| MazdaSpeed 3/6 - Suspension & Brakes Discussion for suspension items like coilovers, springs, sway bars, mounts,chassis bracing and brakes. |
![]() | | #41 | ![]() |
![]() Join Date: Apr 2012 Location: Austin, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 63
| Not Ranked : 0 score
__________________ Chad Erwin -ATX 06 MazdaSpeed6 Gt AWD/Turbo/#5994 MODS: COBB AP // MSD Dashhawk // Street Unit TMIC // Street Unit Test Pipe // COBB SRI intake // Speedies TIP // Turbosmart BOV // RPM Street Spring // Bilstein Struts/Shocks // TWM Stage 2 Short Shifter // CPE Dogbone rear mount // CPE Dogdone Diff mount // COBB Shifter weight // HPFP Internals // Magnaflow 3IN Cat Back// Denso ITV 22s // Shorty Antenna // PA Engineering OCC // LED swap |
![]() | | #42 | ![]() |
![]() Join Date: Aug 2008 Location: Marlton, NJ
Rep Power: 470 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 620
How much does all this shit weigh?
__________________ 08.5 CWP MS3 - Cobb AP *Stage 2* ATR tweaked - Cobb SRI w/AEM dry flow filter - RPMC Inlet - Corksport TMIC - Corksport Downpipe (w/OE midpipe) - PTP HPFP - Stock BPV - TWM SS w/bushings - CP-e RMM - Bilstein Sports w/OE springs - Rota 18x8.5 48+ SVN Black/w Red Lip - Bridgestone Potenza RE760 - Cobb RSB - Prosport Boost Gauge/Mearcat pod - Motorcraft XT-M5-QS in the tranny! |
![]() | | #43 | ![]() |
![]() Join Date: May 2011 Location: Winston-Salem, NC
Rep Power: 431 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 411
All the parts, individually, are very light. The four point front brace only weighs a couple of pounds, and it's one of the larger single pieces. Side note- in being light, they're not indestructible. I'll try to snap a pic tomorrow, but my front brace has a decent dent in the top cross member. Two days after I bought the car, before I knew the bracing was there, I took it to a detail shop/wash. They couldn't pull the car through the machine because it was "too low" (stock height). The guiderail was hitting something. Put it on my buddys lift later that day and discovered everything. Dent is still there. Car still feels great. I've put 40k on it in ~17mos, including a trip to the Dragon.
__________________ 2007 Mazdaspeed3 GT Black Mica -~Corksport CBE, SRI, & TIP - Ultimate Racing TP - Autotech FP Internals - Forge V1 - NGK 1 step colder - Cobb RSB - Cobb AP - EBC Red Stuff/Stoptech Posiquiet - JBR SSP, SSB, & 88a RMM - Full GT-Spec chassis bracing - Rota Grids 18x8.5 - Michelin PSS 235/40~- ![]() |
![]() | | #44 | ![]() |
![]() Join Date: Apr 2009 Location: Monterey Park, CA
Rep Power: 70 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4
__________________ ///KW V2 Coilovers///AWR F&R///HyperTech-Tune///HKS Intake Black Edtion///Bilstein Sport///Eibach Pro-Kit///CP-E Rear Mount///CP-E Passenger Mount 75///CP-E Driver Mount 75///Hawks HPS F&R///Goodridge SS Brake Line///Hotchkis F&R///Corksport Front Endlinks///Turbo Smart Dual Port BOV///SPC Rear Camber Arms///Cobb Short Shifter///Cobb Red Knob///Cobb AP. Stg-1+Cobb SF+TIH+91///Cobb Downpipe///Cobb Exhaust///Cobb SF///Corksport Cobb SF Cold Air Box///IVT-22,0.028///Corksprort LED///Sure Turbo Inlet///Silicone Boost Hose///J-Speed SSP///Rally Armor Mud Flaps///JDM Window Visor///IR30 Tint///Yellow Fog Light Overlay///CPE-TowPlate///PTP Baffle Plate///MF Magnetic Tans & Oil Bolt/// | |
![]() | | #45 | ![]() |
| Needs GHES ![]() Join Date: Jun 2011 Location: Parma, OH
Rep Power: 398 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 292
Groaned at 6 Times in 3 Posts
Im interested on a 10 pc set!
