-   MazdaSpeed 3/6 - Suspension & Brakes (http://www.mazdaspeedforums.org/forum/f12/)
-   -   CTS-V Brake Swap (http://www.mazdaspeedforums.org/forum/f12/cts-v-brake-swap-208626/)
Bexar 08-03-2017 10:16 AM
Originally Posted by MoMS3 (Post 3124035)
If DM is going to be designing a bracket for the MS3 then I'd say absolutely go that route, but if they're only designing brackets for the MS6, then us MS3 guys are SOL.
For something that popular I feel like DM would make them for both. At least we had better hope so :bigeyes:!
Well if you're talking about the yellow 6-piston calipers, those are $310 apiece vs $100-150...that said, most of the 4-piston come bare metal, so that means you can powder coat them as you see fit.
The 6 pistons are sick. But 4 pistons can probably do the job just fine for what I'm shooting for. Much more clean than painting stock calipers
MoMS3 08-03-2017 10:23 AM
Yeah, I'd be surprised if DM didn't go ahead and make the brackets for us MS3 folks given the interest, I'd also think the MS3 version would be interchangeable with FoST which would make it a more worthwhile venture.
An issue with the 6 piston versions is that their combined piston area is too far off our stock calipers, which throws off brake bias in an undesirable manner. Granted there are ways to adjust the bias to account for this, but at that point you're getting into the realm of why bother, since there are plenty of other options that would fall within the same price range that are engineered to maintain factory brake bias.
Bexar 08-10-2017 12:28 PM
Another week gone by...wish there was an update on the brake brackets!
Bexar 08-18-2017 08:15 AM
Still no update? Can't wait to get some on my car. Just saw a photo on instagram of someone putting yellow Cadillac calipers on their speed. Looks amazing
mituc 08-18-2017 08:41 AM
Yeah, I'm done waiting, my pot with patience is empty. I will phoken order a set of CS front calipers and paint the rears. I wish I could fit some OEMs of any kind (FoRS, CTS-V, whatever) but some good aftermarket will work. Or I will get new OEMs, the ones I have are baked after 9+ years of hooning around.
Bexar 08-18-2017 09:30 AM
Just something about painting stocks looks horrible. Guy I know in town has a black pu with calipers he painted a year or two ago. They look light red and the paint is flaking.
Those GM calipers look great tho :05:
If nothing happens, later this year I will seriously look at designing and possibly producing my own brackets to fit the aforementioned calipers on an off the shelf rotor. I'm a stickler for beautiful brakes
Pu Manchu 08-18-2017 10:42 AM
it looks bad because most people don't do it correctly, because it's a fuckload of work.
aackthpt 08-18-2017 02:26 PM
I don't want the flash. So if I were to paint my stock ones, it'd be mostly so it is easier to keep them clean and to make every look less grimy. As such I would paint them gray.
So, for me the gray painted V calipers would do exactly what I want.
Front: https://www.amazon.com/ACDelco-172-2.../dp/B0010G0HP6
Rear: https://www.amazon.com/ACDelco-172-2.../dp/B000S2Q5O0
I'd strongly consider this in the future even though I have new rotors and RedStuff on deck...
HardCruise 09-12-2017 11:16 AM
Still nothing?
MoMS3 09-12-2017 11:24 AM
Originally Posted by HardCruise (Post 3128152)
Still nothing?
Two weeks...
Bexar 09-13-2017 08:43 AM
Waiting game :cool:
rik881 09-19-2017 08:13 PM
I want big brakes for small bucks. Painted stock calipers are dumb.
Atomic41 10-02-2017 07:09 PM
news here ...
mituc 10-02-2017 09:03 PM
Nah... was a good idea but it looks like it's dead.
Atomic41 10-03-2017 04:32 AM
Someone must keep the project alive ... it's really a good idea
Juschiln19 10-15-2017 03:46 PM
Bumped interested....
macdiesel 10-16-2017 01:49 PM
If I was a betting man I’d say this is dead in the water.
Bexar 10-19-2017 10:14 AM
Still interested, this isn't dead
SpeedyTurd 10-24-2017 11:51 PM
Interested! I really hope this happens soon.
Bexar 11-13-2017 07:47 AM
Been a minute but I have faith that someone. somewhere, still cares a little about this idea
MoMS3 11-13-2017 07:57 AM
I definitely am still interested now I'm running 17x9 rpf1's and the RS brakes are a no-go.
JakeMS3 11-13-2017 03:40 PM
I picked up a Wilwood BBK 6 Piston from edge, came with the 2 piece rotors, stainless lines, pads and calipers and of course the brackets needed to make it work. It’s a bolt on kit as well. It was $1050 shipped to the door.
