Like Tree17Likes
 Old 03-18-2015, 10:44 AM   #1201
pandita's Avatar
Posts: 989   (View Stats)
pandita is the leader of the worldpandita is the leader of the worldpandita is the leader of the worldpandita is the leader of the worldpandita is the leader of the worldpandita is the leader of the worldpandita is the leader of the worldpandita is the leader of the worldpandita is the leader of the worldpandita is the leader of the worldpandita is the leader of the world
Originally Posted by Tomas View Post
Actually pretty easy to drop the front a 1/2" with the bils. It only requires grinding of a little notch on the lower tap to slide the damper body further into the knuckle. It takes much more work on the stockers and Konis.
I am so sorry for reviving this old thread,
but it bugs me SO MUCH that my car is higher in the front than the rear with my bils and swift springs.
Is this literally all you need to do? Just cut that tiny tab off? I'm assuming you just need to get a sharpie pen and precisely measure everything so it's even.
Also, could you just bend the little tab into it's hole just incase you ever wanted to put them back to the way they were, because technically this voids your warranty.
But then I don't understand what stops the strut from completely falling into the knuckle at high speeds over a bump or something.
Is it really just that one bolt holding the strut in place? lol
2013 CWP:
FREEKTUNE OTS
Cobb AP
Corksport Sri/Tip/Internals/Test Pipe/Rear Motor Mount/Solid Shifter Bushings/Cat Back Exhaust
Rally Armor Mudflaps/HIDS/Yellow Fogs/OEM Window Visors/Super Cool JDM Axela Badge
Enkei Rpf1/Bilstein Struts+Swift Springs
90 Miata:
DDM Intake, Megan Coilovers, Flyin Miata Sways/Master Cylinder Brace,
Corksport Radiator Panel, EGR Rollbar, Enkei RPF1's, 16° timing advance, Foamectomy
pandita is offline   Reply With Quote
The Following User Says Thank You to pandita For This Useful Post:
Tomas (04-06-2015)
 Old 03-18-2015, 12:39 PM   #1202
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
there is a bolt in the knuckle that will stop the tab from going further.
it's fun to do bad things
The Following User Says Thank You to jack_hammer For This Useful Post:
Tomas (04-06-2015)
 Old 03-18-2015, 12:40 PM   #1203
pandita's Avatar
You mean the one and only bolt holding the strut in?
Or is there one I missed lol.
2013 CWP:
FREEKTUNE OTS
Cobb AP
90 Miata:
 Old 03-18-2015, 01:06 PM   #1204
Groans: 549
yes. that one.
 Old 03-18-2015, 04:01 PM   #1205
pandita's Avatar
Perfect. I'll do it in the coming days.
2013 CWP:
FREEKTUNE OTS
Cobb AP
90 Miata:
 Old 03-26-2015, 01:33 AM   #1206
googlebutt's Avatar
Posts: 44   (View Stats)
googlebutt is a splendid one to beholdgooglebutt is a splendid one to beholdgooglebutt is a splendid one to beholdgooglebutt is a splendid one to beholdgooglebutt is a splendid one to beholdgooglebutt is a splendid one to beholdgooglebutt is a splendid one to behold
Has anyone with b8's ridden in a car with FSD's (and maybe cs springs) and able to compare? I'm split on which set to get. Tempted to try @Raider's setup.
googlebutt is offline   Reply With Quote
 Old 03-26-2015, 08:20 AM   #1207
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
Groans: 67
Originally Posted by license2ill View Post
My rear B8s are factory-set to a pretty fast(firmer) rebound, which makes for a more lively and nervous feel over rough pavement, but not harsh with stock springs. Not harsh, but busy, and no way to change it.
I've set my front Koni Yellows to just under a 1/4 turn from full Slow(soft) rebound, which is about where I would expect the FSDs to feel according to reports, which feels stable and smooth, without the floaty feel of a slightly stiffer setting, or the busy and harsh feel of full Firm. At full Soft, it feels a little flat over bumps, and a little washed-out in corners.
The B8s feel like the Sport Yellows on at least a full turn closer to Firm. If I had it to do over again, I'd get the Sport Yellows in the rear too, and adjust the rebound to about the same as the fronts for a stable, but not washed-out feel, and a less nervous rear.
fast rebound ≠ firm rebound
The firmer the rebound damping, the slower the piston will extend.
Conversely, the softer the rebound damping, the faster the piston will extend.
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
The Following 4 Users Say Thank You to Nliiitend1 For This Useful Post:
Deldran (03-26-2015), MSMS3 (03-26-2015), phate (03-26-2015), Tomas (04-06-2015)
 Old 03-26-2015, 08:35 AM   #1208
Nliiitend1's Avatar
Groans: 67
fast=firm setting on the konis.
Explain yourself.
