 Old 07-26-2012, 04:06 PM   #1
Doberman's Avatar
Posts: 269   (View Stats)
Doberman is the leader of the worldDoberman is the leader of the worldDoberman is the leader of the worldDoberman is the leader of the worldDoberman is the leader of the worldDoberman is the leader of the worldDoberman is the leader of the worldDoberman is the leader of the worldDoberman is the leader of the worldDoberman is the leader of the worldDoberman is the leader of the world
Default BC BR Extreme Low Coilovers vs KSport Kontrol Pro Coilovers
I'm curious as to some input on which set is "better". I'm running a fairly aggressive set of wheels currently and want to introduce my car to the ground. I don't want to go super crazy but it's nice to have the option for shows and whatnot. The thing that has me intrigued about the BC's is the custom spring rates (and the fact that everyone seems to run them). I figured I could go with a higher rate and get less bottoming out/rubbing. Even though I don't know what rate I would go with. I look forward to some advice. Thanks!
If there's a preferred vendor I'd also like to know. I prefer to keep my money in the community.
Doberman is offline   Reply With Quote
 Old 07-26-2012, 04:17 PM   #2
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Groans: 67
Six one way; a half-dozen the other...
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
 Old 07-26-2012, 08:50 PM   #3
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
Adjusting the height of your car is gonna fuck up your alignment every time you do it, so you might want to keep that in mind before you show drop it.
2006 Mazdaspeed6
 Old 07-27-2012, 02:00 AM   #4
Doberman's Avatar
Firestone sells a lifetime alignment package and a good friend has a shop with an alignment machine so I'm not terribly concerned about that. I'm not going to be going to shows a lot either. Just using that as an option.
 Old 07-27-2012, 05:22 AM   #5
if your interested in some ultra low our sonic tuning coilovers will give you what you need.
plenty of great reviews here and we even have a GB going!!!
GB: Sonic Tuning Coilovers!!!
 Old 07-27-2012, 01:26 PM   #6
mazdaspeed916's Avatar
Posts: 167   (View Stats)
mazdaspeed916 has a reputation beyond reputemazdaspeed916 has a reputation beyond reputemazdaspeed916 has a reputation beyond reputemazdaspeed916 has a reputation beyond reputemazdaspeed916 has a reputation beyond reputemazdaspeed916 has a reputation beyond reputemazdaspeed916 has a reputation beyond reputemazdaspeed916 has a reputation beyond reputemazdaspeed916 has a reputation beyond reputemazdaspeed916 has a reputation beyond reputemazdaspeed916 has a reputation beyond repute
I run ksport coils at the moment, I like the drop they provide and haven't had any problems but even at a reasonable drop they're still pretty rough even on the softest adjustment.
SOLD AS OF 6/20/13 Velocity Red 2010 Genpu -Drag Wheels DR-31 18X8 5-100/114 48FBR -Cobb DP -Cobb SRI/TIP -Cobb AP Selftune -Cobb Shift Weight -CP-E TMIC-CP-E RMM CP-E HPFP -DENSO Sparkplugs -Ksport Coilovers -SPC Camber Arms - Whiteline Front Endlinks -Forge BPV v.2 -CorkSport Front License Plate -UR Catback
New Ride:
Snowflake White Pearl 2014 Mazda 6 Grand Touring
mazdaspeed916 is offline   Reply With Quote
The Following User Says Thank You to mazdaspeed916 For This Useful Post:
SLOWHATCH (07-27-2012)
 Old 07-27-2012, 02:36 PM   #7
Doberman's Avatar
Originally Posted by Angr-E1 View Post
A first on MSF, someone asking about "the lows" and no one tells him to gtfo? What is the world coming to?
Come again?
 Old 07-27-2012, 07:12 PM   #8
Neverlift's Avatar
Posts: 4,699   (View Stats)
Groans: 1,143
He is saying you are a douchebag, your "stance" is pure faggotry, and you belong in a ditch... so gtfo.
Past Mazdas & Speeds
The Following 2 Users Say Thank You to Neverlift For This Useful Post:
Angr-E1 (07-27-2012), captain slow (07-27-2012)
 Old 07-27-2012, 07:13 PM   #9
Doberman's Avatar
Ah ok, wasn't sure. Eat a dick.
The Following User Says Thank You to Doberman For This Useful Post:
 Old 07-28-2012, 07:35 AM   #10
Doberman's Avatar
What I meant was I was surprised to see people entertaining the idea of "stance" on MSF. Usually they tell you to gtfo and go to 24/7.
No worries. My "stance" is slightly more aggressive than EVO wheels. Not exactly hardcore. Nor do they require some demon camber or silly shit like that. I'm simply wanting the right parts for the application, while trying to keep my money in the community.
I'm well aware of the dickbags that just like to talk shit. I'm used to those elitists from other communities. Not so much from the same one though.
I don't really like the idea of running a first run production. IMHO, it always seems like there are small kinks to be worked out and I'd like for the installation to be one and done.
Last edited by Doberman; 07-28-2012 at 07:35 AM. Reason: MSF Database - Automerged Doublepost
Angr-E1 (07-28-2012)
Ksport,d2 racing,bc or megan coilovers? jays-slospd3 MazdaSpeed 3/6 - Suspension & Brakes 21 09-18-2011 08:22 PM
MPS specific Ksport Coilovers Jarods7920 MazdaSpeed 3/6 - Suspension & Brakes 17 03-04-2011 06:40 AM
NEW KW V1 COILOVERS! allen624 MazdaSpeed 3/6 - Suspension & Brakes 29 01-22-2011 06:44 PM
Page generated in 0.30856 seconds with 25 queries