JakeMS3 11-13-2017 03:46 PM
Posted that above for the guys who still want a BBK for a good price. They’re out there, just have to search on the net. I almost went with the CS calipers but once I priced them along with new rotors and pads stainless lies, I was in the $1200 range.
Bexar 11-15-2017 09:25 AM
I'm not about it. What I do see myself doing is picking up some used calipers on the cheap off eBay or something. Not looking to dish out that much for a BBK, although a price like that is to be expected. Pair the used calipers with some hopefully relatively inexpensive brackets and hopefully we can see a more affordable kit
Djohns 11-15-2017 11:26 AM
I think at this point it wouldn’t be a bad idea to just get a list of cars that have the same hub pattern as we do and start looking into their brakes.
Bexar 11-20-2017 08:58 AM
https://www.wheel-size.com/pcd/5x114.3/
So we did confirm at least that the Focus RS caliper will bolt up directly? As in the brake lines will just bolt in? So the challenge is to find the correct rotors and pads?
MoMS3 11-20-2017 09:39 AM
I don't think the brake line subject was broached per se, however I'd imagine brake lines for a FoRS should in theory mate up to the Mazda connections without issue (correct me if I'm wrong).
The caliper bolts up to the existing caliper mount per Matt@Damond, however it sounds like the holes in the knuckle that the caliper mounting bolts go through will have to be bored out to accommodate the FoRS caliper bolts (unsure how much bigger holes need to be).
Pads will should just be stock FoRS sizing, no need to adapt anything there, and as for the rotors, the stock FoRS rotors will work with a bit of machine work. The hub center bore will need to be increased from 63.4mm to 67.1mm dia. and the lug pattern will have to be adapted from 5x108 to 5x114.3, which will essentially make the holes a bit oblong (each will be drilled out roughly 3mm further from hub center, if that makes sense).
In other words, doable with some adaptation, should be pretty straight forward though. The only other thing to consider is the wheel size needed to run the FoRS brakes, Matt mentioned that you need a minimum of 18" wheels to clear calipers, not sure on offset but I figure going off the RS specs would be a good start there.
Bexar 11-22-2017 08:12 AM
It would be awesome to find a drop in rotor ..... all that extra work is extra $ .... surely there exists a 5x114 rotor off the shelf for some other car. Just would need to do alot of test fitting
JamesHansenDTD 11-22-2017 08:30 AM
Damond motorsports has a CTS-V brackets under development right now. I don't know what the eta is on them.
MoMS3 11-22-2017 09:37 AM
That is going to be tough to track down methinks, the FoRS rotors have an oddball thickness (25mm) and everything I'm seeing which is going to be similar diameter and offset are anywhere between 30-32mm thick.
Our stock rotors fit the bill aside from the fact they're 320mm vs 350mm in diameter.
Wp.Chris 01-04-2018 03:29 PM
Bump, still crossing fingers
Bexar 01-11-2018 12:37 PM
Same, hoping to hear something on this
MichaelAress 08-08-2018 12:18 PM
CTS V Brake Swap
Hi guys
Im swapping out a power brake system from one 1971 LeMans into another. Im taking the power booster, pedal rod and master cylinder off the car with the power brakes and dropping them into the non-power one. Do I need to swap the proportioning valve as well?
Thanks
Db09ms3 08-08-2018 02:54 PM
Originally Posted by MichaelAress (Post 3149045)
Hi guys
Thanks
Wrong topic doober. BUT yes, you should. Doesn't the GM A-body have a forum? Peep that shit son.
sarm1084 11-09-2018 02:21 AM
Originally Posted by KingKhan (Post 3110173)
Would also be interested if they made a kit for the speed 6
Evo front brembo calipers have already been proven to fit the MS6 with little modification and no bracket. I've seen it on YouTube and I'm sure its on the forums.
Sent from my VS835 using Tapatalk
Fstrnyou 11-11-2018 11:08 AM
Good job quoting an 18 month old post and thinking you're contributing.
jerzyiroc 04-29-2019 07:28 PM
Sooo, someone got them to work...
https://i.imgur.com/sDelhh6.jpg
https://i.imgur.com/59FaAKe.jpg
Bertospeed3 04-30-2019 08:38 AM
seen this video all over my instagram the other day. Once i saw this thread had a new post, i knew it was related to this video lol. Shits look sexy. I wanted to see more pics but his profile was private and I wasnt gonna request just for that.
Dark_Signal 04-30-2019 11:38 AM
Interesting. In for more info.
jerzyiroc 04-30-2019 11:50 AM
So we have an idea of what rotors to use now. Just need the bracket. https://uploads.tapatalk-cdn.com/201...13bc45da1b.jpg
Sent from my ONEPLUS A6013 using Tapatalk
Page generated in 0.20801 seconds with 11 queries