__________________ Needs to install the GHES. |
![]() | | #46 | ![]() |
![]() Join Date: Jun 2008 Location: Bowling Green KY
Rep Power: 993 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 435
Groans: 35
Groaned at 45 Times in 37 Posts
I'm not lowered so no problem for me but I could see how someone slammed might scrape. My question to you then is if you are wanting your slammed car to handle better then un slam it. I love my set. I have Koni FSD's on stock springs with a Cobb rear sway. I don't have the front lower tie brace or a trunk brace. I might get the trunk cage someday but I don't see how the trunk brace would help much and tightening up the front too much on a FWD car will cause you to loose grip hence is why I still have the stock front sway and won't be putting on the front lower tie brace. There is a fitment issue with the front lower tie on the older ones. GTSPEC recently redesigned that part so it would fit.
__________________ Cobb AP // Stratified 20% E-85 // Cobb SRI Amsoil Dry // Cobb TIH // NGK 1 colder // Custom FMIC // Test Pipe // Forge BPV V1 (red) // Autotech // DCR VVTA // Koni FSD's // ACT 6 puck Prolite Fly // Cobb RSB // Chassis Braced // Sure SSP // JBR 88 RMM // JBR 70 PMM // CorkSport SS lines // Indy Fogs // DDM 6K HID // 6K LED fogs // FD's W/RE-11's // 13.196 @ 110.84 Last edited by 08cosmic3; 09-19-2012 at 06:45 PM. |
![]() | | #47 | ![]() |
Groans: 35
A company called Tigertunning has them in red slightly cheaper than GTSPEC but still much more expensive than the price Haltech got them for. I have 1 pc that's GT spec and the quality looks the same. Tiger Tuning | Mazda 3/Mazdaspeed 3 (2004 - 2009)
__________________ Cobb AP // Stratified 20% E-85 // Cobb SRI Amsoil Dry // Cobb TIH // NGK 1 colder // Custom FMIC // Test Pipe // Forge BPV V1 (red) // Autotech // DCR VVTA // Koni FSD's // ACT 6 puck Prolite Fly // Cobb RSB // Chassis Braced // Sure SSP // JBR 88 RMM // JBR 70 PMM // CorkSport SS lines // Indy Fogs // DDM 6K HID // 6K LED fogs // FD's W/RE-11's // 13.196 @ 110.84 |
![]() | | #48 | ![]() |
anyone running this chassis brace setup with H&R or Swift or Eibachs and not have any problems with scraping the bottom?
