Notices
  • 1 Post By TiGraySpeed6
 Old 11-01-2012, 08:54 PM   #1
crtguns's Avatar
Posts: 384   (View Stats)
crtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the worldcrtguns is the leader of the world
Groaned at 292 Times in 79 Posts
Default Bigger rear rotors?
So yeah, we have huge fronts... im embarrassed at the size of my rear rotors.
Has anyone put a big rotor on the rear?
Searched... only found front axle upgrades.
and... would a bigger brake on the rear help much? Consodering that most load during braking in on the front tires.
"You have enemies? Good. That means you’ve stood up for something, sometime in your life."
- Winston Churchill
crtguns is offline   Reply With Quote
The Following 4 Users Say NO Thank You to crtguns For This Un-useful Post:
captain slow (11-02-2012), Keko (11-01-2012), Mizzle (11-01-2012), xtasy (11-01-2012)
 Old 11-01-2012, 08:58 PM   #2
uncorked11's Avatar
Posts: 1,126   (View Stats)
Groans: 156
There is a reason for that.. in for the trolling.
During braking there is a significant weight transfer from the back to the front of the car. A car that has a 50-50 F/R weight distribution at constant speed, can have 85-15 F/R weight distribution during braking. This means that the front brakes have to do a lot more work than rear. This is why the front brakes are usually a lot larger than rear brakes and why the braking system sends more force to the front than to the rear when you press the brake pedal. A correct bias exists when all four tires start locking up at the same time as you apply the brake. This makes sure that all four tires are delivering maximum braking force to the car.
quick google search so i didnt have to type
2011 Black MS3
2006 Jeep Wrangler
-20 grand of Shit
uncorked11 is online now   Reply With Quote
 Old 11-01-2012, 08:59 PM   #3
Mizzle's Avatar
Posts: 2,578   (View Stats)
Groans: 297
Groaned at 186 Times in 102 Posts
No trolling. Please just get this guy to shut the fuck up.
The Following 2 Users Say Thank You to Mizzle For This Useful Post:
Tokay444 (11-02-2012), xtasy (11-01-2012)
 Old 11-01-2012, 09:01 PM   #4
uncorked11's Avatar
Groans: 156
i edited my post
2011 Black MS3
2006 Jeep Wrangler
-20 grand of Shit
 Old 11-01-2012, 09:01 PM   #5
Dmurray06's Avatar
Posts: 2,597   (View Stats)
Groans: 122
Groaned at 49 Times in 15 Posts
People have gone threw a cars entire life without having to change rear pads.
So...yea...sorry for feedin the troll.
2010 Mazdaspeed 3 Black Mica w/ Tech Package
Insalled: Corksport SRI/TIP // Cobb AccessPort// Autotech Internals // Corksport LED Kit // Corksport Stubby Antenna // Forge v2 BPV // JBR SSP// JBR 80a RMM // JBR Weighted Shift Knob // ETS TMIC // Corksport Catless Downpipe // Corksport RacePipe // Denso itv22 // Stratified Guardian Angel // block8head Defrost Pod // Prosport Boost Gauge // Zoom Boom Box
Awaiting Install: HTP 3" TIP // HTP Battery Tray // Sure 3" MAF // Stratified Boost Dial
Dmurray06 is offline   Reply With Quote
 Old 11-01-2012, 09:23 PM   #6
m4tic's Avatar
Posts: 4,512   (View Stats)
Groaned at 22 Times in 20 Posts
There is a very simple way for an unneeded larger rear rotor.... But
2007 w/ Cheez
// COBB AP // COBB SRI // COBB TIP // CXRacing FMIC // HKS SSQV v1 // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // BC Racing BR Coilovers // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Prosport Elec Boost Gauge // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob
m4tic is online now   Reply With Quote
 Old 11-02-2012, 06:18 AM   #7
mrdouble99's Avatar
Posts: 210   (View Stats)
mrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the worldmrdouble99 is the leader of the world
Groaned at 4 Times in 2 Posts
Just use mazda5 caliper bracket and rotor and you have bigger rear brake
Mazdaspeed3 11"
Mazda5 11.9"
Mazdaspeed3
- Cobb AccesPort - Cobb SRI - 259whp@280wtq - 12.737@108.51mph
- H&R spring - SPC camber kit - Team Dynamic Pro Race 1.2 18X8 et50
mrdouble99 is offline   Reply With Quote
The Following 3 Users Say Thank You to mrdouble99 For This Useful Post:
daafisch (11-02-2012), Mr Wilson (11-02-2012), Nliiitend1 (11-02-2012)
 Old 11-02-2012, 06:31 AM   #8
lowspeed
TiGraySpeed6's Avatar
Posts: 2,666   (View Stats)
By a speed6, get real brakes...
