| MazdaSpeed 3/6 - Suspension & Brakes Discussion for suspension items like coilovers, springs, sway bars, mounts,chassis bracing and brakes. |
![]() | | #121 | ![]() |
![]() Join Date: Apr 2009 Location: Monterey Park, CA
Rep Power: 71 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4
| Not Ranked : 0 score
__________________ ///KW V2 Coilovers///AWR F&R///HyperTech-Tune///HKS Intake Black Edtion///Bilstein Sport///Eibach Pro-Kit///CP-E Rear Mount///CP-E Passenger Mount 75///CP-E Driver Mount 75///Hawks HPS F&R///Goodridge SS Brake Line///Hotchkis F&R///Corksport Front Endlinks///Turbo Smart Dual Port BOV///SPC Rear Camber Arms///Cobb Short Shifter///Cobb Red Knob///Cobb AP. Stg-1+Cobb SF+TIH+91///Cobb Downpipe///Cobb Exhaust///Cobb SF///Corksport Cobb SF Cold Air Box///IVT-22,0.028///Corksprort LED///Sure Turbo Inlet///Silicone Boost Hose///J-Speed SSP///Rally Armor Mud Flaps///JDM Window Visor///IR30 Tint///Yellow Fog Light Overlay///CPE-TowPlate///PTP Baffle Plate///MF Magnetic Tans & Oil Bolt/// |
![]() | | #122 | ![]() |
![]() Join Date: Mar 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 812
Groaned at 102 Times in 66 Posts
| The Following User Says Thank You to TRex For This Useful Post: | Constantin (09-24-2012) |
![]() | | #123 | ![]() |
![]() Join Date: Dec 2011 Location: Fort Lauderdale, FL
Rep Power: 1187 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,415
| Not Ranked : 0 score So, I looked at my engine bay today to take a closer look at those brackets. I took some pictures. Is that what you are talking about? In my situation, only one bolt is attached, to (what seems to be) plastic. Which, I don't see how it can help more then front strut tower. I didn't find anything going to the firewall... Please point me in the right direction. Because I'm ether looking in the wrong place, or I just don't have those brackets.
__________________ 2008 MS3 Tuned by rfinkle2 on 93 - 321whp / 365wtq Cobb AP, SRI, TIH, DP, BPV | Autotech FP Internals | Treadstone TR8L + PG Pipe Kit | Grimmspeed EBCS | JBR TIGs, RSB, SSP & Bushings, EGR Delete, RMM (88dm), TMM (88dm), PMM (80dm) | MD OCC | KW V2 | SPC Camber Arm | GTSPEC Trunk Cage | Goodridge Break Lines + StopTech PowerSlot Rotors + Hawk HP+ | Whiteline End Links (front) | MOOG End Links (rear) | DDM 55w 5k Head Lights and Fog Lights | Speedline Mirrors |
![]() | | #124 | ![]() |
did you touch it? put your hand on the under side of the bracket and follow it, there are 2 bolts, and they are bolting into a metal ledge if you continue to follow that ledge as it curves downward you will see that it is a continuous piece and is in fact the fire wall | |
| The Following User Says Thank You to TRex For This Useful Post: | Easter Bunny (09-30-2012) |
![]() | | #125 | ![]() |
Learned something new today
__________________ 2008 MS3 Tuned by rfinkle2 on 93 - 321whp / 365wtq Cobb AP, SRI, TIH, DP, BPV | Autotech FP Internals | Treadstone TR8L + PG Pipe Kit | Grimmspeed EBCS | JBR TIGs, RSB, SSP & Bushings, EGR Delete, RMM (88dm), TMM (88dm), PMM (80dm) | MD OCC | KW V2 | SPC Camber Arm | GTSPEC Trunk Cage | Goodridge Break Lines + StopTech PowerSlot Rotors + Hawk HP+ | Whiteline End Links (front) | MOOG End Links (rear) | DDM 55w 5k Head Lights and Fog Lights | Speedline Mirrors | |
![]() | | #126 | ![]() |
like this? ![]() yea that is certainly a great way to do it what i dont like about this setup though is that the bar going from the strut tower to firewall is very long, so that provides a huge moment arm for lateral forces to act through that is probably why the used a tie between the strut towers to increase rigidity, because the way the firewall bracing was done was not sufficient alone our setup uses very very short arms (as you can see) and is much much more rigid than this evo's firewall bracing alone EDIT: after looking at this some more, the moment arm is really no longer than ours as the lateral loads will be acting on a moment arm that extends the fore/aft direction you can see here http://i.imgur.com/iP8U0.jpg the green is the ours and the blue is evo ....the evo has a nice triangle that is very very very rigid....it is indeed more rigid than our setup due to the strut tie, when viewed from the top, indeed this shape is ideal, but there is another