 Old 04-15-2017, 07:52 PM   #1
Analytical's Avatar
Posts: 36   (View Stats)
Analytical is on a distinguished road
Groaned at 6 Times in 2 Posts
Default Alignment of the front coil over once seated
How does one turn the coilover once seated? Do i need to unseat in order to give it a slight turn or am I good? As far as seating do you think it needs seated more? Can I leave the bolt off, wheel on & put on ground, or is there better method?
Tricks get applause, style gets respect.
Analytical is offline   Reply With Quote
 Old 04-16-2017, 04:18 PM   #2
sheston's Avatar
Posts: 1,844   (View Stats)
Yes, you need to seat it more. There should be a tab on the backside that needs to fit into the slot in the collar of the steering knuckle. I just man handled the brake rotor to jiggle it in place. If you need to rotate it, just grab the tabs and spin it.
As far as getting it in enough, grab your scissor jack, and just up the steering knuckle once you get everything lined up
The Following User Says Thank You to sheston For This Useful Post:
Analytical (04-20-2017)
 Old 04-18-2017, 06:38 PM   #3
ibcrusn's Avatar
Posts: 494   (View Stats)
ibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the worldibcrusn is the leader of the world
Find a chisel or some other wedge and tap it into the the slot in the knuckle, it'll make wiggling the strut into place easier. You need to ensure the tab fits into the notch is fully seated as shown in the Mazdaspeed install manual (see attached).
FWIW, it's easier to seat the strut into the knuckle first rather than doing it after the top hat is bolted in.
'10 VRM MS3
3" JBR WP, ETS TMIC, KMD/Aviva HPFP, NGK LTR7IX, M2 TP, Grimmspeed, JBR & MD EGR delete, MD OCC, MD PMM, CPe Stg2 RMM, CS TMM insert
Mazda Motorsports C/O, JBR RSB, SPC camber arms, Konig Hypergram 17x9 +40 & 200 UTQG rubber or Drag DR-49 18x8 +45, Michelin Pilot Sport A/S 3
Strive for perfection in everything. Take the best that exists and make it better.
If it doesn't exist, create it. Accept nothing nearly right or good enough.
Sir Henry Royce
ibcrusn is offline   Reply With Quote
The Following User Says Thank You to ibcrusn For This Useful Post:
 Old 04-20-2017, 09:11 PM   #4
Analytical's Avatar
I honestly do not see any tabs, could they have broken off. The guy I bought these off claimed they are kw v3's. If you were to pick these up what would be a fair price? This is how they are currently seated... do I still need to seat them more? I adjusted the angles to allow for distance to not stress out the brake line & still allow the u clip to be seated at the line mount.
 Old 04-20-2017, 10:00 PM   #5
MoMS3's Avatar
Posts: 224   (View Stats)
MoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond reputeMoMS3 has a reputation beyond repute
Pretty sure the tab is what I've got the arrow pointed to in pic below. Looks like you've still got a bit to go, if it's the tab in question.
2012 Velocity Red Mica MS3 Tech
For Powah: JBR Tru 3.5" WP, CP-E TMIC, UR V3 Catless DP/Reso. TP, CS Resonated CBE, CS HPFP Internals, Cobb AP, DM PMM, DM TMM, CS Stg 2 RMM, CS Shifter Bushings, CS Dual VTA BPV, South Bend Stage 3 Endurance clutch, Damond Motorsports SSP, CS 3.5bar MAP, Stratified S-OTS+ Stg 3 E85 tune for summer, Pump S-OTS+ Stage 3 for winter, for now
Handling: JBR .250 RSB w/ billet brackets.
So I can see/be seen better: DDM LED for Nagare Accent lights, DDM Switchbacks Front turn signals, Osram CBI's, ADVmonster LED Fogs
To-do List: BNR S4, maybe S5...bottom end build, probably should do brakes/suspension at some point. Shooting for a 450-500whp daily driver.
MoMS3 is offline   Reply With Quote
The Following User Says Thank You to MoMS3 For This Useful Post:
jtday (04-20-2017)
WTB: Stock MS6 Front Coil Springs jmettee MazdaSpeed 3/6 - Suspension & Brakes 1 11-02-2016 09:29 AM
Rear coil locking nut stuck, possibly front endlink question too thatsmrgimp2u Sonic Tuning 3 05-31-2013 04:09 PM
Front Wheel Alignment Inquiry J_Logik 2010 MS3 - Suspension & Brakes 1 02-24-2012 11:18 AM
Page generated in 0.26212 seconds with 24 queries