![]() | | #49 | ![]() |
![]() Join Date: Sep 2012 Location: Oceanside, CA
Rep Power: 16 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27
| Not Ranked : 0 score Interested! If you need a gen2 for fitment let me know, Im in your area
__________________ Current mods: Accessport, autotech internals, aem cai, 2.5" tip, ets tmic, ngk step colder plugs, streetunit racepipe, magnaflow exhaust, JBR short shifter plate, jbr rsb, sure street rmm, enkei fujin rims, snow performance stage 2 WMI, occ, PnP IM/TB (w/ vcts delete), IM tig, tb tig STRATIFIED (Part time corn fed) |
![]() | | #50 | ![]() |
![]() Join Date: Dec 2011 Location: howard, pa
Rep Power: 657 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,330
Groans: 44
Groaned at 14 Times in 5 Posts
50% off sale right now with tb performance if anybody is interested? TB Performance-Products | Facebook
__________________ |
![]() | | #51 | ![]() |
![]() Join Date: Feb 2012 Location: San Bernardino, CA
Rep Power: 2883 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,187
Groaned at 9 Times in 7 Posts
tapafuck | |
![]() | | #52 | ![]() |
__________________ 08.5 CWP MS3 - Cobb AP *Stage 2* ATR tweaked - Cobb SRI w/AEM dry flow filter - RPMC Inlet - Corksport TMIC - Corksport Downpipe (w/OE midpipe) - PTP HPFP - Stock BPV - TWM SS w/bushings - CP-e RMM - Bilstein Sports w/OE springs - Rota 18x8.5 48+ SVN Black/w Red Lip - Bridgestone Potenza RE760 - Cobb RSB - Prosport Boost Gauge/Mearcat pod - Motorcraft XT-M5-QS in the tranny! | |
![]() | | #53 | ![]() |
| Levi Tran is my bitch! ![]() Join Date: May 2011 Location: Alhambra, CA
Rep Power: 989 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,099
__________________ ![]() ![]() 2010 BM MS3 - Cobb AP||3gal corn||Autotech Internals||ETS TMIC||Forge BPV||Denso Iridium ITV22||TurboXS DP||ARK exhaust||CP-E Nano SRI||PG TIP||JBR RMM||JBR PMM||TRZ TMM||NRG ETD||DDM 55w 5000k HIDs and DDM 35w 3000k HID fogs||JB Heavy Knob||JB SSP||ST Coilovers w/ Eibach rear Camber Kit(made by SPC)||18x8 +47 Drag DR34-black/time attack red lip||HKS TT Type 0||Clarion EQ||MB Quarts speakers||Pioneer amps and 10" Competition Sub. 346hp 392lbs of sexyness | |
![]() | | #54 | ![]() |
![]() Join Date: Jul 2011 Location: Miami Beach, FL
Rep Power: 959 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,579
Groans: 49
Im intrested in this, waiting on Haltech's review to jump the gun. Constantin Im thinking of getting a trunk brace too, lmk when you install it i wanna see it. btw how much you getting it for??
__________________ ![]() Nator,FL BROTASTIC BROMOVEMENT ![]() Cobb AP//AEM custom sri//HTP tip//Ebay catted long dp//NJSPEED3 PnP'ed IM//PG piping kit w/ Treadstone tr8 core//Autotech FP internals//NGK step colder//HKS cbe//HKS bov VTA//JBR ssp,88d rmm,80d pmm,Rsb,camber arms,IM/TB tigs,egr delete,5mm spacers//BC br coils//NRG steering wheel w/ quick release,frp bucket seat,4 point harness,harness bar//JDM shift knob//Muteki lugs//Hawk hp plus pads ![]() Pump gas/E85 tune by ms3blackmica |
![]() | | #55 | ![]() |
![]() Join Date: Dec 2011 Location: Fort Lauderdale, FL
Rep Power: 1159 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,405
Hopefully I'll get it installed before AutoX.
__________________ 2008 MS3 Tuned by rfinkle2 on 93 - 321whp / 365wtq Cobb AP, SRI, TIH, DP, BPV | Autotech FP Internals | Treadstone TR8L + PG Pipe Kit | Grimmspeed EBCS | JBR TIGs, RSB, SSP & Bushings, EGR Delete, RMM (88dm), TMM (88dm), PMM (80dm) | MD OCC | KW V2 | SPC Camber Arm | GTSPEC Trunk Cage | Goodridge Break Lines + StopTech PowerSlot Rotors + Hawk HP+ | Whiteline End Links (front) | MOOG End Links (rear) | DDM 55w 5k Head Lights and Fog Lights | Speedline Mirrors Last edited by Constantin; 09-20-2012 at 09:04 PM. Reason: MSF Database - Automerged Doublepost | ||
![]() | | #56 | ![]() |
Groans: 44
Lol sorry guys I don't have them just saw the link figured I'd share.