12.6 front
12.4 rear
DamagedGoods likes this.
Mazdaspeed6 GT #3476 TiGray slicktop
Cobb AP, SRI & TIP, BNR S3, MAC 3 Port, FMIC, TS BPV, 3 BAR MAP, VTCS Delete
M2 DP & Magnaflow, KMD Internals, GPWerks BSD & Baffle, SM OCC, EGR Delete, TB Coolant Bypass, SU Billet RMM
TWM Stage II STS & JBR SSB, Prosport Mech Boost
RX-8 wheels & 235/40 RE760, H&R Sport Springs, SPC abj's, Strapped diff
Stage 1 Brakes: Slotted, Hawk’d, Lined & Blued
405/394 AWD - cf1.01 e38 BNRs3
315/372 AWD - cf1.01 e38 k04
 Old 11-02-2012, 06:56 AM   #9
CaptObvious75's Avatar
Posts: 392   (View Stats)
Who the fuck cares about the size of their rear brakes???
 Old 11-02-2012, 06:59 AM   #10
indiscretion
leon78's Avatar
Posts: 1,933   (View Stats)
Groaned at 22 Times in 15 Posts
Originally Posted by crtguns View Post
im embarrassed at the size of my penis.
fixed
2013 Scion FR-S (Whiteout)
White 17x9 Rota Grids w/ 245's_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP.
leon78 is online now   Reply With Quote
The Following 3 Users Say Thank You to leon78 For This Useful Post:
MS3-a(sore)ASS-rex (11-02-2012), silvapain (11-02-2012), Tokay444 (11-02-2012)
 Old 11-02-2012, 07:05 AM   #11
Posts: 5,620   (View Stats)
Groans: 121
12.6 front
12.4 rear
You realize that the MS3 has the same size front rotors with better calipers, and that the rear brakes are smaller only because its not nearly as heavy in the ass and doesn't need them, right?
The Following 4 Users Say Thank You to silvapain For This Useful Post:
daafisch (11-02-2012), MS3-a(sore)ASS-rex (11-02-2012), Nliiitend1 (11-02-2012), Tokay444 (11-02-2012)
 Old 11-02-2012, 07:09 AM   #12
(Toe-kay)
Tokay444's Avatar
Posts: 9,552   (View Stats)
Groans: 503
^Beat me too it.
Demodded.
Mwho?
 Old 11-02-2012, 07:25 AM   #13
lowspeed
yes I do.
was just trolling the OP since, you know, size is everything lolz
 Old 11-02-2012, 09:13 AM   #14
mrdouble99's Avatar
I just gave him the answer he want and did not say it was worth it.
Mazdaspeed3
 Old 11-02-2012, 09:19 AM   #15
captain slow's Avatar
Posts: 1,661   (View Stats)
captain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the worldcaptain slow is the leader of the world
Groans: 307
Groaned at 44 Times in 29 Posts
Another fascinating thought brought to you by the same guy who wants to do an intercooler delete and thinks a hood scoop would ram more air into the cylinders.
Oh and he can do 0-60 in like 4 seconds!
2007 Sunlight Silver MS3 GT
CP-E SRI / CP-E TIP / Cobb AP Stage 1 slightly tweaked by me / JBR 88 RMM, SSP, SSB, Heavy Knob / Turbosmart Dual Port BOV 50/50 / Autotech internals
_______________________________________________
Sitting in my garage: ......
To be ordered: CorkSport TBE
captain slow is offline   Reply With Quote
The Following User Says Thank You to captain slow For This Useful Post:
Where to get Rotors Gr33ntumb Canada 3 08-19-2012 02:48 PM
Rotors Bulgdoom MazdaSpeed 3/6 - Suspension & Brakes 0 10-21-2011 09:36 AM
need new rotors xfeejayx MazdaSpeed 6 - Engine, Transmission & Driveline 13 09-08-2011 10:53 AM
Video: Fórmula Truck - The bigger they race, the bigger they crash Haltech Automotive News 0 08-02-2010 08:50 AM
rotors armarine04 MazdaSpeed 3/6 - Suspension & Brakes 7 03-30-2009 03:49 PM
Page generated in 0.36561 seconds with 31 queries
