Notices
 Old 02-28-2012, 04:31 PM   #1
Atomic41's Avatar
Posts: 551   (View Stats)
Atomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond reputeAtomic41 has a reputation beyond repute
Default Corksport Endlink CLUNKING NOISE
Problem with Corksport endlink kit !!!
I just want to know if it's normal a lot of clunking noise ... with this kit.
I just pass for your kit this afternoon but after I go out to a run test ... The clunking noise was so LOUD that I can't tolerate that.
Can you confirm me that it's not normal ????
But when i grab one when I open the box already they have a "lousse" in ... is it normal ? Do you have a problem (already know) with your endlink kit ?
How I suppose to install them to have ZERO noise ...
The noise was at his highest point when I drive at low speed over bump ...
Video link :
#1 -
#2 -
#3 -
2008 MAZDASPEED3 Black
Stratified Tune
Current VD Numbers: 330 hp / 392 lbft
Cobb AP // TurboSmart BPV // AutoTech Internals // Denso ITV22 Plugs // MD OCC // Corksport RacePipe // Corksport Boost Tube // Ultimate Racing Catted DP // COBB Exhaust // CPE TIP // CPE TMIC // CPE CAI // Hotchkis FSB&RSB // CPE RMM // Powergrid Endlink // Stoptech BrakeLine // TWM SS + Bushing + Knob// Sure Shortcut // RX-8 Wheels // Bridgestone RE760Sport 225/40/R18 // Bilstein B8 // Eibach Pro Kit // Eibach Pro Spacers 10mm // WeatherTech DigitalFit (Winter Setup) // Rally Armor Mud Flaps (Winter Setup) // MS3 OEM Wheels (Winter Setup)
Atomic41 is offline   Reply With Quote
 Old 02-28-2012, 04:34 PM   #2
Able
helmetface's Avatar
Posts: 4,407   (View Stats)
Groans: 124
I hear this is the complaint with a lot of aftermarket endlinks.
Which is why I decided to just replace mine with stocks
helmetface is online now   Reply With Quote
 Old 02-28-2012, 04:36 PM   #3
POWERED BY POLSKA
themytb's Avatar
Posts: 738   (View Stats)
themytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the world
Groans: 38
well its not right to have a clunk, but I don't know what the fuck else you're trying to say.
BNR S3---GS 3PORT---3bar map---COBB SRI & TIP---PG/GODSPEED FMIC ---DNP MANI--- CNT catted TBE--CP-E HPFP-- DIY P&P'd intake mani---SURE TIG(mani & tb)---DIY EGR delete---DIY VCTS delete--- DIY OCC/PCV reroute(through old egr port)---CP-E S2 RMM---JBR 80 PMM---TS BPV--- SURE ANCHORS---JBR shift weight---Whiteline RSB
25%E85FREEKPERMED
themytb is offline   Reply With Quote
 Old 02-28-2012, 06:19 PM   #4
grantmm's Avatar
Posts: 500   (View Stats)
grantmm is the leader of the worldgrantmm is the leader of the worldgrantmm is the leader of the worldgrantmm is the leader of the worldgrantmm is the leader of the worldgrantmm is the leader of the worldgrantmm is the leader of the worldgrantmm is the leader of the worldgrantmm is the leader of the worldgrantmm is the leader of the worldgrantmm is the leader of the world
From what I've experienced, it could be two things. Then again, I've never installed or even seen the Corksport endlinks, so these suggestions are general shots in the dark.
Check to see that the top bolt isn't hitting the body when the suspension compresses.
Check to see if the endlinks are too short and that the sway bar is hitting the body here:
grantmm is offline   Reply With Quote
 Old 02-28-2012, 06:21 PM   #5
Don06speed6's Avatar
Posts: 1,837   (View Stats)
Don06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the world
Groans: 58
Also check to make sure endlinks are completely tight, i had a clunk in my front and one of the endlinks needed like a quarter turn more to tighten.
Cobb AP(FREEK TUNED)/CS TBE/SURE AEROS/CPE TIH/ ITV 22/SU RMM/KMD INTERNALS/SURE DREADNAUGHT/JUGGERNAUGHT/WHITELINE RSB/SURE ANCHORS/SURE COUNTERWEIGHT/SURE SHORTCUT/JBR HEAVY KNOB/JBR EGR DELETE/SPC BALL JOINTS/CENTRIC BLANKS/HPS PADS/BNOON BOLT/ALTERED CUSTOMS FMIC/TURBO XS RFL
Don06speed6 is offline   Reply With Quote
 Old 02-28-2012, 09:15 PM   #6
Atomic41's Avatar
Updated with videos
Stratified Tune
 Old 02-28-2012, 09:41 PM   #7
grantmm's Avatar
If the sound is the thud noise every second or two in the first video, then the cause is most likely not what I suggested. Tighten those little bastards.
 Old 02-28-2012, 09:46 PM   #8
Groans: 58
Still going with my first post, tighten them again.
 Old 02-29-2012, 03:24 AM   #9
Atomic41's Avatar
With the weight of the car on the suspension or it doesn't matter if the car is on the lift in the air no weight on the suspension ???