| The Following User Says Thank You to exentix For This Useful Post: | Constantin (09-20-2012) |
![]() | | #57 | ![]() |
Groans: 49
| Not Ranked : 0 score yea im getting all of them. Im waiting for Haltechs review
![]() | | #58 | ![]() |
![]() Join Date: Jan 2012 Location: Sutton, Massachusetts
Rep Power: 824 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 239
Groaned at 29 Times in 11 Posts
I'm currently in the process of making a rear hatch brace. I already made bracing months ago for myself but I came up with a new idea that should take the guess work out of cutting the interior and be the cleanest set up. I see no need to brace anything except the rear strut towers. I'll post some pictures here when it's done.
__________________ 08.5' MS3 GT www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. |
| The Following 3 Users Say Thank You to dpolseno41 For This Useful Post: |
![]() | | #59 | ![]() |
![]() Join Date: Mar 2008 Location: 60607
Rep Power: 2144 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,441
Groans: 59
Lol. The MS3 doesn't have rear strut towers...
__________________ Stance is not a verb. |
![]() | | #60 | ![]() |
| Not Ranked : 0 score You know what I mean! I call them strut towers in my mind to keep it simple but admittedly I'm completely wrong in doing so haha This was my first crack at it. I've since taken out the cross bracing when I was lying under my car one day and realized it isn't doing shit when looking at how the body/ chassis is set up.
![]() | | #61 | ![]() |
![]() Join Date: Mar 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 812
Groaned at 102 Times in 66 Posts
honestly all this bracing shit is silly imo the only part of the car the needs tightening up is the ass end and at the most a rear tie bar (with rsb) is all you need.............maybe a hatch brace if you really want to go crazy but if you got the moniez, hey more power to you |
![]() | | #62 | ![]() |
| Eatin' Your Tuna ![]() Join Date: Feb 2008 Location: Nator HQ - San Diego, CA
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,284
Groans: 211
Polsen, nice braces... But why are you those spherical ends?
Welcome To http://www.mazdaspeedforums.org The HARDCORE Of Mazda High Performance Tech! COBB FMIC V2.0 | COBB SRI | COBB AP Stage 2 W/MSF_V1.08y | COBB 3" Downpipe | COBB CBE | Devil's Own Stage 2 Meth Injection | AST 4300 Coilovers | Haltech Fuel Pump Internals | Rota Torque 18x8 w/ 235/40/18 | ACT 6 PUCK Sprung/Streetlite ![]() | ||
![]() | | #63 | ![]() |
Groans: 59
Further to the point, even tying the tops of the two shocks together does very little, if anything, to better brace the car from suspension loading. Those shocks pretty much carry zero lateral load... Of course, bracing the shit out of open space in the hatch of the car (with the likes of a welded-in cage or similar) will increase the car's rigidity, but at the expense of cargo room, which was the reason a lot of us bought hatchbacks in the first place. Furthermore, the tangible handling benefits of doing something like that on a car that is still utilizing rubber suspension bushings are for all intents and purposes imperceptible...
__________________ Stance is not a verb. | |
![]() | | #64 | ![]() |
Groans: 211
Not sure why the are tying to top of the shocks together.
![]() | | #65 | ![]() |
Groans: 59
If you want to increase rear rigidity in a meaningful way, you need to tie the rear underfloor (where the subframe bolts up) directly to a bracing system that utilizes decent cage geometry (and that is tied into the roof and sides in multiple places)...
![]() | | #66 | ![]() |
Groans: 211
Since this cars subframe uses bolts and the front portion requires its subframe to be unbolted to remove the front swaybar, I wouldn't recommend welding in subframe connectors. However, subframe connectors will greatly remove unwanted flex while tying the front to the rear. We could in theory, build bolt in subframes connectors, although not as strong as welding, to facilitate in a stronger chassis. None of our cars are really race cars.... So a cage is out and very dangerous to have in a daily driver. So we have to become a bit creative in our endeavors. The aftermarket really hasn't addressed flex in our chassis. But it's there... Especially innthe rear hatch area... And a good majority of it CAN be removed without having to take extreme measures.
