 Old 02-07-2011, 07:06 PM   #1
dukebrown's Avatar
Posts: 264   (View Stats)
dukebrown is the leader of the worlddukebrown is the leader of the worlddukebrown is the leader of the worlddukebrown is the leader of the worlddukebrown is the leader of the worlddukebrown is the leader of the worlddukebrown is the leader of the worlddukebrown is the leader of the worlddukebrown is the leader of the worlddukebrown is the leader of the worlddukebrown is the leader of the world
Default Coil Spring Spacers
I am looking for a 1" coil spring spacers. I am a big'n and I always carry a 40lb tool bag in the back of my car and I have bearly in spec camber in the rear.
So I am looking to go beefier such as the Cobb but I am not looking to ride lower. My jack only has 1/4" clearance as is.
Have yall seen spacers so I can keep stock ride height?
GM coil spring spacer pictured in the thread.
That pic is in a Miata. Damn midget mobile. Seat was all the way back.
Mods: Turbo Inlet, Short Ram, IDRVSLO's L2AIC, TRZ RMM, Shifter Bushings, PG Mani, CS DP,HF Cat, DS Trans Mount, Stiffened Passenger MM, CDFP Internals, Saikou Michi OCC, DIY BS Delete, DIY Windage Tray. Falken 235/45 17 7.5
dukebrown is offline   Reply With Quote
 Old 02-07-2011, 07:10 PM   #2
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
ok dude..am i on crack or is there a thread about this shit that u posted on close by??
wtf man
 Old 02-07-2011, 07:14 PM   #3
dukebrown's Avatar
Ya that was an old post the dude was asking about the mr gasket donut. I am not looking to reduce the coil compression like he was. I want stock height maintained.
 Old 02-07-2011, 07:16 PM   #4
Fuck sushi rolls
rodrigo's Avatar
Groans: 356
didnt u sell or werent u selling the car?
 Old 02-07-2011, 07:22 PM   #5
dukebrown's Avatar
No I was wanting to sell my stock parts and a few other items. I know you are just being mesmerized by my zexy legs in the pics. I understand.
 Old 02-08-2011, 08:23 AM   #6
thewheelman's Avatar
Posts: 27   (View Stats)
thewheelman is a glorious beacon of lightthewheelman is a glorious beacon of lightthewheelman is a glorious beacon of lightthewheelman is a glorious beacon of lightthewheelman is a glorious beacon of lightthewheelman is a glorious beacon of light
I've actually been looking for something similar to this for my Speed 6. I'm lowered on RPM Street springs and would like to raise the front about 1/4" to 3/8". The only thing I've found is the spring inserts that circle track users put in their springs to raise spring rate and ride height. I'd be interested to see what other people have to say about this.
Here's what I'm talking about: Spring Rubbers : Coil Spring Rubbers : Coil-Over Spring Rubbers
thewheelman is offline   Reply With Quote
 Old 02-08-2011, 09:05 AM   #7
senor blanco ms3's Avatar
Posts: 1,353   (View Stats)
senor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the world
Groans: 49
wheelman, check out DFW Mazdas Home and come out to our thursday night meets in addison.
2008.5 Crystal White Pearl MS3
A lot of mods
Check out my big turbo build!
senor blanco ms3 is offline   Reply With Quote
 Old 02-08-2011, 08:24 PM   #8
trdsw's Avatar
Posts: 141   (View Stats)
trdsw has much to be proud oftrdsw has much to be proud oftrdsw has much to be proud oftrdsw has much to be proud oftrdsw has much to be proud oftrdsw has much to be proud oftrdsw has much to be proud oftrdsw has much to be proud oftrdsw has much to be proud oftrdsw has much to be proud of
maybe another solution but there was a post about adding air bags within the spring to add spring rate and stiffness. I cant seem to find a link can someone chime in on this.
trdsw is offline   Reply With Quote
 Old 02-09-2011, 08:18 PM   #9
slow215's Avatar
Posts: 12   (View Stats)
slow215 is a jewel in the roughslow215 is a jewel in the roughslow215 is a jewel in the rough
I had Airlift1000 (made by Airlift Air Lift - Home) in a minivan before. It works great. But I can't find one for the Mazdaspeed3. I guess you have to measure the ID of our rear spring and get one from Airlift that fits.
slow215 is offline   Reply With Quote
 Old 02-13-2011, 03:02 AM   #10
trdsw's Avatar
Thats exactly what the guy did. he shared his measurments and results I just cant locate which forum it was on before
 Old 03-11-2011, 05:39 PM   #11
trdsw's Avatar
I find the how to thread
Uhhhhh Air Lift Kit 1000
 Old 03-11-2011, 11:28 PM   #12
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,796   (View Stats)
I am mesmerized.
You are a huge motherfucker.
Like squeezing a bison in a miata.
MAKE LOVE TO THE CANVAS
 Old 04-09-2011, 10:05 PM   #13
dukebrown's Avatar
I was in a mood to comment in equally and opposite magnitude of stupidity that is all Tomas.
The air bags were wow, but to much for me.
Thanks for the replies. I will try and take the negative camber out first. But Mr Gasket looks the 1st option I try.
How To: Ignition coil spring stretch mod cld12pk2go MazdaSpeed 3 - How-To's 56 03-21-2016 01:58 AM
Possible track spring spring setup for use with Koni yellows stretch MazdaSpeed 3/6 - Suspension & Brakes 154 04-18-2011 11:18 AM
Donut Style Coil Spring Spacer booya620 Drag Racing 2 02-07-2011 07:00 PM
Another "read my plugs" and Coil Spring Mod Frequentflyer MazdaSpeed 3 - Engine, Transmission & Driveline 2 12-13-2008 10:16 PM
Page generated in 0.33423 seconds with 27 queries