Stratified Tune
 Old 02-29-2012, 05:20 AM   #10
pewpew
Sacrilicious's Avatar
yes, you should be doing this with the suspension loaded, but that's going to making reaching the adjustment nut at the top of the link really hard, so you're going to have to crank that one tight ahead of time. i'm going to guess that your problem is that one or more of your adjustment nuts came loose. i had the same problem when i was using the AWR adjustable end links.
so far as i can figure it, the really thin adjustment nuts are really hard to keep tight once you start twisting the end link back and forth from turning the steering wheel. my AWRs just wouldn't stay put no matter how hard i cranked, so after a shitload of annoyance, i ended up trying out the turnermotorsport end links, and they worked from the start without issues. notice the thicker adjustment nuts (i'm pretty sure these are the ones that fit our car, but can't be sure):
Turner Motorsport | Turner Motorsport Custom Length Adjustable Front Sway Bar End Links (Pair)
just make sure you figure out how long you need your links to be. the easiest way is to attach just the top of the end link and put the wheels back on the car and let it rest at normal ride height...then measure how long you need the link to be to attach to the bottom position without preload. in my case (bilsteins + cobb springs), i called up and had them make custom links that were 1" longer than what they normally carry. they were really good about it, though, and had them out to me in about 2 weeks at no extra charge.
good luck with your problem...i know how annoying this can be...
 Old 02-29-2012, 12:07 PM   #11
Atomic41's Avatar
Do you think I must change my endlink for another kit like yours ???
Stratified Tune
 Old 02-29-2012, 12:14 PM   #12
pewpew
i was probably not very clear on that: no, i don't think you should go to the extreme that i did unless you absolutely have to. for now, i would do the following if i were you:
1. check to make sure that no part of the end link is hitting the wheel well or some other part of the car.
2. do the adjustment to the end links with the suspension fully loaded as i mentioned above.
3. crank the adjustment nuts nice and tight when you have them where you want them to be.
4. hope for the best.
if doing all this doesn't work, then you're going to have to consider going the route i went. in the meantime, you should definitely give CS a call if you are at wit's end. at the minimum, see if they will refund/help you out with your situation.
 Old 02-29-2012, 12:15 PM   #13
I<3Groceries's Avatar
Posts: 1,851   (View Stats)
Groaned at 25 Times in 20 Posts
Just out of curiosity, if you guys aren't getting corner balanced, or if you aren't pre loading one side for circuit racing or something, why get adjustable end links? Why not use the OE links?
Sent from my Galaxy Nexus using Tapatalk
I<3Groceries is online now   Reply With Quote
 Old 02-29-2012, 12:16 PM   #14
Atomic41's Avatar
Do you think I can put some locktite on the shape where they are the adjustement nuts ?
Stratified Tune
 Old 02-29-2012, 12:17 PM   #15
pewpew
i don't know about the OP, but i did it because i altered the suspension geometry by switching to the bilsteins + cobb springs.
The Following User Says Thank You to Sacrilicious For This Useful Post:
SLOWHATCH (12-26-2012)
 Old 02-29-2012, 12:20 PM   #16
Posts: 5,621   (View Stats)
Groans: 58
If you lower the car it will put preload on the FSB, by having the adjustable links you can take it out. As far as the clunking goes check to see if your tie rods are good as well.
Sponsored driver~~~First amphibious PU~~~World record fastest fully bolted 2013 Pu! Fast Pu is Fast best ET> 12.586 best trap> 114.25. Thanks to all who helped me get back in the Pu!
kritz is online now   Reply With Quote
 Old 02-29-2012, 12:20 PM   #17
pewpew
yes, you definitely can. i only tried the blue stuff, but it was not enough. i probably should have tried the red stuff too, but the way i figured it was that if it required the red stuff just to keep from backing out, i was just setting myself up for unexpected fail sometime in the future when i could least afford it...
for reference, i did not use any kind of loctite on the turnermotorsport links (fyi: i think they outsource to power grid for their links)...just cranked it decently tight and it has held without complain for over 6 months now.
 Old 02-29-2012, 12:21 PM   #18
Atomic41's Avatar
Samething for me ... I'm now on bilstein B8 + eibach pro kit
Stratified Tune
 Old 02-29-2012, 02:14 PM   #19
Nliiitend1's Avatar
Posts: 3,828   (View Stats)
Groans: 59
Just a point of clarification here:
You're not really preloading the bar per se if you lower it equally on both sides, but you ARE changing the "angle of the dangle" of the swaybar at static height, which can adversely affect bar engagement feel and transitional behavior if that angle changes too much.
I myself haven't gone to the trouble of corner-weighting my car, so I'm using some appropriate-length non-adjustable endlinks on my car for the time being.
Stance is not a verb.
The Following 2 Users Say Thank You to Nliiitend1 For This Useful Post:
helmetface (02-29-2012), kritz (02-29-2012)
 Old 02-29-2012, 03:37 PM   #20
Atomic41's Avatar
So you think a can solve my problem by just rethigten all that like a FREAK
Stratified Tune
The Following User Says Thank You to Atomic41 For This Useful Post:
tddvrrn (04-02-2012)
 Old 02-29-2012, 06:41 PM   #21
grantmm's Avatar
<< Corner balanced. I don't see why anyone wouldn't invest the little bit of extra time to do this.