![]() | | #67 | ![]() |
| 708 ![]() Join Date: May 2008 Location: Maple Valley, WA
Rep Power: 44457 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21,836
Groaned at 26 Times in 22 Posts
__________________ I'm doing it wrong, just ask all the other Mazda DISIs making 700+HP ![]() | |
| The Following User Says Thank You to Erich For This Useful Post: | guitarzan134 (09-23-2012) |
![]() | | #68 | ![]() |
Do it the right way and inject some foam into ur chassis lol
![]() | | #69 | ![]() |
![]() Join Date: Apr 2010 Location: Louisville, KY
Rep Power: 63 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 229
Been wanting to do this for awhile now. Looking forward to Haltech's review.
![]() | | #70 | ![]() |
__________________ 08.5' MS3 GT www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. | |
![]() | | #71 | ![]() |
Groans: 59
"Strut towers" carry lateral suspension loads. The rear "shock towers" do not. A parallel bar along the floor of the car connecting the areas where the rear subframe bolts up will do way more than any bar stretched between the vertical sides of the rear cargo area, I don't know why you're throwing talk about the front subframe into this conversation, as I never mentioned it... You guys are chasing the sun with these stupid bolt-in hatch cargo area "braces." Until I see a true before/after chassis rigidity study to prove their worth, I won't be putting much stock into them.
__________________ Stance is not a verb. Last edited by Nliiitend1; 09-23-2012 at 10:03 AM. Reason: typo | |
| The Following User Says Thank You to Nliiitend1 For This Useful Post: | Manny (09-23-2012) |
![]() | | #72 | ![]() |
![]() Join Date: May 2011 Location: Washington, DC
Rep Power: 185 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 288
Groaned at 36 Times in 18 Posts
I need these in my life! Just got a set of H&R Streets, and in the summer im throwing on some Sonic tuning wheels 8.5" with 235 Nitto NT05s, then im going Evo hunting! Haltech will you be helping us MS6s out. Were like the abortions that just happened to survive. So we're hated through life. Lol
__________________ CorkSport SRI/TIP w/ AirBox -- CP-e 3.25" TMIC -- AutoTech HPFP -- Magnaflow Catback -- Sure Dreadnaught -- Denso ITV22 -- Cobb AccessPORT Stg. 1+SF -- StopTech Slotted Rotors -- EBC Redstuff Pads -- White Line RSB--AWR Endlinks--H&R Coilovers--XXR 522--BFG Comp-2's 245s--ATP FAILpipe Yet to install: Rich Tune |
![]() | | #73 | ![]() |
Groans: 211
Subframe connectors are relative to this conversation... And it wasn't written in context to your comment directly. What you just described in your owns words was a subframe connector. I do believe a box has 4 sides... if you reinforce only 2 sides, you are left with two sides vulnerable. IF you tie one of those sides into a V, you are left with one unprotected side... Are you tracking yet? Your worthless lateral bar now comes into play here... You can use it, top or bottom to tie the fourth side together. If you cannot be constructive in this conversion, then stay just stay out of it.