direction, when viewed straight on you can see that the strut tie is slightly raised, that means there is a moment arm and forces are not being imparted directly in line with the bar, that means that bar is subject to bending, the firewall connection is also subject to bending, but the shape of the firewall is much more resistant to bending so is the evo's setup better? yes, because race car will adding a strut tie to the top make your setup up stiffer? yes (but the cost vs. value is very high imo and not worth it) will you notice the difference? doubtful....but if someone has hard evidence of increased lap times or lateral g holding i would love to see it will removing the stock brackets and replacing it with a strut tie be a better setup? no, absolutely not, you have greatly reduced the rigidity by taking the stock connections out should i buy a top strut tie? imo, no....but if you are swimming in disposable income, have bought every other mod on the planet for this car, and want some engine flair....then maybe....sort of...if you want to should i buy lower ties? i would, see this picture http://i.imgur.com/IY0hh.jpg basically what the lower braces are doing is creating a rigid box that doesnt exist with the factor setup arguable exhaust tunnel bracing would be beneficial as well, but i personally cant quite grasp the loads occurring there as easily as i can at the suspension, but again on those, if you got the money...go for it Last edited by TRex; 09-25-2012 at 08:39 AM. |
| The Following 3 Users Say Thank You to TRex For This Useful Post: |
![]() | | #127 | ![]() |
| Not Ranked : 0 score TRex thank you for even more detailed explanation! Personally, I would not buy the front strut tower brace by itself, but if it come in the kit that Heltech is working on, I'll install it anyway. Unless some by buys it from me for like $100 ![]() Now, speaking about testing. Is there a way to test the different loads? I offered to test the trunk cage, but to no avail so far.
![]() | | #128 | ![]() |
well, without getting crazy about it with like strain gauges all over body the only real way to test would be lap times on a course (which is tough because there are so many variables) or a skid pad test (http://en.wikipedia.org/wiki/Skidpad)...because essentially chassis flex reduces traction....so if you were able to travel faster and achieve higher g's without going outside the radius of the pad then your braces are helping you....but even that is a hard test to replicate for a common person because of the instrumentation needed unfortunately without some financial backing it really comes down to whether or not you have felt a deference.....and some of these improvements will let you tell a major difference the rear sway bar for example, is a major change and very easily noticed, the tie bars i think would come next on the feel scale, and the rest would have less of a noticeable feel |
| The Following 2 Users Say Thank You to TRex For This Useful Post: | Constantin (09-26-2012), Ms3_Miami (09-26-2012) |
![]() | | #129 | ![]() |
if you were to take a car and do some hot lap and take it on the skid pad then use a thermal gun couldn't you find the flex points on the car that needs to be reinforced? wouldn't the twisting and turning of the car flex the metal then cause heat to be generated on weak points of the car?
![]() | | #130 | ![]() |
| Monk Tuning ![]() Join Date: Dec 2010 Location: Humble, TX
Rep Power: 886 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,049
I imagine the heat would dissipate rather quickly due to the surface area of air surrounding the stress points, and due to the thin material being measured.
__________________ 2011 Speed3-CP-E Stage 2 RMM, JBR TMM, JBR SSP, JBR SSB, 3.5" JBR WP, DDM 55w 6000k, Hoen Fog Lights, Autotech Internals, Enkei 17x8.5 RPF1, TIGs, EGR Delete, OCC, Treadstone TR8, FoMoCo Trans Fluid, Swift Springs, BSD and Baffle Kit, Ported Intake Manifold ala Driver311, CPE Injector Seals,PTP injector stud kit, RB Fabrication Ex Manifold, PTP 1950 Rail valve, ITV22s, Cordova Throttle Body, E85 blend Tuned by ME!!! Waiting to install- JTMS3 SUB BOX!!! TEAM LBN BEERS -- FYCN TEAM MUMFORD -- FYCN |
![]() | | #131 | ![]() |
| Now with BNR Power ![]() Join Date: Jan 2010 Location: El Cajon, CA.
