-   MazdaSpeed 3/6 - Suspension & Brakes (http://www.mazdaspeedforums.org/forum/f12/)
-   -   Correct Motive Power Bleeder Adapter (http://www.mazdaspeedforums.org/forum/f12/correct-motive-power-bleeder-adapter-95458/)
Lex 10-26-2011 08:15 AM
Bleeding the brakes is a dreadful job for most. However using a power bleeder really speeds things along and ensure firm pedals :).
I use the Motive product because it's cheap, available, and works well.
What hasn't been documented is what adapter to use with this power bleeder in our cars. Turns out our fluid reservoir is the same as most European ones. So here is the kit to buy that fits the MS3 including the adapter and bleeder:
European Bleeder 0100 -- Motive Products Online Store
rfinkle2 10-26-2011 08:32 AM
Wish I had this info before stripping my rear caliper with speed bleeders.
Thanks for the info Lex.
superskaterxes 10-26-2011 08:38 AM
n00b friends to pump brake pedal + flare wrench FTW!!!
Lex 10-26-2011 08:53 AM
Been doing the pump method for a long time until I got to do my 951's slave cylinder. 3 hours, even using a vacuum pump, and still no clutch pressure.
I bought the motive product and was done in 15 minutes. Just can't beat the speed and ease using something like this.
802MS3 10-26-2011 10:03 AM
i have a motive bleeder too, pretty awesome. just watch how much fluid is in the reservoir!!!
therpmstore has had the correct part listed for a pretty long time (where i bought mine).
Tomas 10-26-2011 10:26 AM
Well this is only of use if you are changing all the brake fluid at once, right?
If you just bleed a little at a time you still got to pump and hold or use speed bleeders, no?
bova 10-26-2011 10:56 AM
i have the stupid universal adapter for my motive, its ok but a pain in the ass to seat correctly and not have it leak.
Design 10-26-2011 11:55 AM
Thanks for the link. Easily pays for itself in one job.
Here's a related DIY in case anyone wants to understand the benefit of this $60 tool.
DIY Pressure Bleeding
Lex 10-26-2011 02:37 PM
Nope, it can work for any amount of bleeding of the hydraulic system. Fill canister with fluid, pressurize, open the bleeder of choice. Let some fluid come out, closer bleeder. Done.
Tomas 10-26-2011 05:54 PM
ohh ahh. I thought it worked by creating a vacuum in the canister and then sucking the fluid from the reservoir, not pressurizing it in. Clearly I was fatally erroneous. I thought it worked on the same principle as my Pela oil extractor.
Not a bad little apparatus after all then.
Design 10-27-2011 10:08 AM
One thing to emphasize with these pressure bleeders is you HAVE to pump slowly! No fun tasting brake fluid from a ruptured reservoir. :(
Uberfly 07-13-2012 10:09 AM
i think the store moved. I was able to find it here though. Is this the same one as referenced above?
Motive Products European Brake Bleeder 0100
Lewis7789 01-30-2014 09:15 AM
^^^ Thank you for the updated link. Can anyone verify if this will also fit the MS6?
Lewis7789 04-21-2014 08:24 AM
For the MS6 Motive 1108 adapter fits perfectly.
http://www.summitracing.com/oh/parts/mvp-1108/overview/
Nitr0EngiE 08-17-2016 01:50 PM
TY Lex, the link you posted is no longer live so here is a link to what i just got on Ebay
Motive Products European Power Brake Bleeder w Adapter PN 0100 | eBay
going to use this to bleed the clutch
stockms3 08-17-2016 02:14 PM
My cap just popped off when I pumped fast, made a fucking mess. Brake fluid sucks.
texasboy21 08-20-2016 09:07 AM
What pressure is everyone using bleed the brakes? 12-15psi is good for the fronts, but even at 18-20psi the rear calipers flow much more slowly than the fronts.
Page generated in 0.18700 seconds with 11 queries