 Old 03-02-2012, 04:22 PM   #22
Atomic41's Avatar
So I retight all the nuts from my endlink and the noise is there again ...
So I think it don't come from my endlink. I try in the same time to put my stock endlink and the noise was there either so ... it's not the endlink the problem ...
Any others ideas ?
Stratified Tune
 Old 03-02-2012, 04:41 PM   #23
Atomic41's Avatar
Do you think it might be my corksport endlink was not at the good lenght and if is too long it could be the sway bar hitting my car frame.
Do you have a measure (the length) it must be to have no clunking issue ?
Stratified Tune
 Old 03-03-2012, 04:27 AM   #24
Atomic41's Avatar
Must I go shorter or longer than my oem endlink with my setup (bilstein B8 + eibach pro kit) for my ajustable endlink ?
Stratified Tune
 Old 03-03-2012, 04:34 AM   #25
Groans: 58
Check the tierods, I just had them replaced on my car and one was not tight making a rattling clunking noise. I had to make mine longer, but that was with the oem struts.
 Old 03-03-2012, 04:40 AM   #26
Atomic41's Avatar
Are you listening the noise in my videos ???
I think it's more like my sway bar hitting my subframe ? or you think it can be my tie rod as loud as that ...
Stratified Tune
 Old 03-03-2012, 04:52 AM   #27
Groans: 58
Did you tighten and recheck all the subframe blots after the CorkSport FSB install?
If the FSB is hitting the car you will see tell tail of it on the bar if not the underbody.
That sounded like my tie rod issue.
 Old 03-03-2012, 05:22 AM   #28
Atomic41's Avatar
No I will check that ... and for your tie rod how much it cost ?
Stratified Tune
 Old 03-03-2012, 05:32 AM   #29
Groans: 58
Mine were under warranty, 60,000 miles. I think they run $90 each. Check onlinemazdaparts.
 Old 03-03-2012, 08:37 AM   #30
Atomic41's Avatar
No other suggestions ???
Stratified Tune
 Old 03-03-2012, 09:38 AM   #31
Nliiitend1's Avatar
Groans: 59
What length did you make the endlinks before you installed them? Longer than OEM, shorter than OEM, or equivalent to OEM??
 Old 03-03-2012, 09:44 AM   #32
Atomic41's Avatar
equivalent ...
Stratified Tune
 Old 03-03-2012, 10:02 AM   #33
Nliiitend1's Avatar
Groans: 59
Well then I highly doubt they're hitting the control arms.
Have you put the OEM links back on to see if the noise is still there?
 Old 03-03-2012, 10:22 AM   #34
Atomic41's Avatar
Yes just one side and the noise is still there.
Stratified Tune
 Old 03-03-2012, 10:35 AM   #35
Nliiitend1's Avatar
Groans: 59
One side is not enough to rule them out as a source, IMO... Both sides are engaged any time the bar is being "worked," so-to-speak.
Is there any evidence (scrapes, scratch marks, dings, etc.) that the Hotchkiss bar is making contact with anything (tie rods, subframe, control arms, etc.)?
 Old 03-03-2012, 10:41 AM   #36
Atomic41's Avatar
So must I try to drive without endlink on to see if the noise still there ?
Stratified Tune
 Old 03-03-2012, 10:47 AM   #37
Nliiitend1's Avatar
Groans: 59
You could do that, or you could put the stock endlinks back on as well if you still have them.
If driving around with no endlinks gets rid of the noise that could also just mean that the bar itself could have been making contact with something (possibly even with no dependence on the endlinks themselves).
If you put the OEM links back on (assuming they're still in decent shape) and the noise goes away, then it's a bit easier to narrow the diagnosis down to the CS endlinks...
Sacrilicious (03-03-2012)
 Old 03-03-2012, 01:13 PM   #38
Groans: 58
Any luck yet? Keep us posted.
 Old 03-03-2012, 08:56 PM   #39
Atomic41's Avatar
No news for today sorry ... I just receive cold so I don't go out today but I will keep you posted
thanks again for your help
Stratified Tune
 Old 03-05-2012, 01:34 PM   #40
Atomic41's Avatar
Somebody know ... if the endlink attach between bilstein B8 and stock shock is the same ?
Stratified Tune
Clunking Noise after H&R spring install Soffball 2010 MS3 - Suspension & Brakes 25 11-13-2011 08:15 PM
CEL, Clunking noise on shutdown etc DC2_2_MS3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 06-26-2011 03:12 PM
Clunking noise Cool Whip MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 11-06-2009 11:18 AM
Clunking noise sleeping MazdaSpeed 3 - Engine, Transmission & Driveline 5 09-21-2009 05:20 AM
Clunking noise when stopping chisss MazdaSpeed 6 - Engine, Transmission & Driveline 2 01-19-2009 08:58 PM
Page generated in 0.60021 seconds with 28 queries