Rep Power: 849 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,188
Groaned at 10 Times in 9 Posts
| Neutral : +1 score
__________________ www.MOTOIQ.com 2010 LSM Mazdaspeed3 | |
| The Following 2 Users Say Thank You to Todd98SE For This Useful Post: | Nliiitend1 (09-28-2012), TRex (09-30-2012) |
![]() | | #132 | ![]() |
| Veblen Goods ![]() Join Date: Jan 2009 Location: Dania Beach, FL
Rep Power: 2126 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,375
This is a great thread and I have two questions: 1. It appears many who autox like to either not use a stiffer front sway bar or remove the stock one altogether or use stiffer springs in the front. Now why would you want to stiffen the chassis in the front if you use a stock sway bar or even no sway bar? Sort of seems counter intuitive to me. How do you compare a stiffer FSB against engine cradle bracing? I mean... why would you want a stiffer structure in the front if the vehicle is till going to roll/lean in the front in a corner? 2. When are these fucking china braces being installed by Haltech?
__________________ ![]() GHEY THUNDER Last edited by Tomas; 09-29-2012 at 10:28 PM. | |
| The Following 3 Users Say Thank You to Tomas For This Useful Post: |
![]() | | #133 | ![]() |
| Neutral : +1 score
However this lack of roll resistance in the front also leads to camber loss under bump which contributes to a reduction in cornering ability and overall stability. I'm not going to say no front swaybar is a AutoX only type of thing but it is much more prevalent in that type of motorsport especially with the relatively low cornering speeds encountered in AutoX. Now jump onto a road course and in most cases the lack of a front swaybar is a quick way to spin the first time you enter a really high speed sweeper. The car is "harder" to drive as it can become twitchy and less predictable in a corner. Typically you have the big bars, softer springs approach and the small bars, heavy springs approach to suspension setup. Each one has its advantages and disadvantages and is entirely dependent on the chassis and driver preference. Neither is "better" than the other, just different. Personally I prefer the big bars, softer springs approach on a MacPherson strut car and small bars, heavy springs approach on a SLA (double wishbone) car but my experience is relatively limited compared to some of the other guys on this board. A stiffer structure is better no matter what, but a stiffer chassis simply allows your suspension to do more of its job instead of losing its ability to dampen due to flex and minute geometry changes. For at least Gen2 MS3's I think your money is better spent on betters dampers and bushings before you worry about increasing chassis stiffness. Also a little tidbit on these different approaches, Japanese motorsport chassis engineers traditionally favor a chassis with some flex in it believing it is essential to maintaining grip on irregular surfaces. You can see this in their relatively minimal cage designs. American chassis engineers like the stiffest chassis possible and let the suspension handle the damping. Compare the cage designs in your typical Japanese built time attack or D1 car versus the American designed car and you can see this philosophy. I am interested in hearing others opinions.
| The Following 12 Users Say Thank You to Todd98SE For This Useful Post: | Constantin (10-01-2012), Cpt_Rum-bo (10-02-2012), daafisch (09-30-2012), IE.SD.Manny (10-04-2012), Lex (09-30-2012), Micha (10-08-2012), Nliiitend1 (09-30-2012), skiptowncat (09-30-2012), smoogs12 (09-30-2012), super_pablo_ (09-30-2012), Tomas (09-29-2012), TRex (09-30-2012) |
![]() | | #134 | ![]() |
i have to agree with todd88 the front strut might not be need if ur only going to be maxing out 2nd gear all the time. but on high speed turns u can feel the car flexing and when it flex it turns funny and you have to take a different line then you would like.
![]() | | #135 | ![]() |
| Neutral : +1 score
The bar I'd be most interested in is the front lower tie bar. http://www.corksport.com/corksport-m...arm-brace.html The front mount for the control arm is cantilevered out away from the subframe with nothing to add to its rigidity. The lower tie bar would probably be fairly helpful in minimizing geometry changes.
| The Following 3 Users Say Thank You to Todd98SE For This Useful Post: |
![]() | | #136 | ![]() |
![]() Join Date: Oct 2008 Location: Carson, CA
Rep Power: 580 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 100
Groaned at 53 Times in 26 Posts
Tie brace is cheap enough and would offer marginally enough rigity to buy... I don't understand why more are not talking about the ladder and rear subframe brace. These 2 braces actually connect the subframe to the chassis. This to me would offer the greatest improvement.