Soft to Firm is how it works. If you insist on putting "speed" labels on the settings, then it stands to reason that you should use a descriptor that follows what the damper is doing. Softer rebound damping allows faster damper piston movement, and firmer rebound damping allows the damper piston to move less easily (more slowly, in the terms I guess you insist on using).
2008 MS3 GT
2016 MX-5 Club
Deldran (03-26-2015), div2 (03-26-2015), MSMS3 (03-26-2015), phate (03-26-2015)
 Old 03-26-2015, 09:15 AM   #1209
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
firmer setting on damper allows piston/spring to return faster, makes for floaty feel. same as my mtb shocks.
No, that's not how damping works. The more force there is, the more resistance there is at a specific velocity.
Imagine no damper at all - the spring oscillates at its resonant frequency. That's the fastest the spring will ever move. Now add damping force to either the compression or extension phase of the oscillation - that force RESISTS the springs movement, slowing it down.
Now add a bunch of damping, way more than is necessary. That force will actually prevent the spring from returning to neutral until it has slowed WAY down. That process takes much, much longer than undamped movement or critical damping, otherwise known as overdamped.
Extrapolating in the overdamped situation a little bit and you can see that successive bumps can actually force the car to ride lower or higher over those successive bumps - aka jacking - because the movement is so slowed the system can't return to neutral before the next bump.
-06 MS6
-Corn fed 07 MS3 - Sold
CaptainCode (08-06-2015), Deldran (03-26-2015), div2 (03-26-2015), MSMS3 (03-26-2015), Nliiitend1 (03-26-2015), Tomas (04-06-2015)
 Old 03-26-2015, 09:38 AM   #1210
Eth Fiend
phate's Avatar
Neutral  -1 score
Soft is slow rebound, more damping, jacking down.
No.
xfeejayx likes this.
-06 MS6
Chuthor (03-26-2015), Deldran (03-26-2015), div2 (03-26-2015), Nliiitend1 (03-26-2015), Tomas (04-06-2015), WetzMS3 (03-26-2015)
The Following User Says NO Thank You to phate For This Un-useful Post:
license2ill (03-26-2015)
 Old 03-26-2015, 09:48 AM   #1211
xfeejayx's Avatar
Posts: 1,729   (View Stats)
Groans: 78
yeah, it's just how the shock company labels it. The Fox shock on my mtb has slow and fast on it, meaning slow or fast return.
Bro, that was so people know if you're serious or not. Like they roll up next to you, and you got your shit set on fast, they don't want a piece. And if it's set on slow, race for pinks.
license2ill likes this.
-Wetz
QFT
The Following User Says Thank You to xfeejayx For This Useful Post:
 Old 03-26-2015, 09:52 AM   #1212
Groans: 549
yes.
The Following 2 Users Say Thank You to jack_hammer For This Useful Post:
div2 (03-26-2015), WetzMS3 (03-26-2015)
The Following User Says NO Thank You to jack_hammer For This Un-useful Post:
 Old 03-26-2015, 10:00 AM   #1213
xfeejayx's Avatar
Groans: 78
yes.
Please, tell me more. I want to learn your ways. How can I get shocks that defy physics?
-Wetz
QFT
 Old 03-26-2015, 10:02 AM   #1214
WetzMS3's Avatar
Posts: 5,772   (View Stats)
Groans: 430
Neutral  -1 score
Proposed name change:
license2eatpenis
2013 MS3 Black Mica
SLUGGISH RUGGISH BONE
SLUNTWORKS SPEEDSHOP
The Following 2 Users Say Thank You to WetzMS3 For This Useful Post:
Deldran (03-26-2015), jack_hammer (03-26-2015)
The Following User Says NO Thank You to WetzMS3 For This Un-useful Post:
 Old 03-26-2015, 10:16 AM   #1215
xfeejayx's Avatar
Groans: 78
first you've got to understand physics and simple language, tough guy.
I didn't make it all the way through ESL. Maybe that's the problem. Although, maybe if you explain it slowly I'll get it.
It might take a while for me to understand, but after I get it I'll go back and explain it to my old physics, controls, and design teachers that they all had it wrong this whole time.
We might be starting a new era in suspension design where decreasing damping coefficient increases force at a given velocity. Can you picture the magnitude of this?! Maybe we can take this breakthrough to other applications. Maybe if we oil our tires and reduce friction coefficient we'll get more traction!!
WetzMS3 likes this.
-Wetz
QFT
The Following 5 Users Say Thank You to xfeejayx For This Useful Post:
Chuthor (03-26-2015), Deldran (03-26-2015), Nliiitend1 (03-26-2015), phate (03-26-2015), WetzMS3 (03-26-2015)
 Old 03-26-2015, 10:36 AM   #1216
MSMS3's Avatar
Posts: 2,826   (View Stats)
Groans: 157
Regardless of the fast/slow descriptors, which are not accurate, the Bilstein HDs on my car are extremely firm with stock springs. Especially on compression, less so on rebound or extension, if I am using those terms correctly. My HD's (B6's) are, I think we established perhaps earlier in this long thread, identical to the B8s except for shaft length.
