> MazdaSpeed 6 - How-To's
 Old 07-26-2010, 07:53 PM   #1
boostjunky's Avatar
Posts: 16   (View Stats)
boostjunky can only hope to improve
Default Trouble codes
I keep getting a trouble code for inconsistant coolant temps. I am guessing i need a coolant temperature sensor or possible a thermostat. Does anyone get this code thrown alot. Will the Cobb unit read trouble codes or do i need to buy a code reader? I was thinking of buying the Cobb unitI noticed some of the code readers i have been looking bat do not read abs codes. It seems like only the more expensive code readers in the $250 and up price range do read abs codes.
boostjunky is offline   Reply With Quote
 Old 08-01-2010, 10:29 PM   #2
sno328's Avatar
Posts: 44   (View Stats)
sno328 is a name known to allsno328 is a name known to allsno328 is a name known to allsno328 is a name known to allsno328 is a name known to allsno328 is a name known to all
whats the code number?
wait sorry, if you dont have a cobb/dash hawk/etc, how do you know its a coolant temp problem?
2007 MS6 GT Black Mica - Forge BPV - SU TP - DH
Last edited by sno328; 08-01-2010 at 10:29 PM. Reason: MSF Database - Automerged Doublepost
sno328 is offline   Reply With Quote
 Old 01-14-2011, 06:43 PM   #3
antwon1's Avatar
Posts: 15   (View Stats)
antwon1 is an unknown quantity at this point
the cheaper obd2 readers wont read abs codes and yes the more expensive ones like the actron scanner will....not sure about the cobb accessport but yeah what is the code number your throwing?
[SIGPIC][/SIGPIC]2008 Mazdaspeed3 GT - CPE Nano Intake, Cobb Turbo Inlet Hose, James Barone Short Shifter, James Barone Solid Shifter Bushings, TurboXS Test Pipe, HKS Catback Exhaust. Prosport Boost Gauge
antwon1 is offline   Reply With Quote
 Old 04-03-2012, 09:48 AM   #4
BigRed06's Avatar
Posts: 96   (View Stats)
BigRed06 is a name known to allBigRed06 is a name known to allBigRed06 is a name known to allBigRed06 is a name known to allBigRed06 is a name known to allBigRed06 is a name known to all
ive been getting the po128 and ive already replaced my ect sensor didnt fix it now im doing the thermostat and we'll see if that fixes it
MODS: AP V3, 3.5" intake, 3bar, gt3076 atp ewg, 38mm wg, SS turbo lines, 3" catless dp, 3" exhaust dp, hpfp, egr delete, vtcs delete, Mac 4port, lil intake mani port work, cxracing fmic, 51R battery cut stock battery tray, Toyota injector seals
BigRed06 is offline   Reply With Quote
 Old 09-05-2012, 02:09 PM   #5
j.hall@fuse.net's Avatar
Posts: 1   (View Stats)
j.hall@fuse.net is an unknown quantity at this point
I had the same issue. Replaced the sensor and the car threw the same code after a week. Replaced the Thermostat and haven't had an issue since.
When changing the thermostat, It's easier to get to if you move the power steering pump to the left. Keep the hoses on the thermostat until you remove the 3 bolts on the thermostat. It'll make it easier to remove the hoses. Overall, it's a pretty straight forward fix. I'm a rookie when it comes to fixing cars and was able to finish in about 2 hours.
j.hall@fuse.net is offline   Reply With Quote
 Old 01-10-2013, 06:29 AM   #6
19SpaghettiOs88's Avatar
Posts: 27   (View Stats)
19SpaghettiOs88 will become famous soon enough
I keep getting the code P0571, but I get no CEL. I know what the code means (brake switch/cruise control malfunction ... I can't seem to figure out how to repair the problem. Anyone have an idea?!
19SpaghettiOs88 is offline   Reply With Quote
Mazda OBD-II Trouble Codes Haltech MazdaSpeed 3/6 - ECU Computer Tuning 9 06-18-2019 04:12 PM
Please help trouble codes P0012,P2187,P2088!!!!!!!!!!!!! gt5 MazdaSpeed 3/6 - Turbo Induction 7 02-25-2010 06:43 PM
Trouble Codes is there a list? Arrowpoint MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 02-01-2009 01:21 PM
Link to trouble codes...... winniep MazdaSpeed 3/6 - ECU Computer Tuning 2 03-20-2008 06:22 PM
Page generated in 0.26677 seconds with 25 queries