__________________ *COBB: AP, shifter weight *CP-e: Stage 2 RMM ,TMIC *JBR: RSB, 88TMM, EGR delete, WP *Grimmspeed: EBCS *TWM: Full Shifter *Tomei: Shift knob *KDM: HPFP internals *Ford: syn trans fluid *UR: TP, CBE *Bremmer Kraft:18x8 et45 BR05 (5mm rear spacers) *Dunlop: 245/40/18 Sport Maxx TT * Bilstein: B8 Sport *SWIFT: Spec-R springs *gtspec: 4point ladder brace, rear subframe brace * AC DELCO : Adj. camber arms *Denso:ITV22 *Stoptech: Performance pads *MORIMOTO: 5K HID elite *OEM: Gutted primary cat |
![]() | | #137 | ![]() |
__________________ ///KW V2 Coilovers///AWR F&R///HyperTech-Tune///HKS Intake Black Edtion///Bilstein Sport///Eibach Pro-Kit///CP-E Rear Mount///CP-E Passenger Mount 75///CP-E Driver Mount 75///Hawks HPS F&R///Goodridge SS Brake Line///Hotchkis F&R///Corksport Front Endlinks///Turbo Smart Dual Port BOV///SPC Rear Camber Arms///Cobb Short Shifter///Cobb Red Knob///Cobb AP. Stg-1+Cobb SF+TIH+91///Cobb Downpipe///Cobb Exhaust///Cobb SF///Corksport Cobb SF Cold Air Box///IVT-22,0.028///Corksprort LED///Sure Turbo Inlet///Silicone Boost Hose///J-Speed SSP///Rally Armor Mud Flaps///JDM Window Visor///IR30 Tint///Yellow Fog Light Overlay///CPE-TowPlate///PTP Baffle Plate///MF Magnetic Tans & Oil Bolt/// | |
![]() | | #138 | ![]() |
![]() Join Date: Nov 2010 Location: 93401
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 373
Groaned at 4 Times in 2 Posts
Does the ms6 have those stock firewall braces? Because I had a front tower bar when I got the car and I don't want to be compromising anything. Sent from my ADR6300 using Tapatalk 2
__________________ Corksport 3" catless DP - Magnaflow CBE - KMD fuel pump internals - Cobb AP Stage 2 tune - Koni yellow struts - H&R springs _ (Looking for BT) |
![]() | | #139 | ![]() |
![]() Join Date: Mar 2008 Location: 60607
Rep Power: 2151 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,489
Groans: 59
I highly doubt it, as the MS6 has a double-wishbone front suspension. The front damper/spring assembly is not a locating member with regard to the suspension geometry, and doesn't see near the same kinds of forces that the top of a MacPherson strut damper/spring assembly sees.
__________________ Stance is not a verb. |
![]() | | #140 | ![]() |
With the same set up in the rear, a stiffer front sway bar increases roll stiffness --> more understeer. Ok agreed. This same increase in roll stiffness leads to reduced negative camber on the outer front tire under bump. OK also agreed. But then you are saying that this reduction in negative camber under bump reduces cornering ability / stability. Well... yes and no. You will loose a few decimals of negative camber since the car won't lean so much. But does that mean that the added roll stiffness is not worth the trouble since the inability of the vehicle to load the front tires with more negative camber will sort of negate the benefit of the added roll stiffness? I'd have to argue against that statement. I was of the impression that the autoxer crowd liked small, or no sway bars in the front so they could rotate the rear better in tighter turns when breaking into them. I.e. brake in oversteer. Not to improve cornering stability. Put in a different way: would you say that added chassis stiffness in the front will increase or decrease outer front tire camber under bump in a turn? I have also heard the big bar soft spring on macpherson and small bar stiff springs on double A arms theory. To a degree it makes sense since the camber curve for A arms is much better than Mcpherson. But I have also heard most nascar teams are actually steering away from that set up and using more bar now a days and less spring. The decision which way to go will depend a lot on road condition of course, but the overall trend seems to be in that direction.