Now, in honesty, I have tires with very stiff sidewalls, Yoko AD08Rs. That contributes to the firmness. This is especially noticable when encountering expansion strips on the highway. The combination is extremely effective from a handling standpoint, with amazing grip and very precise body motion control. But any semblance of a soft ride is gone.
My wife and most female passengers (daughter, co-workers, etc.) are not thrilled to ride in my car. But, I am.
The Following 3 Users Say Thank You to MSMS3 For This Useful Post:
div2 (03-26-2015), Nliiitend1 (03-26-2015), phate (03-26-2015)
 Old 03-27-2015, 12:29 PM   #1217
Groans: 549
@license2ill; i have a question for you regarding...
oh, wait. nevermind.
The Following 5 Users Say Thank You to jack_hammer For This Useful Post:
div2 (03-27-2015), phate (03-27-2015), WetzMS3 (03-27-2015), xfeejayx (03-27-2015), zenit (03-27-2015)
 Old 04-05-2015, 01:15 AM   #1218
kt411gcn's Avatar
Posts: 4   (View Stats)
kt411gcn is an unknown quantity at this point
Did you guys notice a ride height change after installing the bilstein's? My front is higher than my rear by about a finger. I noticed the previous owner installed bilsteins in the front. Rear oem shocks. Oem springs f+r.
kt411gcn is offline   Reply With Quote
 Old 04-05-2015, 06:11 AM   #1219
smileyspeed3's Avatar
Posts: 25   (View Stats)
smileyspeed3 is a glorious beacon of lightsmileyspeed3 is a glorious beacon of lightsmileyspeed3 is a glorious beacon of lightsmileyspeed3 is a glorious beacon of lightsmileyspeed3 is a glorious beacon of lightsmileyspeed3 is a glorious beacon of light
Did Bilst B8 with Cobb springs. Front seems lower than the back which is what I wanted. I am trying to do everything possible to prevent the front lifting during WOT.
smileyspeed3 is offline   Reply With Quote
 Old 04-05-2015, 07:43 AM   #1220
MSMS3's Avatar
Groans: 157
No. But I put B6s on all four corners at the same time and stayed with stock springs.
zjnspeed3 (04-24-2016)
 Old 04-24-2016, 06:12 AM   #1221
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
The front B8s are the same for both gens, but the rears have different part#. Does anyone know what is the difference between the 24-196550 (listed for gen2) and 24-215237 (listed for gen1)?
For the B14 coilover kit the parts are exactly the same so I don't know what the difference between these two B8 rear dampers may be since both gens basically share the same suspension parts.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 04-24-2016, 09:08 AM   #1222
Nliiitend1's Avatar
Groans: 67
The rear shocks have different width shock eye bushings:
Gen2 shocks on gen1
gen 1 to gen 2 suspension
2008 MS3 GT
2016 MX-5 Club
frothy (04-24-2016), Mauro_Penguin (04-24-2016), meicalnissyen (04-24-2016), mituc (04-24-2016)
 Old 04-24-2016, 01:18 PM   #1223
mituc's Avatar
Groans: 111
Ok, so just to be sure, for fitting a gen1 rear shock to a gen2 all that's needed is a longer bolt (gen1 bolt) to accommodate the wider mounting ear, right?
 Old 04-24-2016, 07:53 PM   #1224
Nliiitend1's Avatar
Groans: 67
Correct. I always just tell people to ask the parts guy for two "camber arm" bolts (the outboard ones, specifically) as they are the perfect size.
2008 MS3 GT
2016 MX-5 Club
mituc (04-24-2016)
 Old 04-24-2016, 08:38 PM   #1225
FrankRizzo's Avatar
Posts: 71   (View Stats)
FrankRizzo is a name known to allFrankRizzo is a name known to allFrankRizzo is a name known to allFrankRizzo is a name known to allFrankRizzo is a name known to allFrankRizzo is a name known to all
and here I am looking up rear shocks as one of mine starting leaving puddles in the driveway today! At least it isn't brake fluid...
Ordered up a set of bilstein B6's to go with the stock springs on my speed3.
Thanks for all the helpful info!
