  • 1 Post By bova
 Old 10-26-2011, 09:15 AM   #1
Posts: 12,651   (View Stats)
Default Correct Motive Power Bleeder Adapter
Bleeding the brakes is a dreadful job for most. However using a power bleeder really speeds things along and ensure firm pedals .
I use the Motive product because it's cheap, available, and works well.
What hasn't been documented is what adapter to use with this power bleeder in our cars. Turns out our fluid reservoir is the same as most European ones. So here is the kit to buy that fits the MS3 including the adapter and bleeder:
European Bleeder 0100 -- Motive Products Online Store
The Following 13 Users Say Thank You to Lex For This Useful Post:
alien_sporez (10-26-2011), charlesfist (10-27-2011), daafisch (10-26-2011), Design (10-26-2011), helmetface (10-27-2011), jv92red (10-26-2011), kmac (10-26-2011), MZR165 (10-26-2011), p057 (10-14-2013), rfinkle2 (10-26-2011), sadak (03-02-2014), Synmoo (07-13-2012), Tokay444 (10-26-2011)
 Old 10-26-2011, 09:32 AM   #2
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
Wish I had this info before stripping my rear caliper with speed bleeders.
Thanks for the info Lex.
The Following 3 Users Say Thank You to rfinkle2 For This Useful Post:
helmetface (10-27-2011), Lex (10-26-2011), p057 (10-14-2013)
 Old 10-26-2011, 09:38 AM   #3
n00b friends to pump brake pedal + flare wrench FTW!!!
fishin53 (07-15-2012), rfinkle2 (10-26-2011)
 Old 10-26-2011, 09:53 AM   #4
Been doing the pump method for a long time until I got to do my 951's slave cylinder. 3 hours, even using a vacuum pump, and still no clutch pressure.
I bought the motive product and was done in 15 minutes. Just can't beat the speed and ease using something like this.
rfinkle2 (10-26-2011), sadak (03-03-2014)
 Old 10-26-2011, 11:03 AM   #5
rabble rabble
802MS3's Avatar
Posts: 5,311   (View Stats)
Groans: 221
i have a motive bleeder too, pretty awesome. just watch how much fluid is in the reservoir!!!
therpmstore has had the correct part listed for a pretty long time (where i bought mine).
'08 CWP MS3 w/ T3 3071r
The Following 4 Users Say Thank You to 802MS3 For This Useful Post:
Design (10-26-2011), Lex (10-26-2011), rfinkle2 (10-26-2011), wolly6973 (10-27-2011)
 Old 10-26-2011, 11:26 AM   #6
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,768   (View Stats)
Groaned at 33 Times in 19 Posts
Well this is only of use if you are changing all the brake fluid at once, right?
If you just bleed a little at a time you still got to pump and hold or use speed bleeders, no?
MAKE LOVE TO THE CANVAS
 Old 10-26-2011, 11:56 AM   #7
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
i have the stupid universal adapter for my motive, its ok but a pain in the ass to seat correctly and not have it leak.
Bobforapples likes this.
 Old 10-26-2011, 12:55 PM   #8
Design's Avatar
Posts: 1,885   (View Stats)
Groaned at 9 Times in 5 Posts
Thanks for the link. Easily pays for itself in one job.
Here's a related DIY in case anyone wants to understand the benefit of this $60 tool.
DIY Pressure Bleeding
09 CWP MS3 GT
Ownership & Build Thread
Design is offline   Reply With Quote
The Following 2 Users Say Thank You to Design For This Useful Post:
karl-hungus (10-26-2011), rfinkle2 (10-26-2011)
 Old 10-26-2011, 03:37 PM   #9
Nope, it can work for any amount of bleeding of the hydraulic system. Fill canister with fluid, pressurize, open the bleeder of choice. Let some fluid come out, closer bleeder. Done.
 Old 10-26-2011, 06:54 PM   #10
Bob Ross Fanclub
Tomas's Avatar
ohh ahh. I thought it worked by creating a vacuum in the canister and then sucking the fluid from the reservoir, not pressurizing it in. Clearly I was fatally erroneous. I thought it worked on the same principle as my Pela oil extractor.
Not a bad little apparatus after all then.
 Old 10-27-2011, 11:08 AM   #11
Design's Avatar
One thing to emphasize with these pressure bleeders is you HAVE to pump slowly! No fun tasting brake fluid from a ruptured reservoir.