__________________ ![]() GHEY THUNDER Last edited by Tomas; 09-30-2012 at 02:16 PM. | |
| The Following User Says Thank You to Tomas For This Useful Post: | vrspeed10 (10-06-2012) |
![]() | | #141 | ![]() |
Now here is the tradeoff, larger bars increase weight transfer to the outside wheel in a turn meaning the outside tire has to do more work than the inside tire. The trick is to find the sweetspot in preserving the largest contact patch via camber preservation while not overloading the outside tire. Hopefully I explained that better. Introducing the relationship between roll couple and camber curve into this thread would further clarify things but I probably dont know enough about it to explain it correctly. Anyone interested in a very detailed look into suspension design and theory should read all the parts in this article. Mr. Kojima is a genius especially when talking about suspension and I think he does a good job in translating the complex engineering into terms and ideas that can be understood by anybody. The Ultimate Guide to Suspension & Handling
![]() | | #142 | ![]() |
Well, the camber curve on a mcpherson strut gains camber as the control arm moves upward up to the point where it is perpendicular to a horizontal line crossing the middle of the vehicle. Only after that does the wheel start losing camber. Regardless, I just want to understand why someone would want to stiffen the chassis in the front without first using a stiffer FSB. May be I am missing something but stiffening up the chassis in the front should only be considered after reducing roll IMO. Be it via stiffer springs or sway bars. I just don't see the benefit of the front bracing without reducing front roll first. I look at it the same as the rear. Why would you want to tie down the whole rear subframe with braces without first using a stiffer RSB?
__________________ ![]() GHEY THUNDER |
![]() | | #143 | ![]() |
| Eatin' Your Tuna ![]() Join Date: Feb 2008 Location: Nator HQ - San Diego, CA
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,296
Groans: 212
Us road racers use the sways for entry/exit entry stability due to our higher speed, braking, throttle, etc. Personally, i would run a larger front sway bar and a rear adjustable. The only way to get better in autox or road racing, is... being thrown in with tougher competitors anyways.
Welcome To http://www.mazdaspeedforums.org The HARDCORE Of Mazda High Performance Tech! COBB FMIC V2.0 | COBB SRI | COBB AP Stage 2 W/MSF_V1.08y | COBB 3" Downpipe | COBB CBE | Devil's Own Stage 2 Meth Injection | AST 4300 Coilovers | Haltech Fuel Pump Internals | Rota Torque 18x8 w/ 235/40/18 | ACT 6 PUCK Sprung/Streetlite ![]() | ||
| The Following User Says Thank You to Haltech For This Useful Post: | daafisch (10-02-2012) |
![]() | | #144 | ![]() |
I have started to participate in local AutoX's. Have been only in 3, so have very little experience. However, since FWD = "point and shoot"; i.e. exiting the corner is very important. I am finding out that entering the corner at lower speed, and good positioning for the exit yields better times. So, would it be beneficial to have a tighter front (with FSB) for better corner exit?
![]() | | #145 | ![]() |
look, at the end of the day more front bar means more understeer period, no way around it if you are ok with that, and also like the benefits of a heavy front bar (snappier steering response, a stiffened feel), then by all means use it it is just a different way to do things |
| The Following User Says Thank You to TRex For This Useful Post: | Constantin (10-02-2012) |
![]() | | #146 | ![]() |
![]() Join Date: Aug 2011 Location: Coral Springs, FL
Rep Power: 124 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 236
__________________ Had: 2011 Black Speed3 - In speed heaven Now: 05 Miata MX-5 LS - still has iracing driver mod | |
| The Following User Says Thank You to Cpt_Rum-bo For This Useful Post: | Constantin (10-02-2012) |
![]() | | #147 | ![]() |
| The Following 4 Users Say Thank You to Todd98SE For This Useful Post: |
![]() | | #148 | ![]() |
![]() Join Date: Jun 2011 Location: Wilmington, Delaware
Rep Power: 329 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 600
Groaned at 25 Times in 10 Posts
| Not Ranked : 0 score Todd98SE heeltoe Tomas Hey guys i have been trying to read up on some but looking for some input. I am looking to mod my suspension. Its my daily driver with the ocational 1/4mile and would like to do some road course classes. This is my list so far. tripoint eng rsb & adj end links, corksport adj camber arm, gtspec ladder, trunk, rear subframe and front lower tie braces, whiteline anti lift kit and rear bump steer bushings. Now here is where i need help. I have eibach pro kit but want to go a little lower. So this is what i was thinking. Sonic tuning CO but i think its to much and not really needed?? or swapping out the eibachs for swift springs that lower it a bit more but will be able to run stock shocks. Now for my case would stock shocks be good?? For the cost of springs and aftermarket shock i should just by coilovers right? than i would be able to adj my ride height if i please. I am also woried that CO for a DD would be to harsh. Thanks guys for your input..
__________________ If your not first your last. ![]() 03 Speed Protege.. SOLD 10 Speed3 Bolted and getting Dizzy!! |
![]() | | #149 | ![]() |
i dont know if you want to go any lower if its ur DD and you have under braces. but if the gap is what concerns you then how about thicker side walls on the tire? and get rid of those stock shocks if your using aftermarket springs.