FrankRizzo is offline   Reply With Quote
 Old 06-04-2017, 03:56 PM   #1226
mhx
mhx's Avatar
Posts: 10   (View Stats)
mhx is an unknown quantity at this point
ignore delete
mhx is offline   Reply With Quote
 Old 06-26-2017, 08:57 PM   #1227
Oshiguru's Avatar
Posts: 102   (View Stats)
Oshiguru is a name known to allOshiguru is a name known to allOshiguru is a name known to allOshiguru is a name known to allOshiguru is a name known to allOshiguru is a name known to all
After reading this thread and the swift springs thread I ordered B8s with Swift Spec R's to replace my 4 leaking KW v1 struts. I have a feeling both setups will feel the same (KW is progressive IIRC) but Swifts will be a bit higher, which is good since my kw v1s are tucking tire at the highest setting.
Enough of my storytelling, but I was reading in this thread to put shock boots over the rears to prevent them from wearing down prematurely.
Anyway I went to a local 4WD/offroading store and picked up pro-comp boots ( Pro Comp Suspension - Pro Comp Poly-Vinyl Shock Boot (Gray) - 12126 | 4WheelParts.com )
The top end of the boot is approx 40mm and wraps perfectly snug on the 2nd rib on the VW bump stops I ordered ( https://www.fcpeuro.com/products/vol...ta-1j0512131bf ), and the bottom end of the boot is approx 50mm so it goes over the whole strut/shock. It even comes with zip ties incase I want to make it snug to make sure nothing goes in or out. All the boots they had have 4 "holes" in them but aren't punched out unless wanted (see the 2 pinpoint holes here http://www.procompusa.com/suspension...artno=EXP12120 ), so its pretty much sealed unless you punch it open.
Just a lil bump incase anyone searches for a dust/shock boot and doesn't know which to order. These are hella cheap at $9.99 CAD for a pair, so around $6USD for two.
mazdaspeedmyk likes this.
Oshiguru is offline   Reply With Quote
 Old 06-27-2017, 06:05 AM   #1228
mhx
mhx's Avatar
I got B8s in the rear, about to order B8 fronts.. Using stock springs and replacing OEM junk.
 Old 06-27-2017, 07:29 AM   #1229
mituc's Avatar
Groans: 111
B8 with stock springs?
 Old 06-30-2017, 06:57 PM   #1230
Nliiitend1's Avatar
Groans: 67
Nothing wrong with using B8s with stock MS3 springs.
2008 MS3 GT
2016 MX-5 Club
 Old 06-30-2017, 10:25 PM   #1231
zenit's Avatar
Posts: 1,364   (View Stats)
Groans: 57
Groaned at 7 Times in 6 Posts
it'll work.
-feejay
-wetzel
 Old 08-07-2018, 05:03 PM   #1232
Sierra248's Avatar
Posts: 22   (View Stats)
Sierra248 is an unknown quantity at this point
Got any pics? Also how come you ordered VW bump stops? Have you got wverything installed and if so how’d it all turn out. Did you do camber arms in the rear?
Thanks for any info
Sierra248 is offline   Reply With Quote
 Old 08-08-2018, 06:59 AM   #1233
MSMS3's Avatar
Groans: 157
Thanks for any info
You are replying to a post over a year old. He may not be keeping up with the thread. Might want to try PM to him if you want a quick response.
 Old 09-02-2018, 01:01 AM   #1234
MichaelAress's Avatar
Posts: 8   (View Stats)
MichaelAress can only hope to improve
Groaned at 6 Times in 2 Posts
Neutral  -1 score
Default Bilstein shocks for the ms3
Avaliable for sale again. E36 Bilstein sport shocks,
2 - brand new front monotube sport shocks,
2 - barely used rear sport shocks
650CAD obo takes them.
Dont have a digital camera so didnt take picture of the front shocks, but they are 100 brand new..
Below is a picture of the rear shocks
https://www.sportzfuel.com/
MichaelAress is offline   Reply With Quote
The Following 4 Users Say NO Thank You to MichaelAress For This Un-useful Post:
cyber-ms3 (09-03-2018), Fstrnyou (09-02-2018), mituc (09-02-2018), MSMS3 (09-02-2018)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f12/bilstein-shocks-mazdaspeed-3-a-46492/
Koni Yellow's or Blistein Sport shocks with stock springs? - Car This thread Refback 01-07-2012 08:45 PM
Koni Yellow's or Blistein Sport shocks with stock springs? - AcuraZine Community This thread Refback 03-23-2011 09:33 PM
Good read regarding suspension for the MPS3 using Bilsteins dampers (and koni's) This thread Refback 11-24-2010 02:42 PM
Bilstein HD on 6 ccs70 MazdaSpeed 3/6 - Suspension & Brakes 10 03-06-2009 04:42 PM
h&r springs... what shocks to go with... Munnugles MazdaSpeed 3/6 - Suspension & Brakes 3 03-05-2009 10:08 PM
Bilstein Sport or HD ualeks MazdaSpeed 3/6 - Suspension & Brakes 3 09-09-2008 08:31 AM
Page generated in 0.55000 seconds with 37 queries