09 CWP MS3 GT
 Old 07-13-2012, 11:09 AM   #12
Uberfly's Avatar
Posts: 773   (View Stats)
Uberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the worldUberfly is the leader of the world
i think the store moved. I was able to find it here though. Is this the same one as referenced above?
Motive Products European Brake Bleeder 0100
2008 MS3 GT - Guardian Angel, Cobb Acessport, hacked up mazda CAI converted to SRI, Turbosmart BPV
Uberfly is offline   Reply With Quote
The Following 2 Users Say Thank You to Uberfly For This Useful Post:
sadak (03-02-2014), Vader (07-13-2012)
 Old 01-30-2014, 10:15 AM   #13
Lewis7789's Avatar
Posts: 290   (View Stats)
Lewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the worldLewis7789 is the leader of the world
^^^ Thank you for the updated link. Can anyone verify if this will also fit the MS6?
2006 MS6 aka "Fatty". Only 278hp but I'll catch you in the corners.
Lewis7789 is offline   Reply With Quote
 Old 04-21-2014, 09:24 AM   #14
Lewis7789's Avatar
For the MS6 Motive 1108 adapter fits perfectly.
http://www.summitracing.com/oh/parts/mvp-1108/overview/
The Following 2 Users Say Thank You to Lewis7789 For This Useful Post:
Mazdazilla6 (09-06-2016), Micha (03-04-2016)
 Old 08-17-2016, 02:50 PM   #15
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
Groans: 52
TY Lex, the link you posted is no longer live so here is a link to what i just got on Ebay
Motive Products European Power Brake Bleeder w Adapter PN 0100 | eBay
going to use this to bleed the clutch
 Old 08-17-2016, 03:14 PM   #16
stockms3's Avatar
Posts: 840   (View Stats)
Groans: 74
Groaned at 6 Times in 6 Posts
My cap just popped off when I pumped fast, made a fucking mess. Brake fluid sucks.
2007 TR MazdaSpeed3:Autotech FP inernals, CorkSport Turbo, TR8 Front Mount w/CX piping, JBR 3" intake, COBB EBCS, Cobb AP, Toyota Injector Seals, FR stud mod, Fidanza flywheel/LUK clutch, Forge BPV v2, cp-e xFlex stage 2 RMM, Wiseco .20 Pistons/Manley Rods/BSD, Dual DM catch cans, Koni Yellows/H&R springs, FD wheels, eBay downpipe, stock CBE
2005 Mazda 3 SP23: mods include rusty quarter panels and grinding 3rd gear. It does have a fusion motor, so I guess that's a mod too.
 Old 08-20-2016, 10:07 AM   #17
texasboy21's Avatar
Posts: 559   (View Stats)
texasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the worldtexasboy21 is the leader of the world
What pressure is everyone using bleed the brakes? 12-15psi is good for the fronts, but even at 18-20psi the rear calipers flow much more slowly than the fronts.
2012 MazdaSpeed3 - HTP 3" intake, ETS TIMC, Autotech internals, Corksport racepipe, Accessport V3, custom Freektune, CP-E RMM, Koni sports, Progress Technology RSB, AWR endlinks
2003 A4 1.8TQ
APR stg2+, MTM 420cc injectors, EuroCode FMIC, PSi testpipe, Techtonics Tuning downpipe, Forge TIP, Hyperboost DV, 240mm clutch, LWFW flywheel, B5S4 calipers, Goodridge SS lines, Stern snub, motor and transmission mounts, Powerflex rear diff bushing, 034MotorSports rear diff. carrier bushing inserts, JHM SS shifter, solid linkage, stabilizer bushing and weighted knob, Vogtland Jr. Cup Kit, B7 RS4 front and rear sway bars.
texasboy21 is offline   Reply With Quote
What is F&R Bleeder Screw Thread Size? RacerX78 MazdaSpeed 3/6 - Suspension & Brakes 4 06-08-2010 02:38 PM
Motive Bleeder for Mazdaspeed 3 AlpineFD MazdaSpeed 6 - How-To's 9 06-19-2009 12:41 AM
Without its editor-in-chief, Motive closes up shop Haltech Automotive News 0 03-13-2009 03:30 PM
Kensington 33197-RR 120W Notebook AC/DC Power Adapter (refurb) $19.99 Haltech Hot Deals Section 0 04-03-2008 08:10 AM
Targus APA01US Mobile 90W Universal AC Power Adapter $24.99 Haltech Hot Deals Section 0 03-26-2008 01:24 AM
Page generated in 0.37298 seconds with 31 queries
