.
Welcome. See post number 5 above and link there for how-to.
Broken Belt Bucker 2010 MS3 - Engine, Transmission & Driveline 9 06-25-2011 04:53 PM
Serpentine belt 07Speed3007 MazdaSpeed 3 - How-To's 19 02-12-2011 08:01 PM
serpintine tensioner is screwed, now the dealer want s to screw me for $280 flyrevs2 MazdaSpeed 3 - Engine, Transmission & Driveline 2 07-30-2010 05:37 PM
serpintine belt issues anyone? Sirwill798 2010 MS3 - Troubleshoot/Diagnostics 9 06-03-2010 10:41 PM
belt diagram ms3-87 MazdaSpeed 3 - Engine, Transmission & Driveline 4 05-16-2009 07:38 PM
Page generated in 0.44763 seconds with 36 queries