Welcome To http://www.mazdaspeedforums.org The HARDCORE Of Mazda High Performance Tech! COBB FMIC V2.0 | COBB SRI | COBB AP Stage 2 W/MSF_V1.08y | COBB 3" Downpipe | COBB CBE | Devil's Own Stage 2 Meth Injection | AST 4300 Coilovers | Haltech Fuel Pump Internals | Rota Torque 18x8 w/ 235/40/18 | ACT 6 PUCK Sprung/Streetlite ![]() Last edited by Haltech; 09-22-2012 at 11:02 AM. Reason: MSF Database - Automerged Doublepost | |||
![]() | | #74 | ![]() |
| Stage 2 Waiting for corn ![]() Join Date: Apr 2008 Location: San Diego, CA
Rep Power: 290 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 412
Kevin vs Nliiitend1 (sp?) in a suspension war. Great lernin here for everyone. I've had gt spec knock offs from China for about 3 years now. One of the pieces they replace weighs 10 lbs, so I don't know why anyone would think they weigh more. My impression is that they most fucking definitely help reduce chassis flex. This helps other suspension components and systems do their jobs better. This also allows springs and danpeners from having to be stiffer, helping with everyday comfort and compliance. These braces make me feel like the weak part of the suspension is now the tire grip. Right now, I think r compound tires would show the next component weakness. That could very well be the tops of the rear shocks. Think about it, mazdaspeed dudes improved two things regarding the chassis, the front towers and the rear. I believe they would have also put a bar across the rear if they thought they could get away with it. Sent while sitting on the throne. Last edited by Ferdball; 09-22-2012 at 11:29 AM. Reason: Fucking autocorect |
![]() | | #75 | ![]() |
| Not Ranked : 0 score ![]() Stealth black is the way to go, by the way. |
| The Following User Says Thank You to Ferdball For This Useful Post: | Tomas (09-29-2012) |
![]() | | #76 | ![]() |
Gentlemen, lets do some testing. I'm willing to be the test subject for the trunk brace. I have all stock suspension, besides JBR RSB and end links. At ~73k miles, my suspension is quite floppy. Now, I don't track the car, but there is an AutoX coming up. What I can do 1/2 runs w/o trunk brace and 1/2 with trunk brace. I will need your help finding out how to properly measure the differences. Is there a tool to measure it? For example if the string is tied in the trunk with the measuring tool in the middle that will show the tension on the string? Tomas, from seeing your post here and there, it seems like you have a vast suspension experience. Will be nice to hear from you about the entire subject.
__________________ 2008 MS3 Tuned by rfinkle2 on 93 - 321whp / 365wtq Cobb AP, SRI, TIH, DP, BPV | Autotech FP Internals | Treadstone TR8L + PG Pipe Kit | Grimmspeed EBCS | JBR TIGs, RSB, SSP & Bushings, EGR Delete, RMM (88dm), TMM (88dm), PMM (80dm) | MD OCC | KW V2 | SPC Camber Arm | GTSPEC Trunk Cage | Goodridge Break Lines + StopTech PowerSlot Rotors + Hawk HP+ | Whiteline End Links (front) | MOOG End Links (rear) | DDM 55w 5k Head Lights and Fog Lights | Speedline Mirrors |
![]() | | #77 | ![]() |
![]() Join Date: Jun 2012 Location: Vancouver, BC
Rep Power: 0 ![]() ![]() Thanks: 12
In for sub. Haltech is $225 shipped? I would be very interested. I don't think it would be a problem to grab more than a handful together to purchase these parts, maybe not 100, but 30ppl probably shouldn't be a problem. The Genwon MS3 is a lot stiffer than my old car, but not as stiff as I like it to be |
![]() | | #78 | ![]() |
Groans: 211
![]() | | #79 | ![]() |
Did you get your shipment yet? I do want to know how much lower it hangs compared to stock. Its a good mod cause the girlfriend can't see it. | |
![]() | | #80 | ![]() |
![]() Join Date: Jul 2010 Location: Rowland Heights, California
Rep Power: 111 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 77
If they turn out to be ok, group buy?!?!! :p
| TB performance braces? | snailD | 2010 MS3 - Suspension & Brakes | 27 | 03-28-2013 11:54 PM |
| GT Spec Chassis Braces Install | bugsy3823 | MazdaSpeed 3/6 - Suspension & Brakes | 58 | 07-24-2012 09:54 PM |
| Pu smile w/ braces | Prestige | Exterior | 19 | 06-16-2012 08:26 PM |
| AX and GT Spec braces | Obey the Speed | Auto-X / Road Racing / Time Attack | 16 | 01-19-2011 07:09 PM |