![]() | | #150 | ![]() |
You don't want to go lower, you should go to stock height or just below with some decent coilovers like H&R or KW. Lower just equals a shittier camber curve, shittier roll center, and worse handling. Swift springs with some Bilsteins would be good if you don't want coilovers.
| The Following 2 Users Say Thank You to Todd98SE For This Useful Post: | Nliiitend1 (10-07-2012), TRex (10-07-2012) |
![]() | | #151 | ![]() |
| Not Ranked : 0 score well the eibachs only lower it .75" the swift will lower it to 1.2" and can be used with stock shocks without blowing them.
![]() | | #152 | ![]() |
Haltech you going order yourself a set of these braces for Christmas ? lol
__________________ ///KW V2 Coilovers///AWR F&R///HyperTech-Tune///HKS Intake Black Edtion///Bilstein Sport///Eibach Pro-Kit///CP-E Rear Mount///CP-E Passenger Mount 75///CP-E Driver Mount 75///Hawks HPS F&R///Goodridge SS Brake Line///Hotchkis F&R///Corksport Front Endlinks///Turbo Smart Dual Port BOV///SPC Rear Camber Arms///Cobb Short Shifter///Cobb Red Knob///Cobb AP. Stg-1+Cobb SF+TIH+91///Cobb Downpipe///Cobb Exhaust///Cobb SF///Corksport Cobb SF Cold Air Box///IVT-22,0.028///Corksprort LED///Sure Turbo Inlet///Silicone Boost Hose///J-Speed SSP///Rally Armor Mud Flaps///JDM Window Visor///IR30 Tint///Yellow Fog Light Overlay///CPE-TowPlate///PTP Baffle Plate///MF Magnetic Tans & Oil Bolt/// Last edited by heeltoe; 10-07-2012 at 04:00 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #153 | ![]() |
Groans: 59
__________________ Stance is not a verb. | |
| The Following User Says Thank You to Nliiitend1 For This Useful Post: | Todd98SE (10-07-2012) |
![]() | | #154 | ![]() |
.. So with so many opions out there whats your opions Coilovers or shocks and spring?? they will both be about the same price in the end
__________________ If your not first your last. ![]() 03 Speed Protege.. SOLD 10 Speed3 Bolted and getting Dizzy!! | |
![]() | | #155 | ![]() |
__________________ www.MOTOIQ.com 2010 LSM Mazdaspeed3 Last edited by Todd98SE; 10-07-2012 at 07:12 PM. | |
![]() | | #156 | ![]() |
The speed 6 does gain camber in turns in case anyone's wondering. As in it gets more negative. Not sure about the 3. Sent from my ADR6300 using Tapatalk 2
![]() | | #157 | ![]() |
| Not Ranked : 0 score Yep the Speed6 has an double A-arm or SLA front suspension much like an older Honda. Unfortunately the Speed3 is stuck with a much less desirable mac strut setup.
| The Following 2 Users Say Thank You to Todd98SE For This Useful Post: | dot584 (10-07-2012), Nliiitend1 (10-07-2012) |
![]() | | #158 | ![]() |
__________________ ![]() GHEY THUNDER | |
![]() | | #159 | ![]() |
![]() Join Date: May 2011 Location: Riverside/San Diego
Rep Power: 62 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 64
I'm loving all this info. Subbed. Here is a hatch view of a Grand Am Gen2 Speed3. Might help determine what needs to be done to stiffen up a street driven MS3 with braces or may start another argument.
__________________ ![]() Last edited by IE.SD.Manny; 10-08-2012 at 12:38 AM. |
![]() | | #160 | ![]() |
^no it only shows the best way to do it as Nliiitend1 said....you can see where they welded it into the floor i still think it stands that the trunk BOLT in bracing is meh |
| The Following User Says Thank You to TRex For This Useful Post: | Nliiitend1 (10-08-2012) |
| TB performance braces? | snailD | 2010 MS3 - Suspension & Brakes | 27 | 03-28-2013 11:54 PM |
| GT Spec Chassis Braces Install | bugsy3823 | MazdaSpeed 3/6 - Suspension & Brakes | 58 | 07-24-2012 09:54 PM |
| Pu smile w/ braces | Prestige | Exterior | 19 | 06-16-2012 08:26 PM |
| AX and GT Spec braces | Obey the Speed | Auto-X / Road Racing / Time Attack | 16 | 01-19-2011 07:09 PM |
