 Old 05-28-2015, 11:35 AM   #1
qkrthnu2's Avatar
Posts: 131   (View Stats)
qkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond reputeqkrthnu2 has a reputation beyond repute
Default Bad Wheel Bearing or Hub?
When installing new brake rotors I noticed that the front driver side wheel has a bit of play.
With the wheel off the ground, grabbing the top/bottom of the wheel/tire and push/pull there is a little play and slight clunking sound. Push/Pull on the rotor doesn't do anything, not enough leverage. The other wheels don't have any noticeable play.
The bearing isn't making any noticeable noise when driving (I've had plenty of bad wheel bearings on other cars).
Ideas?
_______________________________________________
Driver Mods - Mid Ohio Three Day Racing School
2006 Mazdaspeed 6 GT - 130k+ miles. Daily driver (Actually my Wife's car)
Shooting for a reliable 350 AWHP.
Surefire Remanufactured Engine Installed @ 135k.
Mods: BNR S3 Turbo \ Grimmspeed EBCS \ Guardian Angel \ Cobb AccessPort \ Bosch 3 Bar MAP sensor \ AWR RMM \ TurbineTech FMM \ Corksport HPFP \ cp-e Injector seals \ Autolite XP5263 plugs \ Ebay Circuit Werks DP \ Stock CBE \ HTP 3" Intake w/ DIY CAI \ cp-e TMIC \ DIY boost tubes \ Primary & Secondary EGR delete \ Bilstein Shocks \ 215/45ZR -18 Continental ExtremeContact DWS
PERM dual PVC plate and two Damond Motorsports catch cans. Full vacuum setup w/ VTA for over pressure.
PERM #1 -> DM OCC V1 -> DM PCV valve -> Check Valve -> Intake Manifold.
PERM #2 -> DM OCC V2 w/ VTA -> Check Valve -> Tee -> Valve Cover & TIP.
The others:
2009 BMW 135i - N54 - JB4 w/ backend flash \ SRI.
1998 VW GTI VR6 - 248k miles (stock clutch!) when wrecked (not my fault)
1995 Jeep XJ - 4.0 - AW4 \ Lift/Tires etc. 230k miles. Rust bucket / winter beater.
1995 Honda del sol VTEC - DIY hodge podge turbo setup \ self tuned w/ Neptune. 2550lbs ~270whp \ 150k+ miles on stock bottom end (4th clutch though) \ knock limited on 93 octane.
qkrthnu2 is offline   Reply With Quote
 Old 05-28-2015, 11:52 AM   #2
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
Sounds like a bearing to me.
The Following 2 Users Say Thank You to Raider For This Useful Post:
anavrinIV (05-28-2015), qkrthnu2 (05-28-2015)
 Old 05-28-2015, 11:54 AM   #3
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
^That's about all there is to say.
Blue Pu.
 Old 05-28-2015, 12:43 PM   #4
SuckSqueezBangBlow's Avatar
Posts: 266   (View Stats)
SuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond reputeSuckSqueezBangBlow has a reputation beyond repute
Bad bearing, they are cheap and its not so bad to replace. Dirty, but easy. Just make sure you get a six pack as well
2013 Genpu GT, 245/40 Direzzas, CS SRI+TIP,CS TP+CB, CS TMIC, CS FP Internals, CS 80a RMM, CS BPV, Accessport V3, Tuned by Nishan
SuckSqueezBangBlow is offline   Reply With Quote
Wheel bearing jracer MazdaSpeed 6 - Engine, Transmission & Driveline 94 11-09-2013 06:19 PM
MS6 wheel bearing needs replacing kladuscan MazdaSpeed 3/6 - Suspension & Brakes 7 03-11-2013 01:29 PM
MS3 wheel bearing going out??? buckeyepost MazdaSpeed 3/6 - Suspension & Brakes 22 01-07-2013 03:07 PM
Think my wheel bearing needs to be replace? contreras MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 09-08-2012 08:11 AM
Bad Wheel Bearing?? emag remrofni MazdaSpeed 3 - Engine, Transmission & Driveline 4 01-15-2012 09:43 PM
Page generated in 0.24853 seconds with 23 queries
